- Another "How much hp?"
- 580 RWHP possible on N/A?
- I just might have the most RWHP for a cam only (TSP Torquer V3) LS1...opinions?
- TSP: 228/228 .588/.588 113LSA dyno results?
- HMS Dyno Results: F13 "cam only" +44rwhp
- new dyno numbers
- stock 2008 Viper just dynoed 545 rwhp
- Updated Dyno Numbers!
- 02 Z06 842 rwhp / 696 rwtq
- What do head problems look like on the dyno?
- vortech results
- 11's??????????
- Patrick G cam dyno #'s and track times...
- 408 TFS results
- Precision Race Components LS7 Cylinder Head Engine Dyno Results!!
- whats the ideal AFR?
- PRC STG 2.5 5.3L Heads TSP 228R Cam
- Stock Internal LS1 dyno numbers
- Vengeance Racing 440 stroker after 15,000 miles of abuse!!!
- what will it gain?
- Prc 2.5 5.3 heads and tq 3 cam
- dyno numbers got questions
- New numbers.
- dyno results
- Stock Head/Cam 346 LS6 w/ bolton's pre-post Fast 90/90 Results
- Torquer v.3 Reading a little low
- 407 rwhp through a 9" with 4.30's and A4
- 383 stroker results soon to be upgraded
- Wobble in AFR
- ASA cam #'s (updated)
- 347ci through a 4L80E makes 428rwhp corked with LS6 intake and stock water Pump
- Slow Car Dyno Sheet
- Stock cube LS2/Typhoon/+ F1= 785 rwhp
- Mild Mannered AFR/Vengeance Racing Combo ...Results Inside
- Please Help With Dyno Graph
- H/C vette tuned
- Dynoed my camaro
- TR224 .581/.581 114+4 Dynoresults
- F13 dyno numbers
- Weird tsp torquer v3 results...
- AFr 205 224/230 114 lsa FAST 90/90 dyno results! PART 2
- Prelim AFR 205: 468hp/449tq - 5800rpms
- New 402 is alive with 500+hp
- Had the ss dynotested. Confused!!!
- 00 TA PRC 5.3L Heads 230 Cam
- power to be gained removing air/power steering
- Patrick G spec'd cam swap results (thanks to Williams Performance)
- To Buy a Dynobench
- MTI 416cid Stroker Dyno Results...
- Vengeance Racing 416 Stroker Dyno AND Track Results Inside!!!!
- how much power does the prc 5.3 stg 2.5 and trq 3 make
- 484 Rwhp 426 Tq A4
- After cam Results
- 2006 GTO 451hp 418tq
- step by step results on modding 08 z06
- PP Stage 2 59cc Heads, SI5 Cam, M6, FAST\NW
- dynoed ms4
- new dyno numbers with video
- 1999 Trans Am Dyno Results
- H/C - TR230, PRC 5.3 2.5's
- CARTEK built LS2 w/ 4X dyno #'s..
- My latest trip to the dyno
- Just got off the dyno.
- Who has got a back to back dyno run's and seen a gain with a throttle body?
- 408 results part II
- LQ9 Heads Decent Numbers 1350 rwhp
- New Dyno#'s
- Dyno Numbers Bolton LS1 4000 stall
- Dyno numbers to go with my track numbers.
- First dyno: PRC 5.3's & Patrick G cam
- affects of degreeing a cam
- Dyno# locked-V-unlocked?
- Curious on power potential w/ TQR II, 90/90 and AFR 205's?
- engine dyno help?
- How bout THIS torque curve
- XS Longtubes/ory/catback
- 826 RWHP from the 346 cube APS twin turbo
- is this where i shoud be???
- My Final C5Z n/a numbers
- H/C/I # Coming soon from 228 Terminator heads and RF3 Ported Fast
- Let me get some help
- need yuor opion please.
- hp estimate
- GM CNC L92 Head Results!
- What do i need??
- Just got back from Dyno Day
- some dyno #'s on my 402ci/l92 heads l76 intake.
- Need info on understanding the dyno #`S
- Just got back from the dyno: MS4
- Top Bolt-On Dyno Results
- Affects of an unlocked stall.
- HP numbers
- HP Estimate?..
- Cam Only GTO Results...
- stock dyno sheet anyone?
- dyno runs on the 408
- How much hp can i get out of my 383 ls1
- LQ9, LS6 intake, 232/234 .595/.598 cam 113 lsa firebird
- flat lining HP....question is why?
- New 402
- Analyze this...
- My 408 on new tranny
- Greatest Dynosheet ever!!!
- 400 baby
- how much hp??
- Dyno Day, need to make a guess...
- 454 LSX 252/256 Cam dyno
- T Rex, PRC LS6, Fast 85 Graph, XS LT's 462 RWHP
- Should i hit 400rwp cam only?
- *Help* Underpowered Torquer V.2 on 02 M6 LS1
- '02 Lid catback numbers
- Thanks again StraighLine! Mike
- New Numbers....need opinions
- lookin for dyno results 224/228 and G5X3 with AFR 205'S
- Vengeance VRX3 and Headers only
- hows about these #'s....
- dyno #'s look low, is it the stall?
- Question about recent dyno pull's
- dyno numbers....cam only (bolt ons implied)
- opinions on my first dyno today!
- My first dyno pull today. chart and video inside
- "Full Bolt on" Dyno
- Question about effect of wheel weight on dyno
- anyone running v3 torquer cam
- Stock Mustang GT vs Bullitt Mustang on the dyno?
- Any results with Accufab 4 barrell TB??
- TSP dyno tune next thurs, what to expect??
- C5 Z06 Ms 3,4
- Big cubes+L92 results?
- RESULTS TFS 215,Vinticator,Fast 90/90unported
- Comparison between my Cam only LS1 and my old Mustang 347
- Another L92 package result...
- finally got my numbers
- new #'s for me
- elp! LS2/L92 falls down at 6100 rpm on Dyno
- Dyno Tune Cam Vinci High Performance
- dyno tune results
- Predator tuning, the real results
- SI5 Results finally :D
- expected more from my set-up
- Dyno #'s lower with nitrous?
- Wanting some suggestions for improvement
- First Dyno Very Happy
- Are these numbers respectable?
- took the APS GTO to the DYNO to tune it and well....
- Help posting funny looking Dyno Sheet
- H/C dyno number From PRC Term heads and 228 cam.
- What is my RWHP????
- Before & after dyno #'s
- Mamofied AFR FAST90 238/240 9" rear 347
- Need Opinions from the Dyno Gods!!!
- the truth hurts
- l92 engine dyno result.whats up with this thing?
- 402 Finally tuned.... small cam 465/454
- 402 results.....disappointment..?
- 403 LS2 / AFR 205’s lays down 550+ RWHP!!
- TEA/Patrick G cam numbers
- My dyno video
- 6.0L L92/L76 cam estimate
- Late Model Speed tuning and dyno special
- 414 numbers??
- SLP Dyno and Install Specials
- Tested a NASCAR LS2
- New TR230 numbers, interesting.
- Just Got Back With Numbers
- Mustang to dynojet conversion???
- New Dyno Sheet. CK It Out!
- My Dyno #s
- PRC Stg. 2.5(5.3's) ,MS3, FAST 90/90 results...
- Going For A Full Dynotune Any Guess's?
- 1st dyno numbers... need some help.
- Disappointing 383 dyno curve...cam?
- Advice wanted after Formato tune
- Thank you Ed Hutchings!!!!
- 04 GTO heads and cam----467rwhp 404 rwt
- 2001 SS some bolt ons happy with results
- Vortech S/C results 521 rwhp
- MS3 Dyno Numbers
- Anyone have t-rex and heads #'s?
- Finished my 02 Z H/C
- Ported Fast 90 dyno results
- CAM EXPERTS PLZ:What is the advantage of SPLIT DUR. cams over EVEN?
- Texas Speed Dyno Tune Price
- T Rex, PRC LS6, Fast 85 = 462rwhp
- Looking for a Dyno Shop!!!
- dynoed my bolt on 2000 T/A
- how many MS4 cam users with nitrous?
- What rpm on dyno tune
- Dyno Results - PRC 5.3L Stg 2.5, Torquer V3, Ported FAST 90
- Finally got my Tune done---Results!!! :)
- Dyno Simulators
- video of a 2 wheeler with high torque #'s
- Horsepower Tuner Question
- Dynojet vs. Mustang
- Confused, Please help
- air temp humidity and horsepower.
- 6.0 iron
- LS7 - cam/headers/intake - 560 rwhp
- MS4 Cam only dyno numbers
- 1st dyno tune on Monday...Thoughts?
- Cam only LS6 Vette, Nice results
- 2000 Magnacharged Camaro SS
- Anyone ever used/owned a DYNO-MITE dynamometer???
- 700 RWHP 348 cubes 91 octane how many out there?
- Synergy Stage 2 L92 package on C6
- S197 Dyno numbers
- 447rwhp 396tq. 346 Cubic Auto.
- What % of loss with a 6-speed and 3:73 Moser 12 bolt?
- fwhp ?
- 5.7 H/C, Ported FAST90, LT,EWP, Pulley #'s
- Pacesetters, ORY, Magnaflow
- Powere guesses
- New numbers for the T/A
- Anyone seen big cube lsx 4xx ci numbers yet?
- Just Got Home From 1st Dyno !!!
- Dyno Results
- Viper question
- stock heads stock bottom end bolt ons and cam 404rwhp
- Near stock Dyno run
- Old combo vs new combo
- Cam only results
- Disapointing numbers
- 348 cubes. 91 0ctane 700 rwhp
- Finally got my numbers for the Hawk...
- My first ever dyno #'s
- another TRex car
- Bolt-ons/Sprayed SS results
- what should i expect?
- Procharged 408 Dyno Results
- Questions about dyno?
- how much RWHP do you think I have?
- 02 z28 H/C numbers....
- Realistic ganes from 5.3l heads
- 2008 C6 LG Headers, K&N Intake & Tune
- H/C numbers - It's about damn time
- 408 * L92's * CarbStyleIntake * TH400 * Unlocked 3800 Nitrous Stall = Dyno Results
- Thanks PatrickG, new dyno numbers
- 581rwhp 508rwtq - LS7 C5 Z06 - all motor
- Look at this UNDER the curve power
- #'s w/ prc ls6 heads/ported fast 90/90 & yt rr's
- please post dyno number with th400
- Peak HP w/ ported FAST
- LM speed magnusion kit on 02 WS6
- what hp if I add heads / FAST to my TRaK cam only Vette?
- Is this even Close To Right? 400w/ H/C/I
- question for u guys....
- need an opinion....please
- t-rex cam or similar Dyno Graphs Please?!?!?!
- went to the dyno and got a full tune.
- dyno diffs.
