View Full Version : Generation III External Engine
  1. How do i know which heads i need?
  2. pics of kooks true dual tips on a camaro
  3. Any pics of DIY 2-piece timing covers?
  4. wich exhaust for me?
  5. TSP TD's or GMMG
  6. What intake??? Mast,Holley High Ram, Super Vic??
  7. random misfire after header install
  8. ls conversion
  9. Electric cutout help!
  10. Engine mounts help!
  11. LQ4 Swap guys cmon in
  12. Hose diagrams??
  13. "Cool Flex" Radiator Hose
  14. Throttle body help!!!!!!
  15. powersteering?
  16. New mods..
  17. 25% ud pulley belt rubs on alternator bracket lower bolt
  18. NW TB Question
  19. Is it possible to put a small portable a/c unit in a car?
  20. underdrive pully qestion
  21. different size header bolts
  22. where to pull vacuum for headlights operation?
  23. broken exhaust manifold bolts
  24. Fuel injector question
  25. 02 LQ9 BDW throttle body no response..
  26. ls1 motor mount bolt question
  27. Fast 92 TB install
  28. pn for accessory belt
  29. Coated vs Stainless steel
  30. Removing all the accessories?
  31. 3" exhaust with UMI short TA, Who has pic of theirs?
  32. Need input on intakes!!!
  33. Finally installed my ARH 1 7/8" longtubes today...
  34. Reinstall intake or value covers first??
  35. Wire mod done... what is this for???
  36. Texas Speed headers good reputation?
  37. GMMG with CME question
  38. New to LS motors
  39. main engine harness.
  40. 01-02 manifolds
  41. Should I replace the cat?
  42. Need Advice on a intake set up (ram air).
  43. I think i got RIPPED OFF from ebay !!!
  44. LS1 swapped truck. Running rich and lean on different banks
  45. Can anybody identify this throttle body??
  46. IAC sensors
  47. How much I am leaving on the table?
  48. 102 intake problems
  49. turbo ls1 leaking oil between motor and tranny!!?! not main seal!
  50. Intake Gasket change now p0107 code and tcs off light on
  51. low idle after intake swap
  52. Valve cover bolt spacing?
  53. older fast 90 tb sticking closed/off idle
  54. Best Priced FAST 92 TB??
  55. Starter Question
  56. broken intake manifold bolt
  57. A/C Wiring Diagram 98 Trans Am?
  58. 408 spec'd cam in a ls1
  59. Comparison Pics Potz TB And Maf to STOCK
  60. Pilot bearing swap
  61. wiring pusher fans?
  62. Quick drive by vid. Bolt ons, catted Y/LM1
  63. Alternator output voltage is low
  64. bad battery or alt?
  65. 2000 LS1 valve cover gasket part number??
  66. Another belt squeak/chirp question
  67. Will Volant dual cone intake fit Camaro SS hood?
  68. Texas speed duals vs SLP loudmouth sound?
  69. Home made LM1/Borla style exhaust???
  70. SLP Traction Logic Module Question
  71. Different mufflers and tips
  72. ls6 TB vs ls2
  73. Ls6 intake swap oil press gauge
  74. broke bolt on header install!! need advise!
  75. Need replacement Hooker Aerochamber muffler
  76. Fast 90/90 MAF?
  77. Which heads?????
  78. Intake leak - power loss?
  79. PCV help 2002 ws6
  80. Which mm throttle body gasket?
  81. Fast fitment?
  82. Did Some Mods, now the car runs like garbage
  83. Part number for the pin tetainer at the top of the clutch pedal
  84. O2 sensor confusion...Help
  85. Will L99 or LS3 Exhaust Manifolds fit an LS1
  86. Are all ls motors the same on the outside?
  87. slp lid doesnt fit on stock lower airbox?????? help!!
  88. Meziere Black Anodized WP
  89. Chrs1313 a/c vs non a/c version
  90. Intake Question
  91. Stock T-Stat on a Car Tuned for Lower Temp T-Stat?
  92. Broken wires to oil level sensor and alternator
  93. White smoke/Cold Startup
  94. Front crank seal, inner diameter dry or lubed?
  95. 5.3 head choice! Need help
  96. TSP ORY fitment issues
  97. VATS or Ignition Switch?
  98. Fbody Long Tubes and Autokraft Pan???
  99. Need pics of moroso vac pump mounted to block.
  100. Gains from Mid tube headers to LT headers on a Heads/Cam car?
  101. EGR and A.I.R delete?
  102. ls1 engine harness ? whats the differences
  103. JAAM vs. Chris1313 Ram Air?
  104. exhuast is to loud, need help
  105. Lower MAP readings with FAST 102 intake .
  106. Trouble starting/running with bigger MAF
  107. Which setup would you suggest?
  108. What year for Z06 MAF?
  109. Pep Boys intake pieces?
  110. Cold air intake box options
  111. TPIS 90MM ls6 guys, what lid/maf setup are you running?
  112. C6 throttle body question
  113. C6 throttle body question
  114. Pacesetter lt's
  115. Exhaust, cut-out based question....
  116. Blade and Boot slip MAFS
  117. Installed TFS 215 milled to 61cc(.018") with Torq V2
  118. Long tubes
  119. Bosch HR9LPX plugs cheap
  120. Cbm twin turbo 440 937 rwhp dyno video
  121. Cbm twin turbo 454 1008 rwhp dyno video
  122. Poly motor and trams mounts...
  123. squishy V-band gaskets
  124. used a BFH to make magnaflows fit in the back
  125. headers ? 01 gmc
  126. Idler and sump question
  127. Air / Egr Delete !! help the newb !
  128. Dry Sump / Vacuum pump and stock PCV?
  129. APS starter/American Racing exhaust interference
  130. 99 WS6 problems?
  131. headers+exhaust
  132. Anyone in the Richmond,VA area know of a good exhaust shop
  133. MAP Location critical?
  134. starter motor with solinoid underneith facing down
  135. LS1 fuel rail clips
  136. Headers
  137. Where to get 4" cutout?
  138. Unusually High Idle.. (99 SS Auto)
  139. Did GM use Anti-seize?
  140. tsp lt headers and bolts help
  141. Deleting my AIR lines after a Long Tube install....
  142. LS1 and LS2 Injector O-ring Confusion (Manifold)
  143. What is the correct tubing to connect 100mm MAF to 92mm TB?
  144. Gas mileage issue
  145. need help with pushrod length
  146. Best Air Intake for the money?
  147. Ebay headers guys come in here
  148. ls2 intake on a ls1
  149. Any idea how to mount d585 coils onto perimeter bolt valve covers
  150. One more Ebay header question
  151. C5 coil relocation
  152. Questions about MAF
  153. please identify this part!!!
  154. Single 3" cat
  155. Exhaust Cutout
  156. OR-Y for Factory Manifolds
  157. headers catback big gains
  158. Might Buy LS1 Car With Security Light On, 500 Miles Away
  159. need help/input on broken piece on my block
  160. Rectangular to Cathedral adapter?
  161. Plugs for e85 NA motor
  162. Need help figuring out a miss, wire resistance.. 99 LS1 (Video)
  163. Adding cats to TSP ORY
  164. Just Had My Engine Rebuilt
  165. Does anyone know the angle of this bracket?
  166. Is this upgrade worth while?
  167. NVUSZ28's Build Thread
  168. Good All motor/nitrous cam?
  169. 78 to 85mm maf issue
  170. Ebay header question
  171. Would this hurt my heads?
  172. Vette O2s
  173. Help! Car started freaking out
  174. question about cats
  175. To port or not to port 102
  176. Looking for a P&P TB, who sells them?
  177. Custom Y-pipe Questions
  178. That little gasket on the driver side pan
  179. Evans vs Edelbrock High Flow Water Pumps
  180. Looking for parts!
  181. Cant decide on next mod. some recommendations would be appreciated.
  182. SLP 85mm to 100mm maf sensor worth whats involved?
  183. m.a.f. help
  184. 2011 avalanche exhaust
  185. coils not firing need help
  186. Ported TB Question!
  187. Holley Valve Covers on LS1!
  188. Carback question
  189. My review of TSP LTs and ory...
  190. Pulling an ASP underdrive pully
  191. pacesetter armor coat
  192. 243 as cast gains
  193. LS6 intake vs. Ported Fast 78
  194. RX catch can bracket
  195. LM2 Pics?
  196. Slow Cranking
  197. For anyone that bought the BBK LTs and ory.....
  198. Any benefits by doing this to exhaust?
  199. Cbm at the sand sports super show
  200. Got all my ducks in a row - help me re-check my list
  201. porting intake question
  202. wireing the gauges
  203. Pros and Cons
  204. Beck intake TPS?
  205. Those with TSP 1-7/8" headers...
  206. fires up and dies imediatly then runs perfect 2nd time cranking
  207. Nick Williams 92 to Fast 92 intake
  208. 99 Trans am air intake setup
  209. Trickflow top end kit
  210. What size is the Brake booster fitting on intake
  211. Best cats for emissions
  212. DIY - Cylinder Head Gasket Replacement - Right Side (C5 Corvette)
  213. Kooks Cats.
  214. O2 sensor broke off
  215. Ok' so how did you weld your stainless y pipe??
  216. 15 dual valve springs, need 1 more?
  217. Bad Head Gasket or Intake Manifold Gasket?
  218. BBK Chrome headers durability
  219. Muffler swap question!
  220. kooks catted x-pipe
  221. gm 85 maf and trunion upgrade ?
  222. HELP- identify this broken sensor
  223. Installing TSP LTs...a few questions
  224. ls1 throttle body vs ls6 throttle body, are they the same?
  225. 85mm maf and water pump question
  226. -1998 LS1 Trans Am Auto A/C problems-
  227. late model engine take outs
  228. Paging Anyone From DMH or Texas Speed....
  229. 5.3 pcv quick question
  230. Magnaflow muffler swap
  231. Is a FAST 92/92 necessary?
  232. Combustion Chamber Volume?
  233. Can I use stock intake port seals on fast 92?
  234. True duals vs dual-single-dual - which one is better and why?
  235. Horsepower Question
  236. Just did Urethane motor mounts...have some suggestions.
  237. TSP y-pipe fitment issues
  238. How much different is my car going to sound?
  239. K&N FIPK replacement filter?
  240. longtubes and exhaust
  241. IAT Relocation-Where to??
  242. Victor Jr. vs Performer carb intake???
  243. ITB - Individual throttle body - air filters
  244. LS6 intake manifold cracking
  245. MAP sensor interchange?
  246. Ws6 Exhaust Help
  247. Need help on coil pack question!!!!!!
  248. Performance Chips
  249. Stock TB
  250. what causes a slow revving motor?
