View Full Version : Cadillac CTS-V
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. revshift trans insert
  2. Chrome trim around grill.
  3. Awesome CL find
  4. 04-07 CTS-V factory aluminum hood?
  5. Aftermarket component sets for 04-07 v
  6. Help me solve my engine smoking issue!
  7. Rolled the dice, and won.
  8. For the love of god all I need is one bolt.
  9. carrier bearing
  10. Hood material
  11. Not something you see every day . . .
  12. Coolant Level Sensor Location
  13. Ls2 CTS-V vs 5.0
  14. Name change
  15. Huge props to Gforce Engineering for stepping up
  16. Getting a 04 CTS-V with a bad motor... how about a 6.2 stroked?
  17. 2005 CTS-V with a LS2
  18. High oil temp
  19. Looking for a used FAST 90/90
  20. Meth injection on my V1
  21. ashtray on cts vs ctsv
  22. Outboard most heater/AC vents not working
  23. For those who have an LS2 throttle body on their LS6
  24. Will eventually be selling my turbo kit FYI
  25. New Driveshaft Installed
  26. Clutch install gone wrong
  27. TT-V goes to Pikes Peak
  28. Shakey wheel
  29. Fastest Stock Cadillac CTS-V Coupe? - 11.97 @ 116.9 mph in +1100 DA
  30. Looking for lower center shifter linkage bushing
  31. cam choices
  32. V Wagon on Weld RTS
  33. Revshift Subframe & Control Arm Bushings Installed
  34. Engine is TOAST!!!
  35. Congrats to V12baker!!
  36. Ok found a deal on some drag radials. Should I even waste my time?
  37. what are you guys doing with Gen I slave LS7
  38. Android Phone Integration - V1?
  39. Need a driver hid headlight w/washers
  40. Two questions from a new STS-V owner (sorry to crash the cts-v forum lol)
  41. WTF Over? V on Craigslist?
  42. OEM Wiper Blade part number?
  43. My V flag solution
  44. Nitto NT05R 305/35R19 Drag Radials Mounted:
  45. cadillac cts (non v) starting issue
  46. Cargo net anchors
  47. How much is this catback exhaust worth?
  48. Quick KW V3 Installation Question
  49. I know it's a long shot but.........
  50. Any suggestions for the install of the radiator and ac condenser?
  51. Anyone want to trade Lloyd mats? Black for ebony.
  52. Proper rotor change technique
  53. Best place to locate IAT sensor? Also, best drag tire for stock rim?
  54. Should I go for it?
  55. Need new radiator and ac condenser, floor jack accident...
  56. Does tracking a car on a road course make the car more noisy?
  57. 638rwhp - CAI, pulleys, and E-85
  58. Getting air out of power steering system
  59. Fuel rail covers
  60. Another new CTS-V Owner
  61. Good deal on a grille for someone in need
  62. Can this shifter be swapped out?
  63. Sunroof Problem
  64. RMP surge at idle
  65. MAF Options
  66. In search of a new intake FORCED AIR. Airaid no results LOST POWER
  67. Headlights, halo's, and HID's
  68. Console differences
  69. Whoops... Snapped the inner CV
  70. 745-rwhp/729-rwtq '13 CTS-V Sedan | VR Heads+Cam/Pulleys/Nitrous!
  71. "THE ULTIMATE" first gen fuel pump thread.
  72. Detail and Clean [Pics]
  73. Nick Williams 102 Throttle Body (electronic) worth it on...
  74. Thinking of buying 09-11
  75. Another " Whats my V worth" thread
  76. 05 CTS-V Walbro 450lph E85 pump install
  77. Maggie overdriven rears DONE!!
  78. Warranty Question - Noise in front end
  79. Dorman OE Style Flex Disc Replacement
  80. lost keys
  81. broke radio!!!
  82. Thinking about selling the V
  83. Gen 1 passing BMW like a pro.
  84. Just bought an 05
  85. WHATS UP you wild animals...
  86. '11 Replacement Exhaust Pipe Size?
  87. Just got my h&r installed but
  88. 07 won't start, what else can I try
  89. Best options for fuel pump(s)
  90. New video - April Compilation
  91. Various questions for tuners...
  92. ARP balancer bolt number? Also install help for harmonic please.
  93. Ls7 clutch on ebay, good deal?
  94. Which Rocker Arms?
  95. CTS-V LS7 Clutch Upgrade How To - Confused? Read!
  96. Car cover for new owner? Exhaust too.
  97. WHATS SMALLEST RIM FOR V1 REAR, custom offset??
  98. Oil vs Coolant Temperature - Am I freaking out for nothing?
  99. Noob question about lowering
  100. KW Variant 3 for $1250 new!
  101. Short Throw Shifter
  102. color decision
  103. Fix for Monster clutch engagement ?
  104. V1 temp
  105. Scratched stereo buttons
  106. CTSV fuel line HP rating???
  107. insurance betterment
  108. What gear ratio should I do for the 8.8?
  109. Plasti-Dip Headlight mod.. V1
  110. sqeaking from front suspension possibly lower control arm bushing?
  111. Aw shucks, shifter shaft shuffle?
  112. Need a New Driveshaft
  113. CTS - LS1 swap?
  114. D2 coilover tire rubbing bounce help
  115. Maple Grove 2013...who's gonna be there?
  116. Swapping cams, suggestions? (I know it's repetitive"
  117. V1 LED tails advice
  118. Volant Air Box
  119. Corsa or pypes street pro
  120. My next step = Heads
  121. Buying CTS-V
  122. Preferred fluid for slave cylinder?
  123. V1 under tray
  124. "Upgrade" to ARP wheels studs?
  125. Advice/Recommendation Needed
  126. Mid-Atlantic track day folks - possible VDay 6 in Fall 2013
  127. Carlisle spring show
  128. AC not working ?
  129. Big 3 and AD244 Alternator Upgrade
  130. 31 Spline Level 5 Axle testing
  131. G8/Camaro short throw for V1?
  132. Vengeance Racing | 611-rwhp/601-rwtq '11 CTS-V | VR Camshaft/Pulleys/Bolt-ons
  133. Nashville Cars & Coffee
  134. MM install instructions
  135. Camber issues after coilover install
  136. Stepping it up a little..
  137. Ordering from Revshift
  138. LS6 PCM vs LS2 PCM How much difference between the two???
  139. New clutch install - problems!
  140. Gremlins?
  141. Just some pics of my V
  142. Oil and Water temp in th 230s!?
  143. A/C smell...
  144. Smelling oil when stationary, with heater on.
  145. Yooperls6?
  146. Hairline crack in dash
  147. Super hard clear coat
  148. Need a state inspection center in the DFW area?
  149. Twin COMP 5858's for rear-mount build
  150. Motor Mounts - Ridiculous interior vibrations
  151. V1 Electrical Issue?
  152. Silver V1 spotted Saturday on MD 32.
  153. 2005 cts-v ls6 engine install questions
  154. A few pics of the V.
  155. Alignment question
  156. Local Car Show Locator
  157. Anyone order kooks headers lately??
  158. Lowered problems
  159. Caution those with Revshift DS couplers
  160. Headlight Splitting for paint in a 07 CTS-V
  161. MD V owners
  162. New CTS-V Owner Sup!
  163. Onstar Bluetooth
  164. AMP replaced Stereo works again! BUT new issue revealed.
  165. Oil Cooler from V2 to V1?
  166. OBX headers to B&B
  167. Custom made gauge pod in a/c vent
  168. I test drive the CTS-v in yass race track
  169. high oil temp links
  170. Was this you?
  171. LSxTV - Corsa install on first Gen-V
  172. custom strange coilovers on my V1, swaping rockerarms out and a new tranny
  173. new breather/ oil catch can setup
  174. just bought some new tires for the rear
  175. those with pacesetters come in please
  176. Clear fogs & side markers GROUP BUY is happening right now
  177. 2014 CTS-V?? Ugly
  178. Jewelry for our kind
  179. Stiff shifts after Revshift Trans Insert Install
  180. Help! Stripped Motor Mount Bolt!
  181. Coilover Guys
  182. K&N true CAI
  183. Ms3 cam only cts v
  184. 20" Cadillac SRX wheels on my V!
  185. Local Car Show Locator
  186. anyone that has a stock driveshaft coupler laying around come inside....
  187. Steering wheel shims to move wheel closer to seat?
  188. Maggie Purchase
  189. Maggie rear pulley swap a NO go
  190. anyone order from 8th day recently
  191. going against the grain
  192. New headlights installed + basic instructions to make them HID
  193. New project, almost starting
  194. 5.1 surround sound install
  195. Looking to buy a V2, any suggestions where to look
  196. Hid install ?'s
  197. Looking for a cheap emblem
  198. Still have the dreaded clunk! What's the deal?
  199. Rear still high with MM kit and eibach pro kit install
  200. Going with FG2s
  201. Interior Lights
  202. Headlight repair
  203. E-Brake Does not work after bigger brakes install. Help
  204. Extractor Hood....
  205. V runs hotter with new rad.
  206. Did you have your stock wheels widened?
  207. Stock trailing arms with spherical bushings
  208. 2004 cts-v piston replacement different weight
  209. Some pics of my 07.
  210. Is Revshift always slow processing orders?
  211. Back up camera
  212. 2014 CTS leaked
  213. Do I really have to pull my header off to change the starter?
  214. Don't know what this is
  215. Ls7 throw out bearing/slave exploded
  216. I want more.....
  217. A V2 I can afford $17,900!
  218. This is ridiculous....
  219. GM OEM CTS-V emblems on Ebay
  220. rev shift bushing install?
  221. LG Motorsports Coilovers, Roll Bar and Seat Install
  222. I need a pic of a 04V MAF sensor plug
  223. Cammed Engine Sputtering
  224. 2 cars!
  225. P0327 KS Code / New owner intro
  226. Gen 1 CTS-V Engine Removal/Pull R&R LS6
  227. New 05 cts-v owner
  228. TruBendz Cats
  229. Super Sports on special
  230. Sway bar bushings
  231. Cadillac confirms 420hp TT V6 for new CTS (not V)
  232. Proud New Owner of a 07 CTS-V
  233. holy shit what a difference
  234. Need lug nut covers
  235. Indianapolis v meet, April 6th
  236. Xm adapter for stock xm plug
  237. Pacesetter lts for v1
  238. Quick CS 8.8 axle build question
  239. another slow V out there
  240. Hennessey Twin Turbo V on E-bay
  241. CS 8.8, Wheel hop fixed? Max torque capability?
  242. Plastic strip between roof and windshield
  243. Nav disc stuck inside, won't read
  244. Steering wheel swap
  245. Anyone in SE Michigan want to swap taillights?
  246. To bleed or not to bleed?
  247. Quick question regarding PFADT
  248. Nav system not working
  249. Blacked out
  250. Down force question
