View Full Version : Generation III External Engine
  1. intake gaskets
  2. My headers or y pipe are hitting my floorboard...
  3. Magnaflow Dual/Dual (quad tip) Kit
  4. Yet another Vic Jr vs Fast 90 thread
  5. 90mm Street warrior Intake, and dyno results
  6. installed a FAST 90
  7. Question about bore/stroke
  8. headers
  9. My LPP header review
  10. 4.8 Truck valve covers + brackets
  11. slp dual tips don't look right...
  12. 42# pinjectors
  13. MAC headers and Y-Pipe?
  14. 00 TA Exhaust Questions Headers/Cats/EGR/AIR
  15. I have a question for you guys....
  16. AIR/PCV problem! HELP!!!
  17. Borla/Corsa exhaust setup? Got a question
  18. Short belt mod
  19. What kind of headers are these???
  20. 3 in pipe
  21. Any sponsors have this part in stock?
  22. So what happens when your catch can fills up all the way?
  23. Please critique these headers
  24. Cleaning duals
  25. Magnaflow muffler placed in Loudmouth?
  26. stupid question
  27. Volant hole plug - HOW TO - PICS INSIDE
  28. have kooks headers/kooks catted y and b&b...not loud enough
  29. TSP catted y with kooks headers?
  30. LTs, Mufflers, and turn-downs
  31. LS6 vs FAST 90/90 vs Fast 92/92
  32. skip shift??
  33. Port our LS6 Intakes
  34. LS Spyder manifold
  35. Rotten egg smell
  36. best shift point
  37. Sewing Machine + Ticking/Knocking from collectors = ????
  38. Aftermarket Intake and throttle body which ones ?
  39. Ls1 Polyurethane Engine Mount?
  40. Corsa look alike tips, $55.
  41. Fast 90 -92 Is one better than the other
  42. A4 or M6
  43. 2000 trans am build up questions
  44. It feels alot like Christmas!Lt's and others arrived some Pics!!
  45. Need HELP!!!!!
  46. just ordered my pacesetter Lts!!!!
  47. TPIS 90mm ls6 intakes
  48. question about pplacement of a vacuum line
  49. help with engine info
  50. What would you do?
  51. California legal headers?
  52. e cut out wiring installation
  53. Meziere EWP install....some tips for Fbodys
  54. Plug wires longer than MSD's?
  55. Can I make my own Y-pipe anti-floor-board banging hanger?
  56. Bigger than 1 7/8 headers?
  57. MAF to close to TB
  58. anyone running trick flow 235cc with victor jr?
  59. Edelbrock 3864 90mm TB
  60. best y pipe for clearance??
  61. Bosch green-tops too much for h/c?
  62. header torque rate
  63. LS6 intake question
  64. Anybody used Hooker Max Flow mufflers?
  65. intake lsx 9.700
  66. How to clean....
  67. biggest cam i could go....... plz help
  68. ls6 intake with cam swap
  69. Power Steering
  70. Throttle cable
  71. Hooker headers any good?
  72. removing FAST intake lid
  73. going from 3.42's to 3.73's
  74. going from 3.42's to 3.73's
  75. Torque specs
  76. question about installing fast 92/92
  77. motor mount bolts
  78. Possible LPP LS1 Header GP:)
  79. Which hi flow cats?
  80. *I need a Y-pipe*
  81. need help!!!!
  82. Need help big time?
  83. Connecting 92mm TB to 85mm MAF?
  84. MAF sensor help, bought new MAF and STILL not working...
  85. What to do for my exhaust and emissions
  86. TSP help
  87. resonator or bullet muffler?
  88. Turn downs,Enough back pressure???
  89. Fabricated an X-pipe today
  90. Flexplate
  91. what is this?
  92. Weiand intake gaskets?
  93. exhaust tick/rattle/annoying sound on decel HELP---VIDEO!
  94. Anyone with a cutout even make more power closed?
  95. tsp 1 7/8 header install questions
  96. Thrush.....
  97. LS bolt on water pump pulley
  98. Header bolts/studs
  99. Underdrive Pulley Question
  100. Slp maf
  101. New design SLP header owners come in...
  102. What are some consequences of Exhaust leaks
  103. Installed some headers today
  104. Ls1 dbw
  105. need a vid clip? magnaflow 4" ROUND RACE SERIES
  106. !!!Installing Pacesetter Longtube headers!!!
  107. weird coolant fan problem
  108. Intakes...which one?!?!?!
  109. Jet Hot LT install question
  110. Pics/Videos & info on my new exhaust
  111. What should be the next MOD????
  112. exhaust manifold removal help
  113. new weiand intake
  114. pulleys
  115. anyone not running catalytic converters?
  116. Best TB
  117. Pacesetter and Borla?
  118. Someone might know this!!!!!
  119. SLP Underdrive Pulley
  120. Question for the guys with the volant...
  121. Texas speed
  122. ?? for you f bod guys about the vic jr intake
  123. New Balancer removal?
  124. Katech tensioner...
  125. QTP exhaust cutout?
  126. Upper rad hose part number???NON-PS
  127. Coil pack?
  128. What does the LS6 intake, ports flow, any flow #'s
  129. PCV system issues
  130. Roller rocker questions
  131. why bassani only 2.5"?
  132. H-pipe true duals
  133. Booster hook up
  134. Intake manifold
  135. In retrospect, my bolt on experience
  136. Underdrive pulley
  137. any sponsors port aluminum lsx intakes?
  138. Passing Emissions
  139. TB Question
  140. FAST 90 intake gaskets
  141. coolant crossover block offs?
  142. thermostat question?
  143. ?new heads or work up existing ones?
  144. Best Spark Plugs on These LS Motors?
  145. wat head castin with this set up?
  146. Insalling Headers ?
  147. stripped TB screw what do you suggest
  148. Ory
  149. Air intake for my 69 camaro
  150. Wilson throttle body???
  151. What underdrive pulley to buy?
  152. Swapping intakes. Difficulty?
  153. e cutout ppl come in
  154. 2001 ls1 with no spark *HELP*
  155. I need a way to measure exhaust backpressure...
  156. LS1 oil sender ohm range? anyone know?
  157. header bolt specs
  158. HELP!! Need last min. Ordering Lts by friday and need final opinions
  159. Fuel pump installed, not getting power! Pics.
  160. Ls6..
  161. LQ-4 oil cooler
  162. Exhaust install costs
  163. Non-Coated headers
  164. Cat in I-pipe
  165. tensioner pulley
  166. fittment issues? lq4 to 4l60e?
  167. arh headers
  168. Borla XR-1 with a cutout
  169. sparkplug wires
  170. Mac Headers fit Stock y?
  171. WS6 Ram Air hood help
  172. Tired of the spiral flows
  173. Thoughts on Dynomax Catback?
  174. EGR Question
  175. Problems starting
  176. Gas pedal sticking after new TB
  177. car wont crank
  178. Possible gains.....
  179. 2.25 or 2.5?
  180. Quick Question??? Should I replace my headbolts?
  181. Egr block off problem
  182. what will i need???
  183. Any way to quiet my TD's?
  184. vacuum leak?
  185. true duals help
  186. pcv broke?
  187. Is my y-pipe too narrow?
  188. Finally got my headers in.
  189. JAAM vs. current setup?
  190. aftermarket water pumps, are they any better?
  191. alternator question
  192. real quick question about TB
  193. MAF replace with spacer question ?
  194. need quieter exhaust with no loss of power what do i get
  195. iron block alt mounting help!?!?!
  196. Fast 92 Throttle Body work on Fast 90 Intake?
  197. single or dual cutouts?
  198. Broken PCV...
  199. Engine Noise
  200. fast problem
  201. Engine Sensor List
  202. Are LS2 coils better, more powerful over the LS1 coils?
  203. Need a different x-pipe!! Help
  204. Car stalls, when hit throttle??
  205. fuel injectors on 99 SS
  206. Installed Summit underdrive pulley!
  207. custom exhaust any Ideas????
  208. is it normal to have more valve train noise
  209. Expected horsepower and torque??????????
  210. CAI help
  211. will the throttle body be ok this way?
  212. centerport exhaust
  213. Mac Exhaust Good deal?
  214. Losing power in the 3k plus RPM range...
  215. Another CAI thread...
  216. who makes cylinder head plates (like MBA) with "LSX" on it?
  217. $1,300 Worst Bolt On EVER...
  218. Thread size
  219. True dual mufflers
  220. Coil?
  221. What cutout to get??
  222. Where to mount oil temp guage sending unit?
  223. Weiand Manifold installation question
  224. Should I get a Cutout?
  225. Edelbrock Valve Covers
  226. who sells a nice vented catch can?
  227. 2000 engine harness in 1998 car?
  228. 4-barrel Throttle body!!
  229. What's the best flowing QUIET Catback these days?
  230. Grotteyham lt's and kooks ory?
  231. LS6 IM swap on 99 T/A
  232. KRC Steering Pump
  233. 317 vs. 243... question
  234. intake?
  235. Spohn Solid Motor Mount install?
  236. waterpump swap help
  237. SLP Loudmouth muffler replacement???
  238. Deleting AC
  239. H/c help
  240. I think my steering rack is going back squeeks when I turn the wheel
  241. P&p throttle body
  242. FAST 104mm
  243. P0135 p0155 p0102
  244. Gasket Opinons
  245. exhaust cut out
  246. Best intake when it comes to nitrous use.
  247. Alternator Issues
  248. How can I get this thing running?
  249. cutout nut?
  250. Gibson Exhaust Fit?
