View Full Version : Generation III External Engine
  1. Could someone clear this up for me. Cam/Crank Sensor Replacing.
  2. Which Pulley for stroker?
  3. Muffler suggestion?
  4. Where are you getting your pieces for custom exhausts?
  5. 98 water pump gasket
  6. LS1's 98-00 vs. 01-02
  7. headers?
  8. Intake... LS1 vs. LS6
  9. Cut-out Info Needed
  10. Welding the Block off plate on Mainfold
  11. how much rwhp do i have stock?
  12. H/C/I car -- Replace MAF & Injectors?
  13. TSP Catted Y-Pipe + Dual Electric Cutouts
  14. Terrible noise after intake install... im stumped
  15. ...adding cats...
  16. virgin corvette to be modded.... help
  17. want to make a my dual/dual a lil louder
  18. first impressions with q45 TB
  19. fast 92 combo - need advice
  20. LS2 intake fit and LS1??
  21. getting a custom Y made... wheres the best location for the cats?
  22. 98 style water pump
  23. Glowing D side cat. Internet mechanics in here!
  24. I really need help
  25. autozone power steering pump
  26. CME Camaro guys...what do you think???
  27. Autometer Oil Pressure gauge.
  28. Cats and A/F...
  29. HP gains from 90mm intake/TB?
  30. Compressor seized, what should I replace?
  31. What MM is the stock Ls6 intake TB
  32. Cut-out after catted-y pipe
  33. replacing TPS on stock TB
  34. Intake Questions
  35. Is full bolt ons all at one time a bad idea?
  36. shifter hitting console
  37. intake flanges
  38. will removing my a/c belt hurt anything?
  39. Smoking On The Dyno..
  40. DTC P0452 Fuel Tank Pressure Sensor Low Voltage
  41. Question about my Corsa exhaust
  42. Serpentine belt...
  43. ordering parts, need advice
  44. Hooker Header's part # 2468-2hkr stainless steel grade?
  45. QTP headers, Custom Y w/ Flowmaster merge and Magnaflow cat back...
  46. How much better
  47. Vengeance ported 92/92 is here, pics!
  48. flowmaster merge w/ pacesetter y pipe ?
  49. Lost torque with FAST 92 intake!!
  50. Typhoon 96mm intake manifold
  51. Little problem with ported tb
  52. Help: ugly sounds coming from my car
  53. Upgrading stock rockers??
  54. Reuse Head Bolts for Torque Plate?
  55. Ls6 intake
  56. most power made through sweet thunder mufflers
  57. real quick question!!!!
  58. water pump line?
  59. c5r heads with fast intake? can it be done or do i need an ls7 intake?
  60. Choke or not?
  61. Need an opinion
  62. Blew my P/S pulley, recommendations on a new one.
  63. LS1 to lq9 starter issues
  64. Air intake ?
  65. difference between FTRA and SLP?
  66. Cylinder 5 misfire...HELP
  67. what do i need to make 500 hp?
  68. why does my car sound like a diesel??
  69. open headers = love at first sound
  70. what spark plugs to use with 402cid with patroit stg 3 heads , and what MAF sensor ?
  71. belt ?'s
  72. Here's my future exhaust setup so far.
  73. motor mounts.
  74. What's the best Y-pipe for QTP Headers?
  75. 2001 Z06, Kooks Vs LG
  76. edelbrock elbow
  77. Y Pipe!!!!
  78. HELP!! Longtubes/T'Ds running like shiz!
  79. Valley cover...
  80. Anyone tap into the water pump for the coolant crossover?
  81. !AIR Removal ?'s
  82. Random Technology Catalytic Converters?????
  83. Dynatech headers
  84. how to port an ls6 oil pump?
  85. Changin Oil Pressure Sending Unit?
  86. flexplate is rusted?
  87. Cant decide between two exhaust setups.
  88. LS6 intake, which TB?
  89. arh 1 7/8
  90. How to tell SLP dual/dual?
  91. How to kill the rasp without cats or duals!!!
  92. 16 volts to much out of the alternator?
  93. 1 7/8 headers for my 370??
  94. Installed XS Headers today
  95. Just installed wideband now wonding about my AFR
  96. Different stock MAF sizes?
  97. 06 Corvette Coil Pack On 2000 F Body?(brackets)
  98. Manual Rack Question
  99. How long did you elictric water pump last?
  100. For anyone looking at buying Flowtech headers
  101. i want to build em' wanna help?
  102. What spark plug for my application?
  103. where to get bolts??
  104. Electirc water pump
  105. Texas-Speed headers
  106. header gasket problem
  107. delco or bosch 02 sensors?
  108. Victor Jr Porting Services
  109. Egr
  110. Stock HP A4
  111. cut outs after cats... is it worth it?
  112. Quieting down true duals with tailpipes
  113. How long is the ls1 i pipe?
  114. LS6 Camaro's come inside
  115. How can I check my tack output on a stand alone harness? My tac does not work.
  116. injector?
  117. How do i make my magnaflow louder?
  118. Difference between Hex Head stud and 12pt?
  119. LS6 with EGR, or BBK SSI??
  120. New billet belt tensioner color available
  121. should I change my MAF?
  122. Which Headers?
  123. Question about Bo white TB porting....
  124. Short video of GMMG, LT's, w/o cats
  125. looking for new exhaust..
  126. what do you guys think of....
  127. Intake manifold..screw up!!
  128. New engine cooler + new fluid = water pump start to leak
  129. collector extensions
  130. LS6 Intake or 150shot Dry Kit??????
  131. should i sell my borla and get hooker exhaust?
  132. plug for rear 02 sensor in AR y-pipe?
  133. are oxygen sensor extensions ok?
  134. Guess these WIRES!!!???
  135. Worth it?
  136. HotwhipT/A's wild exhaust setup. Pics and a video.
  137. removing cat with stock manifolds
  138. lm1 with headers
  139. what year head bolts
  140. Possible Electrical Issue??
  141. Vacuum pump
  142. Need to replace I-pipe
  143. Just a thought
  144. yellow valve springs
  145. what do you think about this exhaust idea
  146. Rubbing from my ORY driving me crazy!
  147. who has thunderbolt cats?
  148. hight idle when cruising in neutral to a stop
  149. air removal
  150. pics of my dual exhaust with my bmr trakpac
  151. does this do anything
  152. Question about Rasp?
  153. Looking to build a street machine. I got ?'s
  154. Dyno Results After 228/228 and 5.3l Heads
  155. Damn A/c! ! ! !
  156. Umm... what is this black box of death?
  157. QTP LTs.... What Y pipe?
  158. ses light comes on
  159. catalytic convertor placement on X-Pipe
  160. 98 cars???
  161. How do these plugs look? worth changing?
  162. AIR - vacuum hose from Intake
  163. Water pump?
  164. random backfire
  165. 2002 SS Throttle Body on 98 T/A??
  166. Flowmaster CB vs. TSP TD Sweet Thunder(or other)
  167. My LS6 intake won't seat properly in its valley
  168. Rear o2 sensor Question????
  169. Tsp duals / 27" sweet thunders
  170. EGR / AIR Removal 2000 Trans Am
  171. Does anyone know if the ARH ypipe will work with a set of standard collector QTP's?
  172. crank damper help
  173. Just installed the cutout!
  174. What TB for the FAST 92 intake?
  175. Exhaust manifolds
  176. Corvette ZO6 corner lights signal day??
  177. No Flow Restriction Exhaust Cut Out...
  178. Bosch o2 question (13444&13111)
  179. question about slp loudmouth
  180. Need Borla exhaust pics....
  181. Exhaust question??????
  182. new thermostat
  183. Cam In...Crappy Video
  184. Noob- full exhaust question
  185. Newb question On o2 sensors
  186. Why get a new harmonic balancer/crank bolt?
  187. Exhaust help.
  188. Need some advice on making my car a bit more quiet
  189. Corsa Catback Flow CFM?
  190. Ported throtle body gains?
  191. stainless ebay header Y-Pipe
  192. average "full bolt-on" gains from tune
  193. Opinions...
  194. LS2 TB onto my 408, and now Codes, help
  195. Hard to put in reverse, Exhaust related??
  196. Guy's with MSD 6010
  197. head gasket bore size
  198. How do I remove my A/C?
  199. what to do to swap ls1 for ls2
  200. exhaust question
  201. alternator?
  202. TSP Y pipe problem, another question.
  203. crazy question
  204. Ebay headers?
  205. Hooker header question
  206. Bullet Muffler on stock exhaust w/ cutout?
  207. The Hooker Aero Chamber Muffler
  208. Whi sells the GMPP manifold tapped for injectors?
  209. Magnaflow vs Hooker
  210. best place to get...?
  211. lookin for some 2.5" high flow Cats
  212. Just Bought $2k Worth Of Mods!!
  213. Would this work?
  214. Too much load?
  215. Just arrived in the mail....
  216. what tb and maf setup & injectors??
  217. Lucas oil stop works..
  218. ARP Crankbolt Question.
  219. need to know the truth
  220. Low speed hesitation/knocking
  221. 06 243 heads on 98 ls1
  222. Rear pics of FAST 92 intake?
  223. Loudmouth I or Flowmaster american thunder 3'' all the way????
  224. What water pump for a 98 LS1?
  225. slp maf + diablosport
  226. Pulley Wobble
  227. volant question come in plz
  228. What headers are available to a guy in Cali
  229. bolt question
  230. As promised, my ebay header installation experience...
  231. mezere electric water pump problems
  232. Putting a cutout on this tuesday!
  233. Fast 90mm vs Fast 92mm TB?
  234. what causes the loud POP when the cars cold?
  235. anyone ever done sidepipes like you see on a 67 vette stingray?
  236. Rockers for MS4 Cam?????
  237. Damn Valley Cover Bolts....
  238. Bolt on question about HP.
  239. tuning codes out
  240. First impression of the new TSP 1-7/8" headers....
  241. FAST 92mm throttle body bolts
  242. Intake ?
  243. Anyonehave PICS of TSP catted y pipe NOT bolted together?
  244. what is so special about the bosch corvette 02 sensors?
  245. Flowmaster 1 chambers on SSS.
  246. What size injectors will I need?
  247. These Headers Any Good?
  248. Which exhaust is for me?
  249. f-body front o2s connector.
  250. Tb Help Asap!!
