View Full Version : Generation III External Engine
  1. Ceramic header break in ?
  2. SES light came on what could it be and how do I erase?
  3. Cost of these parts?
  4. Exhaust... Plz help a dumbass
  5. Which is better kooks or ahr headers???
  6. hat what point do you outgrow single exhaust?
  7. Port Fast intake or wait till heads ??
  8. Rain issues!!!(o2 wiring)
  9. P0332 Knock Sensor Code
  10. could it be o2's?
  11. 2002 transam
  12. MSD 2 Step 8733 and 98's
  13. tighting sequence of intake manifold?
  14. SLP and cats
  15. Anyone else have a bitch of a time installing QTP...
  16. Ported tb
  17. Speed Density, no MAF, what coupler?
  18. ebay fluid pulley
  19. Kooks Y-pipe
  20. muffler
  21. Yet another Header ORY question
  22. header gaskets ?
  23. Best LM1 Direct Replacement
  24. Ls6 pcv
  25. your thoughts on header replacement
  26. doing engine swap and need info on different years of ls engines
  27. Buying a used FAST intake
  28. TSP true duals w/ out the back configuration!?
  29. Size of stock exhaust pipe
  30. Building a 3" exhaust the easy way (4th gen)
  31. pcv system
  32. ls1 pcv system? 5.3 with ls1 intake
  33. might buy a Phab exhuast from ebay? opinions??
  34. Installed FAST Intake and TB-Air Intake Does Not Fit
  35. Wasnt impressed with the fitment of the qtp headers
  36. throttle bodies?
  37. Removing Egr
  38. Sweet Thunders
  39. pacesetter non-coated headers?
  40. Exhaust Too Big??
  41. Flowmaster merge in a Kook's catted y?
  42. Are LPP headers and y-pipe good?
  43. 3" True duals, stainless over the axle
  44. Billet 90mm Throttle body IAC valve problem...please help
  45. 01 F-Body PCV Catch can plumbing question
  46. Exhaust Leaks
  47. Pacesetter header question
  48. which plug would be the best?
  49. Ram air Through Fog light holes
  50. Lightweight (thin wall) Exhaust Pipe Piping?
  51. Starter
  52. Cannot get fuel fitting adapter for Speed inc rails to stop leaking?
  53. Exhaust tips?
  54. What Headers are These?
  55. Machining Keyway into pulley
  56. What header gaskets and bolts do you use???
  57. Cat clogged?
  58. LS6 Cam gains
  59. What exactly is going on with my exhaust here?
  60. skip shift ?'s
  61. flowmaster merge
  62. Muffler help
  63. Oil Pressure Sender Voltage??
  64. LS6 427 Help
  65. HELP: ORY + cutout OR TrueDuals ?
  66. Any reason not to increase redline to 6200rpm?
  67. SLP U/D Removal Tool?
  68. SLP Fan Switch Problems
  69. Best E-cutout DMH?
  70. Compare KOOKS and ARH Collectors For Me
  71. Stock TB/MAF on "mild" 383?
  72. How to make LS6 intake fit?
  73. underdrive pulley (belt) and alternator bolt interference
  74. Painted header longevity (Texas)
  75. CAT help
  76. question on tsp CB and magnaflow tips
  77. 80mm throttle body or S3
  78. exhaust studs. are these ok?
  79. Ram Air Mod for non WS6 TA?
  80. HELP LT Pacesetter Header install stuck on drivers side
  81. pre 01 headers on an 02
  82. TCS/Cruise Delete
  83. will these work?????
  84. ALT quits at 5K?
  85. Fast 90/90 Setup on mild H/C setup?
  86. Corvette running rich will Fast intake help lean it out??
  87. Finally dumped my Flowmaster
  88. Hoping for some help finding a resonator
  89. spark plugs
  90. F-body 4 inch over axle pipe; new or used.
  91. 97 LS1 DBW to DBC
  92. ls1-->ls6 intake?
  93. Ported aluminum intakes pics?
  94. LS? Intake Part # 12592191 What Is It???
  95. Powerbond balancer heavier then stock?!
  96. Mid tube install?
  97. Victor Jr. Intake???
  98. which sounds better
  99. PS pump issue
  100. is this normal (pic inside)
  101. need help pinpointing sound from front of engine
  102. How much HP did u pick up from cutout?
  103. help with Y pipe beating the **** out of my car
  104. camaro ss ram air box on a transam?
  105. quick slp lid question...
  106. Wix air filter vs Fram vs dirty K&N flow results inside
  107. Which Loudmouth is which?
  108. Is this MM package a good deal?
  109. 1 7/8 headers?
  110. which heads?
  111. accessory set up
  112. Is there a big gain from LS6 intake to FAST92 on a H/C 346?
  113. new single 4" setup dumped
  114. slp maf
  115. will i need to flycut?????
  116. GREAT DEAL on revXtreme catch can going on now!
  117. Tune or not?
  118. replacment mufflers?
  119. Victor Jr or Super Victor in a F-body? Post up some pics installed
  120. exhaust.. will this work?
  121. ls6
  122. CME test fit
  123. !air/!egr
  124. TSP Rumbler catback
  125. band clamps
  126. kooks quad core race mufflers?
  127. Plug wire shorted out
  128. C5 guys vararam vs ????
  129. what would cause this?
  130. Anyone running a carb and a 6ls box
  131. What's all needed for LS6 intake swap? Ya, I searched
  132. FAST Valley Cover Bolts?
  133. Why doesn't the 2001+ LS1 have a 6500 rpm redline too?
  134. ported ls6 to fast 92??
  135. hooker super comp Longtubes headers
  136. 2OTL Exhaust Different Design Question
  137. changing throttle bodys
  138. Muffler removal
  139. HOOKER Headers
  140. dual exhaust pics
  141. Headers/Spark Plug Question
  142. magnaflow anyone?
  143. Exhaust options, gmmg? magnaflow?
  144. Truck oil pressure sending unit?
  145. O2 Simulator help!
  146. Red fluids....?
  147. thread in injector bungs?
  148. GMMG's in, fitment problem
  149. Help with Kooks install
  150. trying to build a stealth exhaust...help plz
  151. finally
  152. Need the thread size of an oil sender
  153. coolant sensor placement?
  154. Do intake gaskets swell?
  155. People selling FAST intakes?
  156. Removed air/egr... use mini breather or seal up?
  157. Upgrading intake, suggestions?
  158. wanting 11:1 wit 243 on stock ls1
  159. Fast 90/90 Vs. Victor Jr setup - Need opinions!
  160. Pacesetter Headers = Poor Quality & Warranty
  161. O2 sensors?
  162. cut out issue
  163. Qtp electric cutout issue
  164. anyone know if c6 z06 manifolds will fit gen4 f body?
  165. Shorter o2 sensors?
  166. Serpatine System?
  167. Which way do stock intake gaskets face??
  168. Front cover install procedure?
  169. Long tubes for 2002 SS
  170. victor jr/ super victor fuel rail question
  171. quick cutout question
  172. MSD Digital ignition? any real gains or is stock ignition good enough???
  173. Gto Help
  174. *VIDEO* Camaro catback swap, before and after with Magnaflow then SLP dual/dual
  175. Determining ls6 block year for head studs
  176. Need Help with gauge install
  177. Oil Pressure Sensor
  178. Stock or underdrive?
  179. Wrap results??
  180. catted Y pipe for 02 SS
  181. Alternator exciter wire off PCM
  182. ls1 oil pan BOLTS part number
  183. Throttle Body Question!!!!
  184. Throttle Cable Bracket
  185. Another LT cat back question
  186. My IAC is F****D
  187. Fernco, home depot, lowes, etc, smooth bellow's. Pro's and Con's?
  188. Drilling the throttle body nessecary?
  189. Header & exhaust
  190. Which long tubes header have most clearance?
  191. Solid mounts need poly trans mount?
  192. Need pictures of front bumper support on 98-02 camaro
  193. Exhaust Leak
  194. loudmouth
  195. Home made GMMG cat back?
  196. Opinions please...
  197. Who Has ported Stock 00-02' Exhaust Manifolds?
  198. which lid??
  199. 6.0 problem.... Need help in paducah ky
  200. Different kind of Ram-Air
  201. What sensor is this?
  202. SLP "NEW" design headers
  203. valve cover spacers
  204. hoses on valve covers?
  205. SS Airlid needed
  206. which densos?
  207. 160 deg Therostat doesnt fit in stock housing?
  208. 6.0 Oil filter Bypass
  209. need some part numbers please
  210. SLP MAF Question
  211. Magnaflow or Loudmouth 1 or 2
  212. help me decide on exhaust
  213. Exhaust cutout turn down
  214. Car won't start up after rebuild. What to do?
  215. FAST Intake and Coolant Rail Question
  216. Anybody have picture/diagram of '98 PCV setup?
  217. Slp underdrive pulley
  218. 1998 f-body LS1, Rebuild, need some assistance.
  219. Anyone have a ls1 on the stand with the pan off?
  220. Make your own oil cap breather ~$20 *Guide*
  221. All F-Body TBs interchangeable?
  222. throttle body ?
  223. power steering pulley
  224. Stock Cat flow-through pipe
  225. TD people with lowered cars - would you do it again?
  226. TD people with lowered cars - would you do it again?
  227. Is part #19212593 in fact an H3 pan?
  228. LSX Block
  229. Easiest LT Headers to Install
  230. anyone gutted stock cats?? what are they made of??
  231. switching headers question
  232. Trying to find plug for factory pcv location in valve cover?
  233. Dual Dual removal
  234. Looking for A good ypipe for stock manifolds.
  235. Need help on AIR removal on an 01 pics inside?
  236. '99 vs. '02 headers?
  237. Mufflex -VS- GMMG...
  238. which header stays cooler stainless or Jet Hot?
  239. The flat spot.
  240. Removing engine dipstick
  241. sheet metal intake questions
  242. crap! another magnaflow fitment issue
  243. oil pan removal
  244. are my mac headers a bottle neck?
  245. Anyone coating MLS header gaskets?
  246. Free Ram Air Mod pics
  247. high idle and surging at low rpm need help
  248. Ok im stuck and confused need help please
  249. Catback
  250. CC Performance Relocation Kit
