PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315
  1. Expected horsepower and torque??????????
  2. CAI help
  3. will the throttle body be ok this way?
  4. centerport exhaust
  5. Mac Exhaust Good deal?
  6. Losing power in the 3k plus RPM range...
  7. Another CAI thread...
  8. who makes cylinder head plates (like MBA) with "LSX" on it?
  9. $1,300 Worst Bolt On EVER...
  10. Thread size
  11. True dual mufflers
  12. Coil?
  13. What cutout to get??
  14. Where to mount oil temp guage sending unit?
  15. Weiand Manifold installation question
  16. Should I get a Cutout?
  17. Edelbrock Valve Covers
  18. who sells a nice vented catch can?
  19. 2000 engine harness in 1998 car?
  20. 4-barrel Throttle body!!
  21. What's the best flowing QUIET Catback these days?
  22. Grotteyham lt's and kooks ory?
  23. LS6 IM swap on 99 T/A
  24. KRC Steering Pump
  25. 317 vs. 243... question
  26. intake?
  27. Spohn Solid Motor Mount install?
  28. waterpump swap help
  29. SLP Loudmouth muffler replacement???
  30. Deleting AC
  31. H/c help
  32. I think my steering rack is going back squeeks when I turn the wheel
  33. P&p throttle body
  34. FAST 104mm
  35. P0135 p0155 p0102
  36. Gasket Opinons
  37. exhaust cut out
  38. Best intake when it comes to nitrous use.
  39. Alternator Issues
  40. How can I get this thing running?
  41. cutout nut?
  42. Gibson Exhaust Fit?
  43. Which Exhaust
  44. throttle body question
  45. Traction Control Light?
  46. Which SLP exhaust do I have?
  47. powerbond
  48. What TB to use
  49. Temp sensor problems
  50. JAAM Ram Air Worth a Tenth?
  51. ***update***
  52. modifying ls6 intake to 00
  53. Seals for ls6 intake mani
  54. What catback with ARH? Not happy with GMMG.
  55. Weiand LS1 Intake?...
  56. Can you safely drive a bolt on car without a tune?
  57. Spark Plug wire help?
  58. Volant CAI vs. Lid....
  59. Quieting duals
  60. 2.5" y-pipe vs. 3" y-pipe
  61. 243 LS2 heads on LS1?
  62. Dremel for porting aluminum intake mainfold?
  63. Muffler and X pipe-anyone run this
  64. help me pick gauges
  65. Magna flow merge?
  66. Installing long tube headers on Camaro
  67. Kooks Stainless vs. Hooker coated 1 7/8"
  68. Vacum leak code?
  69. Exhaust Setup
  70. QTP exhaust leak (mad)
  71. Muffler Options
  72. cylinder #6 misfiring
  73. Gmmg
  74. throttle body ???
  75. where is the cheapest place i can get a magnaflow muffler
  76. FINALLY!!! Clips of TDs
  77. ls1 powersteering pump
  78. cut out pics
  79. From True duals to catback w. cutouts
  80. My idea for true duals over the axle
  81. Low voltage?
  82. SLP MAF on LQ4
  83. Accufab 75mm TB?
  84. Issue with alarm/no start...help!
  85. ARH prices
  86. SLP LM1 and LT Headers, Too loud?
  87. Rear Main seal ???
  88. ANybody have real back-to-back H vs. X numbers/times?
  89. Resonator/cat question
  90. v-clamp for headers
  91. Who knows this? Where can I get this bolt? I need help!!!
  92. I just bought a neapco brute stength u joint.
  93. Cutouts
  94. Vacuum Hose Location
  95. I did a top end cleaning and it took almost 2 cans
  96. All four 02 sensors useable in different locations?
  97. TB coolant bypass!?
  98. Volant fitment and pics please!
  99. Removing parts need help !
  100. Almost done with my MS4 install, but... (radiator)
  101. GMMG with Corsa tips
  102. Hmmm ebay underdrive pullies are same as SLP, listed for $115 new
  103. starting issue
  104. throttle cable?
  105. 2 muffler question
  106. flowmaster 40 series
  107. ceramic coated Y pype ?
  108. Will stock TB work?
  109. LS6 PCV delete
  110. Removing A/C System
  111. Alternator problem
  112. Valve COvers??
  113. Header install, wrap Clutch hydraulics due to heat?
  114. Pacesetter headers with AIR/EGR
  115. Old Dynatech Headers Pacesetter Y?
  116. LPP sale extended.
  117. Fast 90 advice...
  118. need help, car missing bad!!!!!
  119. Gen III vs Gen IV
  120. what about the LS1 Edelbrock Intake.....?
  121. Which mufflers
  122. please help power steering problem
  123. CTS-VR headers
  124. My pacesetters took a shit!! PIX inside!!
  125. Header Help Needed
  126. fbody blackwing bellow?
  127. Opinions on this exhaust.
  128. Got my hookers
  129. question for those who have LT's
  130. WTT: Nitrous kit for 3" exhaust.
  131. Anyone tried the RPM underdrive pulley?
  132. Texas-Speed Rumbler 3" cat back?
  133. Burnout Videos!!!
  134. JAAM WS6 Ram Air Kit Sale!
  135. ignition and electrical problem
  136. which cats for mac mids ory
  137. Harmonic Balancer Flew off!?!?!?
  138. best lsx intake chose ? fast , ls6 , weind for blower n20
  139. Power loss and backfires afer exhaust install
  140. Coolant through intake
  141. Suggestions on getting car up in air for header install
  142. Stroker Build Coming Along/Pics
  143. Will this 85mm throttle body work with my Holley/Weiland intake?
  144. trickflows + ms4 ptv clearance
  145. Patriot stage 3 heads 6.0 Cam choice???
  146. sounds like a corvette??
  147. couple fast 90 install questions
  148. Fuel Pump on it's way out... Hesitation at HIGH RPM...
  149. Jet Hot LT's installed
  150. Anyone know where I can get this piece?
  151. Header Install Problem
  152. Sound deadening advenures... New tips... (Just read)
  153. MAC headers discontinued? What to do.
  154. Bullet
  155. Issues getting crank bolt out... Help with Ideas
  156. Alternator
  157. Coolant Sender Location - FINALLY FOUND!
  158. Msd Super spark coils and Random misfire code
  159. Pacesetter long tubes rusting
  160. My SES light keeps coming on. HELP!!!
  161. Wont start!!!! Out of suggestions!
  162. loud ticking PLEASE HELP!
  163. Fuel rail fitting
  164. Is this a Head Gasket Problem???
  165. Anyone using Dynatech 1 7/8" Headers w/ slip on collectors?
  166. If and when my fuel pump goes should I go with stock?
  167. Exhaust Shipment
  168. supply/return on water pump holes???
  169. When is a 3in true dual needed over a 2.5in?
  170. race muffler off the header?
  171. March vs. ASP Underdrive Pulley Questions
  172. ABS module question
  173. ported throttle body
  174. fuel pressure regulator
  175. Need to tune a car after, short or mid tube header install?
  176. Polished BBK intake?
  177. exhaust help
  178. Drive By Wire Throttle Body ? for a LS6 Motors
  179. ARH 2in race header and 4in race muffler sound clips
  180. Please help!! Fast 90 worth it?
  181. 90mm air lid?
  182. how hard are motor mounts to put in on an F-body?
  183. can anybody post pics of your cme from under the car
  184. Scored a TSP true dual Set-up today
  185. accessory drive part # and cost?
  186. ls6 intakes
  187. Any sponsors have plans to do real world testing on the F.A.S.T. vs. Street Warrior?
  188. Aftermarket 90MM DBW TB??
  189. has anybody tried 2 port a fast 90 2 100mm?
  190. questions about 317 heads
  191. stock air lid modification
  192. thermostat
  193. stock exhaust??!!
  194. hidden coil valve covers
  195. tsp tds hang to low
  196. clunking/banging noise when spinning out/shifting
  197. Atlanta area tuners
  198. cam spec question?
  199. 1998 AIR Quick question??
  200. Removing intake MAP fitting?????
  201. early xmas - ar headers!!!
  202. GMMG tube sizes? length?
  203. What to use to cover battery
  204. Need help
  205. Oil Pressure Sender Threads?
  206. Injectors?
  207. VIC JR & Aaron Elbow owners
  208. New exhaust set up
  209. wheres the new weiand intake?
  210. intake install ?
  211. #5 Has Water....F*CKING PISSED
  212. Oil catch cans
  213. O2 Sensor(delete)
  214. what is a good fitting Y pype
  215. headers?
  216. Leaky Meizere EWP? Picture inside
  217. PTV clearence on 5.3l heads?
  218. new SLP ceramic coated give off less heat ?
  219. I Have a very Strange Cooling Problem
  220. Is this normal?
  221. SLP Underdrive Pulley
  222. emergency brake adjustment
  223. ls1 stainless headers on ebay.....
  224. LPP performance part headers? anyone running them???
  225. trying to change my exhaust note!!!!!
  226. which headers
  227. 2004 Ls1 Head Bolts??? Mid-year change???
  228. smaller pulley
  229. Weiand intake ?
  230. Help with gauges on swap
  231. How much will this combo make
  232. 2 Borla mufflers in-line = QUIET?
  233. True Duals Back In Stock at Texas Speed!
  234. X-merge before cats or vice-versa?
  235. ARH Exhaust
  236. MAf sensor quit working. any quick fix tips?!?
  237. Which spark plug wires?
  238. BBK SSI Intake Discussion
  239. MotoBlue UD Pulley?
  240. under drive pulleys
  241. quick heads ?
  242. Quick ?
  243. Should I trade my Hooker Catback + Cutout for Under the Axle Duals w/ XR1's?
  244. more questions about ebay headers i know...
  245. Lid
  246. Long tubes ory flowmaster cat-back
  247. MAF sensor questions
  248. Flowmaster merge..
  249. horse power help
  250. Will this work...
