- What is the Best Spark Plug
- 85mm mass and lid worth it??
- o2 Extensions
- exhaust help! borla tunable
- What should i expect????
- Looking into getting my heads ported.
- Tranny Mount question/opinions
- magnaflow muffler ??
- vendor options on duals
- guys with magnaflow cb, come in for help!
- Whats better
- Stainless braided strap...
- Rick
- o2 ext with o2 sims?
- LS2 Intake on 346ci ANYONE tried this!!!
- NC Fbody owners come on in.
- Empty Cat?
- Why does noone make a budget throttle body?
- squeaky belt after winter storage
- help me put together a combo....
- Granatelli M.A.F. Tuning Required ????
- Sponsors hook me up Bassani X Pipe SS
- Is this the right UD Pulley?
- 6.0 LQ9 in f-body questions on accessories
- o2 extensions
- sorry, but which intake on a budget?
- painted or not?
- problem with underdrive pulley
- exhaust too loud? What to use to quiet down?
- trqr v3 + dual/dual w/ cutout should i do TDs?
- which intake? LS6 or Performance products
- True duals muffler swap question
- 5 Bolt LS2 TB
- When do you need larger injectors
- Engine Removal Questions...
- 75 0r 78 mm stock tb
- how much hp am I leaving on the table
- I want a quiet muffler to replace me LM... but just the Muffler
- FAST 90 worth it over '99 Stock Manifold & FIPK???
- ignition problem? *video inside*
- Muffler Size
- !AIR system
- Porting LS6 Intake
- Buying exhaust setup tomorow!!
- Having trouble installing Oil Dipstick help!!!
- Buying new intake.
- header bolts
- head gasket??
- enough exhaust?
- Cammed ms3 ws6
- Electric Cutout Help
- C6 tips? part numbers? inlet size?
- Question about intakes
- UD Pulley question
- F Body headers in 66 TCI Frontend????
- Cat question
- 4" velocity stack or air horn ?
- stock to 80mm TB
- 98 ta 5.7 to 5.3 swap?
- which y pipe with jet hots?
- What headers to get?
- ls2/ls7 coils on f-body questions
- True Duels from a M6 to a A4 car ?
- Universal x pipe true duals
- Any Vic Jr guys running a Fast toys lid?
- camaro manifold flange
- Questions about Texas-Speed H/C packages..
- maf question
- FAST 90 Flow Data
- Need to find 90mm LS2 TB Cable Driven w Cable holders
- 243s compared to 317s
- This Ypipe work for Hooker Long Tubes?
- Evap system
- What spark plugs are you guys running 450+RWHP guys.
- What heads do i need?
- getting a catchcan
- 02 Exhaust Manifold Mod:
- !Air (quick question)
- Edelbrock water pump - Thermostat housing??
- ??Part #/name needed??
- Random Misfires After Engine Swap
- Quick cam qeustion
- Underdrive pulley with high hp.
- ls7 cam
- Fan connector plugs
- Review of SilverGhost Ported TB!
- ls1 fuel line setup?
- pacesetter headers flange not square?
- Catch can?
- Fuel line clip
- Front o2
- can ported maf ends cause this?
- Porting 90mm FAST, needs a new internal seal?
- Passing Emissions Test In Ohio
- Catted y pipe or no cats?
- Exhaust Manifolds:
- LS6 valley cover questions
- throttle body question and intake question
- Witch headers? Lpp or hooker
- factory or aftermarket power steering cooler
- old: dual/dual new: magnaflow c/b w/ cutout :D
- where can I find arp header bolts??
- Heads and cam question
- 2 questions about purchase.
- WTF is a flowmaster merge
- Headers
- ARH VS KOOKS. Which one is easier to install???
- Quick Exhaust question?
- ls6 head vs ls2
- Opionions please?!!
- header questions
- Finally finished my headers!
- Plexiglass intake??
- Questions on installing headers myself
- FAST questions
- PCV delete question
- Finished Exhaust setup...link to video inside!
- Need help with engine noise [video]
- Looking for intake gasket set for Weiand/Lingenfelter manifold
- Victor Jr. intake
- im installing a magnaflow catback....
- What is this?
- throttle cable
- 98 Camaro SS setups
- Fianlly got the L92 Intake from Cary !
- powersteering fluid leak/ possible leak into cooling system
- Header question
- Pictures of Powerbond pulley
- New Exhaust ideas...what do you guys think?
- BMR Kmember install help ASAP!!!
- Cant wait anymore time to spend some cash! Help?Advice?
- How to lock engine down
- intake wont come off
- Intake opinions
- alternator swap writeup? the search is down
- cant get #7 injector connector off...
- LS6 intake/PP TB installed! Now couple quick questions??
- Hypertech=Motorad=Duralast? Thermastat WTF
- One Gutted Cat??
- ZOMG! HaS ANYONE SEEN THE NEW WEIAND INTAKE MANIFOLD?!
- Great....
- Alright fellas just had the ebay ud pulley installed
- High NOx, can't pass smog
- Is it worth it
- Can I run mechanical gauges in the pillar pod, anyone?
- Quick question
- aftermarket temp gauge that uses the stock sender?
- people with rev xtreme cans
- crank pulley socket size?
- LPP LS1 Headers
- touching kmember
- Need some advice...
- Borla xr-1's on TSP true duals...?
- Need a PS Pulley
- P0354 P0352 P0650 Misfire codes
- SO im having problems...
- Mufflers on true duels
- Port my stock heads or buy new?
- Stupid question? Will a stock throttle body fit a FAST intake?
- LT's and Y/loudmouth 2 or True Duals/Bullets
- Best Hi Flow Cat
- Wiring Harness Questions!!
- Anyone used these headers?
- beck sheetmetal..
- tr230, whats your exhaust though?
- Please Read!!! Car won't start. gotta be at work at 7am
- question about T56 fitment on LQ4 blocks
- Help me out!!!
- Moser M9 owners how's YOUR true dual exhaust setup?
- What exhaust for cali emissions
- Best setup w/emissions!!
- Is this for real? 33.4hp gain with SLP exhaust set-up?
- jvt headers
- Yet Another Exhaust Question
- which ORY..
- How much will I gain from mac midtubes?
- Best Bang for the buck INTAKE
- Question About AFR 225's 72cc Heads.......
- Victor Jr bolt size
- Seafoam after new headers?
- Rockers?
- PATRIOT STAGE 2 317 CASTING HEADS wHAT CC?
- Intake manifold ratings?
- Intake decision
- Magnecor wires
- 85mm mass air??
- Typhoon Intake
- what is a stock LS6 timing?
- Casting # 317 LS6 Heads
- Cranks but wont turn on
- BBK ISS manifold vs ls6
- Ram Air "Interior" Parts
- Cai .....
- Finally started my headers!
- Ider assembly help 2000 T/A
- o2 sims
- Embarrassed to ask this but? Engine alignment.
- Ls6 Heads
- oil pressure gauge needed!?!
- Where to buy ARH headers?
- Ls1 pcv system
- 1 241 / 1 853?????
- Manual cutout leak
- People Using the Summit Universal X-pipe
- really need help on this one...urgent problem
- Breaking up from 2-3k
- where to get decent 3"-4" y merge
- F-Body ASP pulley users
- iron heads on 2001 LQ4?
- volant installed but got a temperature prob
- QTP headers question
- magnaflow
- 87 GTA intake
- Any Ideas For My Next Mod
- Anyone ever try Quaker State Q power oil?
- LS6 intake with EGR
- Post cam clips of your LS1
- Ported TB not geting for throttle?
- e-cut out question
- broken header bolts HELP PLEASE
- 98 LS1 How much power can be had with bolt ons and what are the best ones??
- Did GM change plug gap?
- Is the 2006 Lumina ss same as the 04 GTO ?
- Locking header bolts
- Need a muffler that is quieter than a spiral flow.
- Spark Plug Recommendation
- Best way to spend a Grand
- just got a nice grip workout
- Daily Driver - Bolt-On's?
- question about dipstick/oil level
- Intake Manifold Dissaembly
- Purdy Headers (Kooks)
- Alternator crapped out
- AC Delete How to????
- Suggestions/Ideas?
- ported FAST 90/90 overkill on cam only? NOPE
- How well do exhaust Butt Joints seal? Lap joints? V-bands?
- 85mm MAF info
- My jantzer ported tb review
- C6 VaraRam looks like it might fit a F-body
- Gains from 1 inch carb spacer for Victor Jr. intake?
- What weight oil...
- Random Cylinder Misfire with a Twist
- What is this and where can I get one?
- U/D pulley question.
- Opinions on PCV removal?
- i ported my fast 90 2 100mm guys look at the pics
- ? about intake manifold
- Throttle body/cable question
- 80mm throttle body fit on stock ls6
