- PRC Street LS6 Heads & 235/238 Prelim. Results
- Heads/Cam/11 psi/ A4
- TTP Stage 3 Equalizer Heads/Cam on 2005 LS2 GTO
- A4 H/C #'s with AFR 205's
- dyno
- decided to dyno
- allngn_c5 on the dyno 473 rwhp 431 rwtq
- Numbers? (mustang dyno)
- TSP LQ9 402 (Patriot heads)
- 224/224 or 228/230 and AFR 205s
- How to open Dynojet File?
- Reverse Split Cam Results (TR227)
- I'm thinking of tunning my light modded 99Camaro M6
- 228/232 Camshaft results?
- post up some 228 cam gains.
- Dynotune Soon To Come
- LS2 402 ETP 245 Results 535 RWHP SAE....
- ported throttle body dyno results...
- My purchased mods will do what?
- LS1Joe New Dyno Numbers
- Mustang Dyno vs. Dynojet
- Dyno results from Intake/Exhaust Swap, Best Money I Ever Spent!
- h/c dyno #'s Thanks Patriot!
- Is it possible to put down 430-440hp with tr224?
- IAT and dyno results...
- What happened
- i need a basic tune for a 98 ls1 with a vortech supercharger
- Long Live the LT1 - 692RWHP
- le2 383 heads/cam setup whatcha makin?
- 100oct vs dyno afr??
- Heads/Cam Dyno Results 475 RWHP
- Aluminum 427 Results
- New Dyno #'s
- STS turbo dyno, stock motor, no bolt-ons, 523rwhp 545rwtq
- dual stage results
- Tuning reults with just an intake on my 02 z06...
- '01 WS6 Dyno results with 224/222 camshaft
- 02 WS6, 1st time on the dyno
- new #'s mustang dyno today.
- my dyno video would anyone send like me to send it to you?
- 02 Z06 with MS3
- New 402 from Rapid Motorsports-Thanks Mikey
- Who has the highest HP 402/408 motor with a Fast intake?
- New cam without tune on A4
- Any #'s on the budget CNC 243 patriots?
- Dyno Tuned by Jeff Creech...
- rwhp vs crank
- 2002 WS6 Dyno Results
- Dyno #'s Predictions..
- My 2000 Z29 A4 dyno results mustang Dyno
- How much u think ill make on the dyno?
- First Dyno on my stock Trans Am
- 4th gear spin?
- MS3 Cam Only: 424HP & 389TQ
- dyno'd my SS with NOS
- NX MAF kit dyno results
- dyno numbers seem low
- anyone have any good TREX dyno graphs?
- What exactly is a dyno queen?
- Descreening maf gains?
- mustang dyno numbers only plez
- Before/ after ls6 heads and ms3 dyno results
- Dynocom Dyno
- lt1 puts down 440
- FFHP Shop Car Dyno results
- Dyno #'s on my Lawnmower inside!
- 2002 SS finally dynoed, full exhaust and lid
- cam results...
- my dyno results!!!!
- installed tr224....crappy dyno results
- Very Dissapointed with dyno results today...
- Comp Cam?
- Dynoed today my M6 swap
- My 1st time dyno #'s
- As promised..TRak with full bolt ons and 90/90
- Post up your Dart head results.
- Dyno results. Is this Right?
- tranny downshifting on dyno
- Dyno'd my LS1 power Mazda RX-7!
- dynoed at 723 rwhp
- TRak with full bolt ons and FAST90/90
- 490 to the CRANK
- 224/228 .637/.639 110LSA cam dyno results
- can't wait
- 408 A4 Dyno Numbers, What Did You Make?
- Mizfit LS7 #'s
- Nice numbers with small mods :-)
- How do you lock the converter during a dyno pull?
- How much can i expect??
- Estimate my hp 402 ci AFR 225's
- Magic stick dyno numbers, if ya got a magic stick post up your dyno numbers
- How much power will i gain w/ this?
- any dynos in the bay area?
- TSP 402 LS2 Low Comp Dyno #s
- Trailblazer SS Tuning
- my #'s seem a little low...help me see what wrong
- We need a new Sticky in the Dyno section!
- TSP head/cam results are in!
- tsp ls6 heads+tr224+fast90/90+bolt ons=?
- Comp vs. Lunati Lobe Profiles
- Dyno graph from my TR224/AS heads
- 492 was not good enough
- My new setup results!
- Dean and Dynotune KICK ASS
- Anyone wana guess my HP
- How much will i do with new setup?
- Does Anyone Have a PC File From a DynoJet Run?
- 550 RWHP NA 408 on pump gas???
- 20 rwhp from cutout
- TSP Dyno question with tr224.
- just got my car tuned friday at Rapid Motorsports
- F14 Cam only A4 results.
- Vid from my dyno yesterday.
- TEA LS6 Heads and Custom Grind Dyno Numbers!!!
- Victor Jr. intake ETP 225s big bore 383 dyno results!!!
- Combination Motorsports LS2 402 dyno numbers w/ Dart 225's
- Results: PRC stage 2.5 LS6 heads/ tqr v2 cam/ intake
- TSP 233/239, TSP PRC stage 2 heads
- Adding pulley/water pump, what will it dyno?
- Looking for a good tune in Houston Texas.
- 16:1 Af Vs 13:1
- FFHP 408 + T88 = WOW. Preliminary dyno numbers inside!!! 1000+
- Re Dyno Tuned my H/C setup. numbers....
- Wheel HP vs. track performance?
- Baselined it today before the CAM!
- New #'s on spray!
- Highest Stock LS1 #???? Is this BS?
- 463 rwhp stock bottom end LS1...
- what is my car gonna make I cant take it anymore.
- dynoed on wed
- Bolton dyno numbers
- Pacesetter L/T, ORY, & Hooker Catback
- Who has Dart 205's/LG5X-3 and has dynoed?
- New results.. nothing special..
- Dyno results
- 492RWHP 05 GTO Heads/Cam car
- tracton control on dyno
- good tuner
- What should I expect
- What kind of #'s
- How much should I be putting out ?
- Getting tuned tomorrow
- how much did your dyno tune cost
- Good or Bad? Take a look at the graph.
- MS3/PRC LS6 heads Dyno Number/ Thanks Slowhawk/Don/Dez Racing/TSP
- Tony Mamo's Vette??
- How does it rank for the first dyno.
- 408 w/patriot heads dyno chart!
- LS2 Stroker low torque numbers
- CTSV H/C results..
- Curious Dyno Results w/ New Cam - need suggestions!
- Tuned bolt on car and nitrous numbers
- 451 rwhp heads/cam C5
- Anyone use a Mustang Dynamometer?
- does this sound right?
- Stock 346 C5 puts down 647/583 thru an A4!!!
- o2
- 150 shot results
- TSP Torquer v2 Dyno
- Question What Numbers should I put down.
- Dart 205 Results
- Dyno numbers
- what kind of power could I put down?
- Made it to the dyno today and tuned
- which borla plate
- Realistic #'s for Lid
- crappy dyno numbers
- What numbers woould this WS6 put down?
- SAE +440rwhp on slipping clutch
- Dyno Graph
- Dyno after all bolt-ons.
- New Z06 with LG Headers 495 / 470
- LT's dyno on 01 M6 Z28
- Will i make 400 rwhp with these mods??
- TRak cam only dyno
- Dyno with TEA 5.7 STG1!!
- question about dyno #'s??
- 06 Z06 Stage 2 results inside.....
- AFR 205's, 228/230 dyno....
- I finally scanned my dyno sheet
- Went to the dyno toady!!
- 98-00 VS 01-02 stock?
- What should stock Ram Air dyno?
- How Safe are Dynos?
- My car is going into the shop tomorrow :-)
- make sense to you?
- what numbers with a 408?
- More TSP/PRC ls6 heads and MS3 #'s
- Engine dyno to chassis dyno
- Next mod for 400hp?
- What Affects dyno results?????
- New #'s with LT's, ORY, Tune, etc.
- 4" QTEC on 4" Catback Dyno Numbers
- GTO Dougie's ET/408 part II....540/475
- What tires better to use on dyno?
- Benchmarking dyno run - Where's my hp?
- why is it running lean?
- How much rwhp is header coating worth?
- Opinions on my tuned dyno #'s
- my camaro is going to get tuned on the 28th. what does everyone think it'lll put down
- dyno difference
- back to back dyno runs, inconsistent #s
- 1000 rpm's MISSING
- big CI and small heads...?
- RWHP Difference with exhaust???
- With ZERO tuning the LS7 Monte SS rocks the dyno rollers with 487/470 RWHP/RWTQ!
- F-13 cam only(mustang dyno)
- just had dyno tune...these numbers sound right???
- 02 z06, ms3, LT's, OR-X, catback, tune results
- Just wanted to post my numbers....
- 500 RWHP or am I in for a big disappointment?
- Anyone running a g5x4 with afr heads with some dyno numbers?
- please post 5.3 head/ any cam numbers
- CARTEK 4X Heads/Cam hits 507.9-RWHP!!!
- Swapped AFR 205's for Dart 225's, gained 13 rwhp and same torque, 443 rwhp
- TSP 402 Dyno Number?
- efi live tuning and dyno tune
- Take a Look, Questions....
- What kind of numbers will I put up???
- NEW TSP LS6 heads/MS3 numbers anyone???
- rwhp converted to flywheel?
- Dyno'd my TSP 233/239 cam only car>>
- any G5X2 dyno #'s
- A4 to M6 How much HP will be gain on dyno?
- TREX Cam only numers
- Wondering about #s
- Th350 Questions
- Pacesetter 1 3/4" to Kooks 1 7/8" results on a "SI" car.
- F1-R Procharged 370
- what do you think?
- 644 rwhp on 7 psi? YEP!
- 04 GTO AFR205+EDC = 112.3 rwhp gain
- 382ci & 402ci H/C post your numbers.
- Any H/C numbers with the TRex??
- Solid AFR 205 Results (A4)....
- weird results from dyno printout
- Rear wheel loss to accessories
- g-tech ????
- Nice Gain from Diablo/Gran handheld...
- TSP 228R camshaft dyno results
- 03 zo6 dyno predictions
- what is a/f ratio
- LS2 402 Way Low Dyno Numbers. Help Please!
- New dyno #'s and it will pass smog
- A4 D1SC Dyno
- Lingenfelter heads & cam dyno results
- Dyno'd the TA today, expected more HP
- Hit 400.88 rwhp & 387.37 rwtq at the dyno today...cam and a few bolt-ons
- 441 NA Results Inside
