View Full Version : Dynamometer Results & Comparisons
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
  1. 02 SS a4 dyno
  2. A4 403 Dyno
  3. 417 CID with new "V2" AFR 230 heads (now UPDATED w/chassis dyno #'s)
  4. Should I be disapointed? Dyno Back.
  5. How to determine optimum shift points?
  6. Raptor Cam Results
  7. Build Results IN !!!!
  8. Texas Speed Twin Turbo Corvette - 1040 HP!!!
  9. 926hp on an engine dyno NA
  10. Kooks 1.7/8 - CAI - VeangeanceRacingX5
  11. AR 1.7/8 Headers/ VR CAI / Custom Cam C6 ZO6
  12. Just dynoed my ZO6 with EPP (BruteSpeed) Cam
  13. Trans Am Dyno'd @ All Out Performance Today.
  14. 468ci with PI 275 heads/Harrop itb-- 710hp, 680tq--missing power?
  15. EPS Cam only Dyno Results
  16. AFR 215 Preliminary Results 01 C5 Corvette (Auto with Stall)
  17. High rpm C5 street car VIDEO
  18. TSP Texas Giant to EPS custom spec Cam Swap Results
  19. help me get to 400rwhp
  20. New 416 break in dyno numbers.
  21. i have heard that vettes dyno higher then fbody/gto's?
  22. G5x3 Cam Only
  23. Sound right?
  24. 01 SS 6 spd , H/C/I dyno #'s , gears hurt me ??
  25. 416 on ITB's
  26. G-FORCE 1999 346 LSX Stang!!! Track vid and dyno!!!
  27. 340HP 330TQ good/bad?
  28. 368hp/355tq Sound pretty close?
  29. 2000 Camaro finally Dyno Tuned 372.7hp
  30. VRX4 A4 Dyno Numbers
  31. Fast 102 Results Dissapointed
  32. Dynojet 228/232 H/C A4 Unlocked
  33. Speed Inc TB SS Torquer cam pkg, Kooks, results
  34. DynoJet results unlocked A4 with boltons
  35. Does this sound about right for a 408?
  36. vic jr vs. super vic
  37. My LQ4 numbers what do you think
  38. Accuracy of G-Tech Pro SS/RR
  39. LS6 + MS3 = 434rwhp on mustang dyno but have some questions
  40. Are my #'s too good to be true?
  41. Disappointing #'s for a 408, what should i be making?
  42. Dyno Results...Low?
  43. 2001 Z06 blackwing intake and some exhaust...
  44. 383 camshaft help
  45. Dyno tuned. How are my numbers?
  46. i have never been more disappointed with a car in my life
  47. EPS Cams
  48. Broke the TA on the Dyno..
  49. 2010 SS , SI cam pkg, Kooks, Borla #'s
  50. Virginia Speed 427,Mast LS3's and a TVS2300(901bhp)
  51. Looking for dyno graph 1999 Z28
  52. 2009 CTS-V dyno tune
  53. So how bad is the low pro edelbrock 4150 elbow...results inside
  54. Bolt-on Z28 348/355, 414/430 on spray
  55. Whats the difference......
  56. Question about my Factory Freak WS6: 343/361
  57. First ever Wegner built Magnacharged LS3 makes 914 hp & 870 tq
  58. 408 w/ MS4 STOCK 799s LS6 intake Mac Mid Headers - Place your bets!
  59. low l92 numbers with a 229/236???
  60. Results after just a header+ory and ssra
  61. EPS cam only ls6
  62. 6.0 T/A Dyno problem
  63. got the 233/239 installed... low #'s?
  64. th400 383/old 346 stalled 4l60 dyno numbers
  65. Dyno, Bolt Ons Only!!!
  66. Nice 427ci results
  67. What are Bone stock 08 LS3 Corvettes Dynoing 6 Speeds?
  68. 228/232 Custom Grind Ls1
  69. 2010 gmc sierra 1500 4.8l 4wd 4l64e?
  70. cam only 6.0 lq9 in my SS
  71. Opinions on Rwhp > Crankshaft HP?
  72. low ms3 numbers
  73. D1-SC Procharged C6 results :)
  74. Stock Shortblock 2004 LS1 GTO 6-speed.... Not too shabby!
  75. long awaited tune.. FINALLY.. results!
  76. what gain would you get going from maf to speed density?
  77. LS6 cam 6.0, GT45 Master Power turbo, 602/573
  78. 403LS2 with L92s on e85 ... 532/476
  79. Cam-only LS2 C6 Vette makes 503rwhp
  80. LS1gto LT's cam, tvs2300
  81. Stock Cube 98' Ls1 Dyno results
  82. 230/242 6.0L results
  83. Engine Dyno Headers
  84. ECS n/a cam results
  85. RWHP Post Em Up
  86. TSP 233/239 Cam Only
  87. AES 442ci LS stroker on the dyno
  88. EPS cam, STEM 241's, Typhoon intake go 450/423
  89. Follow up results, Frost Tune and Bolt On's 2000 Trans Am
  90. How much HP to spect?
  91. Huge thanks to Vengeance Racing.
  92. 98 trans am dyno results!(vid inside)
  93. Videos Added!!! Mustang Dyno, TSP 233/239, Huge Converter & 7,000 RPMs
  94. Tall Deck Dyno Results
  95. Baseline Dyno
  96. new dyno numbers help plz!!!!!!!!!
  97. my bro's trex cammed ws6
  98. AES 402 on the rollers (C5 M6)
  99. LS6 cam swap results
  100. Any ideas what this could be?
  101. Dyno #after my H/C install
  102. Dyno'd my solid roller 418
  103. 2004 Procharged Trex M6 GTO
  104. C5 Corvette: LS1 w/ Bolt-ons (automatic) TDC Tuned
  105. 418ci heres my results, but still want more, please chime in
  106. Cam Head install finished and dyno'd
  107. Vengeance VRX5 dyno results (LS6 engine) :-/
  108. My LSX
  109. Have an engine dyno sheet, what is the difference between A/F and AFR-R
  110. Another TR230+Longtubes dyno tune
  111. 402 Ls2 Stroker, 516 rwhp 488 rwtq
  112. 416 dyno results
  113. Any 400+ cubic inch guys running a Super Vic or Vic Jr?
  114. 380 rwhp Heads/cam LS1- Help needed
  115. Formato's Florida Tuning Schedule for July:
  116. 404ci w/ prc 237s
  117. Turbo GTO
  118. highest dyno number with TSP LS6 2.5 ?
  119. Dyno #'s Comparsions 224 cams
  120. Finally got tuned after PRC LS6 head install
  121. 465/444: Late Model Racecraft's (LMR) stage 2 cammed LS3 in 98 Z28
  122. 5.0 vs. LSX and the world! dyno sheet comparisons!
  123. Finally got a tune (vid uploaded)
  124. Mamo Ported 102 Fast LSXR LS7 vs. Ported LS7 Intake - Results
  125. 2011 GT dyno results...
  126. Ran the car on with a G-tech
  127. Dyno results from Friday
  128. maggiecharged 08 G8 GT
  129. Trick Flow 220 Results
  130. NEW 226/234-113 EPS cam only numbers!!!
  131. Anyone have a e85 n/a Before and After dyno sheet
  132. Hand ported 853 heads from 2002 with a TR224 cam, GUESS!
  133. whats wrong with this pull >>
  134. Who runs a low lift/medium duration cam?
  135. How much does lower compression affect an NA engine?
  136. C5 bolt on dyno
  137. 388 hp
  138. EPS Cammed Z06
  139. Ms3 Cam only A4 98 Formula
  140. how much diff will running on 7 cyl make?
  141. Do you think it will break into the 11's?
  142. new setup with dyno numbers
  143. Dyno estimates for the new setup?
  144. 2002 Camaro SS RWHP results???
  145. Numbers with the jug....
  146. Dyno results ls1 gto FAST 102/102
  147. 2000 TA on a mustang dyno
  148. New tune, new numbers *UPDATE WITH TRACK TIMES*
  149. Why is my torque so low?
  150. What else can I do for a safe dyno session?
  151. CSP Grand Opening $200-250 Dyno Tune RESULTS THREAD
  152. how to get std/sae numbers from my uncorrected numbers? dyno issue
  153. 506hp ls1 383 Edelbrock RPM Xtreme heads
  154. what do you think about my dyno?
  155. 317 heads 460rwhp
  156. LS1 SS with long tubes and hot cam dyno results
  157. Disappointed with numbers!
  158. new numbers 240sx H/C
  159. question about my dyno results
  160. LETHAL / PRC LS7 heads / boltons / nitrous dyno numbers (Help)
  161. Bolt-on car with stock results
  162. sae dyno #'s
  163. Killemalls 2003 viper dyno
  164. 2010 L99 Camaro Exhaust & Intake Dyno Result
  165. Hott day or off numbers possibly outflowing something
  166. Need a guessestimate on hp for my 67 ls1 camaro
  167. My First LS1---Cam Only
  168. Forged LS6 w/ D1sc
  169. Has anyone cracked 500rwhp with a4,hyd cam, ls1?
  170. Livernois Motorsports New AWD Dyno-Jet
  171. PRC 227 Head / Torquer 3 Camshaft Results
  172. PRC 227 Automatic Dyno Results
  173. bolt on record
  174. 6.0 LQ4 A4 Budget build Numbers But need an increase.
  175. Stock Bottom End LS1 GTO
  176. Head/Cam A4 numbers
  177. 06 Z06 LETHAL Stage 4 - Ragin Racin
  178. post 1998 ls1 dyno's
  179. Updated - 403 Race Motor with Dyno Video
  180. tune and dyno
  181. Dyno Tuned "El Torro"
  182. 243's prc, cam , longtubes dyno number?
  183. Finally Dynoed my ride
  184. Locked vs Unlocked torque converter, how much power difference?
  185. First dyno results
  186. Smoothing on Dyno Sheet?
  187. SLP cat-back 293 HP/305 Torq
  188. 403 RWHP cam only (MS3) , on MUSTANG dyno !!!
  189. 2002 SS TFS 215's-FAST-102 = 458 rwhp 421 rwtq
  190. looking for 383 ci numbers
  191. highest NA dyno with a FAST intake?
  192. EPS 230/242 cam in stock head lq9
  193. 403 tfs235 low dyno numbers
  194. G-Force Stg III C6 Z06 with interesting results!
  195. l92 bottom end with prc 5.3 stage 2.5 heads
  196. 2010 Camaro LS3, MTI Stage 3 cam/headers Dyno
  197. Iron Block 370 W/ L92 Heads, L76 Intake
  198. New Era Streetsweeper cam dyno results flowmaster catback and open cutout vids are up
  199. HPE C5 Z06 w/ 418 LS3
  200. 907 RWHP through a TH400 and 12 bolt
  201. 418ci ls3, Is this low rwhp numbers
  202. how much wheel HP am im i making
  203. Comp224,Patriot Stg2(59cc),FAST92/92,Vig3600
  204. G-FORCE Stg III 2010 L99 Camaro SS
  205. How could this be?
  206. dyno cross at 5252 rpm...?
  207. forged LS1 LS6 int & TB stock cam - just add T78
  208. 355 LT1, AI Cam W/ Victor junior and 750 HP Holley on engine dyno
  209. i want some opinions or comparisons
  210. (not LS1's) Dynoed my shelby GT and bros supercharged GT
  211. 6.0L L92 ported heads 227/235 cam Dyno
  212. Thunder Racing's Brand New Stroker Cam is Unleashed
  213. What to expect from a little 224 cam?
  214. 2000 SS cam and bolt ons dyno results
  215. Bolt-on LS1 with TH400.. dyno results
  216. Evolution Performance - First 2011 Mustang GT in the 11's
  217. G-FORCE Stg IV 2008 C6!!
  218. LS6+ streetsweeper HT "cam only" 440hp/409tq
  219. Mustang dyno vs. others
  220. Cam only 2000 ss
  221. Dyno help!
  222. Performance Induction 215LXR Dyno results!!
  223. What do you think of these? anything wrong?
  224. Missing power somewhere?
  225. H/I/C dyno prediction?
  226. 5.3 with LS6 cam
  227. Finally dyno'd
  228. 454 with TFS 245's/Fast 102 makes 705 hp/630 tq *599 rwhp* *video* *9's N/A*
  229. Is this good numbers?
  230. A&A Supercharged C5 Corvette A4 Results
  231. TEA/TFS As Cast Cylinder Heads/Pulley Pick up 54RWHP/35RWTQ
  232. Horsepower TV E-Rod LS3
  233. kinda of a dumb question about cam and dyno
  234. New numbers with TFS 215s
  235. Gained 33 hp / 27 tq with Fast 85 and underdrive
  236. dyno c6 m6 402 f1r
  237. Results from Gettysburg Tuning Trip - Dyno Results Inside
  238. Cam only. What do you guys think of the power numbers it put down?
  239. 2010 Camaro SS LS3 bolt on dyno #'s
  240. LS3 + Lunati 65602 cam
  241. A4 Mild Bolt-On Car 328/352
  242. Got some numbers today...
  243. Confused with results
  244. 2010 SS + Rapid Cam Results
  245. tuning Gear change in automatic, how much ET will drop from tuning
  246. building mild ls2, difference on dyno or non dyno tuning
  247. dyno gains with kooks and ported fast
  248. Obvious dyno issue
  249. My cam only #'s are an epic failure.
  250. My stock engine A4 w/4000 stall #'s
