View Full Version : Generation III External Engine
  1. Line locks
  2. 3" tubing...
  3. Porting TB
  4. 02 sensor 24" extensions
  5. Victor Jr. help please!!
  6. LS1 conversion radiator? tranny side used as a oil cooler ?
  7. I messed up one of the bolt holes for the head. NEED SOME HELP
  8. Need coupler for intake
  9. CYL 5 misfire... tricks to narrow it down?
  10. changing exhaust
  11. coil questions just wanting to double check
  12. Summit 85mm throttle body
  13. Hello all
  14. hole in pacesetter primary
  15. EFI with no ECM? 1998 Ls1 vs 2001?
  16. What am I missing? Installing Headers in due time
  17. overdrive alt pulley broke off?
  18. 500+rwhp guys what radiator are u running
  19. PLEASE HELP!! car running horribly after moser 9" install w open headers
  20. ? about EGR
  21. Finally pics.
  22. need pics of engine
  23. Blew out header gasket......help...
  24. Water Temp Gauge... Using Passanger Cyl. Head
  25. Wanna do my own header install, couple problems i am for-seeing
  26. Smooth bellows
  27. HP Muffler for my 02 CME
  28. HP Muffler for CME
  29. will be needing a good sounding catback soon!
  30. 02 Z06 cam?
  31. How many 01 and 02 fbodys had a ls6 intake?
  32. **Plug-N-Play Oil Pressure Sensor Relocation Kit**
  33. LS6 spark plug wire crapped out..
  34. stock maf on 402?
  35. FINALLY...Kooks LTs, catted Y, GMMG. videos
  36. overheating ?????
  37. Pacesetters with cutouts
  38. what battery ya'll using?
  39. How is everyone running AN lines to catch can?
  40. quick question about my throttle body
  41. bbk ssi
  42. Stainless Headers for $155 ?????
  43. Anything wrong with have one hi-flow cat on the I-pipe??
  44. 1998 Camaro tach re-wire
  45. Coolant Leak Help
  46. damper torque
  47. Question on ARH/Y-pipe installation - Rear O2s
  48. 98 TransAm Alternator issues, help?
  49. pacesetter LT's getting out on next week
  50. Sleeve for my Lid
  51. Where to buy headers for a good price?
  52. To High Co in the exhaust.
  53. Pacesetter with cutouts??
  54. What LS6 intake to buy?
  55. Hood clearance with what intake/elbow..
  56. Loud popping sound, but no misfire after exh gaskets
  57. Help! 01 supercharged corvette white smoke from breather cap
  58. FAST intake bolt sizes?
  59. Opinions wanted on Mufflex 4" Catback
  60. Cooling issue
  61. idle issues
  62. Stock fuel pump LPH specs?
  63. 78mm to 85mm intake upgrade?
  64. so here's my magnaflow
  65. Poly Motor Mount
  66. Got a problem lol
  67. vette o2's vs. extensions
  68. Coil arc question
  69. 2 1/4" exhaust ?
  70. Need Muffler help !!!!
  71. Vats issue please help
  72. exhaust help!
  73. Idle Gremlins...
  74. Cut outs on dual exhaust?
  75. where do I put the Wideband Sensor (Pic)
  76. A.I.R. Delete
  77. 5.3 LM7 Jeep CJ7, What muffler do I go with?
  78. Cobra guy needs some quick advice
  79. pacesetter y-pipe w/ hooker lt's
  80. Just got an S3 TB and tune from Shaner. WOW!
  81. Valve Covers for shaft rockers ??
  82. LS1 intake on a stock 5.3, what injectors to use?
  83. AIR!/EGR! check list...
  84. Got My Headers pics.
  85. A4, HID, 500w sub,pulleys+lightweight battery?
  86. Vid of my 2000TA w/ LM1 exhaust
  87. Catch Can?
  88. Cat-Back for sale??
  89. HELP!! I put off starting thread as long as I could surging/missing rough low idle...
  90. Mass Air Flow Sensor
  91. Any free mods i can do?
  92. Ls1/LS7 crank bolt?
  93. T/B only opening 84%!!
  94. LS1 Engine/ 4L60E Removal
  95. Crank pulley fell off!!! Damm
  96. How to delete AIR/EGR? Help please!
  97. Wondering if anyone can lend me ATI Drill Pin Fixture
  98. Bolt ons to make 450 rwhp in ls1 camaro?
  99. Question about triple pillar pod
  100. Upgraded throttle body?????
  101. Do i need my 02 sensors?
  102. Easier way of doing motor mounts.
  103. What is this plug and wire for?
  104. removing oil pressure sensor
  105. PICs of Edelbrock LS1 valve covers?
  106. Starter Issue Please Help!
  107. Headers Installed...Need Help Tuning
  108. Driveshaft loop and Flowmaster merge
  109. should i take off my flowmaster?
  110. Formula exhaust question
  111. LS2 Pro Flo intake test fit.
  112. Intake and valley cover torque specs?
  113. Installing LS6 Intake
  114. Where can i get a qtp y pipe
  115. Best Throttle Body For an LS6 Intake?
  116. Exhaust without headers?
  117. change oil pressure sensor without pulling intake?
  118. What is the inlet diameter of the ls6 intake manifold?
  119. Disconnected autometer air fuel ratio and now car runs like shit help please!
  120. intake that flows over 300 cfm???
  121. GMMG or Magnaflow
  122. 00 LT headers on 98 car??
  123. installed my new intake and exhaust...
  124. Sticking Throttle?
  125. Help Me ID this Noise *Video*
  126. 383 stroker
  127. Check engine light code....
  128. what to use to install headers
  129. Porting an LS6 Intake Manifold......Worth it????????
  130. Need help!
  131. New exhaust setup...
  132. busted lug/stud
  133. *Dilema* is it worth it??
  134. HELP! Balancer bolt will not stay tight
  135. 98 F-Body turning over but not start... help needed.
  136. L33 5.3 build fast intake question
  137. coolant crossover- part numbers
  138. Dual Catch Cans?
  139. Which 12 bolt rearend-Moser or Strange?
  140. Anyone run no muffler?
  141. B&B triflow tips
  142. New headers
  143. Strange whining upon exceleration...?
  144. those with G2 super springs and headers..
  145. Header/Y Packages
  146. GTO Oil Pan, oil cooler question
  147. Needed: Pictures of FTRA!
  148. lt's, which o2's?
  149. do i need the oil pressure sensor?
  150. Which Edelbrock Manifold?
  151. is the pcv valve at auto zone any good???
  152. ebay lts/tsp rumbler question
  153. Trying to install my 92mm FAST & nothing but problems
  154. problem with this code. p0300 random multiple missfire..
  155. Just wondering if I hurt my car with a M/F
  156. Failed Smog
  157. bosch universal 02's
  158. stock ls1 heads on a 5.3 motor?
  159. Bosch oxygen sensor part numbers
  160. what do you think? Intake or heads
  161. got some goodies the other day
  162. SLP power flo with CME?
  163. magnaflow rattling bad...
  164. Windage Tray
  165. dumb question about header bolts
  166. Tachometer Problem
  167. Borla pro xs?
  168. Cap off driver side valve cover?
  169. which cam should i use
  170. Auto and pulley
  171. what catback sounds best with no cats?
  172. Could this be causing my problem?
  173. What's the latest take on knife-edging the TB blade?
  174. Borla XR-1 muffler question
  175. Measure your borla catback muffler
  176. y pipe for LT's...?
  177. Low speed fans are not coming on?
  178. Got Headers/ORY...have an O2 question??
  179. best cat??
  180. Looking for a drivers side valve cover PCV Nipple...
  181. Pick a CATCH CAN
  182. Different year throttle bodies
  183. best Lid??
  184. Wall Street virtual stock trade game
  185. Installed a set of LPP LTs and offroad Y - PICs and Video
  186. Band Clamps
  187. Keyed Power Source
  188. Anyone here get rid of Borla for something else?
  189. starter issues help~!
  190. Dumb question I bet
  191. Another LS6 intake manifold question
  192. underdrive pulley?
  193. lets hear your Borla catback
  194. stock ls1 heads for sale
  195. Bang for your buck Headers
  196. Where to buy Valve Seal Kit?
  197. Flowmaster merge install specifics
  198. Bolts List???
  199. Need help with 02 sensors big time struggling.
  200. 6.0 swap????'s
  201. Spark Plug Gap?
  202. Plugs - TR6 or TR55s?
  203. Where do you hook up the tach wire from a tach on an ls1?
  204. exhaust tick
  205. SS Hood Question - Functional Ram Air
  206. 2000 Ws6 True Duals Vid
  207. Mid length vs. Longtubes
  208. What do i need????
  209. ls6 intake swap question
  210. should i get gears for a A4?
  211. My newly ported&polished TB+New Shoes!
  212. back coil pack on driver side not firing at all "need help"
  213. Looking for a better water pump
  214. Valve Cover Bolt Part Number???
  215. Air pump problems
  216. Edelbrock Pro-Flo XT Vs Fast 90on a 346
  217. help, I Think im losing coolant ! (LS6)
  218. Finally got rid of rasp
  219. too rish at wot. stock ls1
  220. Things needed for header install...
  221. Buddy put a hole in my TB
  222. Tricks on getting EGR tube back on?
  223. Edelbrock pn 7140
  224. pulley broke need help
  225. Whining Alternator
  226. Exhaust Bypass Mod On Stock C5...VIDEO
  227. LS6 MAF and ported TB.
  228. Wiring Harness Clean Up
  229. Victor Jr. on a street car?
  230. Header gaskets...
  231. spohn solid motor mounts uneven?
  232. 1 3/4 hookers Vs 1 7/8 American Racing Headers Results to be posted
  233. Coil Pack Test
  234. New Detoxx vid with 00BadfnTA
  235. Is it SAFE to de-screen the MAF?
  236. Under drive pulley???
  237. Scoop
  238. So I broke that little plastic thing on the intake...
  239. stock lid
  240. 160 vs. 180 thermostat
  241. will a fast 90tb fit a ls6 intake?
  242. I am so pissed off !@^%#!@
  243. 1 3/4 vs 1 7/8 for my application?
  244. size of injector holes for efi victor jr intake
  245. plug wires with truck coils
  246. Whining Pulleys, which ones?
  247. New Water Pump
  248. Speed Engineering Rant
  249. pulling the crank pulley
  250. bracing required for solid motor mounts??
