View Full Version : Cadillac CTS-V
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. clutch bleeding question
  2. CATBACK cat back? Confirm I'm not crazy...
  3. LSR grind cam
  4. Can I use my Fidanza Flywheel w/ a LS9 Clutch and pressure plate?
  5. Oil Pan
  6. 2012 Auto dynoed
  7. clutch issues...fixed..now new issues
  8. V wheels for sale or trade?
  9. Help me on a clutch
  10. New CTS-V Record
  11. Negative camber in rear wheels
  12. Rocker Question
  13. Imports vs Domestics this weekend!!
  14. LG Motorsports coil overs and G-Force 9" rear ordered!
  15. How much vibration after cam?
  16. So need some help with building my h/c V...
  17. New CTS-V 1/4 mile record, also done with stock motor/trans
  18. Coffee & Cars 11/1/12
  19. New cts-v 1/4 mile record
  20. Maggie 2.6
  21. Maggie uncharted territory 1:1 rears
  22. Heavy's ULTRA RADIO MODIFICATION
  23. 04-07 CTS-V Drop-In Dry Flow Air Filter
  24. Winter Maintenance
  25. Well.. Hurricane Sandy is almost here..
  26. Cts-v r u a milf
  27. More LED installed.
  28. taillight lens cover
  29. Not excited about the 1/4 mile times
  30. radio
  31. V1 what's it worth?
  32. new to me v
  33. Spectre CAI Intro
  34. Not sure what went wrong here...
  35. Hennessy CTS-V hits 220.5 on Texas highway
  36. Thinking about getting an 04-07 CTS-V
  37. Re-Pairing TPMS sensors = dead battery ???
  38. Maggie guys. ;big tensioner pulley
  39. 06 CTS-V Is this a good Buy?
  40. where can i find spacers
  41. Fire extinguisher bracket
  42. Wanna lower by 05... any suggestions?
  43. LS2 Pulley Squeak -- Need help determining which accessory (video)
  44. Electric cutout problems; Help?
  45. Lap Around Sebring
  46. Cadillac "The Lab" Performance day @ PBIR
  47. My stock LS6 V w/150 shot Dyno...
  48. First time at the track!
  49. Question for those with IW overdrive crank pulley
  50. We have a first gen V in the shop today!
  51. 90mmTB users, What caold air intake are you running??
  52. 2005 Cts-v help!
  53. New Here. Shopping for a V..
  54. HELP think my block is taking a sh!t
  55. Sold/Traded the V1
  56. just picked up a v
  57. 4l80 swap
  58. Dual Mass Flywheel failure
  59. Steering wheel thoughts.
  60. Stopped by Year One today. Scored a deal...
  61. Clutch questions
  62. Can I change intakes without a tune? Also help me pick out some heads!
  63. LS2 intake on a LS6 would it work?
  64. Adjustable Sway Bar End Links Question
  65. anyone have definitive info on LED bulbs?
  66. Best streetable cam for LS6 05 V?
  67. 2011 CTS-V Wtf? $23k?
  68. Pretty much my intro thread...
  69. Heads
  70. O2 sensor and suspension
  71. Shifter Trim Alcantara Mod
  72. ctsv 9k
  73. Clutch position switch help
  74. help with pricing on trans, diff and engine
  75. CV joint part numbers/specs
  76. 2005 V w// 90k miles, rebuilt motor with documentation & warranty (what's it worth?)
  77. Procharger kit
  78. Tire/lug nut question forgestar F14
  79. Avatars
  80. LS6 guys
  81. Local Car Show Locator
  82. Is this a cheap diff whine fix?
  83. Exhaust geeks needed!!
  84. Question regarding crank pulley
  85. Aftermarket Auto Parts Installer Directory
  86. Can any of you Maggie guys help a brother out? (please)
  87. Clicking Coming from Front
  88. picked up a thunder gray '07 cts-v
  89. N2MB Wot Box
  90. Rear end casing broken
  91. Maggie removal.
  92. Cs 8.8 ideas.
  93. Back into an LS-Based Vehicle - 05 CTSV
  94. Earl's Speed Bleeders 2011 CTS-V
  95. Misfiring bad
  96. IAT relocation
  97. Stock LS6/LS2 Balancer Weight?
  98. When factory parts break its time to upgrade (crank pulley problems)
  99. Injector threshold
  100. DIY Ford 8.8 into V1 Build thread
  101. H&R lowering question
  102. identify differential please (04-05, or 06-07)
  103. Super Strong Seatbelt Spring?
  104. no codes, but DIC is reading....
  105. Blacked turn signals clear fogs guys in here
  106. People with HID experience please come in
  107. V spottings everywhere! Is this the V capital of the world?!
  108. Reintroducing... Me.
  109. KW Variant 3 versus GC/FG2
  110. Bad TPMS Sensor?
  111. Ford 8.8 rear end 04-07 cts v
  112. New V1 owner
  113. power steering pumps
  114. Blackout guys in here please
  115. gen tune-up question
  116. Diff bushing install questions
  117. Carbotech brake pads in stock
  118. Getting your fenders rolled in AZ?
  119. Small victory but I'll take it.
  120. Where to get black lug nuts?
  121. stock v2 1/4 time
  122. stressed
  123. CS diff block
  124. Anyone running a Zoom D2?
  125. Lights blacked out
  126. Reason for Concern 80k Miles?
  127. 78mm turbo v1 fuel pump help
  128. Accessory wiring help.
  129. Ran a silver CTS-V sedan on 417 in my GTO. On here?
  130. Z34 Lumina hood vents
  131. What Heads Are You Running?
  132. Catch Can
  133. Need tires: Recommendations
  134. Critique My Setup: Twin Turbo LS6 CTS-V (Sorry, this is long...)
  135. gforce anti wheel hop kit, keep or no?
  136. Radiator suggestions
  137. Ground Control - Dual Rate Spring Configuration
  138. nobody has a spare CV to sell?
  139. Sold the V!!! Just watched it drive off...
  140. Rear bushing bolt; anybody have the GM part # for it?
  141. Katech Shifter 5/8-18
  142. CTS-V Headlite Question
  143. HAHAHahahahahahahah (Fan made Video of a V1)
  144. Saw my first Caprice PPV
  145. HP Tuners stock tune
  146. Eibach install ?'s
  147. Spoiler
  148. Nitrous questions.
  149. Headers.
  150. Need help quieting down exhaust!
  151. Head Cam Intake THrottle Body Install Writeup
  152. Rear Differential Bushing, Does this look bad?
  153. Bushings for the V?
  154. Steering Wheel Buttons Inoperable
  155. Anyone running this cam?
  156. questions about my car
  157. How much freon?
  158. Water Pump Question
  159. Intermittent HVAC Issue
  160. Cam and balancer tool rental.
  161. Need some info on CTS-V
  162. New intercooler install with pics
  163. I wish this was my dog
  164. spec 3 to LS7 clutch
  165. 04 Caddilac CTS-V
  166. SMFH...Changed slave, needs master LOL
  167. Argh... blew the motor.
  168. CS Bushing installation help ... busted my first cs bushing already :/
  169. Help! Help! Help!
  170. Just bought a CTSV
  171. Steering wheel shake
  172. Long time no see/posts lol!!
  173. Help Me Spend Some Monies
  174. camber adjustment
  175. Build questions for TT
  176. Escort 9500ci
  177. 4.0" HPS Silicon Intake Tube
  178. LS7 clutch help please
  179. Another brake line thread...
  180. How to get Marshmallow off of suede? %#$*!!!!
  181. cruise control
  182. 2004 CTS-V w/maggie value
  183. Looking for stock 05 cts-v hp tuners file
  184. Steering Rack Changes?
  185. check out this gem
  186. Went to the 1/4 track tonight, 10.3's
  187. DMV Area meet and greet
  188. went to track more time before i take the drag radials off
  189. So....I Got a Delivery Today.........
  190. Header/Cat Back Where Cat's?
  191. need some info /looking to buy a v
  192. Trunk lid - struts?
  193. Took my V2 to the track last night
  194. Jay Leno's Garage with John Hennessey
  195. power windows
  196. why such poor 60's in time thread?
  197. HELP! New 160 tstat failed-- 20 mins from home
  198. Clutch slave help
  199. Great weekend: autocross and rolled over 100K *pics and video*
  200. hvac relearn
  201. 10.7@125
  202. Broken header bolt broke off,what now?
  203. Really A Fiat Post?
  204. Leaving the dealership after 10 years.
  205. Vette/GTO LS6 water pump differences?
  206. heater only gets luke warm
  207. 07 rear diff fluid change
  208. CS MotorMounts installed today
  209. Video from Tail of the Dragon
  210. Projection . . . Turn Signals?
  211. Getting Through Firewall and +12VDC Power
  212. Lean bank codes
  213. Any clue what these wires are in my car? (pics)
  214. passenger sensing system recall
  215. Tuner ran my car at 20psi and 210 IAT2s, guess what happened?
  216. Guys with 8.8's. 60ft?
  217. Call me low buck 3 inch exhaust
  218. Projector Halo Headlights & Foglights
  219. which fuel pump (aeromotive 340??)
  220. UMI Motor Mounts TWO thumbs UP!
  221. motor mount bolts
  222. abs b0665
  223. stock bose sub
  224. CTS V tranny options
  225. Back to Maple Grove... 12.4 @ 116 w/2.07 60
  226. Dyno tune results
  227. The V's path to a new life
  228. Axle options
  229. Stock parts needed
  230. New Headunit
  231. wow! these things come alive in cold weather!
  232. What would cause this?
  233. Suggestion box
  234. Nearly instant brake pad destruction on '04 CTS-V???
  235. Tampa Tuning for Dyno Tuning and Street Tuning pricing
  236. cts v
  237. rattle scraping sound while driving
  238. V2 Engine mounts in a V1?
  239. Delrin Bushings finally available and upper control arm modifications too :)
  240. Interest in Delrin Cradle Bushings ?
  241. 2005 cts-v -sold-
  242. Starter dead?
  243. Just back from the dyno
  244. Engine Temp Question
  245. bushings
  246. V issues
  247. Finally did my creative steel mount today
  248. Help!! Ls7 clutch not fitting in 05 CTS-V
  249. Looking at a '04 CTS-V ... any known problems?
  250. stock (azn2dmax modified) shifter grease?
