- Replaced clutch/flywheel/slave = HARD pedal
- Any weight reduction to be easily done on V1'S
- 04 CTS-V Shrader Valve??
- That darn vibration issue
- ticket doing 63 in a 65 zone
- Black mats on grey interior - black or ebony?
- Any interest in a CTS Console for aftermarket DD sized head unit?
- Hilarious!
- FYI - traded in 2007 CTS-V
- The Cadillac Challenge Rd. 1 Recap
- My v against 2 stangs
- Seal between the driveshaft and transmission
- Makes it hard to invest in a V1..
- Shifter bolt size
- 2010 V hit the Dyno
- new owner Revshift + shifter ??
- matte green cts-v
- Driveline Vibration?
- Lost a headlight washer cover... Where can I buy a replacement???
- Outer CV clamp size
- Transmission noise after fluid change
- Parts needed to transform (08-13) CTS to CTS-V?
- another V1 homemade gauge pod
- For those who have Nexflix, V1 Top gear U.K. review.
- Needing driver's side headlight
- 05 v MOST ANNOYING DOOR CHIME IN THE WORLD
- Looking for help
- I killed a set of tires in 9k miles. Thoughts on the Nitto NT555?
- 2014 ATS-V car and driver
- Ls7 clutch help
- $820 shipped for (4) 18" STS-V wheels?
- Highest HP stock block LS2???
- Odd request. Oil dipstick...
- The cure for drone-- 1/4 resonance pipes aka J-pipes aka Helmholtz tubes
- Steering Wheel Mod
- High Speed runs: Twin Turbo CTS-V - 911 Turbo X50 - SRT-4 and Turbo Civics
- 04-05 vs 06-07 magnaflow exhaust?
- V2 supercharger on ebay
- I know I'm ghey (V logo ghost LED group buy) thread
- 07 PCM Issue - Battery Drain issue?
- so i got extended warranty today
- Drop 8.8 with axles still in the car ?
- Quick pay pal question
- Maggie guys with slip issues: check this
- Cam with stock manifolds
- V2 production numbers??
- rear end motor and trans build
- 05 v front end vibration...sometimes!
- Leaking radiator.. GM cooling system tabs?
- Intermittant "Battery not charging"
- G-Force Driveshaft(s)??
- Rear LED Tails for V1
- should i matte white plastidip my entire V1?
- T-56 Rebuild Manual & More
- fastest V1 1/4 mi pass?
- Gold Plasti dip wheels
- 780WHP DYNO - Twin Turbo CTS-V
- V1 fuel pressure regulator where is it???
- wtf? my sunroof has a mind of its own.
- Anyone use ATF instead of power steering fluid for their V?
- need spring rates for REAR coil-overs on V1
- Hey all, it's been a while and need me some motor mounts...
- a little fun in mexico
- Headlight ?'s!!!!
- 2007 CTS-V Twin Turbo vids
- broke the V
- Is anyone running a 1 piece Driveshaft?
- CS new trans mount
- Removing Stock Exhaust Manifold bolts- CRC Freeze Off!
- Diff fluid change after 500mi, pics, and questions
- AMSOIL Order
- so i finally bought a ctsv
- Looking at an 05 V this weekend
- Let's talk Heads
- Painted (VHT nightshades) by 3rd brake light and reverse lights.
- Don't know what's wrong
- Beginner Modding-Advice and what you would have done differently
- Hello All
- 06 cts-v dyno run... updated with results
- Nav disc wanted
- going to go look at a v.... 04-05 issues help
- 06 CTS-V Navigation/Radio + Steering Wheels Controls
- Heated seats no heaty
- Some input plz
- Found why the FOB, TPMS, and trunk not working
- Some Video from the CTS-V Rental 2/23/13
- Will MGW work in my 06 V1?
- wtb ctsv but confused
- Cts-v purchase advice specific vehicle
- 8.8 swap and axles/driveshaft
- bay area V meet at c&c 3/3
- CTSV with LS3
- 2005 CTS-V & 2011 Mustang 5.0 Teaser Video
- power steering pump
- if it was not for the snow right now, I would be installing these..
- rolle call for tx2k13
- anyone use the KaleCo AWD kit on their V1?
- Harmonic Balancer
- amp wiring
- Revshift Motor Mounts A+
- got a (new for her) ride for the wife, what y'all think?
- Looking at Parrot Asteroid Smart headunit
- Engine cover before & after
- CTS-V Shootout at PBIR (Florida) 2.23.13
- made some new stuff for my V
- Does any one have an HP Tuner in DFW area?
- What do I need to do befor headers?
- Best place to buy QA1 shocks ?
- Stock Lugs
- headlights question
- NEW GM Releases
- Just ordered...
- Anybody running 275s?
- Zero oil pressure!!
- Group Buy Feeler: T56 Stage 2 Rebuild Kit
- Another exhaust mod
- New Mod to the V1...what do you guys think?
- I love my B&B exhaust but...
- no reverse
- Congrats to mike and the g force guys
- CTSV Front Bumper Cover find...
- Thinking of Selling...What is my car worth?
- Bad ABS Sensor - Service Stability System?
- I took my car apart
- Resistor for blinker
- Having brake problems please help!!!!
- Moog or AC Delco?
- yes another code thread...sorry in advance
- steering wobble
- Seat swap
- Weapon X Carbon fiber group buy poll
- My whipple manifold idea, well sort of.
- Fair price on blower and supporting mods
- CTSV VETTE C3 rear end conversion
- Driver mirror won't move to curb in reverse...
- V misfire.. NO CODES
- LSA clutch
- lets talk shocks
- Thunder gray Chromaflair touch up paint WA417P?
- *pics added shes home* going to look at a 05 cts-v. what concerns should i have?
- right turn signal activates high beams when lights on
- RevShift bushings/flexdisc install, car useless after 15mph
- LS3/Powrmaf Swap
- cradle bushings = shooting myself in balls with a gun
- New V1 Owner in San Antonio (updated w/pics...finally)
- Cam or exhaust first??
- Stock exhaust size
- 04 Ctsv with lemon law title
- Newbie | 2006 CTS-V | Intro | Mod Help/Input/Suggestions!!
- Creative Steel Motor and Trans mounts (whats your opinion?)
- nebody need a t56?
- Aftermarket Parts: What's Missing?
- Need some help finding stock wheels
- Bad Damper Symptoms?
- Need help ASAP! 2003 Cadillac CTS stabilitrak message on the DIC
- help. WTB STOCK LSA 1.9 BLOWER FOR TESTING
- V1 in Alvin
- Rear Tie Rods - Video?
- Finally got my V coupe!
- Few Questions As I Gather Parts
- Can a Ford Raptor fly?
- For those looking: '06 with 8,500 miles!
- supra rear diff
- Revhift Rear Upper Control Bushing Install
- Twin intank walbro install pics
- lifter tick drivers front?
- If you are looking for a CTSV in Houston....2.0
- Forged LSA with LPE ported heads...$5500
- Oil pressure high!
- Remote start Project
- coolant steam pipe crossover on modded engine
- End of rotation . . .
- 8.8" diff lets talk gears
- Stock wheels wanted
- rear door lock
- Pink / tan headlight
- Thinking of Selling My V
- Need your input please
- Another radiator question
- Front Bumper cover?
- what are all the bushings in the rear?
- Problems setting up Nick Williams TB
- Calif canceled the new smog testing
- door locks
- Stumped on a drivetrain noise... HELP!
- Looking for a few parts....
- High Pitched whine
- Oxygen sensor with longer wire
- Evap Delete
- 60 -100 ish
- 2012 CTS Coupe - Eibach Pro Kit / TSW 20x9.5 - 20x10.5 / Toyo 245 - 305
- FAST 102 & MAF Question
- Monster Clutch Sale - $100. off and FREE shipping
- Obnoxiously loud noises coming from speakers weeks after Double Din install SOLVED!
- plug wire question
- oil temp/level sensor installation
- Gen I -Fueling Idea - will it work (shrug)
- Broke Intake manifold bolt, can this be fixed?!
- 05 Stealth grey big cam custom turbo CTS-V (beautiful car)
- You Know It's Been a Long, Cold Winter When...
- Output Seal on Trans
- Rear Cradle Parking Brake
- fast 102 install on ls2
- Just got pulled over
- How to wire your LS6 car for a LS2 throttle body
- "un-paired" 2005 CTS-V Keyless Entry Key FOB - Help
- Air Ride?
- Coolant leak
- good find on ebay!
- 8.8 clunks
- GForce 2-Piece Driveshaft INSTALLED!
- Got my D2 coilovers on!
- Intake Filter Opinions
- Suspension & Rear End Mod(s) Opinion's
- High Pitched Engine Noise?
- Photoshoot (V)
- Revshift rear UCA bushings
- HID Fogs and Headlights (Pics)
- Throw out bearing #
- New rear end break in time?
- Dyno day for St. Jude’s Children's hospital fund raiser
- Underbody wind deflector
- Pinion Seal Leaking
- Removing Sun Roof ??
- Tech couldn't do CKP with a Tech2 scanner
- aftermarket clutch
- Help!!!!!
- Barrett-Jackson CTS-V
- Ridiculous Vibrations
- Colorado Speed Group buy on Hawk Harmonic Balancer Installer
- LED Ambient Lighting
- Group Buy Opportunity: McLeod RXT Twin-Disc 1000 HP Ceramic Clutch
- Revshift install
- LS9R, What Slave to run?
- Aftermarket Axles?
- Some pulls of my new 12' CTS-V coupe
- To tune or not to tune?
- Driving & Engine Building Video's Share
- [PICS] Before and After...New wheels mounted on my V1
- Shifter slack, bushings and linkage mod
- Textralia Clutch Question
- Let the madness begin (blower build w/pics)
- Pics of my solid subframe mounts
- Found a pool of water in spare tire compartment
- Bumper cover on CL, CTS-V maybe?
- Stock manifolds with hi-flow cats VS long tubes
- Custom made Alcantara shift boot made today!
- Purchased a V today!
