View Full Version : Dynamometer Results & Comparisons
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
  1. 402 with TFS 235's
  2. 91mm turbo dyno
  3. Help me with dyno numbers
  4. Speed Inc. 2010 SS TVS2300 results
  5. Someone Help me understand these low dyno #'s please..
  6. 404 LS2 dyno results...
  7. home ported fast yields big #'s
  8. 08 vette, novi 2200, ARH long tubes w/cats
  9. Another Va Speed mild combo
  10. dyno results
  11. Thunder Racing 427CI LS6/TH400 Chassis Dyno Results
  12. Speed Inc. G8 cam only results
  13. Do my dyno numbers seem correct
  14. super victor victor jr back to back?
  15. AFR 205/6016 cam...475 rwhp 425 rwtq
  16. Is 482 on a Dynojet good?
  17. LEP G8 GT TVS2300 8psi 552WHP!
  18. AFR 205's and Patrick G cam dyno results
  19. Lpp headers and Lid numbers not to bad..
  20. Low dyno numbers w/ 228R
  21. 6.0 ms4 ported 243s 431whp
  22. Dynoed H/C AFR's. I wanted more though!!
  23. 05 GTO+Va Speed h/c/i=520rwhp
  24. A4, Lid and catback dyno numbers
  25. 2010 camaro SS2 cam, intake, exhaust
  26. pretty happy with dyno run 403hp
  27. Tune alone picked up 21 rwhp and 40 ft lbs of torque!
  28. Dyno flatline
  29. 2010 Camaro SS ARH CAI TUNE
  30. disapointing dyno today
  31. Finally got the car to the point it needed a Dyno Tune...
  32. RR-STRIKER CAM - Check it out(Vid & Graph)
  33. Not All 224 Camshafts Are Equal... Engine Dyno Data INSIDE!!
  34. 408ci,L92 heads with Cary's carb intake #'s
  35. Dynoed the car yesterday at EPS. Can't wait to hit the track
  36. My new dyno pulls LS2 with all the fixins and a 2 stage
  37. rainy day vs. sunny day dyno #s
  38. lq4 short block w/ stg 3 heads
  39. Geoff at EPS is the man!
  40. Dyno Results - 3rd gear vs 4th?
  41. Dyno Tune Complete Happy with Numbers!
  42. 383 Question
  43. Why is there such a big difference in dyno numbers?
  44. Dynoed the UPD lid vs the fast toys 85mm lid today.
  45. Race Proven Motorsports 580rwhp 520Tq CAM ONLY!!
  46. Vengeance Racing Stage II Performance Package Idle/Drivability/Dyno Results Inside
  47. RR-STAGE 5 LS2 ECS Kit
  48. ls3 416
  49. Dyno tires
  50. Good tires to use on the dyno for high HP cars
  51. 6.0+vindicator idle+ls6 to ported fast setup=463hp
  52. C6 ZO6 Vengeance Racing LS7 II Cam + Boltons Numbers
  53. C5 ZO6 TSP Tsunami + PRC Stg 2.5 LS6 Heads + FAST Intake + Boltons Numbers
  54. 1999 z28 a4
  55. '02 Camaro SS M6 458rwhp/421rwtq !!!
  56. G8 GT Kaltech 224 cam
  57. GTO Vararam gets the job done..
  58. Where did my power go?
  59. SPEED INC. FAST LSX-R - NW 102mm TB dyno test
  60. finally we finished , today 460RWHP tomorrow 700RWHP
  61. SDPC dyno results for LSXR
  62. fbody cam only ls3
  63. G-Force Motorsports Stage I 2010 Camaro Package (video)
  64. SAE HP/TQ corrected
  65. new LQ4 numbers
  66. Whats the lowest Rpm you can start a dyno Run ?
  67. 2010 SS Kooks Headers Dyno Results (video)
  68. 2000 C5/A4 655/656 347/APS... Details inside!!!
  69. 684 rwhp on the stock bottom with a slipping belt!!!!!
  70. 01 firehawk's first start up
  71. Svt bait
  72. Lower RWHP after FAST 90/90 install??
  73. 916RWHP Straight Pump Gas..No Meth!!!
  74. 2010 SS - ARH Longtube and Tune results
  75. gained 40 hp/ 25 tq @ 8psi from modifying my STS kit
  76. G-Force Stage II 2009 Z06 Dyno Results and Video
  77. Tell me what do you think?
  78. FAST LSXR Dyno Results (LS7)
  79. Our latest LT1 396
  80. afr 225 ms4 dyno
  81. My old set up got retuned this weekend....
  82. relatively stock dyno numbers
  83. Dyno Results
  84. desktop dyno & drag sim
  85. H/C LS2 trans am #s
  86. small cam past 400rwtq
  87. Any recommendations for getting a tune in Ft Lauderdale
  88. another 2010 SS tune
  89. Mild 408 build #'s
  90. Step inside to gain knowledge!!!! Detailed A/B comparisons with results!!!
  91. 2001 SS Camaro Dyno #s
  92. Texas Speed Engine Dyno Cell FINALLY COMPLETE!
  93. Dyno Results RapTR cam and TEA/TFS 215's
  94. anyone have new dyno numbers for the polluter cam? possibly track numbers?
  95. 550+rwhp Cam/Headers/CAI on a Mustang Dyno
  96. Mississippi/ Louisiana Dynos?
  97. LME 416 Dyno results
  98. RPM Tuned G8 40rwhp 30rwtq
  99. 02 z06
  100. Speed Inc G8 cam pkg results
  101. New G8 GXP
  102. My 503 rwhp 05 GTO in GMHTP's Street Heat (August 2009)
  103. LS1-T56 RX-7, cam only dyno
  104. Speed Inc. LS2 GTO/APS results
  105. Results from Tom's Dyno Vancouver WA, with 4L80E. Low hp & high torque
  106. 403 rwhp LS1 with stock exhaust manifolds and mild cam
  107. 427 LSX Build - DYNO RESULTS
  108. PRC LS6 2.5/ Tsunami Results
  109. Non LS. 08 Challenger TT. Gettin er dialed in
  110. Tuned/Dyno TA-FAST-6.0 230/236. Kinda disappointed with numbers
  111. 416 - unported L92 heads - Performance Induction intake
  112. Some recent street cars from Kaltech
  113. 08 Vette, TVS 1900, auto
  114. Speed Inc 2010 dyno results
  115. drivetrain power loss
  116. Dyno #s PRC 5.3L & Torquer v2
  117. 427/TF 235 dyno tune results
  118. etp 215 heads/streetsweeper cam dyno numbers
  119. Dyno Results
  120. Trak cam + heads numbers
  121. 00 C5 coupe 1st Dyno
  122. First dyno numbers
  123. AFR Milled 205's, G5X2, Kooks, Fast ported/NW90
  124. 2009 C6/A6 with Vengeance Stage I LS3 cam... Idle/Dyno Results inside...
  125. New Numbers Bolt on Ls1 336/343
  126. LS3 Swap F-Body: Am I down on Power
  127. Had my Hotcam tuned...
  128. Bolt-on '00 T/A dyno #'s
  129. Results: Bolt-on 2003 Z06
  130. Big thnx to EPP!
  131. Are my bolt-on dyno numbers low?
  132. 408 Stroker picks up 73RWHP/54RWTQ with Vengeance FAST 92mm Intake/Cutout
  133. Locked vs unlocked converter dyno run
  134. H/C stock stall ls2 low #s?
  135. MY Pewter Bird ( MS4 + Juice ) MS4 chime in =)
  136. LS2 with L92 heads makes 460rwhp/446rwtq
  137. got my car dynoed last friday
  138. 383 lt1 76mm turbo #s
  139. dyno #'s
  140. LS3 and Hot Cam Results
  141. Engine Dyno needed
  142. Bolt-on LS1 C5 - 348rwhp/360rwtq
  143. Y pipe = Big hp loss
  144. New dyno numbers after head only swap ( PRC 2.5 )
  145. C6z06 & lg-g7x4 camshaft
  146. budget intakes #s
  147. New setup-Forged 347, PRC 5.3s,take a look
  148. dyno #'s finally!
  149. Vid of my N2O run at TTP!
  150. vic jr with 4bble or fast 92/92
  151. **LETHALZ Cammed 454 on Spray(Video & Graph)**
  152. Are these #'s weak??
  153. Dyno Results from 3" Cutout Install (H/C LS1 with before and after graphs)
  154. 2010 Camaro SS Texas Speed Underdrive Pulley Dyno Results!
  155. Freak Cars
  156. dyno results seem low to me
  157. bone stock '99 formula M6 dynoed
  158. Dynoed Full Exhaust LS1
  159. 402 LS2 camaro aps base 692 hp 723 ft-lbs 13 psi
  160. finally got dyno tuned
  161. BABY Cam guys under 228 and under 600 lift inside please. I'm not happy
  162. Texas Speed 2010 Camaro SS Long Tubes & Rumbler 5 Cat-Back Dyno Results!
  163. TBSS w/ H/C and TC
  164. '98 H/C/I A4 just got dyno'ed. Lower #s than I expected
  165. H/c dyno at g force
  166. Street Sweeper Cam numbers are in!!
  167. Vengeance ported F.A.S.T. 92 + NW TB
  168. Texas Speed's First 2010 SS Hits The Dyno!
  169. PRC 5.3L Stage 2.5 Heads and Torquer v2 in RX-7
  170. Dynoed the Z06 today...... Not Happy!
  171. H/C/I +138 rwhp(478hp 411tq)
  172. Cam & Bolt on Dyno numbers
  173. odd looking graph...questions
  174. Lq9 - L92 L76 M6 E85
  175. Torquer 2 cam swapped for Patrick G cam results
  176. Got my Hotcam dyno'd
  177. 02 SS Livernois LS6 Stg II , TSP 224 , Frost Tuning
  178. 02 WS6 M6 Cam and intake results
  179. Dyno Results of Corsa and lid on an 02 TA
  180. Question about flywheel power
  181. 01 M6 SS Dyno Results - Before and After - AFR 205, Tsunami Cam
  182. Alittle TSP228R, TEA/TFS 215's with nice power !!
  183. Exotic Performance Plus, Patriot Performance 225/229 Cam, LS6 Engine, '99 Z28 M6
  184. Late Model Racecraft's prototype Cold Air Induction System and Tune!!
  185. 02 TA - PRC 5.3's, TQ2, and 3600 Vig Dyno Results!
  186. '99 TA - PRC Stg. 2.5 LS6, TQ3 Results!
  187. 5.3 heads and ms3 cam #s
  188. Does this seem right????
  189. 2002 Silverado 2500HD Duramax Dyno
  190. Dyno'd at New Era - 98/M6 (Graph Inside)
  191. stock cam (98-02 ls1) peak power
  192. Few Goodies = More HP/TQ
  193. The no compromise budget setup 80hp / 53tq
  194. dyno #s
  195. 03 c5 zo6 with Boost
  196. ported FAST 92mm/NW VS LS6 at TTP
  197. G-Force 2001 Z06 LS3 Conversion Dyno and Vids!
  198. 98 M6 with a few bolt on dyno results
  199. Noticed something VERY intesting today
  200. Odd A4 dyno graph - any guesses as to the problem?
  201. Pat G custom cam results.
  202. Cam only.
  203. Thumper style cam swap gains big on LS2 Vette
  204. Budget LQ9,PRC 5.3's,Torquer V3, 90/90
  205. PRC 2.5 59cc heads before and after dyno #s
  206. Dynomite Chassis Dyno????
  207. 602 fwhp 383 ls6
  208. Dyno Tune
  209. LG Motorsports 8.0 Liter LS7 Package. Preliminary Dyno results 663/611!!
  210. Torquer v.2 Dyno low #'s?
  211. Race Proven Motorsports tuning and dyno results
  212. TFS 235's+YSi+CDNPERF/CHAMPION 402=924@6300!!!!!!
  213. TSP H/C C6 ZO6 - Boltons C6 ZO6 - Nitrous C6 ZO6 in Saudi Arabia
  214. G-Force ProCharged 2006 GTO Dyno and Video
  215. Race Proven Motorsports C6Z Cam Results!!!
  216. Speed Inc H/C/I 454/410
  217. Whats the difference STD, SAE, and uncorrected
  218. texas speed 408?
  219. ***Dynojet Dyno 224XLC Eddie Brake Dyno and Computer - $30,000***
  220. MY Dyno Woes...
  221. Mustang Dyno vs Dyno Jet
  222. FS: 3 Free Dyno Pulls Certificate
  223. 427 and th350 or th400 numbers
  224. Want trq in a H/C 346? See results
  225. Bolt on A4 - before and after a dyno tune
  226. cam only 5.3 in SS Dyno'd today
  227. 243 Dyno #'s
  228. Head,cam,nitrous record?
  229. Looking for feedback on 416 w/TFS 225 dyno
  230. 470 hp/435 tq??? H/C M6
  231. 243 headed 418+ ci LS3
  232. First time on the dyno
  233. G-Force dnyo tune 2001 T/A WS6 lid and cat back
  234. Interesting AFR 205 comparo....
  235. 2009 Shelby GT500 w KB 2.8H Mammoth!!
  236. home made CAI results on my GTO
  237. TrickFlow As Cast make 57RWHP/38RWTQ over Stock 241 Castings!!
  238. 404ci, A4, Trick Flow 225's..annnnd a very inefficient converter!!
  239. AFR 205s, 224/229, stock LS1 bottom end
  240. CMS Phase 3 package results
  241. 347+Novi 2000+14.4lbs===831rwhp
  242. 1018 rwhp
  243. first time to dyno wery happy with results
  244. 1000+ rwhp 427 f1r gto
  245. Which heads and cam kit?
  246. Champion402+Novi+FlipDrive=NEED MORE FUEL!!!!!
  247. Resurecting the 97-with a Champion 402 and 800RWHP!!!!!!!
  248. 98 Formula Dyno numbers
  249. What is the problem?
  250. ok i tried the search did not give me what i wanted
