- Anybody got this y-pipe?
- Header Help
- Billy Boat Exhaust
- Quick Question
- side vent exaust?
- any way around the knock sensors?
- does the 01-02 fbodys still have air and egr?
- 3 shops denied putting on my tsp catted Y WTF????
- What am I giving up-
- What does a LS1 longblock weigh?
- Need part # for valve cover bolt (center style)
- radiator
- can someone give me a list of the companies that make y pipes for stock applications
- Couple cutout questions
- EMISSIONS ANYONE from KC, MO Lee summit area
- PLEASE HELP, Electrical Problem, Gauge Cluster Going Nuts!
- Belt Tensioner Deal
- GMMG to factory CME
- Header installation questions?
- Removing MAC midlength headers
- my to do list...y pipe fix, magnamouth
- New Magnaflow CARB legal cats put on this weekend.
- Carb Question Ls1
- some quick manifold help
- Need LT's, but which ones? ARH or Pacesetter?
- Does this look like a good 3" to 4" Y pipe?
- PCV Ground Strap?
- 2.5 TD exhaust non-mandrel
- PCV question
- slp ud pulley
- Buying an LS6 Intake off an 04 GTO.
- New Exhaust Is Underway
- Patriot ls1 heads?
- Borla mouth?
- tb bypass question
- Pacesetter ORY
- Mac mid's come on in!
- Replace intake manifold gaskets
- Header Help-Poor performance
- what kind of y-pipe or ORY for a lowerd car
- Bassani true duals 02 formula install
- Need a better throttle body and MAF..help?
- Fast 90 vacuum plumbing on an LS6
- V6 Radiator???
- Percy seal-4-good issues
- hooker polished stainless steel headers
- which ORY should I get for coated pacesetter LTs?
- my ultra z hood
- Where to purchase mandrel bent pipe??
- Just installed the kooks today!!!
- 93-02 V8 NGK TR55-IX Spark Plugs
- what bolt on should i do next...best bang for the buck
- Can I replace a small part of my Maf?
- TSP Rumbler X-pipe TD's?
- Hooker super comp 1 3/4 headers
- Belt #'s
- getting LS6 intake from 02 car, what do i need?
- Different LSx intake manifolds???
- Another Air Removal Quesion
- another mileage thread! =P
- clutch and LTs
- whats louder, loudmouth or true duals??
- SLP ram air duct
- LS6 intake for sale
- Trickflow Heads: Questions
- Question about AN line connecting to fuel rail as mine just blew off the rail.
- MSD Plug Wires
- Is this SLP LS6 intake missing something???
- 2.5" or 3"?
- bumper support delete mode any pics anyone, how much weight saved?
- ypipe bang!
- Need some help to modify my 2002 ZO6
- Need a high flow cat....
- SLP Radiator epoxied cap came off, what size/expoxy to use?
- What to do with my wires?
- power gains
- Modded stock rockers?
- SLP Lid
- what catalytic converter is on these cars?
- intake help
- Who Has Modified The 92mm LSx Intake to 95mm?
- IMCO PRO cherry bomb muffler for the f-bodys
- Can't get to that last spark plug wire???
- Emissions - Anyone from Arizona???
- Sweet Thunder Flow..?
- Where can I get this? (pic inside)
- can't decide... need help!
- Is it true that....
- msd 8739 HELP!!!
- Whats the best sounding stra8 through muffler
- power steering delete?
- MOD LS6 to fit EGR?
- miss question....exhaust related?
- what's the weight diff between TSP duals and 4" mufflex?
- LS6 intake ?
- Question about removing baffles in WS6 hood with K&N FIPK
- cam sensor
- H/C/I motor...SLP MAF or Z06 MAF
- SLP Fan Switch
- Bolt Ons......how Much Off E.t?
- Catback Question??
- Another LS2/LS6 intake question
- Can anyone explain to a non-mechanic how to change the water pump?
- Anyone run the cheap 1 chamber ebay mufflers
- NEED help picking a muffler!
- LS6 intake question
- question regarding longtubes and ory...
- Got my long tube headers... pics
- Knock sensor low voltage = retard timing?
- engine wiring harness
- Problems caused my my Aeroforce...
- I need a new lid and smooth bellow!
- Headers still bang with poly mounts???
- rocker arm stands
- ls7 exaust manifolds
- Simple question about cleaning TB
- oil pan ?
- pacesetter LTs' coated or painted???
- Difference in LS1 and LT1 ORY
- Bolting LS6 Intake manifold after Race headers???
- need some opinions
- Where can I find a Clear Air Lid
- Jet Hot Y pipe w/ removable cats
- header bolt part #
- If you run an aluminum intake manifold chime in!
- where to mount coil pack relocation kit?
- oil pressure sender? thread?
- Vacuum Line question
- FAST intake trouble feeding engines at 6200?
- Intake Bellows and Larger TBs
- QTP Electric cut-out
- frustrated w/ exhaust help!
- quick question.... IAT + CRC MAF Cleaner
- Y-Pipe and Cat advice
- Breaking Poly Locks
- Volant Cold Air Induction Kit
- Exhaust HELP
- LS1 Bora; quick question
- flowmaster bullet?
- Will borla x-1 be raspy?
- Complete HVAC delete question....
- xr1 muffler question
- blowing out exhaust gaskets
- How much of a difference
- Which one will net the best time reduction....
- Wires and Plugs
- patrick g cam, first start up
- Coil packs & wires
- Headers or cam
- Y pipes....
- Results of a K&N Air Filter....
- Will AIR system removal cause emissions to fail?
- Can't get crank pulley off, may have damaged threads.. very pissed please help.
- ported tb help!!!
- What sensors are these (Prof. Products mani questions?)
- My QTP headers...
- GMMG poor fitment
- Where should I cut my exhaust at to get it apart?
- LS2 heads and intake on LS1= how much powaaa
- New, Stainless steel, Full length headers for $221 shipped....wtf?
- PP Typhoon Intake
- Voltage low under acceleration
- 90mm Street Warrior LS Intake
- How much is a FAST upper shell?
- 420/430 code after header install
- "CHEVROLET" GM valve covers - what oil cap?
- Header install in progress
- cat delete
- Wondering wut i should do next
- stuck on this one
- !AIR write up
- LT Headers, Vararam CAI & LS6 Intake=??
- question on Pacesetter Y
- Same TPS sensor for LS1 and LS6?
- write up on wideband a/f and fuel pressure
- EGR/AIR Removal Question
- true duals, Flowmaster super 44's in the stock muffler location
- A few LS1 swap questions?!?!?!?!?
- 4" Mufflex vs 2OTL
- anyone running descreened maf with ram air?
- Deleting AIR on 02 SS
- True duals with or w/o cat HELP!!!
- Switching to TSP TD's.....which mufflers???
- Another Home Ported FAST 90
- engine mount pedastal
- McLeod Adjustable Master
- How to remove upper radiator shroud? SSRA install
- Lastest, Newest CAMS for Heads package
- Swapped Volant to FTRA: Breather (PCV)?
- Too dump, or not too dump?
- Lid Was Rubbing... Poly Motor Mounts F T W!!
- Finally getting custom 3" y pipe with magnaflow cats today
- Why LQ9 Block Over Aluminum
- Cat back install on jack stands?
- Is a Custom Y Pipe Setup Worth It?
- Header install
- where to get a 4" i.d. Mushroom Airfilter
- FAST 92/92 question
- HEADER INSTALL NOW BIG PROBLEM, Electrical
- Is MTI Motorsports of Houston still around
- Need help on headers
- SLP dual dual and longtube sound clip! finally
- Ready to do headers + duals - few questions
- Hesitation on upshifts
- My New Car!
- Help with poly mount install
- Weiand intake
- Stripped Bolt Input needed...
- Which is quieter, Corsa, or Magnaflow compared to the DD
- Tsp 1-7/8
- Longtubes and visual inspection
- Need a few tenths
- Air/HEat only blows floor/defrost after offroad header install / EGR AIR removal
- LMII with LT's
- Another gimick plug??
- running open manifolds
- going from true duals to gmmg and catted y
- High Flow Water Pump?
- Is the SLP catback stainless steel?
- Do 02 Z28's use LS6 intakes?
- what to do next
- Victor Jr Pro's
- 4'' maximum flow
- Ls Engine Motor Plates
- who has the best deal on bosch 13111 02 sensor?
- Hushpower II muffler Q's
- Roller rockers worth a gain?
- Latest design in TB porting...
- Borla!
- My UD Pulley Comparison
- anyone know where i can get a throttle body blade?
- Changing NGK55s
- Just got a 98SS
- 5.3 plug wires on ls1
- Ls2 intake and TB
- Just Lid vs Whole Kit
- Broken Rocker Arms Bolt WTF??
- newb needs help
- Corvette O2s with Headers?
- Once again, another exhaust thread plagues ls1tech.com! :p
- which lid doesn't rub?
- Thinking about an underdrive pulley(s)...
- Egr Delete Problems
- Why dyno need dyno tune after headers install?
- 408 TB and intake questions
- cold air vs air lid?
- name that part
- Magic Stick 4 Cam Performance
- How much should I pay...
- Few pictures of new stuff :)
