View Full Version : Generation III External Engine
  1. Oil leaking from heads!
  2. pace setters.
  3. 2 Videos, 2 Problems.
  4. SLP lm1 vs. GMMG???
  5. 5.3 TB the same as the LS1 F-body TB?
  6. Headers came in.. take a look
  7. Help me decide which ported TB
  8. Which is better????
  9. true duals, got questions
  10. Good deal or not?
  11. which intake
  12. re-installing AIR and EGR
  13. intake
  14. Is 90mm to big
  15. AIR question; backfiring? gas mileage? valves? (mostly gas mileage)
  16. Swap a fast 78 top for a 90?
  17. p0410 how do i get rid of this
  18. Slp lm1
  19. true dual pics plz
  20. ARH + FLowmaster + DMH cutout Clip
  21. How to clean inside of ls6 intake manifold??
  22. Sweet Thunders?
  23. Throttle body questions.
  24. Lq9
  25. Trouble Accelerating
  26. Decided on the Weiand
  27. coolant lines under intake
  28. Will a ARH Y-pipe fit Kook's headers????
  29. TDs and quit"er" mufflers
  30. Stock intake gaskets work on FAST 92?
  31. Heat Wrap for headers?
  32. Broken Starter Mount on Block!!!
  33. LT's Whats your choice?!
  34. Duals w/ Pro-kit??
  35. GMMG/cutout
  36. Rear out of 3rd Gen???
  37. Help me plz!!
  38. Why do we choose MSD wires & why change plugs to improve lost tenths @ the track?
  39. Idling
  40. Header hole. Need some input please
  41. air fuel ratio affected?
  42. Differences in stock exhaust manifolds?
  43. Race Fuels
  44. New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
  45. Help! Cold start fouling plugs
  46. Car makes squeaking sound when turned off?
  47. LS3 with LS1 accessories?
  48. Where can i find bullet mufflers?
  49. Header ?
  50. Torque settings
  51. I have narrowed it down.
  52. Jegs catback installed...my thoughts on it
  53. What coils are these?
  54. little help here..
  55. Wierd Idle Problem. Need Help Please.
  56. New exhaust
  57. Duals with no crossover
  58. Headers What's best bang for the buck!
  59. just cant make up my mind on exhaust
  60. CAUTION: Anyone who has bought a VIC JR in the last 2 years.
  61. Header install W/ OPEN HEADER VIDEO!!
  62. loudest IDELING exhaust?
  63. heads wich ones would be better
  64. Anyone know this connector?
  65. One poly engine mount?
  66. Fan switch mod write-up
  67. Car Won't Start!
  68. Fast or Edelbrock
  69. exhaust
  70. 98-99 Headers Bolt up to a 2000 SS?
  71. Carb style TB guys. What filter setup are you running
  72. Engine build questions.
  73. Header installation????
  74. got my tsp LT,s today!
  75. Would this work as an air filter?
  76. My findings; Ported Weaind vs Ported LS6 intake
  77. Fast 92/92
  78. FAST 78mm smog legal?
  79. Limitations of 1-3/4" headers vs. 1-7/8"
  80. Exhaust piping
  81. How are your Stainless headers holding up?
  82. How many bolts hold the FAST intake shells together?
  83. Can I install a corvette MAF on a Camaro
  84. 2000 LS1 into my old Land Rover
  85. How do you take the Fuel Rails of?
  86. I just installed a SLP lid, and now I have a problem!
  87. muffler/exhasut
  88. lt1 alternator swap
  89. SES Light after mods/non catted y pipe?
  90. Fit problems with metal intake on Z06 weiand 300-111c
  91. Were to buy Exhaust Flange Gasket??? Thats not thin paper type.
  92. Oil pan bolt sizes
  93. o2 sims
  94. Headers Don't Fit
  95. Fixed faulty Catylitic and changed 02s... burning??
  96. Broke header bolt..
  97. started porting my FAST intake
  98. LPP header install questions...
  99. Car is running too hot...Why?
  100. Prothane Poly Motor Mount Install Tip
  101. 317 heads questions...
  102. catback install question...
  103. Installed my headers with ORY and magnamouth...HELP!!
  104. Engine vs Vehicle - ID question (VIN)?
  105. question for u ported fast guys
  106. question about a alumuminum block, what does b stand for.
  107. Meziere water pump leaking grease?
  108. someone please explain these low temp thermostats
  109. LS6 now or 90/90 later?
  110. Diff between stainless Kooks & Eldebrocks?
  111. cam question
  112. carb
  113. What kind of exhaust is this?
  114. True duals... worth it?
  115. No Oil Pressure..
  116. Spark Plugs
  117. flat rate hours for harmonic balancer change
  118. Edelbrock Pro-Flo XT Manifold?
  119. Slp Underdrive Pulley ???
  120. HELP! UD Pulley
  121. Port'n'Polished Vic Jr pics needed + some info
  122. Fuel pump install ? (pics)
  123. Anyone have custom exhaust in the Peoples Rebublic of Washington?
  124. Is this worth it?
  125. Stock tail pipe size on a 2002 WS6?
  126. Does Anyone Sell Front Facing Headers?
  127. happiest day of my car-loving life
  128. Still no SES Light
  129. Mac mids...with a reg aftermarket y pipe
  130. NOS kit compatibility
  131. cai ???
  132. Header install questions
  133. Has anyone checked out the new SLP Powerflo Exhaust?
  134. Slp 160 T/stat?
  135. Header differences 1998-2000
  136. Under drive pulley question
  137. Exhaust Leak
  138. Cam Positioning Sensor??
  139. fuel rail covers...
  140. Question about ported throttle body
  141. *update* no fire with popbacks/backfires
  142. HELP switching from LQ9 to LS2
  143. Where to buy o2 sensor?
  144. Whats The Best Y Pipe Available?
  145. Now that I'm going back to regular exhaust.
  146. Anybody use Edelbrock T.B.?
  147. Spark plug gap ?
  148. Problem aft, header and y pipe install
  149. Longtube recommendation
  150. PCV Valve (Orafice) Integrated into LS6 Valley Cover
  151. cheap LS1 centerbolt valve covers
  152. coil bank pinouts?
  153. How can you tell the difference
  154. LME in business?
  155. Long Tube Question
  156. newb question about exhaust
  157. Air & Egr
  158. Swapping LS1 intake on an LM7; worth it?
  159. Nitrous Dave's Fiber-Tuned intake manifold
  160. Just installed Kook's Headrs, Y pipe SLP Dual,Dual Ldmth 1 cat, Spohn Solid motor mou
  161. LS2 parts on LM7
  162. My GMMG In Action *Sound Clips*
  163. Getting ready for a LSx swap, rebuild pricing?
  164. Car Won't Start!
  165. Cold Air Intake - Worthy Gains or No?
  166. Thinking about making my own TDs.
  167. dimensions?
  168. Places and methods to check for Vaccum leaks ?
  169. 1998 LS1 misfire
  170. Anyone break
  171. smaller replacement LS1 PS pulley?
  172. SLP Headers "new design" review
  173. FTRA vs SSRA
  174. Are these good ploy motor mounts??
  175. Ls1 Camaro Vs Corvette Ac Brackets
  176. 2000 Ws6
  177. Yella Terra Ultra Lites and stock bolts - total weirdness, please help
  178. Sheet metal valve covers???
  179. Will Chrysler Pulley Remover Work With March Pulley?
  180. PCV system smoke
  181. Header Install Help
  182. SLP LID NEED something ASAP
  183. Problems with Auto LS1...
  184. header install question???
  185. GMMG not a sponsor?
  186. Any bolt-ons left for me to get 400 HP?
  187. What do you think about these heads
  188. LS6 intake worth it?
  189. 2004 C5 LS1 - factory LS6 intake?
  190. looking for video true duals out back with bullets
  191. Holley 4150 TB Idle Problems
  192. Does anyone have hooker on their car?
  193. 2000 C5 misfire problems
  194. exhaust clamps
  195. How to debaffel my hood?
  196. part number/ funtion help please
  197. question on a setup from LSX shootout.
  198. JUST GOt 78 VET IS IT POSSABLE TO DROP A LS6?
  199. Underdrive pulley without A/C drive
  200. ls6 intake swap question
  201. cme owners
  202. What else to get to 450rwhp?
  203. LS6 throttle body gasket work on FAST 78?
  204. TSP Lid ?
  205. LT's/other mod ?
  206. Whats yalls average oil pressure
  207. Is there a difference in......
  208. Rank TSP Duals mufflers! Not another which is the best...
  209. LTs/ORY with stock catback
  210. Difficulty of removing engine...
  211. Flowmaster replacement muffler
  212. Looking for Headers
  213. True Duals Kit?
  214. PCM Codes, bad oxygen sensor? Help! Thanks
  215. I really need help
  216. what solid lifters ??
  217. Vacuum leak?
  218. Exaust feed back
  219. Coolant leaking while TB off???
  220. 806 to 241 heads
  221. what hood should I get for the Z?
  222. NGK TR55 vs. AC Delco Rapid Fire #12....HELP
  223. idler pully
  224. damn CEL wont go away! O2 problem
  225. intake swap problems
  226. Exhaust Pics?..I just cant decide... HELP!!
  227. Full exhaust without tune
  228. Anyone that know this?
  229. ls6 manifold
  230. anyone dyno ther 90/90 full bot on car?
  231. Can you tell the difference between these Corsa clones?
  232. Which would be the next best mod...
  233. help me remove my PCV system
  234. Using AIR pump as vacuum pump?
  235. Quieter: Maxflow or Aerochamber?
  236. Those with kooks or ARH 2" headers..
  237. AIR pump
  238. ARH Y + stock i-pipe??
  239. SLP Fan switch
  240. CATCH CAN, LS1 valley cover, PCV really needed???
  241. Building your own x pipe
  242. Pulley Alignment. PS pump pulley too far back? Throwing belts...
  243. Motor Mount write-up
  244. slp loudmouth 2
  245. Moroso race oil filter
  246. Motor mount/exhaust question help please
  247. Need HELP car sputters really bad!!
  248. 02 maf in 99
  249. Kooks Long Tubes And Y Pipe
  250. QTP or any exhaust with it "rubbing" on the K-member
