View Full Version : Generation III External Engine
  1. slp pully belt SIZE, do i got the right ones
  2. which hose in the water pump is the heater INLET hose?
  3. adjusting throttle cable?
  4. header choice?
  5. Throttle Body Coolant Bypass
  6. Kooks 2" headers fit great
  7. Chipping an LS1
  8. Question about heads / cam
  9. Exhaust Hitting.. HELP!
  10. Which Thermostat ... 160 or 180?
  11. Can I tap into the heater hose flange for a water temp gauge?
  12. Car wont start??
  13. slp intake or K&N cold air
  14. Dipstick Alternative??
  15. bump stop too low??
  16. Best Bullet?
  17. EGR question(s)
  18. name those plugs
  19. What is needed to run an LS2 intake on a LS1 engine
  20. Slp Lm 1
  21. Looking for Part Number, PCV Y-Piece
  22. New Exhaust System
  23. SES light after header install
  24. thermostat,fan control, etc. Suggestions...
  25. Just smoothed (ported?) my throttle body...25 min job REALLY worth 3-5 whp???
  26. stage 8 header bolts, should i put anti seize on them?
  27. Sound clip: LTs, TDs, Sweet thunders!!
  28. Leaking Throttle Body
  29. powersticks?
  30. urgent mount help!~!~!
  31. Sweet! ARH + SS3600...
  32. Pulley installer
  33. Hooker VS. Magnaflow
  34. Post Your Pics Of Your PCV *NON LS6 VALLEY PLATE* W/ Catch Can
  35. MAF END's??
  36. Pacesetter LT's welds, anyone else....
  37. Hydrogen/gasoline hybrid kits for your car??
  38. factory spark plugs
  39. Best way to install crank key and keyed damper
  40. Thought I had broken exhaust hanger, this is what I found
  41. A/C question... How to install dryer.
  42. Had a question about wave lengths in 02 sims compared to 02 sensor.
  43. mass air/air temp adapter
  44. What to bolt on LS1?
  45. Cats off, I feel the diff.
  46. can anyone tell me if this is an fbody ud pulley
  47. i need some advice!
  48. SEX came in the mail today lol!!! ARH
  49. O so sweet!
  50. Need Help on what this part is!!!
  51. o2 problems
  52. o2 sensor question
  53. header bolts
  54. figuring out old motor issues.
  55. Help with high pitch whine noise
  56. FAST 92mm INTAKE PROBLEMS!! (NEED HELP ASAP)
  57. What is this picture of?
  58. PCV system help, routing and part numbers?
  59. Install Weekend! Pacesetter,ORY,etc.....
  60. Introducing The All New 1 7/8" TSP Long Tubes!!
  61. pics of my custom true duals under axle
  62. Daily driver lightweight battery
  63. cat bypass
  64. dual exhaust hitting somewhere over axle
  65. Who sells ARH Headers?
  66. KATECH tensioner for 1999 vette on a 2002 Z28?
  67. newbie with an LS1
  68. Switching exhaust...
  69. 85m typhoon versus 90/90 fast setup
  70. bosch corvette O2's or AC delco O2's???
  71. FAST 92mm setup
  72. fbody rear O2's vs C5 rear O2's.....difference??
  73. kooks vs qtp's
  74. CME tips
  75. Iridium vs. Platinum plugs?
  76. stupid catback removal question
  77. Who has MAGNAFLOW hi-flow cats?
  78. EGR Removal question
  79. Shut off switch?
  80. Got the SLP lid on... yikes
  81. Has anybody ever used these
  82. Which single chambers?
  83. My Exhaust Video: SLP LM1, TSP Catted Y, Hooker LT's
  84. White Smoke
  85. ac delco o2 sensors
  86. Can You Run Both, Jaam And Ftra?
  87. 85mm Lid?
  88. In bewilderment, please help! Pic inside.
  89. Long tubes with no tune?
  90. How hard is it to reinstall the A/C and Heater?
  91. professional products or factory ls6
  92. Tips on properly porting and resealing a FAST 92?
  93. Y-pipe - TSP vs Pacesetter
  94. Ported FAST glued shut? F that!
  95. Oil pressure/header install, moderator, please...
  96. fast 92mm question
  97. Pics of my TSP true duals under the axle
  98. Installed Corsa cat back..
  99. Where to get CME Exhaust?
  100. Why not just one cat?
  101. The right cam?
  102. True Dual Poll X or H
  103. B&B Tri Flow exhaust video?
  104. Can someone show me the difference between vette and f-body fuel rails, valve covers?
  105. hooker vs pacesetter
  106. after header install problem
  107. LS1, LS6 intake, pcv system? i did a search.
  108. Performance Header Coating Process (w/pictures)
  109. 02 Sensors
  110. exhaust leak?
  111. Mac Catback for a LSx, anyone have it or heard it?
  112. Exhaust Question
  113. Aluminum intake heat soak reduction test
  114. How to quiet an F-body with LT's and ORY??
  115. who DD w/ their katech tensioner?
  116. NGK Spark Plugs?
  117. Did i do good or what!!!!
  118. PS LT's installed. Link for writeup inside.
  119. Running like Crap!! Sputtering & popping thru exhaust
  120. LT1 catback on an LS1?
  121. magnaflow exhaust question
  122. LT's Y pipe and high flow cats --> SNIFFER TEST (I searched!)
  123. To cut or not to cut?(Ls6 intake)
  124. Corvette fuel rail covers.....what else do i need?
  125. What size is stock exhaust?
  126. LS2 intake on LS1 questions
  127. just bought 3'' stainless pipe, how much will shop charge to do dual exhaust overaxle
  128. Sound clips: ARH 1 7/8 + catted Y + SLP D/D
  129. ok guys need some help
  130. ws6 store egr delete
  131. Where can I...
  132. LS1 Fuel rail mystery hose...help!
  133. spintech muffler?
  134. LS2 intake manifold?
  135. Spark Plug Part #'s??
  136. Got my Gibson catback today
  137. Fast 90 Porting
  138. New Numbers for H/C/I LS2
  139. Broken manifold bolt! Help!
  140. water pump
  141. FAST 92mm Opened up to 100mm by Vengeance Racing
  142. cams
  143. Anybody know anything about these cheap throttle bodys?
  144. 98 camaro ss first mods?
  145. E-Cutout Input
  146. Rear End
  147. Cat-back or replace Stock Muffler?
  148. What psi is the power steering pump? And what line can I use.
  149. New Jersey exhaust set up
  150. im having problems with my 99 vette...help
  151. Performance Clutch
  152. Which Ram Air Setup?
  153. ordered my ARH Headers 1 3/4 catted y today, with free shipping
  154. SS exhaust smell
  155. Is there a thread comparing intake manifolds?
  156. SLP or Fast toys air lid?
  157. Should I go ahead and get an ls6 intake now?
  158. Oil??
  159. Problem with throttle body
  160. when do you need to tune?
  161. Pacesetter Mid-tubes?
  162. 2002 SD-455 Trans Am Tribute Car
  163. Headers?????
  164. Exhaust rub.. Need ideas
  165. Loudmouth with borla muffler sound?
  166. what all for puley install???
  167. egr
  168. Normal voltage at idle? P1637
  169. MAC cats/how do they flow compared to stock..
  170. how to tell a u/d pulley?
  171. is this an LS6 intake
  172. AEM Longtube Headers?
  173. tsp catted y ?
  174. New Weiand intake this summer Street Warrior??
  175. Dyno results from lpp headers
  176. Duals or not?
  177. Which headers to get
  178. Are there different depth crank pulleys? Mine is not long enough?
  179. Jet Hot Longtubes 1/78
  180. my camaro ss traction control
  181. LS6 vs LS2 intake
  182. pacesetter Y hitting the floor
  183. LS1 fans question
  184. TSP catted y-pipe...should I add rear o2's?
  185. Fuel Guage not reading fuel level correctly
  186. OEM waterproofing tar gunk on PCM connection?
  187. Headers
  188. pcv valve tube....where does it go???
  189. Not Compatible on a Auto Trans Conv. ?
  190. exhaust leaks
  191. A/C dripping on header tube?
  192. Rear End
  193. E3 Plugs?
  194. PS LT's installed! Some after-install help needed. Thanks
  195. What would cause this??
  196. O2 Sensor's Question....
  197. squeak noise
  198. because no one made an adaptor
  199. Gears Or LS6 Manifold
  200. high flow cats
  201. corvette O2's
  202. Magnaflow True Duals W/ PICS
  203. ls6
  204. Fast or PTM Throttle Body
  205. hp/tq guesstimation
  206. to block off or not to block off
  207. oil pan rear bolt part number
  208. Raptor light installed, at what rpm do i engage the light, mods inside
  209. catted y or ory with lm1
  210. band clamp
  211. just installed my LPP longtubes
  212. real quick ques. maybe an hour to completion PS LT's
  213. Need Some help Quick!! Please read
  214. best place on exhaust to measure AFR??
  215. QTP Lt's HVCL and AR Y?
  216. ls6 intake difference
  217. kooks ory NEED HELP ASAP!
  218. SLP Loudmouth I Resonator vs Moroso Spiral Flow
  219. How much More HP is Fast Intake VS LS6
  220. Grrr. Creeping cooling temp???
  221. New O2 Sensors??
  222. Need to find my cats
  223. I phoned lingenfelter and....
  224. Just out of curiosity, those with PS LT's,??
  225. exhaust setup
  226. 99 v6 camaro
  227. installing my pacesetter LTs
  228. Dumb exhaust question
  229. SLP LMII Question....
  230. DYNO results - MACs to ARH 1 7/8 headers
  231. How's the port match look on my fast 90?
  232. Why should I upgrade from a stock harmonic balancer?
  233. L92's... What cc are the intake runners?
  234. msd wires and ohm resistance WOW!!!
  235. Heads, Cam, and other opinions.
  236. Headers Question
  237. going from MACS to LT's is it worth it?
  238. Help me out with an exhaust leak problem...
  239. ?
  240. bent o2 sensor
  241. what could cause this?
  242. Intake manifold.
  243. Best Gaskets For Qtp Long Tube Headers?
  244. Does anyone make a 90mm Lid?
  245. where to buy ls6 egr adapter? - besides LPE?
  246. Knock sensors harness???
  247. L92 Swap into a Fbody, None of the PASS coils firing?
  248. LT install question
  249. Header Question????? Please Help
  250. hooker comp vs super comp headers
