- choppy dyno graph???
- What Cam and Heads next?
- AFR 205's + T1 results
- My Formula first dyno. Good? Bad? Etc?
- New Numbers
- New Race-Prep engine package developed & Dyno tested!
- Dyno Question (not sure which forum)
- 393/377 n/a....583/595 n2o cam only
- Dyno Tuning in Central California (Visalia)
- 364 hp TR230/224
- Dyno owners...exhaust removal setup??
- How do these compair?
- 233/239 Revision 2 & PRC 2.5 Heads Results!!
- dyno with stock 3.42's
- Dynoing with slicks? HP loss?
- My 422 dyno results
- mustang-dynojet numbers?
- Anyone ever have numbers below the "corrected" numbers?
- 1 3/4 vs 1 7/8 header dyno RESULTS!!!
- TEA Stage 2.5 Dyno Numbers (WOOHOOO)
- APE 382 #s
- So California Dyno Shop, Must READ!!!
- 03 Cobra
- Initial Dyno Run
- finally dyno'd my bolt on car
- Number on my Z06 & FM13
- Finally got my car dynoed!
- wha kind of rwhp are you guys getting from cam and headers only?
- 2000 and up cobras?
- g5x1 dyno results 3-24-05 ap engineering
- Stock Dyno Numbers are IN!
- mustang vs dynojet
- please see inside for mods, what did you dyno with similar mods?
- first time ever tomarrow!
- G5X4 dyno results are in...
- My new (as of today) dyno #'s
- more FM14 numbers
- dyno results of stock
- 442rwhp with an auto
- Newbies first dyno
- Advise I was told by a tunner that a a4 car with a stall will put down lower hp #'s
- SS Hood gains
- NEED SHOP in DFW area
- Dyno #'s for AFR,FAST,QTP etc...
- getting dyno in 2 days
- Dyno'd the 2001 z06 341rwhp/ 337 torq
- What kind of power to expect?
- Help picking a Dyno Tune Shop - Michigan
- FM11 & GMPP LS6????
- Gear and/or cat dyno affects ?
- Here is my graph tell me what you all think?
- The Warranty Warrior New Best
- FMS F14 Cam Only Numbers
- horse power!!!
- The Blazemobile Hits the MTI Dyno For Check Up
- New F13 dynos...
- MTI G1, Stage IIe, + N2O on my 2004 Z06 #'s
- redynoed the trex/gtp combo
- PRC Stage 2.5 & TSP Mini Stick Before & After Results!!
- Gtech Pro ?
- Eastside Cam in!
- FAST90mm + QTP HVM LT's = *The Real Deal*
- Gas Mileage with CAM ?
- Dynoed the Magic Stick today...
- HPE Viagra mod works
- Another what will my car dyno thread.
- Guess the Gains/loss from an LSX 90mm
- Preliminary results for 385 ci nitrous motor
- 99z20ate dyno
- My cam only numbers....
- New Number Thoughts
- Another hot cam question...
- dyno numbers for SLP LT's???
- TSP Magic Stick v.3 Dyno
- Dyno sheet for a TSP 224/228 114 lsa cam?
- Highest horsepower - 5.7L???
- BIG cam / AFR 205 results....
- Air/Fuel ratio plot
- 04 GTO dyno results, what do you think?
- th400, sloppy converter
- TR224 or TSP224 or TSP224R
- Need an extra 20 whp :) .. opinions needed..
- QTP LT's 1 3/4, QTP catted Y, GMMG dyno results
- What numbers am I looking at???
- 226/226 guys in here...
- 444hp 394tq on a Mustang Dyno
- What do you think my car would dyno?
- How many dyno runs in one setting?
- dyno info for g1
- stock 2000 T/A a4. dyno # inside
- 98-00 853 Heads, cam only: post your graphs!
- Speed Inc. 231/237 Cam
- 370 ci Iron block results......
- Rapid Dominator Iron 408CI Results
- TSP231/237: Old Cam-only, part bolt-on dyno vs. H/C/Full bolt-on dyno
- What to expect, torquer cam
- Cam dyno...
- Mother of All Bolt-ons Swap:SLP/QTP HVM,LS6/FAST90, X/Y *Dyno Result*
- FM13 with AS 5.3 heads
- 98 Trans Am, Bolt on's
- New Dyno numbers!
- New Numbers!!!
- Any good tuners in Austin, TX??
- 2000 TransAm A4 Bolt-On 352RWHP / 357RWT
- any guess on horse Power
- WIll this hurt Dyno #'s?
- What should I get out of this.
- Dyno results and DriveLine Mass
- Just got my numbers on the dyno!
- what shoulld i be expexting, im hoping at least 380
- Just dynoed my Hawk today!!!
- How much wheel?
- how to convert rwhp to flywheel hp?
- About to dyno tr230/224 full bolt/ons
- Shooting for 400rwhp...
- Drivetrain Loss strikes again
- vinci/crane programmer dyno
- stock exhaust vs bassani tru-dual
- sae?std?din?
- Help!
- Slp vs Kooks dyno results..MTI Tune vs HPE tune
- Cam Only Z06 results (RPM 5 Cam)
- FMS F13 / Bo White ported 5.3's - numbers inside
- potential setup, few questions
- Disapointed in my results..
- af ratio
- LS2 intake results on a cam only Vette.
- Dyno numbers after FAST install 427 LS1
- TREX and Stg 2 heads results.
- 224/224 cam info wanted?
- dyno'ed today!!
- Do I need to do anything before
- 1st dyno on a dynomite,questions
- got new numbers again
- Gains with Headman LT's & ORY ??????
- Do all Dyno's have a 175 max speed?
- dyno # for a4 with 224/224 cams
- dyno
- Torquer dyno'd
- how are mac headers?
- fm13 hp & tq
- Are my dyno #'s low?
- 12 bolt with 4.10 gears to a 9"with 4.57 gears..How much loss?
- Hp
- AFR 205 / 232/236 Results - 2000 C5 A4
- What #'s are u making w/ T-350 & Cam/Bolt-ons??
- Pretty happy with my first dyno experience.
- g5x3, and AFR205's, and lsx 90mm hp #'s.
- mustang dynojet
- fm13 vs g5x2 112
- relocating 02 sensors?
- 2nd gear pull numbers for a stock 5.3
- Dynoed my 408..
- dyno tune flint,mi area ?
- Dyno Build Program
- What is up with my A/F? Why am I not putting more power to the ground?
- give me an idea of my #'s please, f13 going in!
- pacesetter gains.
- DynoJet Model 248 vs Mustang APE dyno
- Dyno number questions inside....
- Dyno with small cam and stock 6L heads
- How much timing are you seeing at WOT? Tuned
- FASTech Tuned!
- 99 SS A4 est dyno from 1/4
- New dyno #s with ported TB and LS6 intake
- Low Comp 395ci Stroker TTP Stage 4 Equalizer Results Within --
- 425RWHP....and TQ?
- 427 w/ AFR 225's and G5X4
- dyno vid of 233/239 cam just installed!!!!
- GTO h/c setup 419/379
- Vid of F13 cam only w/fun vids
- How Much Power Are You Making @ The Wheels?!!?
- Mustang Vs. Dyno jet
- Hotcam #'s in GMHTP mag!!!
- TSP MS3 Cam Only Results Inside!!!
- different dyno's?
- HP and Torque numbers?
- FMS F11 / AS Stage II / LSX 90mm results
- Stock exhaust & Manifolds cam only numbers?
- Preliminary TTP Stage 3 Equalizer H/C Package Results Within --
- Ordered F13, good chance of seeing 400rwhp?
- SPM SC Heads/Cam dyno results
- Please help brothers!
- 400 RWHP Cam only A4
- 350 rwhp on a A4 with a Cam, I was expecting more
- Are these numbers low?
- Does anyone have a LT1 vs Ls1 graph
- I Dynoed, but what do you think New Mods will do?
- Dyno sheet and vids, whats wrong??? Help please!!
- Dyno numbers for a 402???
- TTP Equalizer V.2 Dyno #'s
- any idea what i might get for horsepower
- Any 'tricks' to dyno-ing a 700 rwhp car with Powerglide / 6000 stall??
- 2001 A4 WS6 Baseline numbers
- New numbers.. but not happy...
- question what should this car put out, think somethings up
- Are aftermarket heads even worth buying?
- My 1st dyno numbers
- mustang dyno verses dynoject- differences?
- Standard vs. corrected #'s
- My #'s are in hehe
- Low dyno w/224 need help
- #'s are in for my car
- stock A4 LS1 2000 Formula results
- 618 RWHP AFR head dyno
- A4, High Stall, Cam only 405rwhp
- Dyno's in New York State
- Home Ported TB on an f13 cam
- fm11 & g5x1 dynographs please
- 408 w/ AFR 225's
- Dyno Results are In... most bolt ons
- is 1400$ heads woth it???
- My car is a SLUG low dyno #'s
- how come???
- Procharged SS w/ full exhaust
- Had the SS DYnoed Today
- Cut heads or thinner gasket?
- Had car on the dyno for first time
- ASA cam dyno results
- Car isn't running Good After Dyno Tun
- Tsp H/c Dyno Estimate???
- What kind of numbers to expect
- Unbelivable numbers for cam only T/A
- RAPID Dominator 402 CI LS2: 553rwhp!
- PRC 5.3's, baby cam, A4 dyno
- Anyone with larger chamber patriot lq9 or afr large chambers and gt2-3 cam?
- Mustang dyno numbers and questions.
- Anyone have dyno results for TR224 vs. TSP225
- MS3 A4 results!!!!
- My friend and I got a bet..what ya think?
- dyno numbers from my 406sbc
- are my numbers low?
- TSP MS3, PRC 5.3's.. in a forged 348
- 462rwhp
- hows this dyno run
- weird numbers
- More TR 230/224 numbers
- g5x4 cam only dyno
- TSP 239 results...
- Anyone dyno a T-rex or similar with AFR's yet?
- ls1 intake with a 232/232 112 cam
- Guess my dyno numbers.
- Finnaly got numbers on the 383!
- New TR 230/224 Numbers!
- First dyno: opinions
- Dyno #s: Whisper lid and free mods to the daily driver
- Speed Inc 408ci / 12bolt / TH400 dyno numbers
- stock 2000 WS-6 dyno's
- Whats with all the 408's goin around.
- 12.50 @ 114 car puts down 308? 11.5@ 125.5 puts down 376
