View Full Version : Generation III External Engine
  1. Put down 332/329 after new exhaust.
  2. o2 wiring help please
  3. What is the best aftermarket cat?
  4. quick question
  5. Help with Idle & RPM Issue !!
  6. From TA to Z06 Vette
  7. Got my new headers
  8. fast 90 or victor jr
  9. HELP! Can anyone tell me what model FAST intake this is? w/ pics
  10. Alternator Spec / Info
  11. wont crank help please
  12. need help on passenger side manifold
  13. fast intake ?
  14. Header install
  15. what size are these?
  16. Tried the truck coil swap for free
  17. QTP Cutout help
  18. B&B for corsa
  19. Heads question/opinion
  20. question about ls1 to ls6
  21. What do you think of this exhaust setup
  22. Muffler recommendation
  23. MAF reading wayy too high....
  24. Install cats/Tune affected?
  25. Help Please!!!
  26. What else would you replace...
  27. C5 Guys - 100mm MAF & Vararam PowerDuct?
  28. will i pass smog?
  29. 862 casting heads
  30. New Catback/Muffler?
  31. Gasket set
  32. Doug's Electric Cutout
  33. LQ9 Flywheel, Clutch, Pressure Plate
  34. A.I.R. confusion (pic inside)
  35. Noob shorty question.
  36. Pulley removal...
  37. 4" mufflex exhaust
  38. Bolt-on's
  39. Best "Quality" Shorty Header(i know lt's make more power)
  40. Installing crank pulley
  41. What's the most quiet muffler you an put in a Mufflex catback?
  42. Fuel injector question
  43. Painting LS1 aluminum block - primer?
  44. rear main seal
  45. Painless Perfect System - ECM
  46. Underdrive Pulleys??
  47. I need my headers painted v. Troy, MI
  48. intake swap
  49. LS2 oil pan
  50. Thats not a blower, thats my water pump!
  51. Ignition Coils?
  52. who sells the adapter to put rear C5 o2s in front?
  53. LS4 Accy's on LS1?
  54. What To Do About Y-Pipe Clearance w/LTs?
  55. headlight motor issue
  56. What are these called and where can I buy them??
  57. Alternator plug wiring issue
  58. best muffler for true duals??
  59. Which spark plug for stock LS1 with headers and tune?
  60. Different oil pressure sensor?...
  61. Searching for some more power past bolt-ons, heads/cam/intake
  62. 98-02 Exhaust Hangers NEEDED!!
  63. LMR True Duals
  64. Air pump?
  65. ACCUFAB 4150 / IAT question
  66. cheap O2 extensions?
  67. Anyone running magnaflows...???
  68. Just finished installing new style LPP headers/ory
  69. loosing oil pressure
  70. Broke my alternator connector..
  71. LM2/ORY/LT's+cam
  72. TSP true dual with magnaflow bullet's
  73. solid motor mount question
  74. BIG headers...........
  75. what do yall think?
  76. Thinking about this "slp flo pack".. Need feedback.
  77. LS6 Intake
  78. LPP True duals, pics inside
  79. Electronic Tb to Wire Tb?
  80. Texas Speed headers with Pace Setter ORY
  81. PCm ?
  82. High Press. Power Steering Hose Replacement
  83. LS6 Intake Question
  84. Magnaflow blow out....
  85. 383 and ls1 question
  86. How much is my exhaust costing me???
  87. ls2 intake fit ls1?
  88. Looking at doing a maf, ftra, pulley- worth it?
  89. Stock LSX head flow chart
  90. What kind of gas mileage can i expect from my 408?
  91. GMMG with CME question...
  92. 100 MAF's comparsion
  93. K&n fipk
  94. PLEASE help me find a stock GM trans mount!!!!
  95. GTP 4" cutout is falling apart...
  96. need help with motor
  97. is pulley on far enough?
  98. Have cutout to put on corsa catback. best way to put it in there...
  99. D585 Coil Defect?
  100. PCV system on truck blocks/valve covers?
  101. What's the function of EGR???
  102. Will the ARH y pipe fit Kooks Long Tubes? help
  103. LS1 intake fit lq4 with 317 heads?
  104. Anyone have the Texas Speed 1 7/8' headers ?
  105. help in sugarland
  106. L92 heads swap?
  107. exhaust pipes
  108. which muffler/bullet with lt's to mimic the loudmouth w/ stock manifolds sound?
  109. What gap for tr55????
  110. 07+ truck coils
  111. Anyone looking for parts
  112. Anyone ever deal with StreetsideAuto.com?
  113. LS6 exhaust port dimension?
  114. Which is deeper sounding: hooker or magnaflow
  115. LQ4 water pump clutch fan removal?
  116. Which heads to go with?
  117. Coil relocate questions
  118. misfire on 2 4 6 8
  119. Stock MAF differences: 01 and 99
  120. Need some help with my 98 PCV system
  121. Weiand/Lingenfelter Intake?
  122. Muffler is bad, replacement?
  123. Poly tranny mount with stock motor mount?
  124. Header Tick
  125. stumbles on accel
  126. ls1 vs sbc 355
  127. NGK TR55 vs TR6's ?
  128. Different Plugs
  129. Need pics of harmonic balancer
  130. QTP Electric Cutout Install/Issues
  131. Carb conversion questions..HELP!
  132. ORY dumped, 3" or 3.5" muffler??
  133. bought some goodies.. exhaust, headers,ect.
  134. Catch can installation question
  135. new LS2 Throttlebody install : No start??
  136. Stock Manifolds + Gutted Cats. What Muffler for Throaty, Deep, No Inside Drone Sound?
  137. Kooks 2" race headers and BMR Manual Rack
  138. Attaching Throttle cable?
  139. Modifying hooker into a semi slp loudmouth
  140. Air/ EGR delete ok to drive with codes?
  141. F body alternator operation
  142. ls1 idling low And dying
  143. charging issues....
  144. too loud, what now?
  145. Whats the easiest way to put a new gasket on my EGR?
  146. What throttle cable when removing cruise?
  147. Oil Pressure Sensor compatibility question
  148. waterpump on the way out? help!
  149. Poly Tranny mount install help? Pics?
  150. Air Pump Reversed?
  151. Misfire = Vibrations?, but no codes?
  152. how long of a muffler can you run behind the axle?
  153. Magnaflow Catback issue
  154. My little Header Nightmare
  155. Edelbrock Shorty Headers on a 1998 Ls1
  156. ARP Header bolts
  157. hard starting after long tubes and true dual
  158. Stock FAST throttle body hole size?
  159. how should i run my serp belt
  160. SUMMIT/JEGS X-pipe....
  161. Stupid Oil Pan
  162. What Locktite Or Sealer For Studs In An Aluminum Block?
  163. remain turbo or go N/A????
  164. Stumped
  165. Round peg Square hole????
  166. 241/243 VS. 806 heads.
  167. Reaccuring Exhaust Leaks
  168. Cat / Y pipe question
  169. header wrap...
  170. Need some info on lpp headers
  171. EGR and Air block off plates
  172. How to raise the exhaust up about an inch?
  173. SLP Loudmouth questions
  174. TSP True Dual Exhaust-Need Help/Advice
  175. Need info ASAP!!! Weight of LQ9 for shipping quote
  176. MSD Spark Plug Wire Help
  177. holy y-pipe resriction!!!!
  178. T & D Rocker arms
  179. Header gaskets
  180. starting problem!
  181. Electric cutout install?
  182. Fast 90 install, need some help
  183. exhaust insert
  184. fast90/102 r or pro flow intake?
  185. Fast 90/90 on a stock LS1 in a 3rd gen Formula
  186. What heads do I have?
  187. 12.2's now whats neded to get in 11's?
  188. LS6 intake installtion help
  189. Backfire
  190. Feedback on Dynotune From Hp
  191. cfm on the bbk
  192. Alternator mount
  193. ls6 pcv
  194. 2004 LQ4 Idle issues
  195. Swapping K-Frame-dropping oil pan
  196. wtf engine mount bolt
  197. Abaco MAF's....
  198. Power Steering Pump
  199. Help me troubleshoot smoke!
  200. Help with a fuel line
  201. Does exhaust dumps have to be slashed tips?
  202. My new exhaust 3" X-pipe w/Dynatech Splitflows
  203. I am in the middle of installing SLP UD pulley. Help!
  204. Throttle Sticking, Need Some Suggestions please
  205. Crazy Idle....NEED HELP
  206. Water Pump interchangability question
  207. Kooks or ARH worth it?
  208. Tps sensor help please!!!!!!!
  209. Best prices on Fast 90/90?
  210. Drive by wire and auto to manual question.
  211. Seriously annoying DMH E-cutout problem. What can I do?
  212. New car but I hate the exhaust!!!
  213. Need to Cut Welded Y...Ideas???
  214. how hard is it to replace oil pan gasket?
  215. Crankshaft Pulley Wobble?
  216. what factory truck coils would be ideal?
  217. Which Spark Plugs?
  218. 2002 Running rich after long tubes?
  219. header help
  220. people with TSP duals come in please!
  221. lingenfelter 2 step causing car not to run
  222. Nitrous or Heads?
  223. how would i go about making a templet for port matching an intake to the heads?
  224. Which MAP with carb conversion ??
  225. help me...need my oil pan reversed for a sandrail....
  226. longer 02...
  227. Exhaust leak HELP
  228. 317 cast head help please
  229. Is It Safe????
  230. I got a 98 TA WS6 need help with choosing next mods
  231. What does a leaky header/bad gasket sound like
  232. Electric cutout?
  233. FAST 90/92 Guys Come In!!!
  234. anyone running lpp duals yet?
  235. Which Puller to Remove Powerbond Pulley?
  236. Picture request - TSP long tubes
  237. 07 Corvette Injectors?
  238. Will this setup work for cooling my LS1
  239. milling ls6 heads?
  240. Magnaflow C/B Exhaust Rattle, who has it?
  241. pcv in totally differnt place
  242. Help no heat
  243. GM starter VS. Aftermarket starter
  244. exhaust rasp after header install???
  245. Sweet Thunder too loud?
  246. Can you run a cutout in the I-pipe with an SLP style muffler?
  247. Meziere electric waterpump, a few questions.
  248. Normal catch can fluid?
  249. question about idle
  250. Great examples of some hard work:
