View Full Version : Generation III External Engine
  1. SLP with BORLA??
  2. Intake gaskets and bolts
  3. SSRA or FTRA KIT owners ......
  4. ls2 intake on 99 t/a help!!
  5. silicon bellow???
  6. LS6 Swap in a 91 240sx
  7. Finally installed the GMMG
  8. Orielly's special
  9. 08-09 tahoe muffler
  10. Do Hooker LT's come with extensions?
  11. Motor Mounts LS1...??? HELP???
  12. 2002 Corvette Intake Air Bridge
  13. Any harm/good in putting a filter in place of oil cap?
  14. Correct me if I am wrong but...
  15. HELP - 02 Wiring
  16. Are there any aftermarket gauges that will use the facotry CTS sending unit?
  17. slp dual dual
  18. another UDP question
  19. Hooker cat back????
  20. Another header question
  21. C5 vs Fbody underdrive pulley (can they be interchanged?)
  22. Car runs really bad in closed loop, please help
  23. The longest LS6 intake install EVER!!
  24. cme valance & tip for sale
  25. watch the whole vid! lol
  26. U/D pulley swap?
  27. How do i..........
  28. What to do now?
  29. ls6 intake question
  30. Underdrive pulley gains?
  31. Nick Williams 96mm t body
  32. My E-Cut...Need A Straight Answer
  33. built 4l60e or 12 bolt
  34. MagnaFlow or Borla
  35. TR6 number
  36. Modification to Corvette LS1 sheet metal exhaust manifolds
  37. IAC motor makes noise
  38. Goal is low 11
  39. ARP head torque question
  40. how to install Meziere electric water pump?
  41. aluminum heads on iron block (gasket question)?
  42. P0480 - P0481 / With Manual Fan Switch?
  43. Smog/SES question with LS6 manifold
  44. Typhoon Intake
  45. stumble at about 2500
  46. Stock throttle body air hole or nick williams contact info.
  47. Quick question, plug wires bad?
  48. Difference in sound between cats and no cats?
  49. muffler with ricer sound? or very quiet?
  50. ls1 hooker cat back vs lt1 hooker catback
  51. How to build my bottom end??
  52. American Racing 2" or Kooks 2' Racing Headers
  53. ac compressor going on
  54. lq4 or lq9
  55. New Side Exit Exhuast
  56. What to gap TR6 Plugs to - H/C No N20
  57. ASP pulley belt part numbers
  58. thread size???
  59. Moroso Steel LSx oil pan?
  60. help removing stripped nut
  61. Do I need to use a truck MAF with a truck harness?
  62. Worth switching from one LT to another LT header?
  63. Looking to make a 630mile trip, how much gas will it take?
  64. WTB: Does anybody have thier old exhaust hangers laying around?
  65. Got a ? bout a thermostat
  66. Part # for Accelerator cable?
  67. Stater?????
  68. PCV help
  69. will a beck sheetmetal intake fit under a c5 hood if it clears an fbody hood?
  70. OD of NW 90mm TB?
  71. Cam Sensor
  72. tensioner pulley replacement
  73. Need confirmation, will 5.3 parts bolt to an LSx engine?
  74. Volant Cold Air kit/lid....
  75. SLP Loudmouth
  76. Anyone using the Edelbrock two piece timing cover?
  77. New BBK Fuel Rails ****PICS INSIDE****
  78. Victor Jr.
  79. My intake/exhaust mods.. opinions? (2 foot piping on open longtubes/custom cold air)
  80. Which muffler??
  81. more power??
  82. texas speed exhaust
  83. Engine damage without tune?
  84. How well do spintech mufflers flow ?
  85. 2000 WS6 cat converters out?
  86. Egay Header install
  87. Replaced PCV, now it won't crank
  88. Did anybody ever get the WEIAND? Was it ever released?
  89. cuting exhaust welds??? help!!!
  90. !AIR question
  91. anyone have a good cam degreeing video??
  92. Cheapest place for pulley
  93. FLP Headers V-Band Clamp Size?
  94. K&N breather for oil fill?
  95. And on goes the FAST 92 and Throttle Body
  96. True Dual Kits??
  97. which headers should i get???
  98. gm truck coils on procharged vette?
  99. Anyone running OBX headers right now?
  100. Kinda Random But Um!
  101. edelbrock y-pipe
  102. Mac header vs. Pace setter heards
  103. Fuel guage driving me crazy
  104. any of you have a 92 mm TB?
  105. Guages Stopped Working. Need Insight.
  106. SES light / A.I.R. related?
  107. Whining noise -- fan on startup
  108. issues with new powersteering pulley
  109. Fuel Rail Cap
  110. Flywheel for A4?
  111. Air intake ??
  112. quick brake questions
  113. TSP Rumbler
  114. Magnaflow installed *Video*
  115. PCV elbow
  116. How much HP will a 4" mufflex with Flowmaster muffler support?
  117. Finally! TD's Pics and Videos
  118. Catch can and PCV routing
  119. looking for stainless exhaust piping
  120. experience with these shorty headers?
  121. Oil Cooler question
  122. Custom motor mounts? Pics please!
  123. SLP manual fan set-up
  124. Stock tensioner question
  125. 2005 corvette coils/brackets fit on F body?
  126. Need asap please alternator replacement
  127. intake options for L92 heads
  128. Hi-Flow Cats on Pacesetter Headers, which diameter?
  129. 2000 ws6 heads
  130. Intake Air temp Sensor
  131. Modify ls6 for AIR pipe.
  132. How are FLP headers?
  133. ORY plus stock headers?
  134. ls6 intake help
  135. AC compressor making noise when not in use
  136. how do i hook a monster tach in my 99 camaro ls1
  137. PTM 92mm TB vs Jantzer 92mm or 95mm TB
  138. gutting 1 cat
  139. Plug Gap With Cam Only?
  140. Ported 241's vs...
  141. Starter Issues
  142. Pacesetters, y-pipe, cutout and stock exhaust
  143. Exhaust Hurt more than helping?
  144. Need a cap for a cut out
  145. What will it take??
  146. Throttle cable issue Please Help
  147. how to get 500 hp N/A help!!!!
  148. ls3/l92 intake options looking for advice
  149. UD pulley Install
  150. Aftermarket Lid Hose Question
  151. Quick Question needs Quick Answer! Help please.
  152. msd coils on procharged ls1 vette? = missfire...
  153. For those of you with hooker y-pipes or if you are considering one
  154. Shorty header install difficulty
  155. A/C Trouble
  156. Ported MAF and TB
  157. need help wont start
  158. Throttlebody bypass and 160 degree thermo mods
  159. Check Gage Light After New Alternator install,Why?
  160. What length wiring for my DMH cutout?
  161. 241 heads
  162. coil packs
  163. Car Eats Alternators
  164. QTP cutout opinion/confusion
  165. Slp lm1 question
  166. magnaflow tip hanger question
  167. Anyone heard of these guys?
  168. Intake off, what mods?
  169. Best lid for a 01 firehawk
  170. Need MAJOR help. Engine is still stock!!!
  171. Anyone make their own 3 wire to 5 wire MAF adaptor harness?
  172. Question on SLP lid
  173. Longtube header clearance questions
  174. A/C Compressor Install tips
  175. I have a Q for all of u come in.
  176. stock f body damper pulley with slp double roller t chain
  177. GM Plug Wires PN# 12192064 or 88892763?
  178. Step inside to gain knowledge!!!! Detailed A/B comparisons with results!!!
  179. LS6 Heads
  180. Am I Losing Power
  181. Fix Cracked FAST 90 intake
  182. what is going on here!!!!!!
  183. Opinions on Exhaust Setup
  184. Hooker Y pipe piece
  185. Best intake for my aplication .. sheet metal options?
  186. EBay V band exhuast clamps
  187. someone PLEASE HELP
  188. Aftermarket Headers and Y-Pipe Not Sealing
  189. Catalytic converter placement options
  190. What should I do next?
  191. exhaust/muffler experts. corsa/magnaflow
  192. 5.3 Wiring Harness Help Needed
  193. no Power to Alternator.....
  194. UD pulley bolt
  195. removal of AC clutch.. what tool?
  196. Changing pulleys, stocker is cracked?
  197. BBK Throttle Body
  198. Soon to be SS owner. Got a few technical questions. Please Help.
  199. voltage issues with A/C
  200. Major MSD news concerning the red 8.5mm wire
  201. GMMG Install ?
  202. Car goes lean after WOT. need some advise
  203. Curiosity? How much to MOD it!
  204. 408 h/i recommendations please
  205. LT's with cat back
  206. x-pipe installation woes...
  207. IAC questions
  208. IAC questions
  209. FAT CAT exhaust?
  210. stainless steel headers cracking????
  211. Exhaust rubbing heat shield.
  212. CA Carb Legal "Long Tube" Headers?
  213. EDelbrock intake ? is it out yet ?
  214. Need to switch
  215. electronics randomly restart?
  216. Stock exhaust with gutted converters no muffler?
  217. ls6 intake on 6.0 vortec?
  218. Big thanks to Ron at Vengence!!!!!!
  219. What gauge to go with????
  220. Quad Exhaust Tips
  221. Cats (not the animals)
  222. MAP sensor?
  223. Fuel pumps
  224. How do you get two pipes apart after being clamped together
  225. Does anyone know who makes a stainless 3" merge collector?
  226. Is the 04 GTO Alternator a direct replacement for F-body 98-02 LS1 Alt?
  227. hooker?
  228. What mufflers would you recommend?
  229. need tips on getting the balancer off!!
  230. how much to mill 243s?
  231. Exhaust pipe size w/LS1 in a street rod??
  232. Where to buy fuel injector o-rings - HELP!
  233. Need a recommendation for a coupler
  234. 243 heads.. what cam/intake?
  235. What headers are these?
  236. Purchasing a DMH Cutout confusion on what size to get!
  237. free air mod effect on previous dyno tune?
  238. Rear turndowns
  239. Max bore for 5.3
  240. Where can i get valley cover bolts that will fit my fast intake?
  241. lokar ls1 throttle cable bracket
  242. Mail In Tune / Long Tubes Question
  243. What the plug wire options for relocated coils?
  244. kooks header install on a 408....HELP!!!
  245. crank but no start!!!!!!!!!!!
  246. Hmm... Exhaust Tone
  247. 408 true duals, H pipe
  248. 92 or 92 ported?
  249. Can you tell if a head is ported and how much power should I make?
  250. Extremely High Voltage reading?????
