- what the hell is going on with hooker!!!!
- Newb Questions - Dressing my first LS1
- ATI Dampner
- Socrpion 1.7 RR discussion
- How do I get this last manifold bolt?
- FAST 90 Intake install questions
- problem with cruise control? anyone had this?
- 799 Heads??
- 90mm or 92mm TB & Intake??
- adding hi-flow cats
- will these headgaskets work
- 160 thermostat
- 02 sensor spacer?
- ok, what MAF to go with??
- LS2 intake.
- slp lid
- need help with parts list for 408 stroker
- Oil/Residue on Air Lid???
- TPS issues... While driving, push pedal down, no change in RPM!!!
- Hooker headers
- ls2 intake vs ls1 intake
- How do you wire NEATLY?
- coolant x-over question
- Good Price?
- throttle cable routing?
- Car will turn over but not start.
- best cam for a daily?
- Name that muffler
- Magnaflow questions
- oil pressure
- throttle body mod?
- Putting car back together... Forget where these came from.. pics!!
- Spark plug wires - what to lubricate with?
- Help finding X pipe
- pcv routing for 98 LS1, no valve cover port on pass side
- need help rpm guage quit on me
- Introducing Firecore50 Plug wires
- x pipe question
- 02 camaro ss have 2.73 gears?
- What Engine Mounts?
- Can a clogged cat cuase lower engine vacuum and higher A/F at idle + run terrible?
- p0300 code after fast install.Help
- maf and throttle body mod
- Will my car drive with only two 02 sensors?
- Throttle Position sensor HELP!!! Codes listed.
- SLP CenterMount Exhaust
- Burnout
- Can't seal up thermostat....
- how to port a ls1 intake
- How long can the spark plugs be left out of the heads?
- FLP Longtubes
- Any way to test the Coils ?
- LS6 vs FAST intake Swap
- power steering pump
- magnaflow cat back questions..plus others
- 2'' headers
- pacesetter ory vs. tsp ory
- Rear Main Seal? Help a no0b out-
- Fuel Pump help????
- question bout bbk 85mm tb
- header question
- Cylinder head plate
- long tubes for lowered car
- Water Pump Gaskets . . .
- cat?
- spark plugs and gap
- LM2 even more restrictive than what I had before?
- Question about TSP TD's..
- What size mm is a ls6 intake front opening?
- HO Alternator Purchase
- quick question
- Tsp 1 7/8 headers. Anyone running them?
- 02 extensions
- Pacesetter Header Install
- I'm getting 6.88MPG... ideas?
- magnaflow to corsa? good idea?
- spark plug gap?
- Header install
- mandrel bent tubing vs. regular...
- Fast92/PTM92/SVO30# install; gotta couple of ??
- Cam'd LM2 sound clips
- Issue with my LT install. Pictures to help.
- clearance on y pipe
- throttle body question 4 bolt?
- Throwing code P0171 System too lean, bank 1
- I changed my plugs... now the car is running rough. What wires would you recommend?
- what heads to get ??
- Bullets off the collector
- Pro Products TB Reducer?
- balance pulley on LQ4
- P0327 and a LOUD KNOCK
- Blown head gasket issues
- Threaded inserts, LS6 intake, cable throttle conversion.
- headers and ls6 intake,now a vacuum leak?
- Where do you connect a digital speedo?
- ory question
- throttle bodies 5.3 6.0 ls1?
- fast intake install question
- Junk In My Radiator
- What color paint should I use on coated headers?
- longtubes+inspection+ new jersey
- Cam sensor, help?
- Question for speed density guys!
- Failing emission test with TSP catted Y
- Bank 1 O2 sensor
- LT's. How high do I need to jack the car?
- Does anyone make an LS1 header that doesn't turn left when exiting?
- Pulleys?
- thermostat
- One of my pulleys is squealing like a pig...
- Need a 2 Bar MAP for Ported Fast 92
- Cat help
- What is BEST Throttle Body?
- need some TD help, mine suck (Speed Inc DIY kit)
- Need help diagnosing a problem
- MAP sensor install question
- gains with a victor jr intake
- muffler question
- mufflers
- Are the L and R pre-cat O2 sensors the same?
- port LS6 intake
- VIDEO w/ open cut out. The wait is over! :)
- LS1 + KOOKS + CATS + cam + Corsa Video
- Intakes vs hood clearance..
- Won't stay running
- Water Pump Pulley Is To Far In? What to do???
- Whats The Difference In 1 7/8 and 1 3/4 Headers?
- Holley TB
- Loudmouth 2 with Mac mids, catted y, TR224 too loud?
- ARP head stud washer question
- DMH customer service anyone?
- Ported LS1 TB damaged in shipping-need help
- Best Plug Wires?
- Blocking heater nipples
- Throttle Body Modifications??
- Cut outs
- LT Flowtech w/ 2.5" ory vs Kooks w/ 3" ory
- cutout installed
- Inovate LC-1 programing issues
- LS1 running slugish at low RPM in any gear
- Question about 160 thermostat
- Question for ya
- hooker muffler replacement options??
- figured out magnaflow vibrations
- solid mounts with bmr k-member
- My 418 stroker is done for now!
- Anyone ever damage their O2 sensors by going in a deep puddle?
- TD's exhaust drone in 6th gear, at 2000 RPM
- Need help with throttle cable adjustment.
- FAST Porting Number Comparisons
- 180K maintainance: Coils? Alternator?
- not sure
- lt's w/ y-pipe with magnaflow sound
- IAC Motor
- Nick Williams 90mm Throttle Body Question
- High Output alternator (HO alt) = better MPG
- 02 Sensors advice?
- Real World FAST Intake Gains
- What am I missing?
- porting weiand=loss of low end??
- ok, radiator question here
- LS6 intake install, how-to?
- SS Hooker Headers?
- Throtle body polishing
- Problems with Magnaflow
- 4'' Mufflex Catback with Flowmaster Merge Installed
- Installed a Magnaflow Cat Back
- American Racing 2" primary headers. PICS!
- LS1 Exploded View/Diagram
- bad water pump?
- Oil Presure
- what muffler for LM ?
- Question about egr & air pump
- I think I need a catch can. but I am not sure
- ls2 coil mounts...?
- truck MAF questions!
- Front drive help.
- compression ratio est
- Headers Installed Video
- Think I know where my missing HP is, 2 3/4 exhaust?
- Coil questions
- need exhaust help
- Oil Pressure and Temp Sensor Aftermarket Gauges
- Harmonic balancer question...
- UPS guy is my friend
- New Saikou Michi Catch Can
- 85mm tb and ls6 install.... not what i was expecting...
- chambered exhaust vs straight through help.
- which y pipe?
- What happened to the guys thread about sheet metal intakes?!?!
- Flowmasters vs. SLP LM vs. Magnaflow -PLEASE HELP ME DECIDE
- Over heating
- Lid wont stay on!
- why pin the balancer?
- pvc routing question
- Oil Pressure Temp Gauges Electronic?
- Relocate Alt on top
- Intake Manifold question
- LS6 catch can setup??
- Loud exhaust, got pulled over by the po-po!
- New exhaust Setup - 4" FM Merge, 4" Cutout, 4" DMH
- Perimeter Bolt Valve Covers...
- how is everyone hanging their TSP true duals
- Highest ~quality~ catback (fits like it's stock)?
- eldebrock shorty headers on stock y-pipe?
- Motor revs up on its own
- Replacing motor mounts while motor is still in
- Is this a complete throttle body?
- issues with fast intake and throttle body
- Header Bolt size?
- Power Steering Problem
- Clearing o2/cat codes...
- Question Harmonic Balance removal/install tool
- Another Exhaust Question
- Quick and easy question
- loudest exhaust
- What Throttle Body for my 96mm Typhoon Intake?
- my new 4in Exhaust
- Ls6 heads Gain with my mods.About to tackle install
- SLP lid PISSES ME OFF
- Will A Fast 92mm Help My Setup?
- Where to get cometic head gaskets for Darton sleeved 4.125 427 block
- Catback & Lid For 427? 550-580rwhp
- Tell me a little about this intake
- Help.. where to tap Super Victor intake for vacumn
- what is the quitest aftermarket catback
- Rattling coming from the O2's What the hell??
- Realistic Gains from a Re-Tune?
- What kind of exhaust is this?
- Cats with non-emission headers?
- is my car choking.
- Fuel pump harness pink wire, 5V? 12V switched?
- WTB 4" 3hole collector gaskets
- Long Tube Headers Question
- 2002 v6 m5 swap to ls1 t56
- where do i buy little odds n ends stuff??
- Has anyone modified stock valve covers?
- 90mm tb blade
- forgetting anything?
- Deleting PCV to Catch can on ls1 what size hose?
- Any rubbing issues with 98mm Fast toys Lid?
- Do all ORY smell?
- Is a slp maf worth it?
- ls1 locking actuator
- Plugging SLP EGR provisioned LS6 intake EGR port questions
- swapped cam position sensor now sputtering and backfireing
- Building a LS1
- expected gain Ls1 IM to 90mm IM
- TSP Headers finally done
- Anyone know what this is ???????????
