View Full Version : Generation III External Engine
  1. Ls6 intake
  2. Did some throttle body porting last night
  3. Intake hump hose Airlid to 90mm Throttle body
  4. how well will a stock ls1 fbody radiator work with an iron block 408?
  5. Used condenser a good idea?
  6. Just finished installing BBK long tubes!
  7. What length serpentine belt...
  8. intermediate pipe ?
  9. K&N cone filter on tb?
  10. Poly Motor Mounts Install
  11. How can I get a good seal on a lid
  12. Slp lid install questions
  13. help ls1 in a rx7 wont start
  14. Possible to bolt all three grounds on back of head together?
  15. tsp after install questions
  16. Alternator, battery replaced, no charging. 1 loose red wire?
  17. LSx Solid Motor Plate ????
  18. Does This Belong To Anyone?
  19. Fan switch
  20. FAST 92mm...Why no port seals??
  21. SLP Powerflo Catback or Powerflow/LM1 Conversion?
  22. ls6 to lq9 motor mount question
  23. Pro-flo
  24. Need new plug wires
  25. will LT1 cat back fit ls1 car?
  26. Cold Air Inductions Inc Intake questions(IAT)
  27. 160 thermostat
  28. FAST 92 intake shell F & R Short bolt trq specs..?
  29. jegs sfi balancer install
  30. ?s about 25% powerbond pulley
  31. How do you mount the rear exhaust hangers on TSP true duals.
  32. Which throttle body for FAST LSXR102 intake?
  33. 4.3 to 6.0 swap problems
  34. bought new a/c belt, package says 1994
  35. magnaflow, hooker, or TSP true duals
  36. Idle Gradually Increases
  37. Best sounding exhaust*I'm aware of the sticky*
  38. Push Button start??
  39. What features do you need in an LS wire set?
  40. Valve cover question
  41. just FYI: logged car after bolt-ons
  42. valley cover gasket
  43. fel-pro valley cover gasket
  44. Ls7 tbody on lS1 question
  45. 160* Thermostat
  46. edelbrock fuel rails
  47. should I keep my fast 92 mm intake or step up too a 102?
  48. pro's con's of carb set up
  49. How much horsepower can you run...
  50. Missing after header install... got codes.
  51. Power Steering Pully's?
  52. low intake
  53. What alternator to run under drive pulley?
  54. 5.3 cam choice
  55. Could improper plug gap on NGKTR55 cause code p0300?
  56. Do we have removable t stat housings?
  57. Looking for part number for 10.4 mm opti/LS1 coil ends for spark plug wires
  58. New at cbm
  59. Looking for some advice
  60. summit shipping my stuff weeks late
  61. Dip stick location.
  62. How much AC Compressor Oil?
  63. Difference between fast 90mm and 92mm
  64. High idle till i come to a stop?
  65. MTI Lid won't fit over MAF. Pics inside.. Help!
  66. Need a quick measurement, any help would be appreicated
  67. Difficulty Installing Shorties vs Longtubes??
  68. Is this a reverse flow water pump? How else could this work?
  69. battery dieing overnight
  70. Belt routing for water pump as the only accessory?
  71. How big is the TB opening on a LS6 intake itself?
  72. LS6 intake repair near MAP w/pics
  73. Drag racing event
  74. Loud backfiring.
  75. fast 92mm ... need help
  76. Quick opinion please...
  77. A/C compressor removal and reinstall ???
  78. Header wrap questions..
  79. Exhaust resonating
  80. Need a shift light and is my tach really laggin this bad?
  81. Stiff throttle after FAST 90 install?
  82. Serious header heat issue
  83. O2 Sensor Help!
  84. faster throttle response
  85. 16mm hole on driver's side of block for temp readings?
  86. Are all throttle bodies created equal? Help me choose a 92mm tb.
  87. Need some quick help
  88. Need help choosing a replacement exhaust
  89. Good or bad idea?
  90. Anyone go with TSP true duals and NOT like them?
  91. What's your 90-92mm TB depth mounted?
  92. If you have a Voltage Drop at WOT, Here is the Solution
  93. Best muffler for my '00 z28?
  94. How bad is Flowmaster?
  95. speedo or mileage gauge are working
  96. need help
  97. pcv valve guestion
  98. Cracked bolt hole on LS6 intake
  99. TSP True Duals do they have Rasp or no? Owners chime in!
  100. Changed Spark Plugs and now MPG socks !!!
  101. throttle body question
  102. Fast 92 or 102
  103. Ls2 throttle body on Ls6 mani
  104. Exhaust installed!!!!
  105. Help! My throttle is stuck open when i first start it up.
  106. NW 102 TB, anyone used it?
  107. borla with headers question
  108. Crappy pics of my duals over the axle build
  109. Slight Rear End Build Advice
  110. Just installed a CAI on 2004 denali...
  111. Cruise on an Accufab
  112. Problem with nick williams 102??
  113. CBM LS7 Porsche 911 Swap + LSX TV
  114. coil packs wiring harness ???
  115. Poly Motor Mounts
  116. 98 TA Engine Swap
  117. The Oil Leak.... Continued... Leaking oil above starter area
  118. Will I get an SES light if I remove AIR system?
  119. I think I might be sick...
  120. Taller valve covers ?
  121. Fast 102 Install Questions??
  122. Any gains from k&n fipk?
  123. Loudmouth
  124. Just installed Powerbond UDP, now alternator is not working?
  125. C5R heads what intake?
  126. ls6 intake 90mm
  127. cam swamp questions
  128. How loud is an open header LT ls1?
  129. Looking for LS1 Corvette idler pulley bolt
  130. T-Brake/2 Step Wiring for Horn Button
  131. information on kooks true duals install
  132. Magnaflow cat back
  133. need a strange part...
  134. Pic request: Magnaflow 5x8 or (4x9) mufflers AFTER axle true duals setup.
  135. Don't buy dynomax ory
  136. Myth or Fact
  137. Ory to stock heads?
  138. 98 Z28 Verty Engine Transplant Build
  139. Catalytic Problems
  140. 102mm Fast LSX. Yes or no?
  141. Engine stumble and RPM indication spike
  142. What gains should I see?
  143. ok to drive after headers
  144. H/C/I and headers install question
  145. New black fast 92 installed looks good!
  146. Fast 92 install
  147. Cold Feet... True Duals
  148. Where to get 4" flanges
  149. Texas Speed Long Tubes! Easy Install, Thumbs Up!
  150. Throttle cable for a four barrel throttle body?
  151. Head Casting question
  152. Cam help first time here
  153. How much gain from ls6 intake on cam only trans am?
  154. where to find long sanding rolls and everything i need to port a fast
  155. doings a battery relocation... kill switch loaction?
  156. car starts some times need help
  157. IAT Sensor Placment In A CAI
  158. MSD 6AL Digital Ignition Module w/Rev Control
  159. Best Prices On Parts
  160. Hooker catback fits like crap and chambers are damaged new
  161. 02 sensor question
  162. Chrs1313, SES
  163. anyone have a CAI on a dd?
  164. Catback-without muffler
  165. MSD Wires?
  166. Which muffler for true duals? (opinion and Idea thread)
  167. TSP X pipe back
  168. Vacuum Lines
  169. Proform LS valve covers
  170. Odd question fellas, help if you can
  171. You guys are crazy if...
  172. GTO throttle body question
  173. Dumped duals
  174. LS1 Compression Test now Ive got a miss fire???
  175. has any one had the front seal wear a grove in a underdrive pulley?
  176. GUIDE:Sakou Michi LS1 Dual Cans/truck PCV Install (w/ pics)
  177. s2 throttle body.
  178. KU Coolant Vent system, anyone runnin it?
  179. truck intake
  180. off the wall intake question LS6 specific
  181. Amsoil Drop-In Air Filter EAA-83 Review
  182. Intake swap questions
  183. TSP catted y to non-TSP headers?
  184. what do you guys use to port your fasts/ composite intakes
  185. Torque on the manifold Bolts
  186. Dual inlet truck fuel rails
  187. Another code 1153 thread lol
  188. oil pressure mechanical gauge
  189. Intake question
  190. Header Install...DONE!!!
  191. getting a custom tune couple of questions.
  192. MAP sensor wiring?
  193. how are bbk throttle bodys?
  194. 99 m6 wiring harness/pcm vs 2002 a4 harness/pcm
  195. need info on high mount a/c braket
  196. Need your guys' help on this one. Exhaust.
  197. Passenger Head Tensioner Pulley Deal...
  198. push button starter wiring
  199. TSP Catted Y-Pipe with Ebay header?
  200. 1998 Camaro dead spot 3000rpm in second gear
  201. Vertical Mount Throttle body?
  202. Raptor Performance Digital Mini Shift Light with Launch Feature
  203. Tsp headers PITA!!
  204. Don't like your LM1 or LM2? Consider this...
  205. The vacuum T fitting at the back of the manifold, size of A/C barb?
  206. New CAI Results..Got rid of my lid and airbox
  207. Does Texas do visual emissions inspection?
  208. Can Anyone Tell Me What This Is?
  209. Cut off my tips
  210. high volumen master clutch cylinder
  211. Noise after bbk intake install
  212. ls1 intake manifold
  213. Installed my Headers/Y Pipe/Etc..
  214. Camaro Shorty Headers for LS1 - Cali legal
  215. WOT: Noise from engine bay area - whine?
  216. catted Y pipe to fit QTP LTs
  217. Slim alternator
  218. Magnaflow exhaust tip broke off
  219. PCV Catch can question
  220. how good are 317 heads for LS1
  221. Trying to find intake/vacuum leak help
  222. SLPloudmouth 1 or 2 exhaust system
  223. DSL with TDs?!?
  224. new ls1 for 3k?
  225. car wont crank need help asap plz, need car moved asap
  226. Help first time starting the new motor
  227. Misfire on cylinder 4....out of ideas
  228. Knock-Off FAST Throttle Bodies
  229. Valve cover bolts?
  230. Quick question
  231. What sponsor ports tb?
  232. P&P TB after tune?
  233. What size belt for SLP/march underdrive pully belts?
  234. Stall size for Ms3 cam for DD
  235. Are manifold gaskets the same?
  236. Corvette Cold Air Intake on Camaro?
  237. Cons of welding ypipe?
  238. Got wrong headers in mail, 1 7/8 instead of 1 3/4
  239. Unique Exhaust need QUIETER!
  240. New cbm whipple side mount throttle body adapter lsx
  241. fly by wire tbody?
  242. whats the best mods for a stock ls1??
  243. 2OTL Owners, come in!
  244. Wiring
  245. Wiring
  246. building my own ram air..where do they sell sheets of clear or black plastic?
  247. FAST 92mm Lower Shell
  248. Header issues
  249. Where to get hump hose coupler
  250. How much do cut outs help
