- TT g35 dyno # guess
- What kind of power?
- 477/427 StreetSweeper cam 06' vette
- 400 hp cam only a4
- Does this sound about right? 243's Torquer V3
- G-force 1102 rwhp 09 cts-v!
- Stock cube (346) N/A
- Bolt On 6spd 2000 Z28
- 6.0 LQ9 Build-up with AFR 230 heads
- Bolt On Car 343RWHP & 350RWTQ
- '02 Camaro Z28 'street car' = 1244rwhp
- LS2 102mm FAST dyno test
- EPS 226/AI Heads Dyno
- 2008 LS3 A&A kit, Custom Blower Cam, BT Racing springs 675 rwhp
- lq4/l92 torquer v2 40rwhp gain from removing flowmaster
- 2000 trans am base line
- Is there a big difference between a Dynojet 424XLC2 and a Mustang 1100SE Dyno?
- 370 vs. 376 vs. 408 on 150-300 shot
- My mamofied build results
- SS dynod
- New 408 what will it dyno/run in the 1/4!
- Spartan 402ci GTO goes 530/495 with stock driving manners
- Stock and modified MT ZL1 Camaro
- 70 rwhp gain with a "baby cam"
- 408 with a glide. I did something wrong.
- How important is elevation?
- 4.8L w/4l80E = 730HP/747TQ
- Cam only LS1 w/ KYTP turbo kit
- 99 SS- LS3 - PRC 237cc - FAST 102 - SS4000
- Dyno numbers Widow-R / Texas-Speed PRC LS7 heads / Fast 102 / Boltons 600+rwhp N/A
- smallish XE lobed cam results
- CSP Built LS2 GTO, 227deg HR, Ai 226cc CNC'd 243's - 476/409
- What are the power limits of a 1 3/4 stepped to 1 7/8 with 3 1/2" collector.
- 2006 GTO single rear turbo
- My 5th Piston Gets Broken (dyno pics inside)
- How good is the stock catback pipe?? + $2 worth of washers worth 4 RWHP,with sheets.
- cam only 5.3, PT7675, 16psi, 824fwhp
- Gear Change... What do you suspect will be the result?
- Heintz Racing C5 w/ Ai 226cc CNC'd 243's
- 408 Dyno Numbers
- sponsers step up!
- Can't get full boost on dyno?
- PRC 250CC aftermarket castings/g6x3 cam 505rwhp/464rwtq
- Advanced Induction HCR 241's Dyno Results
- Detoxx Procharger Results: Futral Motorsports Installed/Tuned
- ls1 with 5.3 (706) heads
- low power on the dyno with cts-v ls6 car
- Vengeance built C5 Z06- 879RWHP/749RWTQ- RHS 427/A&A YSI- Pics/Video/Dyno Inside
- F1 engines are amazing
- 402 LS2 535rwhp/490rwtq
- missing power
- PRC As Cast Heads Dyno Results on 01 Z06
- Project OVRMYHD get Dyno'd
- weakest h/c ever?
- has anyone ever thought or made a portable 1/4 mile track?
- 2001 ss
- Thompson Motorsports monthly DYNO DAYS starting in APRIL 2012
- 02 Camaro SS kooks, lid, A4
- Is a Dyno's AFR correct?
- How much HP and 1/4 ?
- dynoed the fireturd
- 228/232 H/C A4 w/ Track Results
- First time at the dyno!
- Sam's N/A motor
- What should I run
- 370 with l92 ls3 manifold dyno time...
- LQ9, torquer V2,Hookers 1 7/8. FAST 92/102. UPDATED with TFS 215 Heads
- Dyno and tune by Pat G
- Bolt on Dyno Results
- Noob thank you
- isnt 317 rwhp a little too high for a mostly stock car?
- 2001 T/A VRX5 cam LS6 heads
- TT 2005 C6 @17psi 1031RWHP ON PUMP GAS AND METH
- New Cam-only LS3 dyno results:: 517whp/462wtq 24* timing
- My last 3 setup's.....
- 2002 z28 Bolt Ons: Surprised Me
- 228/232 Cam only results w/ graph
- 1400 hp TT LSX on pump gas
- GMHTP | ProLine | Vengeance | 4XX All Motor engine dyno video
- 724 RWHP stock short block c5 z06
- Champion motors lsx 454 dyno 647 rwhp na
- Champion motors 454 lsx 647 rwhp na
- What should my numbers be?
- Stock LQ4 with 88mm & 12psi (571whp/527wtq)
- Advanced Induction H/C/I a4 dyno results
- got my first dynotune today
- 383 tfs225 new Dyno numbers
- First time ever at track...
- need some info on cam choice for my
- 278/339....347/364(Edelbrock Headers) after dyno tune...odd?
- horespower seem a little low?
- Bolt-On Car Only
- New 5.3L dyno numbers.
- recommend dyno in dutchess New York
- whats a realistic number i can prepare myself for
- My dyno numbers
- 04 GTO, cam only
- What do you guys think?
- First dyno run ever
- Whatcha think about this combo?
- LPE GT1 cam dyno results. stock heads and motor
- Just got back from the dyno
- best tuner in SC (near Columbia)???
- Dyno results
- G6x3,AFR,stock 346
- 99 ss a4
- Ls2, tfs 225's, eps cam and fast 102
- More power, cam only setup
- First Time to the Dyno...I think I have a Factory Freak...
- Dyno Results -RPM-Motors Small Bore LS7 heads on a 4.005 Bore - C5Z06
- 1109rwhp ttc6z06 on pump gas and meth
- First Dyno Experience... :(
- Dyno sheet
- Place to Dyno my car!! Houston Area.
- Dyno results, Cam+stock manifolds c6 z
- LSX Block 427ci, PRC 265cc Ls7 Heads
- FAST102/92 vs LS6 on Cam Only LS1
- First Dyno on my new '02 WS6
- Wavy Dyno Graph?
- Pitiful dyno results
- 470rwhp 430rwtq Stock Bottom LS1
- Locked vs unlocked dyno 418ci LSX
- G-Force 416cid LSA 2009 CTS-V!!
- Edelbrock Stepped headers?
- C5 Z06 Pat G/EPS 226/230 cam only, makes 450/434??????????
- Yes we work on the dark side as well!!
- What happened to the VA Speed bashing thread?
- Spartan built LS2 GTO goes *492RWHP/448RWTQ*
- 99 with 101K miles on it
- Help with Dyno results
- 2002 SS Heads & Cam
- Dynoed the Bolt on c5 with some N20!!
- What kind of horsepower would i make ?
- If you've always wondered how much rwhp a certain part puts out look here
- CMS built C6 Z06 Dyno video and numbers
- This is why you cant trust the butt dyno
- Finally tuned for the new set-up
- our 5.3 twin turbo shop truck
- 811rwhp. at 15lbs stock shortblock,317's,custom cam,e85,big turbo.
- Only 360rwhp?? is it true
- Well the numbers are in....
- Vengeance Racing Introduces KAOTIC S/C Kit for 2010+ Camaro!! GRAPH/PICS/VIDEO
- 35rwhp gain from small cam in 5.3 L33
- 6L Iron Block, 12psi
- Speed Inc.- Paul's A&A C5 with SC1 cam
- Who dynoed GTOs and CTS-V at Dyno Proven in Lawrenceville ga on 01/14/2012?
- 383 LS6 Does This Look Right?
- CMS Built and tuned 2011 CTS-V A6
- 01 SS dyno results
- Got motor figured what #'s should i be around
- 40X stroker thread
- quick Vid CMS built Twin Turbo c5 z06
- 99 camaro vortech supercharged dyno results
- Vengence built 402 02 Z06 dyno vid
- PRAY built Vengeance tuned C5 408. 825/702rw on break in tune
- Pleased With My H/C Combo!
- WTF very weird Dyno results!!! Confused!
- 441ci LSX Twin Turbo new #'s! Precision 67 CEA vs Turbonetics 70
- Warning!: Contains low dyno results
- 2009 Z06 + ECS Blower
- Decent Dyno Numbers
- Low dyno numbers and confused?
- Vengeance built Twin Turbo C6 Z06 goes 1343/1229... Graph/Video/Info Inside
- 408 Dyno Tune Results
- Vengeance Racing Built 383 Stroker
- CMS C6 z06 E85 Results
- Risk of dyno tune?
- LS2 GTO w/ Advanced Induction 226/234 Cam Kit – Pics & Vid
- Any guess on what HP I will make
- Does 318 rwtq seem low for 01 Trans am?
- Hit the dyno and got tuned yesterday
- LS3 414 results Video added
- 2004 c5 full exhaust and air filter
- Comp 224/230 XER cam results
- Finally got the LT1 on a good dyno
- should I be happy with these results?
- LME + A.I + Mamo + Pat G + AMS = 495 rwhp
- 2002 camaro D1 procharger and custom FMIC pictures video and dyno sheet inside!
- hotcam in a 2000TA results
- Full Bolt on LS1 Dyno results 363hp 380wtq (**UPDATE**360hp correct)
- Just another Virginia Speed Built Motor LSX 418
- measuring power on dyno from low idle rpm
- LS2 + VRX5 & Ported FAST 102 *VID
- Think my numbers are way low: ls6 baby cam long tubes
- 2006 z06, A&A Si-trim
- New stroker results
- Larger primary tube headers , when is it to big on stock cube motor?
- Bolt on LS6 Swap Numbers Mustang Dyno
- Dyno results Shorties to long tubes.
- 2012 GrandSport @ 8.5psi w/ Ai 275cc LS3's - Dyno & Pics
- Has anyone ever nailed down driveline loss?
- ECS LS3 H/C Installed>>> 496RWHP/471 RWT!
- HPS 402 Stroker,LS3 Heads,LS3 Intake..DYNO#s.
- heintz racing is a great place!
- HP Loss
- free dyno run... alittle low?
- Dyno Results
- vic jr 4150 TB, on a STOCK ls1. check out the gians
- Cam swap results EPS vs TEA
- RPM 408 Results
- What are headers really worth? About 40rwhp it turns out..
- 408ci, GT47-88, Stock 317 heads
- Questions on my build
- Vengeance Racing builds '09 C6 Z06 Pics/Video/Dyno Grpahs Inside.. LOTS OF EXTRAS!!!!
- FAST 102, PRC 2.5 LS6, Pat G/EPS 230/234 Dyno
- aftermarket castings touched up
- Looking for graph of 6.0 Trex and TFS 215's
- LS2 402ci #'s :UPDATED: tracvk times included
- My First Dyno with video
- 243s + TR220 dyno and track results
- Latest Dyno results with 160lb high imedpance injectors
- Tested Holley Hi-Ram LS3 intake vs Stock LS3, 45 rwhp gain on stock LS3 heads
- Take a guess experts!
- Low numbers on dynojet
- My 347ci Dyno Results, Tony Mamo spec'd and Patrick G tuned
- Couldnt Be More Happy With My Trans Am...
- My first how much power am i making thread
- G-FORCE Stg I 2012 Centennial Edition Corvette ZR1!!
- 408 with stage 3 ls6 heads dyno numbers
- rwhp advice on rough crank figure.
- Bolt on 01 Z06 378rwhp, Bolt on 2002 Z06....404Rwhp
- Switched from ported LS3 heads to Trick Flow 235's
- Take A Look At My Graph
- 507rwhp / 445rwtq Stock Bottom End N/A LS1!! Update Vids
- Trickflow as cast 220 heads and 228 cam dyno *vid & graphs posted*
- I Dynoed my car yesterday and my TQ is very low. “TRak Cam”
- Stock Shortblock TC76 Turbo
- RWHP Guestimate?
- Tuned a nice turbo F body
- 2000 Stock C5 ***Before***
- RPM Motorsports GS A6 Corvette results ...
- very pleased with cam only results!!
- Numbers seem low to me what do yall think
- Stock Short Block Ms3, Ported 799's, Unlocked Numbers
- This is WHY Bigger is Not Always Better!!!
- New dyno numbers on LS3 427 CETA
- street tune vs dyno tune.....noob question
- How much rwhp can I expect from my new 383?
- 383 LS1, TFS 220, VRX5, 102/102, 240sx
- G-FORCE Big Nitrous C6!!
- why are these numbers so low for a bolt on ls1?
- Tfs 220 & vrx5 ls1
- Dyno results with the bottle
- H/C C5 LS1 346c.i. dyno 430whp / 400wtq
- dyno #'s and track times on a h/c/i car
- 383ci TC78 numbers
- New Dyno of 402LS2 534rwhp/494tq, but too lean?
- 383 Dyno results
- Project OVRKILL: Virginia Speed RHS 460 - 803hp 698ft lbs N/A 93 Octane!
- Bay Area Dyno Special!!!
