- Trip to Speed Inc
- Big Wheels
- Headed to the Dyno- Place your bets...
- 356rwhp and 366twtq..
- E85 vs regular gas dyno
- Northeast Ohio
- How much power you think?
- Dyno results in...mild H/C/I setup
- New Numbers, New Tuner, CAM ONLY
- MS3 Dyno #'s
- Dyno??
- 2003 Z06 cam-only, 432rwhp/400rwtq (Guess the cam!)
- PRC 5.3 Stage 2.5 heads w/ 59cc chambers installed
- H/C Headers done dyno #s
- Seafoam your engine.. What its worth?
- First Time on Dyno (bolt-ons)
- Big stalled auto on motor = 505/421 :-)
- bird only put up 310 rwhp... seems light
- My Stock Dyno #'s
- Need Stalled near-stock DYNO graph for mathematical Calculations PLEASE!!!!
- dyno results on the Z!
- Dominator 2 results on 2000 Z28
- 661hp/583ft.lbs LS7
- Got a dyno pull
- New performance results(346 h/c)
- 408 dyno predictions
- Finally got my bolt-on T/A tuned
- l92 6.0 setups?
- TQRIII, PRC 2.5 5.3 results
- 502 RWHP ? how many HP apprx ?
- Latest ASA results
- lt1 horsepower
- Dyno differences
- Built for DD 416CI L92 Results
- Dyno Results: MS3,5.3L stg2.5, 90/90
- ms3 results, yet problem
- MTI Built ProCharged 2008 C6 Auto, 602rwhp
- 02 Maggied TA
- 07 vette H/C N20
- Anyone with an SLP 402 please come in
- CDNPERF STAGE 2.5, 45rwhp Cam Only!!!!!
- Very Low Numbers G5X4 Cam Only
- Which way to go Patriot or Texas Speed 5.3 or ls6
- 100% Stock '02 A4 Z28 : 306 rwhp @ 330 lb/ft
- Finally got some numbers :)
- 365 HP Good OR Bad?
- HSW "The Big Enchilada" & TFS 215cc results
- Very Happy!!!
- Best place to get a tune near PA
- Vindicator "cam only" Z28
- Rapid Dominator 2 Cam Only 2004 Z06
- Dynoed car and lost hp with more mods.!?
- Macs to ARH 1 7/8 headers, stock motor - DYNO before and after
- 425 RWHP C6 A6 with a set of AFR's
- 70 RWHP gains from AFR's and E-test cam!!!!!
- mainfolds-headers
- Dynoed my 413 cid L92/L76 setup last weekend
- Dyno Tuned Bolt-On 2001 Z28 M6
- RPM Cam only Procharged Z06
- Underdrive Pulley Gains (Realworld)
- BIG GAINS on a cammed C5 from an LS6 intake and 80mm TB
- 540-540-cam
- How much do you loose on the dyno with
- Are this numbers decent
- Small cam only 04 GTO 400/373rw.
- new cam
- cam, exhaust, no heads result!
- dyno'd my car today... some questions
- Procharged 427 Warhawk= 921rwhp
- 408 just dynoed :)
- Switched cams to a G5X3, new #'s
- Still Stock?? Post Dyno results here
- Any dyno numers on a 5.3 GXP?
- Who's got the weakest H/C LS1 out there?
- LPE Heads, Joe Overton Cam, EB Porting Intake N/A LT1 Dyno#s on E85
- Boosted 346 w/ AFR 225's cracks 800 RWHP!
- Dyno Results: Cam w/ stock heads (Includes FAST 92!)
- Help me figure out what the problem is, MS3 Results
- looking for dyno results of hpe c cam
- Cam only 06 ZO6 Numbers
- G8 dyno tune yields 34 rwhp and 29 rwtq (87 octane only)
- Stalled auto w/ bolt ons.
- 408 w/ 241's
- TFS As Cast/Vindicator/Bolt Ons 2004 GTO
- VRX3 Camshaft in Action.. Dyno Results/Track Times inside
- Those with a NA 347 heads/cam/headers, LS6 intake & M6
- Help on HP guess, Posted in Wrong Section Thanks
- 2005 Gto
- ProCharged 2002 F Body... Dyno Results Inside
- Car Is At Dyno Now
- FAST 92mm Results... I wouldnt believe it myself if I didnt see it first hand!!!!
- New dyno number, IM SELLING MY FBODY
- Vengeance Modified C6 Z runs 10s@138mph on STOCK RUNFLATS!!Dyno Results inside :)
- dyno from today
- Dyno numbers in....Patriot setup
- locked vs unlocked
- Dyno Dynamics VS. DYNOJET
- is this good?
- 03 Z06 exhust system only
- LME LS7 440 in a TBSS
- prc ls6 stage 2.5 heads 233/239 cam dyno
- Procharger D1SC Dyno Results Tuned @ EPP
- 408 w/ Dart 225 #'s ... A4
- Any 402 dyno's with small cams?
- Ehh, Im somewhat dissappointed.
- 393cu going to dyno any ideas
- Dynojet 224X user's inside please!!!!!
- New Dyno Resultse - 427 LS3 - A4 - 505 rwhp!
- what to expect
- CMS Dyno Results...
- Post results with MTI X-1 cam!
- Finally Got Her on the Dyno.
- manifolds or 1 1/2 tube shorty headers
- 445rwhp 430rwtq N/A 408Ci how bad are these numbers??
- Dyno Results
- 800 Rwhp@5200 Rpm At 13lbs Of F1R Boost!!!!!
- 04 GTO I/H/C Wrenching/Tuning by Vengeance
- new numbers with the 100 shot
- Why do stalls hurt dyno numbers?
- Dyno before/after SLP CAI/Lid
- please post up dyno sheets of 233/239 texas speed cam please let me know mods too
- I just got my FAST/NW bolton car dynoed today!!!
- flow testing my manifold???
- What is SMOOTHING? Also dyno'ed 224/224 .583 112 Lookie n here for more!!!
- did a dyno run today
- '02 SS MS3 dyno results
- Dyno results for 416 L92 with ETP 245's?
- Going to the Dyno Today after H&C/ Intake swap Guesses?
- anyone have a stock ls1 with 100 shot dyno sheet?
- 2006 A4 GTO Bolt-on results!!!
- My G8 results
- ASA cam & bolt on results
- L92 Headed guy Post up your NA RWHP #'s
- Finaly Got H/C and some other stuff here is the dyno sheet
- So I got Christine Dyno'd this weekend.
- New #'s after H/C and tune!!!
- Can a 5.3L dyno as high as LS1?
- Just an observation.
- Bolt on Fast 90 Car?
- Drivetrain loss through a slipping A4?
- What happened!!!!!
- TSP MS3 vs VSI 228 cam
- livernois stg1 ls6, ls6 intake, tr 220 cam. headers needed for 380+ rwhp?
- 02 z28 camaro bone stock dyno results
- 2001 WS6 w/224 cam, bolt'ons, 160shot
- where can i find dyno comparisons between stalls?
- dyno comparisons
- Dyno tomorrow... Any guesses?
- 403ci motor..Swapped from American Racing to LG Pro Longtubes
- 233/239 Results
- MTI Built F1 Procharged C6Z06, 1014HP
- Numbers Tomorrow, any guesses?
- Dyno Results Norris tune texas speed ms3 cam prc 5.3 heads pics vids everything
- good place in metro detroit area?
- Very dissapointed
- New dyno numbers....new tune
- G-Force 408 Dyno Results!
- Heads and Cam LS2 Dyno Results!!
- Guess'em while ya can!
- How many 402's w/ over 530 rwhp?
- 2008 G8 (888 edition) Dyno numbers inside
- C5 Kenne Bell results
- 6.0 TR224 ASP Shorties Tune?
- question look inside.
- MS3 w/ PRC Stage 1 LS6 Heads
- Vortech G trim Stock motor dyno results.....
- Guess my numbers please!
- Underdrive Pulley on C6 LS2
- Superchargered numbers
- New Dyno Results
- any one have 231/237 with afr and fast 90?
- thinking of tuning my stock car?
- stroker revised - thanks TTP
- cam and nitrous numbers for 04 GTO
- 1st dyno #'s for the SS.
- Daily Driver Dyno numbers: 250fwhp/330fwtq @ 13.5degrees timing.
- dynoed 434 after h/c/i
- My dyno results?
- Dyno Results. Formato LS2 vs Fast 90!
- Max RWHP w/Fast Intake
- Dynoed The T/a Yesterday
- Got My SS tuned yesterday!!!!
- final heads/cam #'s
- Detoxx Dyno Prediction
- best place to get a dyno tune in eastern SC/NC
- TFS Heads/Shmedium Cam results
- whats up with all these "cam only" threads?
- any more results on ported L76 intakes?
- Vengeance Racing VR7X Cam Only Results on '08 C6 Z06
- VRX3.. Small Cam/BIG Power!!! Cam Only Results Inside
- Dynoed my bone stock 2006 Trailblazer SS
- Mustang Dyno 01 z28 A4 numbers
- build complete numbers are
- 383 H/C/I Dyno Results!!!
- carbed intake for l92
- Got the SS tuned today!!
- best cam and heads??
- AFR 225 Vs L92 Top end on 416 Stroker... Results Inside!!!
- My new project...
- Dynoed The T/A On Saturday! Tell Me What You Think!
- 2006 Corvette LS2 Dyno #
- Bolt On Numbers Before And After
- What to expect
- Tested: ARH Headers and Fast Toys 85mm Lid
- Average numbers? MS4, PRC, A4
- Boltons and P1SC
- Dynoed her for the first time!!
- CDNPERF 402/AFR225's/Prochager F1A-912rwhp/912rwtq!!!!!PUMP GAS!!!!
- 408 results
- Can any tell if this dyno is locked or unlocked?
- New Dyno sheet! :)
- 2008 Corvette LS3 580rwhp/499rwtq
- H/C/N2O Results
- AFR 205s, Futral F13 cam, Fast 90/90, M6 Where's the HP & Tq? graph here
- 454 LSX With PRC LS7 CNC Heads!!
- TSP 06 Z06 Heads Cam Dyno Results!! PRC LS7 Heads!!
- G-Force Procharged C6 = 717 RWHP!
- Anyone wanna guess my numbers?? Nitrous APPL
- 231/237 403.14hp/394.79tq.
- how are my numbers?
- give me an idea of hp please
- Preliminary Dyno #'s from my new F1A/402/AFR225 combo
- Custon 232/230 .614 .586 111+2 Cam Only Results
- Got Torque? Rapid H/C package results...
- Patrick G Designed Camshaft C6 A4 results.
- tsp 228r or the tsp torquer v.2
- New tranny, actually LOST HP/TQ!!!?
- look what this idiot said about my dyno run!
- 232/234 xe-r 110+3 cam only dyno numbers
- H/C 5.3 new numbers
- 432.3/402 with a Blown Head Gasket
- new to the gm world need help
- New Tune ahead; worth it?
- 2000 Z28 + APS = 700rwhp !!!
- C5 - AFR 205s - 492rwhp
- dyno-tune coming up!! any guesses on HP/TQ?
- Anyone heard or know anything about this dyno?
- 04 C5 smooth idle build
- where can I get a dyno test done?
- dyno results from gear change only, 04 C5
- 00 T/A M6, LM + Lid, Dyno Results:
- H/C Results TR224/TSP 2.5's
- warhawk /Et heads/ 4l80e trans dyno results
- my first "how much power" thread
- question on loss of power
- G-Force ProCharged '00 SS
- $$$ dyno tune
- low dyno??
- Dyno Results: LS1/LS6, MS4, FAST 90
