- can i adjust the idle or wait for tune?
- FINALLY! edelbrock catback installed
- full exhaust gains
- FTRA install going horribly
- Baffled?
- Bell housing bolts
- Question about ls1 valley cover, timing cover and rear main cover
- Rear Main seal #$%&*
- Started Pacesetter Install
- Header flanges shrunk
- Stripped the tb blade screw!
- throttle bodies?
- Some Little Questions
- **What do you think**
- fab stock cats to a 3" y-pipe
- Is possible that header install lead to burning oil
- Any sponsors with the new Super Victor intake ??
- TSP TD's
- 99 Z28 catalytic converter question
- help! AIR blockoff screw broke
- Cruise control/TC box or module
- Whats the mm size of a stock 98-02 TB??
- can i put a 98 ls1 in a 99 ???
- What should I do?
- Electric power steering?
- Detoxx True Duals
- IAC replacement?
- EGR Questions with PICS
- o2 sensor unplugged
- Anyone running a 3" bullet in the stock location?
- Best Flowing HP muffler
- Cleaning Fuel Injectors..
- why does this happen?
- Headers and Catback too quiet
- advice on quiet catback
- Anyone actually prove hp differences between Borla plates?
- Do i NEED? header bolts and gaskets?
- Fast help please =(
- coolant temp sensor tourqe
- Difference between LS6 and LS2 intake
- Flowmaster Merge
- How can I tell????
- 90mm & stock heads
- Best set of Heads for a MS4 Cam?
- Exhaust slapping underside heat shield
- Thoughts on BBK LT's
- Those of you with FTRA Kit....
- Looking for porter
- 160 degree thermostat
- Can some one tell me who makes this underdrive pulley/balancer pics inside
- P1637, blown gauges fuse, burning smell!
- true duals and torque arms
- Which intake to buy?
- Intermediate Pipe Diameter
- Installed LS6 intake...
- Where to find Best priced ORY
- should i downsize from 4" to 3"
- coil/plug wire crimp terminals
- ??? about AIR removal
- Edelbrock LS1 two piece timing cover #4254
- Intake???
- Loudmouth Over Axle pipe
- Magnaflow install
- MAP Sensor Low Voltage
- EWP...gain more as engine power increases?
- Electrical Question
- !egr AND !egr tables...
- Misfire after header install
- Headers and y pipe???
- SLP Lid Problem!
- Couple Pacesetter Install Q's
- Ron Davis/be Cool
- 99 to 02 ss ls1
- Throttle Body problem
- 180* stat
- the best high flow cat
- Who else sells oval pipe
- Anyone run this 80mm throttle body?
- getting egr tuned out
- Airbox lid
- ditching the borla???
- ls6 or ls2 intake??
- Ya'll help me decide on this please......
- please help im going crazy
- Mufflex Questions, Users Inside Please
- mac mid, ory, dynomouth
- 3" Powersticks on my C5 Z06, pics and video
- SLP loudmouth
- LTS installed, couple of issues, can someone help
- Finished Re-P&Ping the TB (new pics)
- carbed 04 LS!
- Need your opinions for SS LS1 upgrades
- what intake set up
- NEED HELP - SLP LT Install
- Who ports FAST 90/90's
- 2000 A.I.R. removal
- Aftermarket Cat
- would silicone work for bbk tb gasket
- 2 Coils Not Firing.. Whats going on?
- fan trouble...
- air box delete options
- Ls1 Motor!!!
- Do vettes and camaros take the same ps pulley
- header ?
- intake
- true duals
- rear long oil pan bolt
- HELP. hooker y & slp headers
- fluttering sound after ls6 intake install?
- To X or not to X
- Tapping header block offs
- 408 AFR225 head gasket?
- Will stock ls1 exhaust manifolds work on ls2??
- Stainless Steel weld
- NW 90 TB with FAST 92?
- cats or no cats?
- removing cats
- Catalytic Conv. Question
- just finished header swap - check this out
- Painted the LS6 Intake (pics)
- How are the knock sensors wired into the harness.
- Crap! Need Advice, broke an Intake bolt off in the head!
- Should I get rid of my td's?
- Decision Time!! - FAST?? TB?? Filter?? Etc HELP!!
- What size bolts do I need to remove an SLP pulley?
- QTP Manual Cutouts
- BBK LT Headers and ORY
- 'headers' ?
- American Racing Headers
- Flowmaster CB question. I know, its different. Plus another question.
- WS6 Formula
- Question about FTRA Kit?
- Motor Install, Runs like crap, I really need your help!
- crankcase pressure
- My true dual, over-axle set-up (PICS&VID)
- ARH LTS install weekend wish me luck lol
- subframe connects Weld or Bolt on???
- Stroker Kit or shortblock
- ported and polished my TB (pics)
- Time for some new spark plugs
- F.a.s.t. Vs Wieand Intake Maniforld
- Supersprint vs Borla Cat back exhausts
- Lingenfelter...how long til the 58x to 24x converter box???
- Spark plug Gap
- Jet Hot LTs and Magnaflow 59959 CATS, who has done it/have pics?
- spark plugs... what ones are good
- tsp longtubes
- Are LS1 TB and LS6 TB any different?
- 99 C5 tranny problem
- quick question, nowhere else to go
- LS6 - what's it worth?
- New Plugs and wires
- carb hat for intake elbow on vic jr.
- 01 ls6 intake manifold on 01 ls1
- Need Help!
- Problems...need suggestions
- Lost big power and need help
- whats wrong???
- 02 sensor
- Going Over Driver Side Axle True Dual
- P&P Intake Manny,TB, and Head GAIN????
- 2002 Camaro CRACKED FLYWHEEL question.
- Which lt1 radiator??
- jet hot coating stainless headers..
- What mod should i do next?
- How to disable the security light? Gauge cluter is already out!
- 04 gto fan relay mod
- '98 Smog equip vs 2001????
- Clearing up misconceptions of PCV systems
- American Racing Headers dumdumdum!
- carb question
- EGR system
- Need help quickly with SLP lid
- question about my magnaflow catback...
- xs headers owners
- Port & Polish????
- TD Exhaust! What Mufflers?
- Cooling Issues
- porting TB and intake
- slp header question
- Slp Maf And Iat Relocation Harness
- Best Exhaust system w/ QTP Headers
- Exhaust help
- How should I go about modding a stock daily driver LS1?
- Has anyone had this happen to there headers?
- will camaro ls1 underdrive pulley fit 04 ls6?
- Fast and Map sensor?
- Pacesetter Headers Back In Stock!
- ORY off stock manifolds
- TA x-pipe true dual over both sides of axle exist?
- POLL -> My next mod should be? Help out here please!!
- Exhaust Problem
- 2002 Camaro Z28 oil pressure sensor install
- Any flaws in my summer plan?
- 85mm MAF for my 408... Opinions
- headers/ exhaust question inside.
- TSP TD and XS ... driver side collector problem
- Camaro :: Swapped from bullets to Magnaflow 4x9's
- Volant Intake on a SS hood
- eng sens fuse keeps popping
- Throttle Body Size Is there big enough?
- thermostat question
- O2 Sensor help
- Starter mods
- Exhaust Question
- Got E-cutout installed...
- Magnaflow A+++++
- Edelbrock in ls1 race
- What else can I do???
- Engine miss
- NGK tr 5???
- ENG CTRL fuse
- Who's got the quietest best flowing exhaust?
- Now true duals poses another problem if not done right
- LS1 header kits
- whats wrong with my car guys...
- Wiring Cutout Switch (Carling Tech.)?
- '00 SS water pump replacement questions.
- Any reason to upgrade from 1 3/4 to 1 7/8?
- Engine mount ?
- which manual cut-out should I get?
- intake question
- People that have actually bought ebay headers, get in here...
- 4" muffler
- Corburator stlye fuel injection manifold for LS motors?
- ls6 intake swap??
- Help! Hooker 1 3/4 or 1 7/8 Headers???
- Dynatech Split Flow Mufflers
- Different Tips on Corsa Catback-Need Help
- Kooks 1 3/4 or 1 7/8
- Any gains from adding SSRA lower box to FTRA upper box?
- True dual question..
- powersticks vs spiral flows
- 5.3 or 6.0l Vortec Underhood Fuse Box....
- 98 Accessories + 02 PCM/Wiring, Will It Work?
- Head question
- low hp?
- Installed my MAC girdle yesterday...
- Leaking power steering
- how to check coil packs?
- !AIR... no engine light?
- Exhaust Diameter of stock 99 WS6 catback?
- dumped at the exhaust manifolds??
- Intake Bolts Supposed to be Loose?
- Need a little help
- cut out on stock exhaust
- rough idle and miss
- Where do I get bolts for my GMPP carb style intake?
- slp pully belt SIZE, do i got the right ones
- which hose in the water pump is the heater INLET hose?
