View Full Version : Generation III External Engine
  1. I Pipe Modification
  2. Anyone try these bullets?
  3. Bolt ons opinions please!!!
  4. Which intake should I go with?
  5. best ls long tube headers for the $$$??
  6. FYI - Mr. Gasket MLS vs OE Header Gaskets
  7. Where Can I get IAT Sensor Grommet and AIR Grommet?
  8. Different x-pipe types?
  9. Need Some Help Finding EGR Parts
  10. QTP e-cutout fuse keeps blowing
  11. ok to put new heads on before installing balancer?
  12. Tune issue or dying fuel pump?
  13. Suitable Air Lid
  14. eBay stainless true duals are on the way. need muffler suggestions.
  15. Infamous Exhaust Leak?
  16. Hawks Sinister 4 inch exhaust?
  17. FTP Clear 98 & 104 Air Lids - You asked for it - Limited Production Run!!!
  18. what fuel rail is this??
  19. 72 C10 Motor mount LR4 with AC
  20. Building DIY Exhaust Backpressure Gauge
  21. 1 3/4 vs 1 7/8 headers and ORY what's deciding factor in correct size.
  22. Best Electric Cutout
  23. LS6 swap now SES light? UPDATE: o2 help please
  24. ls6 or fast?
  25. My "empirical" testing of the SLP/Powerbond pulley
  26. True Dual Duals Build
  27. Tach?
  28. SLP Headers to Kooks swap
  29. NEED HELP ASAP!!! - Best way to remove harness with motor still in car
  30. LS6 swap complete now what TB?
  31. What size threads in ASP Crank Pulley
  32. Throttle body help
  33. in the middle of heads and cam swap have some questions
  34. which exhaust do you think flows better????
  35. ls1 coils to ls3 coils?
  36. 5.3 swap... more problems...
  37. Having weird O2 sensor issue. (Advice)
  38. Want my camaro to sound like a mustang
  39. Reinstalling engine...what is this?
  40. balancer already pinned???????????
  41. ORY + QTP Header Options
  42. Thicker Intake Manifold Gaskets (rubber oring style)
  43. HELP Fan Belt squeak
  44. Replacing oil pan gasket (price)
  45. Intake bolts tightening
  46. bbk header help
  47. Anyone plumb a line from d/s valve cover
  48. tps fast throttlebody
  49. Built motor ls1 pcv sucking up a lot of oil?
  50. Damn ! Bolts rung off in heads !!! ?
  51. tsp 1 7/8 vs pacesetter
  52. fast replacement intake gaskets
  53. camaro longtubes on c5?
  54. LQ4 build cam specs?
  55. rx dual valve catch can plumbing help
  56. ls2 intake swap
  57. Heads and cam for my new motor
  58. Questions about LQ4 build
  59. Poly engine mount orientation
  60. Attempted to port an extra TB i had earlier
  61. Throttle Body Help for 102mm Fast
  62. Another high idle thread...
  63. Misfire solutions
  64. Dbw issues---first post
  65. 98mm ftp lid
  66. Ls6 intake questions
  67. 102mm NW TB on 96mm Typhoon?
  68. more idle issues....yay
  69. MAF Question
  70. Fast 92 on LS1 Gto
  71. reverse locked out, no ENG SENS fuse blown
  72. thermostat for bosch water pump 99175
  73. msd 2 step problems
  74. 370 lq9
  75. GMMG CME Setup
  76. kooks headers question
  77. Wanting to buy coil pack LQ9 6.0
  78. adding ignition timing
  79. FLP headers/ what Y pipe fits?
  80. Raising Compression Question
  81. Exhaust Leak
  82. Edelbrock Vic Jr EFI / PCV Question
  83. Ls6 valley cover and intake doesn't fit
  84. MAF Question
  85. cross threaded rear header bolt.....
  86. :::Setup for Success:::
  87. Torquing head bolts ???
  88. what plugs and gap for my 4.8 with big cam
  89. trying to find y pipe bracket
  90. SLP Loudmouth tips?
  91. Intake question
  92. What Next?
  93. P0430 - opportunity to spend some $$? Catback, y pipe...
  94. Replacing knock sensors, an wire, but will I need to replace the intakes gaskets?
  95. Bad harmonic balancer on my LS1, which to choose?
  96. To tune or not to tune?
  97. ? Im lost ?
  98. please help me find where this goes!
  99. Am I full bolt on yet?
  100. exhaust QS
  101. 5.3 build project mentor needed
  102. Will LS1 Coil Packs Fit/Bolt onto Stock LS3 Coil Pack Brackets
  103. why does it sound like there are birds in my exhaust?
  104. oil psi sending unit ???
  105. Coil packs with heatsinks?
  106. Summer Is Coming, Time To Build!!
  107. LS1-LQ9 differences?
  108. v6 starter in ls1?
  109. LS6 Intake Manifold Experience
  110. slave cylinder issues
  111. Stock manifolds
  112. Whats the best replacement alternator????
  113. Anyone make an adjustable throttle cable bracket?
  114. exhaust gains
  115. Father Son and College.. Opinions
  116. K-member drop
  117. K&N vs Flowpac
  118. Best place for O2 Bung for Wideband
  119. Kooks headers-cats+slp=aweful
  120. Turbo'd set up with no pcv... why?
  121. 5.7 to 6.0
  122. Installed electric cutout on Borla exhaust...
  123. anyone try one of these intakes?
  124. Clutch kits Recommendations
  125. 90mm lsx intake
  126. nitrous plate + 92MM TB what are you guys using for bellows?
  127. Tach question
  128. out with the old, in with the new!! update videos!!
  129. 2.5" or 3" for my true duals?
  130. TSP 1 7/8" LTs quick question?
  131. Anybody go from headers to muffs w/ turndowns?
  132. just swapped knock sensor question
  133. Another Exhaust thread(Cat back)
  134. Power steering reservoir hits iac sensor
  135. Hooker aero chamber
  136. Kooks Headers Unboxed- With and Without Coating and mid pipes!
  137. Need to tame my exhaust!!!!
  138. wiring up a cutout
  139. MSD 8733 OR Lingenfelter LNC002 2-step modules
  140. Ebay valve covers?
  141. NAPA Radiator
  142. throttle body adaptor help 90mm to 102mm
  143. TSP ORY Question
  144. Low Voltage Code Challenge
  145. whats the sence of having a borla or lm exhaust
  146. Have a few ?'s about air intakes.
  147. Long Tube Headers and offroad Y o2 sensor problem
  148. LT1 Lanes True dual system to LS1 car?
  149. Is my BBK now scrap...
  150. oil pressure
  151. Spark plug range?
  152. 1st-2nd vehicle dies issue?
  153. TSP 1 7/8 Headers with Pacesetter Y Pipe, Might it Work?
  154. 243 header bolt size?
  155. How to Make Stock Temp Gauge Accurate??
  156. 160 Tstat??? YES or NO??
  157. EGR/AIR Removal
  158. 1 wire vs 2 wire oil pressure sending unit
  159. Budget 6.0 build
  160. OBX headers to TSP 1 7/8 headers.
  161. best h/c/i setup
  162. Ported TB worth the $?
  163. Head valves
  164. Deleting ac, need help.
  165. New TB Issues..
  166. JEGS W89711 Pulley Removal/Install Tool?
  167. Is this a vette style WP (pic)
  168. Anyone have a powerstick muffler w/ cats soundclip? I did search.
  169. Edelbrock 90mm TB worth the savings??
  170. LS6 Slp intake.
  171. need help with picking aye muffler???
  172. Floor heatshield after long tube header install??
  173. harmonic balancer won't come off ???
  174. fuel rail leak
  175. What size belt for powerbond 10% under drive balancer??
  176. x-pipe duals muffler choice
  177. Connecting DBW to LQ4
  178. My LQ9
  179. LS6 to F.A.S.T. 92
  180. A/C problem
  181. Starter not lining up with flywheel?
  182. Good Deal?
  183. Doug's headers electric cut out...
  184. Squeeling Noise
  185. Questions about lq4 with 241 heads..
  186. What air boxes fit SS hood?
  187. what throttle body for ls6
  188. Magnaflow Cat Worth More Money?
  189. underdrive crank pulley ???
  190. TBSS Intake on LQ4 fuel rail question
  191. A/C compressor rebuild kit?
  192. Cooling Issues
  193. fuel rail plumbing advice
  194. Have your Throttle Body ported by Peak Speed Shop!
  195. Ported TB
  196. 4" over the axle pipe
  197. Intake manifold nightmare
  198. How much do y'all think this will run me
  199. Ta radio stuck on lock!! Need help
  200. L33 ECM help
  201. Do I need a tune?
  202. Exhaust Setup/ CME / QTPs what a Steal!!!
  203. e85=Cornmaro or not to e85=Camaro
  204. Magnaflow replacement for SLP dual dual
  205. wiring harness question please help
  206. Air intake? Car runs horrible?
  207. Intake swap
  208. LQ9 Water Pump Gaskets
  209. How can I quiet my exhaust?
  210. electric water pump pcm control?
  211. throttle body won't open all the way
  212. What do you guys think?
  213. 2001 truck harness on ls1?
  214. Is my exhaust setup restrictive?
  215. Moroso Air Oil Separator
  216. Question about small flange on side of header tube
  217. air & egr delete questions
  218. starter problem
  219. Need Help Deciding How To Upgrade My Exhaust To Support My 408
  220. need help with exaust 2000 ta
  221. FAST LSXR 102 - lower oring ls1 style injector
  222. Tpis 90mm throttle body
  223. Transmission to engine size?
  224. Low iac counts
  225. MSD Wires
  226. How Long Did Your Cutout Motor Last?
  227. What will I noticed upgrading motor mounts?
  228. Corsa Tips
  229. my magnaflow only flows thru one side
  230. exhaust tips?
  231. Slp CME question
  232. injectors
  233. Any1 here running a cam only LS6?
  234. Help fast!!! Car missing In rain!!
  235. Meziere water pump accessories help needed..help please.
  236. What TB for FAST 92
  237. Ebay Stainless True Duals vs TSP True Duals
  238. Getting air out of cooling system???
  239. pacesetter ory VS tsp ory
  240. Need 35# injectors
  241. IAC Prices???
  242. anyone ever use this throttle cable bracket?
  243. need intake solution for SD tune
  244. TSP bullet length
  245. MAF Delete pipe
  246. i shit you not:
  247. Cat shaped resonators
  248. Spark Plug wire observation
  249. Best high tuck/clearance offroad y-pipe? f-body
  250. 02 LS1 with EGR Plug....
