View Full Version : Generation III External Engine
  1. Diablo Question
  2. Valley Cover question
  3. SLP LS6 Intake Manifold ?
  4. 04 Z06 mods
  5. Anyone try the Trickflow UD pulley yet?
  6. Rubber grommet for IAT sensor has a small tear - ok to reuse?
  7. ARP Crank Pulley Bolt?
  8. Can you tune a car with a malfunctioning clutch position sensor?
  9. how much back pessure is needed?
  10. Exhaust Shops
  11. double wall exhaust tips
  12. Intake price question.
  13. After long tubes will i need....
  14. Isky LS1 beehive springs
  15. two 3 inch cutouts
  16. Were to put cutouts
  17. Just got my rumbler on
  18. HELP! I broke an AIR bolt...
  19. Which o2 sensors do you prefer???
  20. changing coolant tubes with bbk ssi intake?
  21. What to do with unneeded wiring?
  22. Full Exhaust, Plugs/Wires...Now Annoying TICK!
  23. Low oil pressure after H&C
  24. Refrigerant Question
  25. Rust on Painted Headers
  26. Head Gasket Question
  27. exhaust and emissions
  28. Identifying a true LS6 intake????
  29. 99 Escalade modability?
  30. LT headers with a regular muffler?
  31. Exhaust for 3.5" collectors? GMMG?
  32. injectors question
  33. 85MM MAF Harness Adapter?
  34. 68 camaro big block headers
  35. Which spark plug wires do I want for my swap
  36. Oil pressure gauge reads 0.
  37. PICS Bassani Tru Dual X PLUS Moroso Spiral Flows
  38. Magnaflow Catbacks price difference
  39. difference between tr55 and tr6 plugs?
  40. single chamber mufflers
  41. fuel line connection on fuel rail....how to discconect?
  42. truck fuel rails or LS1 fuel rails?
  43. LS6 Intake Swap Help
  44. Thanks Patrick G Nice Gain with Flowmaster Merger Y Pipe.
  45. Removing waterpump
  46. Map Sensor Question - 2 bar?
  47. Are there any advantages to a 2 to 1 to 2 pipe exhaust?
  48. witch head is better?
  49. ARH headers question
  50. Traction Control Delete....How to??
  51. Who offers the best deal on......
  52. Oil pressure sending unit?
  53. 98-99- 00-02 Lid differences?
  54. Is this going to help me at all?!?!?
  55. Catalytic Converter placement
  56. H/C car, 11.1 cr, Plugs ?
  57. Upgrading Headers
  58. Best/ Cheapest place to buy 85mm maf
  59. Rev Extreme catch can pic needed.
  60. Help with Off Road Y-Pipe
  61. Iridium plugs????
  62. Solid motor mount experience UPDATED!!
  63. pulley ?
  64. Need some fast help! Need clips of TSP Duals with spiral flows ASAP!
  65. switching muffler
  66. wrapped headers
  67. Air pump
  68. [PICS] Katech aluminum valve cover (new design)
  69. what else do i need with my headers....
  70. R.P.M.(NC) FAST intake porting ?'s
  71. So I'm running open headers and I have a question
  72. bassani TD or custom setup?
  73. FAST92/92..... what bellow to use?
  74. Gmmg
  75. Exhaust leak
  76. Corsa CME exhaust
  77. Alternator Plug wiring question
  78. What should I get?
  79. new exhaust!
  80. New Style PCV
  81. Best Spark Plug Wires
  82. $400 parts and labor motor mounts?
  83. Shock problem!! HELP!!
  84. Need some info on 02 sensors
  85. Plugs/wires a must with lt's?
  86. Lets see some undercarrige header pics!!
  87. What brand headers are these?
  88. Custon Cat Backs
  89. quick question
  90. Catch can placement affect performance
  91. Settle it Once and for All!!! - FIPK vs LID
  92. help
  93. need help on this part!
  94. Car chemistry header instert?
  95. How do I know what my Final Gears are?
  96. head question
  97. A/C sysem weight??
  98. Ram air + vic jr
  99. o2 sensor wiring after header install.
  100. need help
  101. 6.0l lq4/4l80e swap into 66 chevy
  102. H-Pipe with DI/DO muffler???
  103. Need a Pic! And info on a fitting...
  104. questions for those running metallic spun cats
  105. 1 3/4 vs 1 7/8
  106. 100mm lid/maf/tb/intake manifold anyone make this?
  107. So what should I do with a 4.8L?
  108. need help
  109. Anyone heard of this free mod????
  110. Vic Jr/F.A.S.T TB Combo?
  111. What do I need for header install??
  112. Mezeire water pump?
  113. new toy
  114. SLP crank pulley will not come off, help!
  115. what size is stock muffler inlet/outlet??
  116. Need new exhaust hanger. Where?
  117. Jantzer Performance BILLET Throttle Bodies
  118. Thinking of having SPEED INC install my headers and Y
  119. Header install Grinding the tabs on block?
  120. Waterpump / Radiator hose question
  121. Porting stock intake?
  122. 243 head springs
  123. pcv and vacume line on valve cover
  124. msd wires suck?
  125. L92 Question
  126. vic jr with tb hood clearance
  127. [PICS] Katech Carbon Fiber Gen 3/4 Valve Covers now available
  128. Which catch can?
  129. Header install...Do I have everything I need?
  130. Z06 MAF on a LS1
  131. Fast 90 Valley Cover Bolts
  132. Where can I buy a catch can?
  133. c1 under hood fuse block pinouts?
  134. Catted Y pipe
  135. Too loud!
  136. need wiring help...
  137. Odd Problem.
  138. exhaust question
  139. My eBay headers review...
  140. Spark plug help
  141. erratic idle and surging at low speed
  142. Magnaflow Y Transition
  143. Tsp y-pipe
  144. Which handheld
  145. 02 question for LT headers
  146. Quick Passenger Cylinder Head Question
  147. LS2 heads and L76 intake
  148. Valve Cover Choice's??
  149. just finished my 6.0 swap
  150. You will LOVE this
  151. LPP Header/Y Review
  152. Where to block off EGR?
  153. 01TA catalytic converters bad at 58K miles?? help please
  154. Valve covers for ET heads.
  155. Whats needed for header install? List
  156. Is my AIR Removed? (pics)
  157. slp lm2 with cutout???
  158. where to buy
  159. TB question
  160. How do you get these friggin spark plugs out!!!!!!!!!!!!
  161. dynomax 4" muffler 17557 ??
  162. Exhaust question?
  163. Need Help. Need pics of...
  164. O2 Sensors: AFS97 GM P/N is 19178921
  165. Broke air temp sensor. HELP
  166. when i tap the gas the rpms rev more and stay up?
  167. Cutout
  168. Motor mounts question.
  169. make a pcv system?
  170. Mac Air Filters?
  171. Throttle Body sticking
  172. Any one using these headers
  173. Can't find LS1 M/T radiator!
  174. Lt1 Catbacks work on Ls1 Cars?
  175. Air removal
  176. LS6 intake ID question...help!
  177. oil pressure switch....
  178. Whats a tall tale sign a coil is going south?
  179. Msd pn?
  180. LTs ORY Stock Catback Sound Clip
  181. More horse power
  182. Another Tranny mount Q
  183. Finished Installing Jet Hot LT's, ORY, & Magnaflow
  184. 90mm Fast intake weight???
  185. Runs like a terd after header/y install
  186. Another Fast 90 Question
  187. Cherry bomb
  188. ls6 intake swap
  189. issolating the PVC...to remove it...possible leak
  190. initial timing on LS1?
  191. SLP PowerFlo CB?
  192. Help with porting Z06 TB please
  193. SLP "new design" headers (pics)
  194. Fast 78mm TB question
  195. What parts to make TSP true duals over the axle?
  196. Plugging O2 bungs
  197. lingenfelter/weiand intake question...
  198. SLP Y-pipe
  199. Dip in Rpms at idle and after revving? Whats the cause?
  200. Can you port ls6 intake manifolds?
  201. SLP vs Texas Speed True Duals
  202. installed cam/heads/headers Need help idling
  203. checking for vacumn leak around intake??
  204. Header install question
  205. ported stock ls1 intake vs ls6
  206. Dynomouth Videos
  207. GMPP waist of money or not?
  208. intake gaskets
  209. Ls6
  210. TEA 1.5 5.3 vs PRC 2.5 5.3
  211. 5.3 damper/balancer allignment
  212. throttle cable?
  213. Quick ls1/fbody engine mount question
  214. Knock sensors
  215. Porting progress on my used FAST
  216. Hp level and change spark plugs?
  217. O2 sims
  218. BBK Headers help!!!
  219. 2 step
  220. LT1 catback on LS1
  221. FAST 92 Install Help
  222. Kooks 1 7/8"x 2"x 3 1/2" Race Headers
  223. tb 85mm question
  224. what is this ??
  225. Thrush Welded
  226. What is the Best Spark Plug
  227. 85mm mass and lid worth it??
  228. o2 Extensions
  229. exhaust help! borla tunable
  230. What should i expect????
  231. Looking into getting my heads ported.
  232. Tranny Mount question/opinions
  233. magnaflow muffler ??
  234. vendor options on duals
  235. guys with magnaflow cb, come in for help!
  236. Whats better
  237. Stainless braided strap...
  238. Rick
  239. o2 ext with o2 sims?
  240. LS2 Intake on 346ci ANYONE tried this!!!
  241. NC Fbody owners come on in.
  242. Empty Cat?
  243. Why does noone make a budget throttle body?
  244. squeaky belt after winter storage
  245. help me put together a combo....
  246. Granatelli M.A.F. Tuning Required ????
  247. Sponsors hook me up Bassani X Pipe SS
  248. Is this the right UD Pulley?
  249. 6.0 LQ9 in f-body questions on accessories
  250. o2 extensions
