- Installed Mac mids today...
- where can i get a ported ls2 intake?
- Can it be done?
- Street Warrior Intake
- EGR mounting bracket bolt size/pitch/thread?
- Spark Plug Gap
- LT's and a Lid?
- EGR Question
- R.W.H.P. with bolt ons?
- Is this a good lid?
- Shiping Question Please Help
- I think I have it figured out so looking for true duals and long tube headers help
- Any one have any info on porting a 78mm fast intake?
- True SLP Center Exhaust 2002 Camaro SS...
- True Duals
- TCS Problems
- Is their any link between cyl. 5 & 4.
- FAST 92 question
- Quick Bumpstop Mod Ques
- ASP Pulley with Katech tensioner walking??
- Need tips on cleaning the Throttle body and Air-intake
- 90MM TB (BlueMaxx) to Intake Bellow
- What diameter tubing for bellows?
- TB Question
- Anyone know how to contact PowerBond???
- true duals fell apart
- Which is louder on F-body: Magnaflow muffler or Hooker Aerochamber muffler?
- Powersticks... or... Powerpacks?
- CrossThread header bolt hole on head. Fix questions!
- Header Fitment Question
- Painted a few things for the new motor
- GP on coil relocation kit!
- How does the fast 78 intake stack up against the ls6 intake
- Mufflex LS1 F-Body Y-Pipe Bumpstop Hanger
- Do you have to do this?
- What part is this?
- slp air induction?
- prothane mount bushing stands?
- tubular k-member and 6.0 lq9
- What do you use to best attach Earl and other fittings?
- CC exhaust inserts?
- Should i switch back to ngk tr55's????
- least loud catback/muffler in your opinion?
- confused, cylinder #2 and # not firing but no cel
- Need a little help with the car
- How do I clean the MAF ?
- best muffler for true duals
- headers swap. do the motor mounts? how hard is it?
- I <3 my Hooker Headers
- A/C prob
- Engine wont crank after driving in the rain.
- Y-Pipe
- **NEW** BBK LT's, and ORY **LOT's of PICS INSIDE**
- rear main seal
- Exhaust Fumes stink! any ideas?
- 160 thermostat
- Official LPP Header watch thread
- New Intake?
- Pulley
- clutch knocking
- SLP LM1**LT's**ORY**CAM**HEADS**
- Lowered/dual/trak pak help
- FAST Intake (90/90) install question (exp. installers inside)
- Underdrive pulleys?
- Dart Pro 1 ls1 heads,Any opinions
- NGK Tr-5 = NGK Tr-55???
- ls6 swap info....
- Cost of custom ORY??
- 90mm FAST supporting mods?
- pics of my kooks collectors inside
- Bassani BX57003 Y-Pipe with Cats
- Dumb question...how do you install SLP's fan switch?
- (AIR!) Will code show up?
- Who offers a cable driven ls2 throttle body?
- torque specs for my build
- Odd rattle when engine shuts off
- Now i got a catch can...Where does it go???!
- Cats for a diesel appplication?
- S. Plugs
- OEM GM or Aluminum Gaskets. Please Help
- SES code P0430
- vacuum issue
- Ls6 intake swap
- Question for the guys running 85mm and larger throttlebodys/ intakes
- keep the duals or go back to y and muffler
- my t/ds got pic
- bellows size question
- question about tsp true duel and tsp t.d. or Borla with off road y pipe
- Will this run well together??? (Intake)
- Bumpstop Woes
- oil sendor?
- Opinions on Moroso Spiral Flows
- Welded true duals guys step in...
- Exhaust pulse
- Freeze plug in the head question
- Fuzzy Header gaskets?
- Hooker LTs & OR Y
- I bought a intake off a blown motor!! Part 2
- Electric water pumps
- car wont start after header install
- wht do you guys think
- Wix Oil Filters......
- AIR and EGR Removal - Quick Question
- What is the best sounding exhaust?
- Throttle sticks with car on
- Pic of QTP's ORY with cut outs wanted..
- Carb setup for LS1
- CAI vs LID
- Free Ram Air Mod Vs SSRA/FTRA
- oil pressure
- Just order QTP's which ORY to buy?
- Should I atempt?
- HELP!!! Car goes straight to REDLINE on Start-Up!!!
- Sound clip and exhaust set up help.
- AIR Hose Removal
- I need a sound clip help!!!
- Next batch is in!
- 5.3 Upgrade
- stripped header bolt hole!!
- Please help on SLP ls6 intake?
- Who has a good replacement radiator for the T/A's
- is it worth coating a set of used Kooks?
- is it worth it...
- Car Wont Start
- Changing up my exhaust
- Got Mach Up Done!!! :::pics:::
- Fast Toys Ram-Air w/ SLP Lid (stock MAF) Any issues?
- Racetronix reliability?
- Would this be a bad idea?
- Electrical problem
- TB question
- Extending TSP Duals out the back....
- cant get dipstick back in
- Longtubes - burning oil
- header ground clearance
- What do I need to do about a throttle body
- 92 FAST Intake & PTM 92 TB??
- Tsp True Duals Owners
- Which MAF
- Quick Question about my Lighted Cutout Switch
- Small Basic Tips For Installing an Electric Cutout
- Texas residents....
- Need some info on the profesional products intakes
- best spark plugs to use?
- headers are in
- Victor Jr swap...
- Weld or clamp Exhaust?
- Edelbrock Shorties + Bassani O/R Y installed
- does the pacesetter ory fit kooks headers?
- air removal
- is flowtech's y pipe a 3" ?
- Problem with AIR block off plate ... Need help
- Thinking about duals on he the cheap
- xs header question
- Exhaust Question....
- Actual Head Size?!?!?!!?
- Fans Direction...
- Missing anything?
- had spark plugs replaced - now have ticking noise and somewhat low idle
- Pacesetter LT install ?'s
- LS 1 starter Wiring Solution for A body Ignition
- slp maf question how to figare out which one you have
- LS 7 Exhaust Manifolds Value
- **HELP***How Do I Get The Wiring From My CUTOUT Into My Car?*******
- The Best Maf
- True Dual Help Needed!
- ls1 and ls2 water pumps interchangeable?
- Need pics of newer style water pump ASAP!
- just put poly motor mounts on, can I leave the heat shield off with LT's?
- MTI Throttle Body Help?
- American Racing Headers....ATTN!
- How to remove LS1 Balancer 99 FRC C5
- Misfire only at idle...?
- do slp h cats have a carb #
- cam finally found idle video inside..
- guys with strokers post yall soundclips plz
- whats the best sounding exhaust on a stroker set up
- Will LT's make a big difference?
- Can I put a WS-6/SS lower intake on stock Z-28
- SLP LM Exhausts Not on SLP site?
- mac headers questions
- Does the new fast 92 throttle body work w/ the old...
- Hooker CB, Hooker Supercomp LTs, 3" ory
- QTP elec. cutout help needed.
- Help!!!!
- anyone heard of TPIS
- need to quite my car down
- PAGING: Tracy at RevXtreme
- best Lid/MAF/TB/Intake combo?
- American Racing Headers Review! Super easy install!
- Aftermarket truck intake manifolds
- Quick ? guys, 6.0 and cam Heads
- Headers/Exhaust Help!
- TDīs Installed / Sweet thunders
- Corsa exhaust, what's it worth?
- F1 Racing flywheel!! For all who wanted to know..
- Need an estimate on a exuast job...
- Any pics of UMI Throttle Bodys?
- 02 Sims ??
- Header install cost
- plugging 02 bungs
- why torque through bolt and nut??? motor mount install
- Dumped exhaust question
- Stock LS1 Head help
- O2 sims
- LM1 Bullet-Magnaflow
- 6.0 to a 4l60e
- air bullshit junk
- idle change with header install
- cam help
- H/C swap questions
- What is this part number, picture inside...
- Quite bullet muffler?
- installed headers. cars missing.. please help!!
- What's this connector used for?
- 408 big cam 13.1 comp. too loud!!!
- American racing headers?
- SLP LS6 Intake Manifold for 1997-00 LS1 Engines
- Katech Valve Covers & Stock Fuel Rail
- over axle pipe
- 92mm TB on a 90mm FAST
- MSD Wires ????
- Broke a sensor. Need Help!
- What goes here? (pic)
- 2 questions
- Will Jet-Hot Coated Headers Rust?
- A/C delete pulley for ls engines?
- Time To Get At The Gettin' At It
- Need advice on an exhaust overhall package... Please help me...
- LT1 Intake Air Duct Stem Thingy
- My jet-hot pacesetters
- how hard is it..
- Please Help Guys Mid Or Longtube Headers
- For header install?
- Cats.....
- Exhaust Pop/Backfire
- ARH Banging issues???
- Water Temp Gauge issue
- Help Please!!
- How to check coil packs?
- has anyone bought the z06 85mm MAS from advance auto parts?
- Custom TD's with cats, Edelbrok 304
- Muffler CFM, how much?
- U/D Pully?
- exhaust piping size??
- ? about fast intake,injectors,cam?
- Should I change My spark plug wires?
- Cleaned up engine bay a little with AC delete panel
- Stiffer engine Mounts??
- 90mm nw w/elbow
