View Full Version : Generation III External Engine
  1. Need help with exhaust>?
  2. Scam or good deal?
  3. car fixed it self ?
  4. Information on the SLP 400hp Package For The LS1
  5. We have 1/4mile times how bout your cam install times?
  6. seafoam questions
  7. Vacuum Port Question
  8. Ruff Idle
  9. Fastest LS1 intake'd 346ci car?
  10. Backfires on Start up. Bad Cam Sensor?
  11. what is all needed for the cme exhaust?
  12. charging issues: please help ;)
  13. removing cats on stock exhaust
  14. flanges
  15. Gained 63hp/25tq With H/I/LT's...Normal??
  16. Stock Injectors
  17. Do The 2002 Ls1 Motors Come With Ls6 Intake?
  18. new noise from under teh hood. chirping
  19. Radiator hose extension?
  20. Will removing the air system clog high flow cats?
  21. vararam c5 intake on my 98 z
  22. Bought Headers
  23. Is the FIPK worth it?
  24. speedinc. true duals?
  25. Charging Issues
  26. Question about mods to a car.
  27. Hooker Maxflow? Anybody?
  28. MSD plug wires hit SLP headers
  29. head and intake match
  30. Is It worth putting hacked up CME back together
  31. Exhaust crew... Thoughts on this setup?
  32. Where to buy coated ARH headers
  33. What does these codes mean?
  34. valley cover removal
  35. what is this?
  36. Oil Pump To Oil Pick Up Tube Bolt
  37. PA Racing k-member
  38. damn o2s again i think, help me out here
  39. New exhaust poll
  40. Cut out questions? pics and vids
  41. absolute best exhaust system and setup? ls6
  42. Magnaflow catback vs Direct replacement muffler
  43. Removing SLP loudmouth Problems!
  44. Pics Of LS1 Sensors
  45. Question
  46. EVAP and EGR Removal
  47. tpis 90mm ls6 intake
  48. cut out location?
  49. Engine trouble
  50. LS1 engine stands
  51. American Racing Headers & Intrax 2" lowering springs (lots of pix)
  52. SLP lid plug, where to buy?!?
  53. QTP race headers/Ypipe doesn't bolt up to 01 Ws6 exhuast?!
  54. Escalade?
  55. y pipe bang?
  56. Blow drying an air lid
  57. ses light after header install
  58. BBK CNC Series Headers Question
  59. will polly motor mounts vibrate?
  60. arp ls1 motor mount set do I need one or two sets
  61. Anyone running this setup (exhaust)
  62. Need help! CAR STARTS MISSIN AFTER BOUT A HOUR DRIVIN AND DIES
  63. AIR Removal 2000 Camaro SS PICS
  64. meziere electric water pump problems...
  65. TPS sensor voltage
  66. O2 codes??
  67. ANY pics of TSP True duals with bmr extreme TQ arm?
  68. need name or P/N for eplastic elbow valve out of the brake booster
  69. Another Heater hose , Y pipe question!..
  70. Rear 02 Sensors
  71. throttle adjustment?
  72. Doing h/c install and need A.I.R /EGR removal advise
  73. Pacesetter/Y-pipe from TSP problems
  74. SLP 85MAF VS Stock MAF w/ported ends
  75. LS1 intake porting
  76. LQ4 Block LS1 Camaro Accessories
  77. ls1 intake corvette
  78. I think I made a huge head install boo boo
  79. Halltech Induction Systems Now Available @ Texas Speed & Performance!!!
  80. Merge Collectors?
  81. 85mm mass air flow questions
  82. What do you think of these headers
  83. Kooks headers w/ QTP ORY
  84. removal of one cat
  85. Cross Threaded Head Bolt
  86. Truck Pan in F car?
  87. Brisk LGS Spark Plugs, Revisited...
  88. Exhaust leak? Popping while driving and p1133 code
  89. header problem need help!!!
  90. wierd vibration?
  91. Im Looking For GMMG Exhaust
  92. H-Pipe problems?
  93. High pitch whine driving me crazy
  94. Cam or Headers or Nitrous
  95. Bought a FAST TB off here....TB knowledge needed
  96. ported vs. unported ls6 intake
  97. quick question
  98. Mods?
  99. drivers side lower alt bracket?
  100. Carb Intake manifold question
  101. Single chamber flowmaster
  102. Eliminating the EGR
  103. ls6 vs fast 90
  104. thinking about fast 90/90
  105. new LPP headers install on a camaro
  106. Cai K&n Fipk
  107. CME horespower?
  108. Buying mods, have question
  109. ls1 3-5 wire maf/ait adapter or lt1
  110. Spacing accessory brackets??
  111. Trying to change Valve Cover gaskets on a V6... Need Help!
  112. best street legal headers/ypipe combo?
  113. what else do i need
  114. Weird issues with new intake
  115. how off would my tune be??
  116. Freeze plugs, oil galley plugs..number ,part number
  117. Question for Magnaflow or anyone that knows
  118. Bad Map Sensor?
  119. Clip of the new exhaust.
  120. Broken Sensor In Back Of Motor??????need Help
  121. Manifold Removal
  122. How much does the SLP Y-pipe weigh?
  123. Catback setup question.......
  124. LT1 Radiator <1" core?
  125. best place to buy ARH
  126. slp cme tips , should i sell?
  127. Pacesetter Long Tubes or TSP Long Tubes???
  128. Do I need to keep my MAF sensor if I'm going FAST 92/92?
  129. What Happened to MTI?
  130. Whos running an engine oil cooler?
  131. what do you think of this exhaust combo
  132. Still Needing Help
  133. I can't stand a thief
  134. mass air sensor screen
  135. another catch can ?
  136. Anyone running a Dynomax O/R Y?
  137. Can A Lt Headered Ls1 Pass Emission???
  138. EGR block off at the intake
  139. 98 camaros/ta's intake
  140. LS6 /FAST Intake on 5.3 L33
  141. Rocker Arms and push rods?
  142. Would a 1/8" gap between my TB stop and linkage effect performance that much?
  143. Can't figure out what exhaust setup would make me happy.
  144. 5.3l or ls6 heads?
  145. Exhaust setup
  146. exhaust
  147. need opinions on my exhaust. help!!!!
  148. Would this kill hp?
  149. TSP 100mm maf on this setup
  150. Coating SS Long tubes?
  151. Sweet-Thunder on a v6?
  152. Need some exhaust help
  153. Exhaust piping
  154. o2 bung on true duals
  155. ARP Header Bolts
  156. flp headers what y-pipe to use?
  157. slp air box lid
  158. Routing of AIR and vacuum lines
  159. map sensor
  160. too stock, help...
  161. Any sponsor able to sell Pacesetter LT's for ~$300? Want to support sponsors
  162. Cheap MSD Wires w/plugs... which sponsor was having the special?
  163. Idler pullys that don't squek? Very tired of hearing mine.
  164. Spark knock from old spark plugs
  165. Soldier in Iraq needs help
  166. LS6 Heads and Cam
  167. AR Headers or SuperMaxx headers
  168. 0 gauge wire for battery relocation
  169. SS Autochrome on C5
  170. LQ4/6.0 valve covers with LS1 coil brackets?
  171. Just finished my LT's, ory, and GMMG install
  172. what is this sensor?
  173. misc picture request
  174. dual exhaust help.
  175. More questions!!!
  176. need some help/timing chain
  177. what to do 5.3 swap
  178. need info on CME!
  179. Headers
  180. intake question
  181. Put on new parts
  182. What is actually "ported" on LS1 Ported throttle bodies? Pics?
  183. duals or y?
  184. Ported TB epoxy?
  185. AIR Solenoid Diagram Questions
  186. LS1 Oil Pan Alignment
  187. What muffler are you using with your CME?
  188. Bullet Cat for emissions help!?!?
  189. GMMG, LT(with CATS)=Worth it??
  190. ls9 intake
  191. lift engine for long tubes?
  192. Need Imediate Help
  193. oil leak at track. don't know where from
  194. pacesetters are on! have a few questions
  195. ???real quick question????
  196. Power Windows And Radio Aint Working Help.....
  197. Will 85m vette....
  198. Pulling my Motor
  199. cutout or no???
  200. Best Y pipe ..
  201. LS1 Exhaust port flange spec?
  202. ported throttle body ,now a po507dcode
  203. New Exhaust Hand built by me!
  204. Pics of over the axle TD chambered mufflers?
  205. Need Heads
  206. Full Access to Installation Information
  207. SLP fan switch isntall, Help please!!
  208. Full Access to Installation Information
  209. 160 stat in a 99 ls1?
  210. Any tricks to getting discounts @ GM dealerships for parts?!?
  211. intake manifold swap?
  212. how to mount dual cutouts?
  213. H/c C5 with straight pipes!
  214. LPP LS1 Stainless headers and Y now on Sale
  215. what should i do w/ my slp loudmouth after lt's and ory?
  216. Help-Headers-Not another which brand haha
  217. I Need Instructions On How To Wire My CutOut
  218. what throttle body with 92mm fast intake
  219. HELP what throttle body should I buy???
  220. Installing map sensor
  221. Is it the Borla muffler that sucks?
  222. How to test crank position sensor?
  223. Just when you want things to go smoothly
  224. Cutout sizing help!
  225. What muffler to replace my Flowmaster?
  226. Ftra
  227. Man how much a cracked y-pipe hurts!!!!
  228. Cherry Bomb Crossflow Muffler
  229. quick question about hooker
  230. Installing QTP headers & Ypipe - what small parts do I need?
  231. How restrictive are OEM LS1 mufflers?
  232. Heres A Poll To Give Your Thoughts On Two Cams
  233. How to keep ARP crank pulley bolts tight?
  234. What length bullit muffler
  235. coolant boiling at about 210
  236. tsp true duals not fitting..plan b?
  237. Where to get breather
  238. American Racing y-pipe with Kooks headers
  239. SLP Part # 23060, is it the 85mm MAF?
  240. WHAT CRANK PULLEY SHOULD i USE ON A LS6
  241. true duals with cats?
  242. Getting a whine noise that increases/decreases with rpms...
  243. 92/92 Intake & TB Question
  244. ARH headers installed
  245. Underhood Temps with Stainless LT's
  246. 2001 Corvette Borla Headers for 99 Corvette LS1
  247. stupid flowtech headers
  248. Will headers cause
  249. need opinions for catback
  250. where is the best place to get 02 sensors...cheap!
