- ? for those with gmmg and cme tips
- Those With Cme And Gmmg
- ???which Exhaust Is Quieter???
- Installed a Powerstick on my LS1 today, stock manifolds/cats
- Heater core?
- Anyone selling stock ws6 exhaust?
- Those with K&N fipk, come in.
- Thoughts on engine build?
- need catback opinions please
- Getting my magnaflow muffler tomorrow!
- has this happened to anyone else with their LT's?
- which pushrod with this cam?
- Longtubes for my c5 z06
- What Other Mods/Bolt-Ons Can I do?
- Help won't run right
- Looking to paint my 6.0 408 iron block temp of paint..
- Would this cause my belt to come off?
- coolant crossover pipes?
- Can Mufflex be bought with a borla muffler?
- scorpion rocker arms?
- y-pipe question
- How Much Will A Catback Hold Me Back?
- Kook's vs B&B Headers on LS6. B&B Really 20HP More?
- 408ci vs 440ci Engine Build (Suggestions/Opinions)
- ARH Install Experience
- t.b. bracket
- 4" Exhaust Connectors
- installed my ls6 intake
- ati balancer for gto
- 03 zo6 ls6 intake about to buy..
- Breathing DEEEEEP!
- starter ?
- pully squeel
- what adapters needed for ls2 rails/injectors
- Power Steering Pump bad?
- Which ud pulley
- Vr Jr Intake manifold
- part number for power steering
- power steering help
- Exhaust Temperature Difference
- Burned up my alternator at the track on friday.
- WS6 and Cold Air Intake or Lid?
- what kind of spring compressor
- fast 90 install Q's
- HP numbers?
- ???waterpump To Bleed Coolant???
- What connection is this?
- What happened with the Speedtweekerz raffle?
- DUALS DUALS DUALS lets see the pics!
- What Intake Should I Go With??
- FAST intakes
- FIPK2 Modded
- Changing plugs..
- ls2 6.0L Valve covers?
- My dyno numbers.....
- I have a couple of questions about T-Rex cam
- Alternator Overdrive Pulley?
- NEW UD pulley, What Bolts can I use
- cutout location
- What lid to run with fast 92/92?
- Question on throttle bodies
- Anyone have Flowtech y-pipe pics?
- mac mids
- Corsa installed, Not happy
- Urgent!!! Need a new muffler!
- ??? about ls7
- Wrapping Shorties.
- Meziere Installation Problem
- Pacesetter LT w/Jet Hot Coating
- Clutch Pedal pushes up toward foot @ high RPM
- Mac Midtube Headers?
- headers rubbing?
- cheaper single chambers
- LS1 VS 6.0 Headgasket
- Header swap from the top?
- what did you gain from your longtubes?? and a few questions
- Help on weight of 6.0
- Do any sponsors carry Mufflex products
- heater hoses
- Seconday AIR Injection Help - *Pic*
- True duals?
- Latest CNC ported/patternd TB's in stock!
- EGR code P0401
- How can i make my magnaflow louder?
- Return my Kooks ORY for catted Y ?
- Ory??
- Coolant lines under fast 90 manifold?
- IAT Resistor
- new valley bolts for fast 90?
- Muffler baffle blown out
- Car is popping out the exhuast???
- ARH vs Pacesetter, price/performance...?
- true duals all the way out
- magnaflow?
- underdrive pulleys?
- cutout
- moving and might need cats
- slp ls6 intake manifold??
- TSP rumbler catback..
- Installed LPP headers.
- what y-pipe can i get with stock manifolds?
- Advice on compression...
- Raspy sound after installing ORY
- fuel injectors
- Pricing question for TSP catted y pipe
- Header bolts backing out...Locking header bolts or lock washer?
- LPP Stainless LS1 Headers and Y's now in stock.
- Armor Coated Pacesetters
- Injectors for MS4 cam swap?
- where are ETP??
- ???bleeding Coolant Thru Waterpump???
- i need a link for ls6 intake install
- Car Is Done!!!
- Can a TB be to big..........
- Poor Mans Exhaust!!!
- FAST + meziere WP
- My TSP Y-Pipe cracked!!!!!!!!
- Any luck with ebay headers?? LINK inside
- map/baro circuit?
- going through 02 sensors pretty fast idk why??
- Poly Mount install tips/pics?
- cats Qs ????
- running on 4 cylinders
- who makes the best 3.5" x pipe?
- Strange noise - Ticking
- exhuast pipe vibration dampening
- 98 LS1 coils bolt up to 99+ coil bracket?
- I joined the club
- Custom Ram Air
- low rpm stumble/misfire
- Considering 85mm TB/Intake Manifold Combo
- parts needed for bare motor...
- which y to buy???????
- Really dumb question about intake.
- Fast 92mm intake questions?
- ???gmmg Vs. Loudmouth 1???
- "hunting" idle got worse with PCV valve
- catchcan install with EGR
- Installed manifold today....had a few issues.
- problems with the daily
- which one do i choose??????
- ls6 intake, egr question
- new Z06 intake on L92 heads?
- Mufflers straight off the heads question
- ASP Pulley part number
- poly mounts raise engine height??
- 2000 cfm throttle body questions
- SLP Long Tube Header Install question
- Swap Ls1, what kind of power am i looking at?
- Which mufflers for CME?
- Help!!!!!!!!!!headers!!!
- First Mod
- what size injecters does a 03 z06 hav?
- Best First Mods
- What is a good cat for a GMMG with LPP long tube headers??
- Gonna be getting a new exhaust setup.
- ultra z hood
- SLP help
- will a ls6 intake fit my stock throttle body?
- how much et gain form cut outs
- Who has the best Throttle body for me....LOOK INSIDE!!!
- vacuum canister install
- need fan switch help!! (:() for people that used their own switches.
- Exhaust to fit Kooks 3.5" collector....
- Slp power Flo Catback.
- My next mod having problems choosing
- 92 FAST Install Questions?
- My American Racing Headers got here (pix)
- Need Problem Diagnosed
- This is banging my exhaust
- SLP Underdrive Pulley
- Ms3
- is my cutout broke?????
- ls1 and ls2 bellhousing?
- muffler testing
- plugs help!
- MY Ported and polished T/B
- Help with power steering pulley puller ls1. 2000
- Need bolt ons!
- Something feels off.....
- K@N Cold Air Kit
- Leaded Cam2 + O2 sensors
- Best exhaust setup for slammed / lowered car?
- ls6/fast intake
- Trouble shooting after F.A.S.T 92/92
- Urgent! Borla will not mate up to new Y Pipe
- SLP Dual/Dual
- LT cats and emmisions
- Options for intake
- Y Pipe Options For Pace Setters
- LS7 maf & LS1 pcm
- New Weiand Street Warrior vs Fast 92mm Manifold
- Quick question guys. What is the use of da idler pulley?
- bellow
- Second and third primaries are going to eat my plug wires!
- underdrive pulley bolt
- 02 extensions, what length do I need?
- Installing LG Sreet's Soon What Else Do I Need?
- HEADS what does milling do for them.
- Stock Motor 1 3/4" Vs. 1 7/8 Engine Dyno Results!!
- Stock Z06 or Borla Stinger Catback
- Aftermarket MAF
- Possible to get just the SLP Dual/Dual muffler new???
- p0355b ignition control 5 circuit???
- What would happen if Air got past the MAF
- where is the compression ration for heads and gaskets
- Whats the best spark plugs?
- Occasional, severe stumble/loss of power
- Y pipe confusion
- I want different tips for my SLP DD
- Where to find a/c idler pulley?
- Looking for LS1 fbody front accessories...
- ???how Much Do Vent Tube Plugs Cost???
- Few questions about QTP cutouts.
- Getting headers, y, cats, and catback installed, QUESTIONS
- Long storage
- Good Houston trans shop for 4L60e ???
- LS6 & stock inj. --to--> FAST90 & SVO 30#
- Thermostat Help
- Cooling problems in town
- Which knock senors? Where to get them?
- SLP dual/dual VS. Corsa
- what is the corvette 02 sensors part #?
- changing my exhaust setup
- Has anyone tried these edelbrock headers?
- Vent tube on ls2 valley plate?
- Header to spark plug clearance issues
- O2 sensor simulator
- Qtp Header Question
- Exhaust Suggestions
- Steam pipe vent block off?
- need to quiet down my head and cam car at idle
- Pacesetter question.
- Please help!
- Mass air/Lid combo
- Let Me See Your Cutout Switch Location
- Question Lt1 to Lsx swap Related.
- Magnuson Supercharger
- my exhaust clip
- Exhaust Dilemma
- Which Intake??
- Water Pump Gaskets
- '98 Z Header Install
- looking for 00-02 fbody engine harness+pcm
- Running an Open Cut Out
- question about 3 inch exhaust
- 160* Thermostat for 99 LS1 won't fit?
- will i have enough back pressure
- Need to quiet my SLP LM1 setup.
- Does a stall effect gas mileage?
