View Full Version : Generation III External Engine
  1. new TURN ONE power steering pump and wheel
  2. new billet Katech belt tensioner
  3. Need Help with American racing Headers
  4. slp dual dual vs magnaflow
  5. Battery problem, I think
  6. Aftermarket Water temp sensor question
  7. anyone using these mufflers?
  8. fast 92 intake mani
  9. Broke PCV plastic hose on intake install..??
  10. Question about ARP Head Bolts.
  11. BBK Intake Install....Let the surgery begin
  12. A/C Vent lines..
  13. ms3 like custom grind?
  14. Starter Problem!!
  15. O2 Sensor wire routing.........
  16. anyone have any experience with this ebay full exhaust kit?
  17. relocating pcv ?
  18. 6 liter block differences?
  19. SLP air lid
  20. Thinner Head Gaskets
  21. header removal?
  22. New Build, still burns oil ?
  23. intake for 2000 c5 corvette
  24. Dyno before and after QTP longtubes and Y?
  25. Starter not touching flywheel, Please Help
  26. Are 98 injectors the same as 02
  27. X-pipe design
  28. pcv lead?
  29. will running without tune hurt?
  30. cant find a pcv on my camaro
  31. Pacesetter Longtubes & Y with stock catback?
  32. Replacing Magnaflow 3.5" dual tips
  33. Pvc tube pinched?
  34. flowmaster merge question
  35. Do stock pullies go bad?
  36. Kooks vs. ARH vs LPP
  37. Exhaust Pics
  38. Relocating the MAF - I have a question
  39. lq4 block question
  40. Damn Exhaust! anyone help me out? duals?
  41. Mmm... every guy loves a nice, hot, wet...
  42. Dynomax Bullet or Moroso spiral flow which is better to quiet exhaust?
  43. Why would these be in my LS1?
  44. Y pipe question
  45. Running LS1 on carb setup?
  46. A couple intake and TB questions?
  47. lm7 5.3 questions
  48. Easiest way to pull engine?
  49. Broken Map Clip
  50. Torquer V2 + L92 heads ??
  51. header, ory, intake and flow pac question
  52. Question on Vic Jr with a accufab 4150
  53. BBK intake..
  54. SLP Lids differences?
  55. Any way to get D585 coils out of their holder
  56. coolant sending unit. Can I do this, or is it a problem?
  57. who makes an ORY with a flowmaster merge?
  58. Starting Problem
  59. Timing cover..
  60. Rough Vibration in Car
  61. time to buy TB but what size ?
  62. Draining Water out of my Catch Can,Please Help!!!
  63. Rough Idle Issue
  64. header question
  65. seems like a hell of a deal Full LS1
  66. Lookin for a stock replacement muffler and new tips
  67. lets talk long tubes
  68. calculate my y pipe diameter
  69. starting problem
  70. Knock Sensors
  71. Exhaust Question
  72. 43 WHP gain with shorties, why such a bad rap ?
  73. Intake
  74. Save $110 on Nasty Performance Billet Valve covers
  75. lt1 to ls1 swap
  76. Cutouts worth it?
  77. doing the poly motor mount upgrade which way do they bolt back on?..
  78. anyone know of good site with exhaust fittings?
  79. Car missing erratically. Need some advice.
  80. Just Installed BBK Intake
  81. Has anyone ever tried a borlamouth like this?
  82. Stock muffler size
  83. Victor vs GM Spider?
  84. GMMG exhaust?
  85. Coolant Steam Pipes
  86. Motor mount install info..
  87. ECM issue? I need advice
  88. Alternator Relocation Question
  89. Need help deciding what to do.
  90. Need 1 single MSD spark plug wire
  91. Cutout question...
  92. moblie 1 oil filter
  93. 2.5'' dual setup, better then 3''y with 2.5'' tail pipes
  94. Power Stearing Pump
  95. Ls-6 egr fitment
  96. Are there any bullets that give that high pitched corsa/exotic sound?
  97. What's going on here??
  98. What size hump hose for stock TB and MAF?
  99. Which two wires to check TPS voltage?
  100. advice on where to get stock TB and LS6 ported??
  101. ls6 intake?
  102. Fast 90/90 Stock MAF question
  103. what borla exhaust is louder?
  104. edelbrocks new batch pro-flo intake
  105. Front O2 sensors
  106. 5.3 LS1 Engine questions
  107. truck coil/truck TB fitment issues on Fbody setup, need some input
  108. Tb porting
  109. slp dual/dual with a cam
  110. Need help asap please o2 sensors
  111. help me with my performance shopping list
  112. LT Headers
  113. Squeeky Bearing On My F-Body P.S. Pump-Can It Be Rebuilt?
  114. Meziere race pump and all accessories
  115. help! need info
  116. Weiand intake barb fittings
  117. Single Chamber muffler question
  118. 5.3 heads on 383?
  119. How Do you like my PCV system
  120. a couple of ?s
  121. PCV System from magazine build? Is it OK?
  122. Haven't heard of this yet FAST 102rt
  123. Adapter or way to mate up a P&P LS1 TB to a 96MM Typhoon Intake?
  124. Getting Pissed off!!!!
  125. Will 98 coil packs fit 2000 up brackets
  126. Valve Covers
  127. my duals for your y pipe
  128. TSP Rumbler vs. GMMG clones : opinions?
  129. oil pan help...
  130. Will I need to upgrade fuel injectors??
  131. Narrowed it to 2 TSP cams, don't know which?
  132. Pacesetter TFX catback
  133. Header size...?
  134. Intake manifold decisions.
  135. Starter cover to view the flywheel?
  136. Ls1 inTake and TB
  137. Fast Toys 85mm lid gasket
  138. Need some help on intake and valley cover bolt sizes
  139. Aluminum intake vs. ls6 intake
  140. LS2/3 4 Bolt DBW with LQ4 Help
  141. Oil pressure problem
  142. Coolant Expansion tank for LS1, whats needed?
  143. help on a set of 241 heads
  144. what hp output should i get with this?
  145. LS6 Intake Size?
  146. What intakes will work with 317 heads
  147. has anyone painted their TB and/or MAF red?
  148. Turn the key and all i get is a HORN???
  149. True duals on kooks 1 7/8 headers
  150. 02 z28 swapping in a 03 denali 6.0
  151. hello i have an idea...true duals
  152. ls1 with ls2 typhoon intake ?
  153. Header install help!
  154. Oil pan
  155. Starter tech
  156. Bad pulley squeal! How to figure out which one it is?
  157. Yet another ATI damper question
  158. porting LS2 question
  159. GMMG Guys I need help
  160. balancer bolt
  161. ProCharger install with elec water pump
  162. Plugging the dipstick hole??
  163. Overheating???????
  164. O2 sensor question, PCM section useless, sorry.
  165. Ls6 intake
  166. cut out size?
  167. Performance Starters???
  168. magnaflow metalic cat question
  169. knock sensor ls1-ls2
  170. Mufflex Spintech Question
  171. My exhaust setup (possibly)..comments / criticism
  172. What catch can is everyone using?
  173. sparkplugs...whats everyone using?
  174. LQ4/9 Questions & Front Accessories
  175. PS Pump Reservoir Solution?
  176. No spark while cranking!!!
  177. Exhaust info again....
  178. Just bought a SS with a TSP 408 - what headers?
  179. Nascar power steering cooler?
  180. my power plan any advice?
  181. oil guage and temp guages not working!!! help
  182. 1 chambers or loudmouth
  183. mac ory pipe. cat size?
  184. Typhoon intake?
  185. If you have a a nice deep tone TD set up....come on in.
  186. newb
  187. shorties
  188. Missing on number 1?
  189. power steering pulley
  190. start up problem
  191. Possible Gains from tighter Spark Plug Gap?
  192. Engine Covers
  193. Rattling noise?
  194. 2001 LS1 Stumbles and dies. Ideas?
  195. Car wont start and then it will
  196. TSP Borla Rumbler
  197. Brand New Forged 347 LS1 H/C Needs a Tune?
  198. LQ4 plug n play?
  199. Can I use the 5.3 chevy truck motor in my ls1 car?
  200. quick ? about a rad support?
  201. Alternator bad, or something else?
  202. Bullet Muffler Questions
  203. Ported LS2+NW 90mm tb vs Ported tb+LS6 on 6.0?
  204. How to install LS6 Intake Manifold Video
  205. leak
  206. Dual Cut outs on Y Pipe
  207. Pretty sure i just broke my oil pressure sending unit
  208. 4" cai
  209. Straight thermostat neck?
  210. power steering leak
  211. poly mounts
  212. 2000 camaro ss stock ehaust
  213. Reference source for Sensor locations, functions, connectors, etc?
  214. Need Exhaust Help !! for more Power
  215. What gap and plugs for 16psi max?
  216. New Intake/Cam Debate
  217. heads , exhaust, turbo
  218. what brand of spark plugs???
  219. Strange oil leak...
  220. New Firebird Hood Design
  221. 92 mm maf?
  222. 00 SLP MAF on 04 goat
  223. Can I use a LQ4 Engine in my LS1 car?
  224. Exhaust set up ??
  225. Link to free mods
  226. electrical problems
  227. Vacum System
  228. OPSU question
  229. Differences between Jet Hot and Hooker headers?
  230. texas speed ory (new design)?
  231. Solid or prothane motor mounts?
  232. Alarm/Power
  233. Alarm/Power
  234. Vic Jr. Picture Thread..
  235. Electrical problem after tranny install.
  236. Dayco = Garbage
  237. Electrical short after tranny install.
  238. Who can build true duals over the axle in Kansas, Missouri, Arkansas, or Oklahoma
  239. Anybody tried this aftermarket LS1/LS6 waterpump?
  240. new here and looking for some advice
  241. New Motor and Boost Idea need some feedback
  242. Pictures of my wrapped headers
  243. lifting complete engine - how?
  244. Brand new erl performance 102mm throttle body
  245. all catch cans the same?
  246. HELP car won't idle below 2500 rpm!
  247. Looking for LS1 header bolts or studs?
  248. Wideband gauge question
  249. Will GM Competition valve covers work?
  250. Lowered, LTs, and TDs. any pics?
