- Delrin Bushings finally available and upper control arm modifications too :)
- Interest in Delrin Cradle Bushings ?
- 2005 cts-v -sold-
- Starter dead?
- Just back from the dyno
- Engine Temp Question
- bushings
- V issues
- Finally did my creative steel mount today
- Help!! Ls7 clutch not fitting in 05 CTS-V
- Looking at a '04 CTS-V ... any known problems?
- stock (azn2dmax modified) shifter grease?
- Picked up some 18x9 team dynamics racing ProRace 1.2's in black...
- question for you aftermarket radio users
- 2011 coupe goes 11.44 at lsfest
- Obx header resonators - do they work?
- Three pictures from some fun today..
- Slave Cylinder???
- Interior Lighting
- Newish V1 owner, looking to run Nitrous
- WOT, c0242 code, REP mode, T/C light
- Horn----eew!
- oem vs gm performance water pump?
- dyno tune today. make your guesses what it puts down!
- ls2 Throttle body
- The inevitable is happening... Who wants to trade exhausts??? Lol
- Front sway bar bushings
- sad day.......
- trunk tie down part #?
- Front license plate?
- 8 rib setup
- Bass tubes?
- quick question about rear diffs
- ti brake shields
- Cam ideas
- Any cheap ass wheels that will fit the V? Don't need to be nice....
- need ideas on new brake pads
- Air bag, abs AND T/C lights are all on after seat swap. Help!!!
- Just got a 630hp CTS-V
- Went to the dragstrip Saturday
- LS7 clutch kit on Ebay - compatible?
- Fuel pump/sending unit plug pins
- Stage 1 'low hanging fruit' mods complete - Dyno results
- Best head and cam combo
- Missing windshield antenna parts?
- push button help 06
- P1637C Generator L Terminal Circuit
- 265/35 all around?
- Need a starter!
- Battery light on, but charging fine
- Stiff Clutch Pedal
- cts-v cold air mods?
- Rounded Oil Drain Plug?
- A Camaro Shifter fits a V? Yes it can
- 2012 Hennessey Twin Turbo V1000 CTS-V Coupe
- quick burnout in my V
- Cts-v forged monoblocks | 345/25/20
- exhaust wrapped headers, to trans, wrapped oil pan
- Well i'm making the jump..
- 8.8 Swap axle questions
- How to change CTS-V Upper Dash Pad by Windshield
- 09-12 CTSV engine compartments
- Slave or Master LOL Need help
- Any modded, low mileage V1's for sale?
- Maggie Heat Exchaneger replacement Price
- Shifting issues
- 2nd gear burnout
- Some new pictures of the Caddy
- Projector Halo Foglamps
- Dyno numbers
- Houston V meet
- Black Cadillac symbol
- CTS-V E-Force thread (open to all E-Force builds and questions)
- time sert
- Any good shift knobs?
- Battery change to an optima redtop weight added 5 pounds
- Looking for autocross tires
- Commodore shifter interchange
- A Few Daytime Picks With The ChiCity Back Drop
- Tranny fluid change... What fluid do you guys suggest??
- Think I need new motor mounts?
- Rearview Cam Added
- Headers & catalytic converters - what's the scoop?
- 2009 CTS Driveshaft knocking noise
- ATI Super Damper Install on LS2 V1
- Aftermarket Harmonic Dampner for V1
- Noob question...CAI for V1
- Buying a CTSV thread...
- im back from the grave! sadly not in a cts v but....
- LS9 clutch question
- Lets talk clutches!
- speed sensor A check engine light.
- anyone heard of these guys?
- Help with 2005 CTS
- Extreme Composite Hood and Bodywork
- powder coating wheels does any one know of a exchange program
- how much play should the gear have?
- lifters
- I finally got my benchmark
- 408 installation is done (as of 8/25)
- Belt tensioner for supercharged cars?
- UMI Motor Mounts best price?
- p2135 code
- User Tuning
- radio buttons
- Looking for Exhaust
- Best place to order lowering springs?
- What could be leaking?
- Leather repair?
- Vengeance Racing CTS-V Coupe 591RHWP/604RWTQ DETAILS/GRAPH/VIDS/PICS INSIDE
- murdered out florida V in monroeville pa
- Seeking your experiences (and sound clips)
- Grey interiors - how do you clean your headliners & doors?
- Battery ground = engine light?
- Best lowerings springs for 05 v?
- I want to convert to E85
- High oil temps/fluctuation
- XM iPod interface issue. Help?!
- Stand-still burnout issues
- It lives!!!!
- Monster Clutch Remote Bleeder Installed
- Lingenfelter CAI poor fit on 06 V
- under hood temp stop working
- Check steering/stability system, service vehicle soon. Random heavy steering issues.
- Just got CTS-V.. Snow tires?
- DMH low profile cutouts are installed... Wiring questions?? Come on in cutout guys!!
- Traded the C for a nice V
- has anyone herd of these?
- TVS from 2008 G8 GT
- Stability control/traction issue???
- Need Feedback on My Aftermarket Stereo!
- D3 Partners with Cadillac for the Cadillac Performance Drive Sweepstakes
- Pacesetter o2 extension part number?
- 8th Day Creations
- Difference in model years
- Symptoms of a failed driveshaft cv?
- Want to install my sound system few questions
- Matte White Dip
- LED Turn Signal No Worky
- audio question
- Anyone experience a clunk with their CS 8.8 kit??
- Noise in rear question
- Redline/Infrared V's with tinted lights
- Spark Plug Question (Newbie)
- ls9 CAM
- ls2 throttle body
- Headers/cat back install question
- CTS-V Thottle body porting (Money back guarantee)
- Replacing radiator- HELP
- Driveshaft /Toe Rods/ Axles Value?
- Teaser!!!
- 422 RWHP / 383 RWTQ - Dyno Tune @ Slowhawk - Results!
- Odd Coolant leak
- CTS-V Gen 1 to Compete at Fontana in the Cadillac Challenge
- Kicking it up a notch with AFR heads
- Dyno Results on E-Force
- anyone other than Cobra98 put an LQ9 in a V?
- My Oil Tempertature went above 300 Degrees
- Any V owners coming to Holley LS Fest in KY!?
- Rear Diff Bushing Replacement Help
- Suede Headliner & Interior DIY
- Alradco with maggie.
- Wow.......
- Murdered 2011 V Sedan Finished
- Hard wire radar detector install
- Did anyone notice an increase in cabin noise from a CAI?
- Blank Info Display??
- Dyno tune results from 2.6" pulley and 50/50 meth
- OBX headers leaking-- what to do?
- Head/Cam Install Results with Video
- idle videos with cam, heads and corsa
- Slave Cylinder Question
- Another v gone..
- More LS7/Any Clutch, Slave and Flywheel Install Tips
- Custom bumper speed holes?
- V2 searching
- I'm a Cadillac salesperson now
- Katech Shifter Shift knobs Solution Found
- USA SPEC install question
- LS2 Throttle Body to LS6 Intake Question
- My EQ Settings Keep Changing When I Change Radio Station, HELP
- New steering wheel-- F***ING KNUCKLE-DRAGGER MECHANICS
- Lazy poster alert! Rim question! ;)
- New Project, just checking off my parts list.
- steering wheel shake
- Those that have replaced their Steering Position Sensor
- CTS-V Factory Race Car On Auction
- Easy Way To Lubricate The Rear Diff Bushing?
- Rear shock replacement
- G-force axle clicking?
- What exhaust to get?
- Where to buy headers?
- Anyone looking for a deal on an 06 V in Houston?? My buddy is selling his car...
- Jacking points
- Installed B&B 3" exhaust... PICS and CLIPS!!!
- Sick of the heat inside this car..
- supercharged V(Edited because I can't spell)
- V1 Dash Center Speaker Size
- 90 degree elbow silicone adapter reducer
- Houston Coffee & Cars....This Saturday
- Battery Cover
- Can you rebuild the diff?
- Electric Water Pump
- SPEED INC.- Mike's 2012' CTS-V Stage 2 package results
- My Dyno Numbers & Tune Question
- HID Headlights D1S
- exhaust center support bracket broken bolt
- Let's see your other rides!
- Pulp Fiction in back seat? WTB Black Rear Seat Bottom
- Front Upper Ball Joints? Servicable?
- Installed Brakemotive rotors and pads tonight...
- Recommendations for header gaskets.
- tinted cts-v headlights for sale on Ebay
- Trying to figure out what it's worth?
- Drove Part-Way Across the County and Back
- Insurance Adjuster
- Installing ground control kit this afternoon... Any tips to make it easier??
- new member, Modded V inside
- ABS light????
- Fooling the TPM system for trackday
- A couple more pieces
- IAT Relocate - Parts?
- Rear end feels like its drifting out on corners. Not the tires. Any ideas??
- Question about crank pulley
- D2 Coilovers
- OBX and KOOKS questions along with primary size pros/cons???
- Tune in the Northeast?
- High oil temp
- Need 2nd set of wheels for summer/track- H&R drop, Suggestions?
- How to connect clutch slave cylinder to master cylinder
- I'm looking to trade a C for a V
- Coffee & Rides San Antonio
- Seat has mind of its own?
- Solid Subframe Mounts!!! Check this Out!!!
- Need some updated info
- That Just Happened Too (Maggie Version)....
- Catch Can
- Fu@kkkk!! Help please!
- Anyone ordered Revshift mounts lately?
- Trip/meet in the Mountains anyone?
- That just happened........
- Annapolis, MD Car Show
- Searching for a V1, need more info on this car!
- Potential new V owner
- Black Chrome wheels
- I'm buying this car. Anyone recognize it?
- 2005 Head stud kit?
- Dyno tune spots in Maryland
- Service Manual, E-Books & Software Share
- Back from the Dyno...
