View Full Version : Dynamometer Results & Comparisons
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
  1. The "Do I need a tune" question
  2. G-Force 2010 Camaro L99 #2 TVS 2300 Results
  3. I could use some opinions on my numbers.
  4. G-Force CAM ONLY C6 Z06 Dyno and Vid
  5. American Racing 1 7/8" headers, tune add 50rwhp to 2009 G8 GT
  6. Locking The TCC When On Dyno
  7. G-Force 2010 Camaro w TVS 2300 Results
  8. G-Force 2010 GT500 = 770 RWHP!
  9. G-Force F-1C Procharged Z06 Results!
  10. 1969 Camaro w 427 LSX and TVS 2300 Blower Results!
  11. need help with head n cam car
  12. '06 GTO cam-only results...
  13. LE2 Stock bottom end lt1 426rwhp 393rwtq through ford 9"
  14. 02 ls1/ 280z/ nos...
  15. LS1 RX7 Dyno Results
  16. cam,nitrous and 149k =!!!
  17. cam only F-body 443/405
  18. Tuner to Dyno car in 2nd gear
  19. 01 ss camaro
  20. 2010 Camaro w/ Thunder Racing Camshaft
  21. 603 rwhp 583 rwtq - LS3 427 NA!!
  22. C5 TFS 515hp Top End Dyno
  23. C5 T1 Road Race car Dyno
  24. C6 LS2 Hot Cam Dyno
  25. Yella Terra 1.85 rocker on L92/LS3 heads dyno results
  26. Cam Only with LS6 Intake Dyno Results for my 1999 Trans Am!
  27. 491rwhp & 429ftq
  28. just got tuned up what do you guys think?
  29. 1998 C-5 shop car budget build..
  30. Just got tuned at MASPORT --Dyno numbers inside--
  31. Dyno Results
  32. 01 ws6 dyno
  33. why are numbers so low <dyno graph included>
  34. need ms4 cam dyno charts
  35. G-FORCE Stg II LS2 C6 Dyno Results!
  36. can you lock and unlock converter while on dyno
  37. lq4/l92 06 Sierra
  38. Another Trans Am Dyno...
  39. HKE LS3 427, TFS 235's w/ track times
  40. Ragin Racin Stage 4 Stalker Cam 557hp/513tq 10.8@137mph **Video & Graphs**
  41. Procharged C6 Z06
  42. stall converters and dyno numbers
  43. American Racing 1 7/8" LT results on G8 GXP M6....
  44. SAE conversion .96?
  45. Crappy Dyno...What could it be?
  46. LS1 cam only + 150 N20 A4
  47. 383 Cam choice?
  48. Race Proven Motorsports 520RWHP H/C LS2
  49. Most power NA with a 5.3 head any cubic inch
  50. G5X3 Cam Only Dyno results
  51. What would cause this?
  52. Will a fan change dyno numbers?
  53. low number in my maro!! any suggestions
  54. 04 GTO, cam/intake, results
  55. What are dyno tricks?
  56. 370 and D1SC numbers
  57. Cam Only A4 critique my numbers and dyno graphs
  58. Retune:465/430 is there room for more?
  59. My LT1 is running extremely lean. need help.
  60. How do these numbers look?
  61. 402 with itb's headed for the engine dyno-updated 700.1hp
  62. RR-STAGE 4 on Nitrous and Methanol *VID*
  63. Truck Coils MYTH PROVEN INSIDE
  64. dyno question
  65. 528HP 491TQ.... BUT have you ever seen a graph like this!?!
  66. Low dyno numbers??? Am i wrong?
  67. 410/370 h/c/i
  68. MS4 + 799 heads + slipping clutch = 417 rwhp, 390ish rwtq
  69. 04 ls1
  70. Ms3 Cam Results..
  71. GXP stock Dyno
  72. dyno run: TR 20 cam, ported ls6 heads, lpp headers
  73. dyno day
  74. TR 230/224 = 416tq / 411 hp
  75. NEW N/A Trick Flow Head Record
  76. Another cam only 500RWHP C6 From Vengeance Racing
  77. Vengeance Racing Stage II LS3 Camshaft Installed in C6/A6... Pics/Video/Dyno Results
  78. LS7 Installed in 2008 LS3 C6 by Vengeance Racing... Pics/Results Inside
  79. My 408 Results... I Think I need a Converter...
  80. Bolt-On A4 Dyno numbers (seem high)
  81. Disappointing 408 Results
  82. TFS 225, TFS Stage 3 CAM Dyno Results inside
  83. MS4 Cam Only, before I sheared a rocker bolt**
  84. 2000 camaro dyno what ya think?
  85. LSX BMW M3 little down on power? your input
  86. AFR 205's + 228/228 113* = 500 RWHP!!
  87. (GOT NUMBERS) Going To Texas Speed on monday morning for dynotune!
  88. Any vendors ready to come clean - LS3/L92 FAST
  89. 402 aps turbo with LG upgrades 852 hp 15psi
  90. 799 Heads
  91. FLIP DRIVE - Finding the limit on 6 rib blower drive - Part II - 21 pounds of boost
  92. Finally got my car dynoed!!!!!
  93. Good or Bad Dyno Reading?
  94. Dynoed AFR Heads VRX2 Ported Fast 92mm
  95. Dynotune today, numbers seems low?
  96. 55chevy ls1 dyno results
  97. 2002 Z-28 swap to truck coils.
  98. C5 dyno opinions needed
  99. 418ci high compression budget result cut-out o[en and close
  100. 382 rwhp does this seem right for what I have?
  101. What wiring harness for dyno?
  102. Dyno results - poor parts combo?
  103. My C6Z dyno vs my old cam'ed LS3 dyno
  104. Super Vic on 347 results.
  105. Speed Inc 2010 shop car / 100 octane results
  106. Here are a couple "Before & After" vids...
  107. Speed Inc. 2010 SS 600rwhp / TVS2300, Cam ,LT's
  108. Early dyno results : 01 SS, Homebuilt MPT76 Turbo, Junkyard 6.0 ---->
  109. 2010 SS 7psi procharger/689hp&640tq
  110. Hooray i finally got a tune!!!
  111. 01 m6 SS exhaust and lid dyno numbers, any good?
  112. G-Force 1100 HP GTO!
  113. Working the dyno
  114. 385 Solid Roller Dyno Numbers on E85... 520rwhp
  115. Dynocom results for my C5 daily driver
  116. 02 5.3 with Edelbrock and carb.
  117. PTK / 'eBay' turbo kit, stock bottom end
  118. Can I make 400whp with this setup?
  119. Engine Dyno Testing LS3 Intakes INSIDE!!
  120. 388 corvette c5 dyno results
  121. 416 LS3 TFS Dyno Results
  122. 68 Camaro
  123. COMP Lsr Cams
  124. 402 MS3 Dyno results
  125. Looking for a professional tuner for my LS1
  126. Looking for highest Hp 383 N/A combo
  127. 427 LS7 Dyno results with Vid
  128. TFS 215's/TSP 228R Results
  129. 2010 Camaro SS FAST LSX-R 102mm results
  130. MS4 02 Corvette Z06 results
  131. Cartek 4-XS Heads and Cam results inside.
  132. ls3 Vette-ported heads and cam 521rwhp
  133. Cam only LQ9/LQ4 Numbers
  134. 99 camaro and 04 gto low numbers? Does this seem right?
  135. APS C5 Mild Street Build
  136. LS3 Engine Dyno LSA & ICL Dyno Comparison!!
  137. 5.3L R1900@12lbs + 75 nitrous = 626hp
  138. Not an LSX, but an impressive V12 twin turbo Mercedes
  139. back from the dyno
  140. G-Force TVS 2300 2010 Camaro Pics and vids
  141. Dyno & street tuned stock 06z
  142. N/A 370ci dyno results.......sorta
  143. Dyno results: 01 WS.6 Full exhaust and lid
  144. Vehicle lookup chart
  145. cam only C6Z06 568rwhp
  146. SAM 433ci LSX breaks 1000HP N/A
  147. Pat G spec cam results 226/230, Mike Norris tuning
  148. '02 C5 ZO6 A&A/T-Trim results inside!
  149. Dyno result and opinions needed
  150. C6Z06 879rwhp,823rwqt @13 PSI
  151. Bolt on FRC on dynojet
  152. Any results? LS6 cam plus heads?
  153. Whats the point posting final results and no baseline?
  154. Dyno Day in a Few Weeks
  155. Cam only LQ9
  156. WTF is up?
  157. 454 LS7 2010 Camaro SS Dyno Numbers!
  158. Chasis dyno and great tuner in Detroit area
  159. My LS2 Dyno numbers - rear engine sandrail
  160. PredZ cam only 347 results. Thanks SpeedSouth
  161. Trans am WS6 Cam only Dyno results
  162. AF ratio help
  163. lq4 build
  164. abs inop
  165. Race Proven Motorsports Stock C5Z W/ A&A Kit
  166. LG-G6X3 on a 2006 C6 Corvette
  167. LS6 Cam Only Vindicator with boltons
  168. 344 rwhp for bolt on a4 ok?
  169. Budget 408 makes 500rwhp with ls6 intake
  170. header only 2010 makes 407 rwhp / 404rwtq!!!
  171. cam swap low on power?
  172. numbers on prc 215 and tv3
  173. Would you risk dyno-ing this setup??
  174. LMR works on Vipers too!
  175. 2010 Camar SS
  176. Speed Inc 2010 SS updated #'s
  177. Horrible day at dyno
  178. Big converter loss
  179. My first tune ever. I'm happy with the #'s. Comments?
  180. Dyno shop AFR hook up at the tailpipe
  181. help guess new rwhp numbers?
  182. Crappy day on the Dyno
  183. '09 LS3 21st CMC Stage III Cam results!!
  184. 350RWHP on stock LS1?? Broken Dyno or Freak?
  185. G-Force 440cid 2004 Z06
  186. Meziere EWP and MS3 112...
  187. New numbers: 396ci, D1-SC, 18psi, A4, 808RWHP.
  188. aparently you can make good power porting a FAST
  189. My 2010 SS TVS Blower / Blower Cam / ARH Catted system / ADM Intake results
  190. Carbed combos ????
  191. 416 / 04 GTO dyno results
  192. Retune ?????
  193. Newest Dyno Numbers 2005 CTS-V
  194. 2010 Camaro w/ American Racing Headers
  195. LS6 baby cam dyno numbers.
  196. just wanted to say thanks
  197. Stock LS3 Engine Goes On Dyno @ TSP LS1 vs LS3 Dyno Inside!!
  198. Another badazz L92 GTO
  199. Anyone have dyno Comparson: SC vs Turbo
  200. Looking for a dyno sheet 5.3 stock, 5.3 with procharger
  201. POLLUTER cam RESULST, PICS, VIDS, SHEETS
  202. For everyone who thinks the MS3 is "too big" for a DD
  203. 2008 c6z06 & aps tt
  204. 01 SS bolt on/ms3 numbers
  205. Dyno Guru's, I have a question?
  206. Dyno Operation
  207. 402 w/ L92 heads... another wrong cam
  208. G-FORCE ProCharged Stage IV C6 Z06 Package
  209. Vengeance Racing 440 LSX Dyno/Video/NITROUS results inside!!! 819RWHP/909RWTQ!!!!
  210. 383 Intake & Header swap power?
  211. my truck on dyno
  212. G8 A6 GXP Dyno numbers and vid!
  213. FAST EZ-efi results
  214. Vengeance Racing builds 496 Warhawk... Dyno Graph/Idle Video/Pics Inside
  215. Anyone care to predict my HP/TQ output?
  216. cam only LS2 dyno graph - 414/386 to the wheels
  217. Need your help
  218. got my truck dynoed.....
  219. 2008 corvette numbers
  220. Thanks NLP!!
  221. Dyno results: TSF 215'S, Vindicator, FAST 92, TH400, 9 inch
  222. My Dyno Numbers on my C5
  223. Dyno Results: Bolt-On Modifications for 2010 SS - 402 rwhp
  224. No BS dyno test of Vararam CAI for G8
  225. ls2 swap numbers...
  226. Gained 20RWHP/58TQRW with only powerbond underdrive pulley !!
  227. Ls3 g6x3
  228. LS7 Z06 goes 589/536 NA Full Exhaust.. Dyno/Idle Clip Inside
  229. 2010 Inferno Orange 2SS in for SW full exhaust
  230. Comparison of Trick Flow 220 As-Cast and 215 heads please
  231. Stock '09 LS3 dyno **389rwhp***
  232. PRC Stage 2.5 LS6 & Torquer 2 Camshaft Install Completed!
  233. Backwards cam! 98 Z28
  234. ls1 500HP?
  235. Patriot 225/229 Cam LS1 results. on a Mustang Dyno
  236. dyno estimates?? h/c zo6
  237. just got back from RPM. stock internal tune.
  238. Does this look about right for my mods?
  239. Formato Tuned and Texas Speed H/C C6 Z06 586 NA rwhp
  240. 6.0 GTO L92 heads 508rwhp
  241. Another strong 87 octane G8 tune
  242. Va Speed/APS TT Goat
  243. 402 with TFS 235's
  244. 91mm turbo dyno
  245. Help me with dyno numbers
  246. Speed Inc. 2010 SS TVS2300 results
  247. Someone Help me understand these low dyno #'s please..
  248. 404 LS2 dyno results...
  249. home ported fast yields big #'s
  250. 08 vette, novi 2200, ARH long tubes w/cats
