View Full Version : Generation III External Engine
  1. Unsolved mystery!!! 01 z28 problem plz help!!!!
  2. anyone using 6LE stainless CME tips? got a question
  3. thinking about powerflo's w/o the lm?
  4. Fresh LT install and now car won't idle
  5. Repeat Offender P0136
  6. Purchasing a short block... which gaskets needed to complete the build?
  7. help o2 sensor problems!
  8. new f.a.s.t. lsxr 102 intake
  9. JEGS Electric Exhaust Cutouts
  10. QTP Headers Help.
  11. Are these cats any good?
  12. damn intake gaskets!!
  13. Lids other than slp?
  14. LS6 or F.A.S.T Intake???
  15. Okay stupid question!
  16. ws6 with these tips..help..
  17. intake gaskets
  18. Electric Cutout....
  19. Huge coolant leak now, please help!!
  20. Is it possible to identify this bullet?
  21. What is this hose? Please help!
  22. ebay valve covrs
  23. ***4" mufflex finally installed!!!***
  24. You know this is a good setup
  25. LS6 intake vaccum line plug
  26. O2 ?
  27. MSD Blaster coil packs
  28. Test Fit
  29. transmission ?
  30. tips or no tips (i got the tips pics inside)
  31. Chambermouth length question
  32. Bad stuff in crankcase?
  33. March Underdrive Pulley - Belts?
  34. Oil Pressure Sending Unit
  35. Is this normal?????
  36. SLP vs. PACESETTER
  37. Questions to install headers
  38. SLP Lid + Bellows Results on DYnolicious (iphone)
  39. block hugger headers
  40. Long tubes without tune for clutch break in?
  41. A/C problem has me stumped...
  42. coolent crossover tube?
  43. turn key and nothin?!
  44. What You think about not using a tunnel bracket?
  45. UMI solid motor mount question
  46. anyone ever done a td setup, dumped, without an x or h pipe?
  47. Tune with bullets?
  48. Edelbrock Water Pump pulley OD?
  49. Voltage maxing on car
  50. What Size Injectors Recommended for FAST 90 (or 92)
  51. Suggestions on cam
  52. I got my headers
  53. Texas Speed Rumbler Vs. SLP Loudmouth
  54. 3" radiator too thick??
  55. old style slps or pacesetters
  56. question on headers
  57. Poll: Which plug wires? MSD or Granatelli?
  58. Bolt "snap" when torquing heads
  59. 85mm tb blade
  60. Need Help ASAP!!!
  61. Is the Corvette worth it?
  62. Which header gasket do you like?
  63. WHat's the Biggest Roller rocker possible on a stock LS1
  64. Weird situation
  65. Crank pulley install... What method did you use?
  66. AC Problem
  67. LT's collector leaking, fix with epoxy for metal?
  68. Plug wire boots??
  69. Lq4 or LS1
  70. gonna be gettin some headers in 5 min, quick question
  71. Probably A Dumb Question
  72. Pcm ground question, engine will not fire up.
  73. got my hooker headers in today.....did i get ripped?? pics*
  74. FAST intake questions
  75. Knock Sensor
  76. looking for modification suggestions
  77. Help with slipping belt!
  78. LS1 idles great but very rough under load condition
  79. headers
  80. Seems you can't buy just a PCV valve anymore.....
  81. what size headers?
  82. Backfire when trying to start
  83. snapped header bolt
  84. Best place to get injectors
  85. Battery relocation wiring...Pics needed...
  86. LS1 Coolant flow... For aftermarket gauge.
  87. Need some input
  88. Questions on duel electric cutout location
  89. Questions about a cam
  90. Spark Plugs for Carbureted Ms4 Ls1
  91. Anyone have this cutout
  92. Help with new parts
  93. Catback hp numbers
  94. LS Swap From The Top !
  95. underdrive pulley
  96. Cutout could get ripped off exhaust? wtf?
  97. headers, cat back, cold air intake
  98. Aftermarket exhaust specialist come on in. Need help asap.
  99. Titanium C5 Z06 Type Exhaust On FBODY?
  100. WEIRD PROBLEMS...never seen nothing like it.
  101. Ground wire on wiring harness question
  102. Leaky header tick at idle or wot?
  103. HELP P0154 O2 Sensor Circuit No Activity Detected
  104. SLP Lid/air pump hose
  105. Y pipe install
  106. cam help please
  107. Has anyone done this?
  108. LS1 bolt ons
  109. The most RWHP from an LS6 w/ just bolt-ons?
  110. 408 Engine Swap [What else to upgrade]
  111. ls6 intake modify
  112. lt/ory install ?
  113. Exhaust and Clamp question, and only a whopping 8hp increase with full exhaust.
  114. Hooker ORY (sux) pix added
  115. 01-03 LS6 Valley Cover vs 04 Valley Cover
  116. Question about Headers
  117. Ls2 intake into LS1
  118. Tune Up?
  119. Bassani true duals
  120. Typhoon intake/Injectors...
  121. Someone school me on the valley cover issue?
  122. My belt keeps moving???
  123. what exhaust
  124. 4" exhaust. PHB relocation and other ?'s
  125. Swapping V6 with LS engine.. Thoughts?
  126. Which catback?
  127. Quick TPS voltage vs idle question
  128. AIR delete
  129. Gut out my catalytic converter
  130. first thread
  131. which of these to get..
  132. best headers for the buck??
  133. maf for fast setup??
  134. Good Exhaust/Muffler
  135. Unburnt fuel after frequent idle?
  136. SLP Dual Dual
  137. coolent air tube
  138. Installing True Duals
  139. victor jr intake questions
  140. Borla Non Adjustabel catback???????
  141. Some quick newbie questions
  142. No acceleration even with pedal floored
  143. C5 P0343 code
  144. Anybody know the make of these headers?
  145. 5.3 puter question
  146. 550 for a catted y pipe ouch
  147. anyone have truble with there magnamouth exhaust draging on ground
  148. Question about my fan settings/ should I get a 160 t-stat
  149. FAST 102 cathedral Port and 42lb Bosch Style Injector Question
  150. New O2's or extend the old ones
  151. Volant intake kit
  152. how much power will I lose going from SLP longtubes to BBK's
  153. Intake Question
  154. TSP 1 7/8 header install
  155. How does this sound?
  156. MSD Starter Video
  157. Just installed: AR 1-7/8" long tubes on the T/A
  158. Driving on Clogged Injector
  159. how much is a used ls6 intake worth?
  160. help with headers
  161. New/Existing Diagram for Catch Can (Stock LS1)
  162. SLP Loudmouth's New Tips
  163. okay gurus which cat back is on my car?
  164. LS6 intake issue
  165. Anyone use corvette fuel rail covers on a carbureted motor!!!?!?!
  166. Valley cover?
  167. Fast Intake and Throttle Body
  168. BROKEN Header Bolt ....
  169. AC block off plate
  170. finally got my true duals!!!!
  171. oil leak....advice?
  172. Need help with PCV please help
  173. what are bolt-ons
  174. fuel rail cover questions
  175. Has anybody enlarged the header bolt holes?
  176. which muffler?
  177. Whats is meant by saying......
  178. oes an Edelbrock Pro Flo XT really outflow the ls6?
  179. Tcs
  180. lingenfelter intake
  181. Powerbond UD pulley REMOVAL HELP
  182. Trading lpp lts for?
  183. Ls1 not firing on all cylinders
  184. diagram For plugs that go into coils
  185. buying headers today just got a question
  186. Oil Pressure Sending Unit?
  187. underhood fuse block
  188. need a coupler for stock maf to 85 mm tb?
  189. Any pics of coil relocation?
  190. Solid Mounts
  191. Ran into issues installing LS6 intake lastnight.. Need suggestions*PICS*
  192. water pump pulley idler
  193. P0420 Cat or O2 Sensor?
  194. Can't find 85mm ls6 porting project post..
  195. Car spits water when reved
  196. Replacing full exhaust system opinions needed.
  197. alternators questions
  198. ACCUSUMP in an F-Body
  199. SES light - PO420 Code
  200. Exhaust clamp question
  201. My SLP Loudmouth 2 install and review! ENTER *2 small pics*
  202. Cant get intake to fit TSP 408
  203. 228/228 comp cam
  204. oil pressure sending unit
  205. LS1 Engine Mounts vs. "Chevy Engine Mounts"
  206. Supporting Mods:
  207. LS6 Valley Cover
  208. Header Advice
  209. cherry bomb muffler
  210. air delete question
  211. mac mids vs paceseatters
  212. Header leak?
  213. Header Question
  214. MAF opinion of what i should buy
  215. Installing headers and I had a question
  216. Which fast intake?!?!
  217. QTP Headers and LPP True duals video
  218. LS1 Coolant Idiot Light Temp Trigger
  219. is it worth it?
  220. Any last advice before catback install?
  221. changing alternator 2001Z28
  222. FAST intake gasket ripped
  223. CheaTR cam w/ 205's package:
  224. Will Magnaflow cats be louder than stock?
  225. Why 8 inches???
  226. Battery relocation... Do I really need a 1/0 ground up front??
  227. Power steering pump delete
  228. thermostat help
  229. Ideal exhaust size?
  230. Ls6 heads,cam,& intake questions
  231. Header bolt??
  232. Guys with ORY come in
  233. intake question
  234. Does anyone port stock T/B's anymore?
  235. How loud will dual magnaflows be?
  236. cut out
  237. Rate my build:
  238. lt install
  239. Wires and Plugs?
  240. Help! Need to know thread pattern on Exhaust Hanger Stud!
  241. Lid help!!!!
  242. What kindof smooth bellow for a 92mm FAST to an 85mm MAF?
  243. Removing Corsa clamped-on exhaust from F-body any suggestions?
  244. ET reduction question !
  245. Will an LS1 flywheel/clutch fit on an LQ4?
  246. Cyber Mechanics please chime in.
  247. True Duals with different mufflers?
  248. Anyone else ever break a header bolt?
  249. Anyone ever seen this catback?
  250. How did this even happen?
