View Full Version : Dynamometer Results & Comparisons
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
  1. T-REX cam dyno results
  2. Futral 383 Direct Port results.
  3. rx7 fd ls6 dyno guess? (updated with results)
  4. Cam kit how much power would i make??
  5. C6 Z06 - FMS Stage I package dyno #'s
  6. 427 power guesses?
  7. How much power/torque? Stock LS1 long block, FAST 90/90, True duals
  8. H/C 6.0, NA and 125 shot
  9. How much would i make
  10. H/C/I/ Stalled A4 #'s. Low?
  11. my bolt on dyno #'s
  12. HKE L92 427 waiting to go in... dyno guess?
  13. Whats a good setup??
  14. Cutouts or no cutouts
  15. Finally after 2yrs!!! lol
  16. 6.0 GMC Sonoma
  17. new #'s today. lt1, 5psi boost, cam, head work
  18. Pat G grind cam only dyno results!!!
  19. Stock 241 Heads - 425 rwhp - 175 shot - 595 rwhp
  20. My new dyno numbers
  21. Dyno tune??
  22. E-Cutout gains
  23. dyno help
  24. What's your Top Speed on the Dyno?
  25. 06 GTO Speed Inc SI6/Patriot/Kooks
  26. LS6 vs Ported FAST 90/90 on a C5Z06
  27. Trickflow's and Vrx5 combo!
  28. 370 dyno
  29. PRC 215 Head With TSP Tsunami Camshaft
  30. How many Hyd roller cam 408ci's NA making 550+rwhp?6spd's
  31. Dyno tuned w/ questions about numbers..
  32. New dyno numbers: 04Z, pat g cam, LT, FAST 90/90
  33. What should i expect??????
  34. Novi 2000 & 370 cid c5
  35. My car Dyno MS4 + Nitrous (Graph inside)
  36. Professional products vs Fast vs LS6 intake numbers
  37. C5 Heads /Cam Full Bolt on Dyno
  38. Bolt on 97 WS6 Dyno
  39. 2005 CTS-V Dyno Retune Great Results!
  40. Dyno Tune
  41. Help!
  42. Baseline dyno, wow!
  43. Dyno'd my car for a baseline
  44. 235cc trick flow 408 hit the dyno!
  45. locking the conv on a dyno
  46. More dyno results w/ MS4 cam and heads
  47. Truck dyno but not bad
  48. will this need a retune?
  49. walked away pretty happy
  50. pretty disappointed at my dyno run
  51. 2000 M6 SS MS3 cam and stg 2.5 5.3 heads results
  52. Lets see some APS dyno graphs.
  53. Your numbers with ls1 intake, cam, headers?
  54. dyno numbers after h/c
  55. Dyno Tuner in Victoria TX
  56. Another Proven TR230 cam dyno
  57. First dyno w/ spray (LS6 heads and F13) *video*
  58. Small cam and D1SC
  59. first time dyno- need advice
  60. LS1 Cam/Head numbers?
  61. Update: MTI X1+ built transmission
  62. 243 heads and cam numbers
  63. LS3 427ci /235ccTFS / vengeance racing custom camshaft 794rwhp-821tq
  64. Mustang Dyno #'s on pump 91 & meth
  65. cam + ud pulley=61 rwhp
  66. Ready for my 1st dyno
  67. DYNO TUNE My car?
  68. Spectacle Solutions 58cc 5.3 as heads,vindicator cam dyno results,what you guys think
  69. dyno today
  70. My new DD results (Torquer2 cam only)
  71. D1SC 4 inch pulley t56 swap 584rwhp 532rwtq Thanks EFI Alchemy!!!
  72. Garage-Built 347 makes 412 rwhp with 228/230 Cam and stock 243 Heads
  73. New dyno numbers
  74. F13 Cam Only - 400 rwhp in an A4!
  75. heads and intake dyno
  76. Old Valvetrain (YT Rockers) vs new PAC valvetrain dyno (w/stock rockers)
  77. 150 shot tq numbers
  78. heads cam/dart/torquer 2
  79. What kind of gains by going to 1 7/8" headers?
  80. dyno results hurt!!
  81. finally got numbers
  82. Stock LS1 with D1SC
  83. Before/After on a Gear change C5
  84. Vengeance 383/TTi/ C5 Z06 Dyno Graphs/Idle Clip/WOT Clip Inside.. 800RWHP Thru A4
  85. Gains after Kooks X-Pipe Install..
  86. 1.7 to 1.75 rocker switch
  87. 346 vs 402, UPDATED graph, Now with final tuning and 95mm tb in the mix
  88. steve @ icon
  89. cam swap dyno results inside
  90. 05 vette c6 6.0L stock bottom - vengeance racing head / cam combo 490hp 443 ft lb
  91. Got my car Tuned today got some questions
  92. Dyno Results are In!
  93. Meziere Water Pump
  94. Prepairing for Dyno Tomorrow. What should I check?
  95. What's better? Locked or Unlocked Converter?
  96. another cam only c5z
  97. Going to get a dyno tune tommarow what will I put down?
  98. Dyno Results: PRC stage 2.5 heads and cam
  99. ? For Dyno Operators. AWD TBSS
  100. 427-593 rwhp
  101. Camaro & D1SC@12 PSI
  102. Discouraged about Dyno Results
  103. baseline dyno on Z28
  104. 427 Solid roller numbers
  105. Messy Dyno Graph
  106. Heads and Cam 06 Z06 Results
  107. New Numbers
  108. Went to the dyno today
  109. WS6 bolt on numbers!!!
  110. C6 Corvette LS2 TrickFlow As Cast/VRX4/FAST 92mm Intalled/Tuned by Vengeance..
  111. New results, cam only.
  112. Finally....Retuned, Redynod, VERY HAPPY.
  113. LS6 CTS-V Dyno - Bolt-ons and Patrick G custom grind
  114. Solid roller cam with hydraulic lifters gained 28 rwhp!
  115. Redline Motorsports GMHTP LS3 article!
  116. should i go retune after slp 3" LM1 to mufflex 4" with magnaflow race muff?
  117. gained 16 hp and 21 tq from my dyno tune at TTP
  118. finally tuned
  119. HKE 346 - Comp Cam 239/242 - 458rwhp
  120. C6 Z06 APS Twin Turbo Results... Dyno/Driability/WOT/Idle
  121. FORGED 347 & Procharge D1SC
  122. Headers Only - Untuned - 350 rwhp
  123. Dyno results: MS4 & PRC Stg. 2.5 5.3l 59cc heads
  124. Stock 96' lt1 car
  125. FMS Built 383 #'s Inside
  126. MS4 results
  127. 1999 Camao with 100 Shot
  128. VENGEANCE TUNE LME 402, TFS, FAST 90/90 etc.
  129. Dominator 2 installed - 400whp
  130. just got a tune! does this sound about right?
  131. New dyno results from a header change
  132. VRX3/TrickFlow 215s deliver 458/424 thru Dana 60!!!
  133. 622/660
  134. A4 in WOT lockup = M6 dyno numbers ???
  135. DynoSim 5 and DragSim 5, Fun and suprizingly accurate!
  136. LG 415cid...523wrhp 513 tq
  137. getting tuned. what should i make.
  138. Dyno wheels????
  139. leaning out too much need help any suggestions?
  140. 402 From VA Speed - Thank you Shawn!
  141. suprising dyno results
  142. Got my TSP combo tuned.
  143. cut out vs. catbacks??
  144. Base Line Pull 09 G8
  145. AFR 205, AZPS 02 cam results
  146. 98 Camaro Retune +12 HP!
  147. 02 Z28 With Patriot Heads/Cam, Shortys
  148. My C6 dyno #'s
  149. Sae vs std
  150. Procharger dyno #
  151. rough dyno graph
  152. Well its still dyno related
  153. I need you guys opinion!!
  154. LS6 Top End Numbers
  155. 316hp and 338tq Lts,Intake?
  156. 01 ZO6 Tsunami Cam results
  157. C6 Z06 cam/heads results
  158. Late Model Racecraft just finished my 600+ all motor
  159. On a stock LS6, how much timing should I pull?
  160. Just a little bolt-on car.
  161. stock bottom end f1-c
  162. Turbo 370 762 rwhp on 14lbs
  163. What gear to dyno in?
  164. 235/243 LSR cam results
  165. lt1 car with a lean issue but decent numbers
  166. MS3 HP/TQ #'s!! Post them here
  167. SAE or STD? It doesn't say..
  168. Update Allngn_c5's 402 with REV Xtreme 95mm tb RESULTS
  169. dyno power fall off and 3 psi in the exhaust??
  170. Any guess as to how much power i'm making?
  171. AFR 205 heads + T-Rex + stock LS1 shortblock = 502rwhp NA
  172. LS6 intake/ported TB vs FAST 90/90 ported
  173. Thunder Racing Raptor cam #'s
  174. Fresh Tune on my 403
  175. 98' camaro 1st dyno... cam, bolts ons...
  176. stock lq4 with procharger and epp blower cam dyno
  177. little bit of help.
  178. So close
  179. 99 C5 Lingenfelter TT
  180. torquer 3, 427 hp through a 9" with 4.11s
  181. modded ZR1 dyno results
  182. SLP Loudmouth I Dyno
  183. 348 TC76MPS MAF tune 10 lbs
  184. Boltons/1:85SLP rockers vs H/C Comp Pro Mag 1:75rockers
  185. 05 gto A4 Dyno results
  186. Tuned By Vengeance On Saturday-6.0/L92 Heads
  187. z28 bolt on dyno results
  188. my stock 2000 TA dyno run
  189. Got some numbers!!
  190. What should i be making??
  191. 05 GTO "Tune Only" Suprising Results
  192. Dyno Results Built 6.0L/WCCH L92's/Pat G...
  193. PRC Stage 1 243 heads, MS4 dyno
  194. Another MS4 dyno results thread
  195. 98 ss bolt dyno
  196. Dyno results poor help
  197. MS4 dyno results
  198. PRC 5.3 + 228R results @ Vette Doctors
  199. 87 RX7 + 2002 Z28 LS1/T56 + cam = FUN
  200. DFW Dyno Day
  201. 408ws6
  202. Numbers are in..FAST90/90 FT85mm lid,Delphi 85mm MAF
  203. Dyno Results - 230/228 .612/.588 110-1
  204. '02 SS dyno tune.
  205. HKE Built LS7 With TFS 235's
  206. Got my car Dyno Tuned today, Good numbers,Horrible start can you say LEAN
  207. Smallish Spartan Spec'd cam/tune makes +80rwhp over bolt ons. Final #'s 409/394
  208. Baton Rouge dyno comparison
  209. My 402 LS2 Dyno Video!
  210. dyno found problems!!
  211. Just updated the top end on my LS2 427
  212. 2001 ws6 408 dyno
  213. 2006 C6 A6 RR_STINGER Cam Results
  214. 01 ss stock with ls6 cam.
  215. Dyno Results: MS3, 5.3L Heads, Fast 92
  216. finally got my tune and numbers
  217. Dynoed My Car Today
  218. Dyno results 224/228 .535/.538 114 +4
  219. 2003 C5 Z06- Bone Stock with APS TT Kit 599/593
  220. 99 Z28 bolt on dyno
  221. volant cai & fast 90 results
  222. TSP/PRC 215's, TQ3, RPM Ported FAST 90/90..
  223. Any one else do a cam with no headers or catback in a vette?
  224. PRC 2.5 LS6 & TSP Tsunami Dyno Results
  225. PRC Stage 2.5 5.3l Heads & MS3 Dyno Results
  226. Anybody got edelbrock ls intake manifold dyno numbers?
  227. SAE Vs. STD Comparison Thread
  228. 228R & PRC Stage 2.5 5.3l Install Dyno Results
  229. Dyno in Atlanta/north ga area
  230. Put down some numbers
  231. Dyno pull form last nite!!
  232. need some help with experienced dyno guys
  233. Lunati VooDoo Cam ?
  234. 00 Trans Am A4 - tune by LSXtune
  235. Someone's gonna add some HP this weekend.
  236. bolt on a4 dyno
  237. Injector help!! Dyno Graph included...
  238. Good numbers for Torquer V.3
  239. 2008 C6 M6 Stock Bottom End Heads/Cam Vs 427 shortblock with same heads/cam..
  240. Wow! My FMS 441ci made 884hp/649tq NA
  241. Mostly stock dyno
  242. What so you guys think about these numbers PRC 2.5 heads and custom cam?
  243. PRC 215's , Tsunami ,RPM-Ported FAST 90/90-base results...
  244. Automatic LS2 228R Stage 2.5 LS6 Dyno Results
  245. 09 Pontiac G8 GT
  246. My dyno results...
  247. my car dyno result???
  248. 04 C5 A4 Stinger Cam, PRC 5.3 Head Results
  249. Nitrous Tune, TSP Cam
  250. 02 Z28 ARH Magnaflow CB Dyno
