View Full Version : PCM Diagnostics & Tuning
  1. PCM vs. Alternator
  2. Help!!!
  3. Is 85% Really Full Throttle on an LS3?
  4. Will HP Tuners Recognize a Brand New, Unprogrammed ECM?
  5. Just installed 98 FTP lid/85mm MAF
  6. HP tuner credits..
  7. auto to manual tune file vs emissions
  8. truck pcm w LS1
  9. are these cam sensor #s normal ?
  10. 4.8 harness w/ Upgraded PCM to LS1
  11. retard timing
  12. lost crank signal
  13. '99 FB airbag light on, code B0051
  14. Anyone running a Dual Curve MAF?
  15. Hard time getting ahold of Frost...
  16. Think I got ripped on a Diablo Predator U7198...Vin locked and pissed!
  17. Silverado Tire size change, now ABS+Brake Lights on
  18. 98 pcm and trying to run a 4l80e
  19. Idling too high in neutral and when rolling - how to fix this??
  20. SD tune for turbo 5.3
  21. At wits end....need help
  22. 1st gear transmission slip.....Wiring issue? Need help
  23. First fire up...runs but dies and won't start.
  24. stock maf or 85mm SLP maf
  25. P0128 randomly pops up.
  26. frost tuning on my 05 silverado?
  27. ls1 randon idel spike
  28. MAF stuck at 0.31
  29. PCM Compatability Question
  30. KR going off under load. is this normal?
  31. IS this LEGAL?!? hp tuner question
  32. 98 camaro 6speed tune, Do you have one? few HP tuner questions as well
  33. ASR light always on - switch is dead
  34. Replaced both O2 sensors still getting P0131/0151
  35. Best mail order tune
  36. Anyone work for GM, or GM race shop?
  37. GMMP LS2 controller work with LS3 gold blade throttle body?
  38. Whats the differance ide like to know
  39. Used predator prices?
  40. timing too high?
  41. just back from dealership now have SES light!
  42. Factory Wiring Harness...Need some help!
  43. Will I need to tune out VATS on a 98 pcm
  44. VSS wires??
  45. BS3 or holley dominator efi?
  46. what to do?
  47. Cold start issue...have to pump gas initially...2004 GTO
  48. questione:AEM standalone
  49. trans tune question
  50. O2 sensor plug volts??
  51. LSX PCM questions
  52. Hp tuners question
  53. P0122 p01635
  54. sputtering in all gears in idle help
  55. Will a mail order tune work for me?
  56. user XP and DL time
  57. setting 4>3, 3>2, and 2>1 downshifts hp tuners?
  58. OBD2 scanner android app
  59. Help with VIN code!!!
  60. need a tune for my stall.
  61. voltage drop
  62. What's the point of tuning VE?
  63. E40 ecu question
  64. Predator tuning
  65. 85mm MAF Question
  66. pcm buying time
  67. Just got HPtuners have a question
  68. Turbo wot pulls with hptuners...log and tune inside
  69. Richer Idle?
  70. Timing question
  71. ls3 Block, Heads ,and Intake .. 98 PCM hard tunning
  72. Dallas Dyno tuner?
  73. how many cell hits are you logging for wot pulls?
  74. Do tuners block the PCM so you can't read anything from it?
  75. buying tuning software used, what should i look for?
  76. Need to locate 2 pins...
  77. Dyno vs Mail order tune
  78. Confirmation that crank signal is bad
  79. False knock issues
  80. Still having idle issues, experts inside!
  81. p0068 dtc
  82. My p0134 story
  83. want to switch to speed density
  84. Need help-HP tuners and VIN question
  85. Need stock '98 A4 HPT tune file
  86. 2010 Camaro VSS issue (ideas?)
  87. IAT sensors
  88. schematic noob (determining polarity)
  89. what would cause the o2's to be acting like this? (hp tuners chart .jpg)
  90. Is this wideband any good?
  91. Just replaced 02 V6 Camaro MAF, now I have this problem...please help.
  92. Can I just cut wires at the computer?
  93. What does the PCM use when the throttle position sensor is unplugged?
  94. Factory Wiring Harness, PCM, Open Tune...and EFI Live
  95. hp tuners vs efi live
  96. TX G-Force motorsports or Clearlake speed??
  97. Needing some help....Driveability issues
  98. Tach Signal
  99. delphi pcm? and software...this is a strange one.
  100. conversion harness questions
  101. Tulsa, OKC, possibly texas tuner
  102. cold start problems, leaking injector or just need of tune
  103. PCM corrupted
  104. LS1 PCM in a S10 1993 truck ??
  105. EFI Live....but its used and the old version!
  106. Identifying my PCM
  107. Anyone care to comment on my VCM/HP Tuners E85 Tune and Log?
  108. DTC P0131, 0133, and 0151?
  109. 94Z28 BCM Question
  110. 383 LT1 Tuning Problems
  111. Spark Advance at WOT Bolt-on Ls1
  112. 1992 GMC Pick Up Code 51
  113. gains from tune in bolton/stock M6 car???
  114. electrical issues need help
  115. Shift points after headers
  116. any issues with running a 2002 5.3L w/ a 1998 firebird PCM/harness??
  117. NGK AFX Controller Location
  118. Injector help, 400RWHP Bolt-on LS6
  119. MAP sensor code error
  120. Speedo hookup without using transmission?
  121. Cleaned MAF and WOW!!!
  122. cartek c5r 427 readiness test
  123. tune with rear o2 delete
  124. OL Hunting idle diag
  125. Small physical dimension PCM options?
  126. Wideband/Gauge questions
  127. Are my O2s sleepy (image inside)?
  128. Running speed density for turboed chevelle
  129. spark plug suggestions...
  130. no crank no start
  131. Not starting....
  132. Rolling only high idle???
  133. What in the world is wrong with my fuel gauge? *Nothing to do w/the sending unit!
  134. Went from m6 to a4
  135. P0200 Only, can't put my finger on it...
  136. Changing VIN to match current swapped vehicle
  137. closed loop tuning
  138. Bucking and surging?
  139. car running too rich
  140. Changed MAF, runs poor
  141. Using HP Tuners Without Application Key or Account Info?
  142. 383 LT1 PCM problem?
  143. Random misfire
  144. How close are Frost tunes
  145. HP Tuners Injector flow vs Kpa. Why does it change?
  146. TPS won't reset to 0%
  147. DBW computer for blue/red harness?
  148. Check my codes plz
  149. Does Anyone have CAN network diagram?
  150. Idle Surge help please
  151. First Time Tuner (HP) where do I start?
  152. writing 6.0 tune on my 5.3 computer (hptuners)
  153. Cam/crank sensor question.....
  154. Do wideband O2 sensors wear out?
  155. please help ls swap wiring problem
  156. Check this $#i+ out!!!
  157. Random Misfire
  158. Tuning Necessary? Typhoon to FAST Intake
  159. Missing o2's.
  160. Dash won't light up and car won't start?!?!
  161. Delete front o2 codes, will pay and ship
  162. Big spikes in timing advance
  163. Erratic idle, battery, gauges........ HELP
  164. SES code p0135...
  165. Locked diablosport tuner
  166. What does this dyno graph say about the tune?
  167. Codes thrown
  168. Rlz engineering in nc
  169. VCM suite not working properly
  170. Merry Christmas everyone!!!!
  171. Problems logging the wrong AFR with HPtuners
  172. 98 vs 99+ pcm
  173. 750 ohm 1/4 watt resistor
  174. Where should I start
  175. Swapping a 2001 SD M6 PCM into a 2002 MAF A4 car???
  176. OBD plus Can scanner that works for SES, SRS and ABS
  177. What happens if a 5.3 tune is run on a 4.8 motor?
  178. megasquirt3 injector choice
  179. o2 sensor suggestions and header install
  180. 6l80 Tunes, show and tell!
  181. 408 turbo on a 98PCM?
  182. Tech2 questions 05 GTO
  183. who does thunder racings mail in tunes
  184. Chassis dyno
  185. Idle Dips In Reverse Only
  186. Random idle surge on '98 LS1 *Tune/log attached*
  187. Effect of compression on tune?
  188. help with tuner for ls1.
  189. Random misfire code on one bank
  190. 04 GTO harness,pin out for fans
  191. best tune, more boost?
  192. Tuning differences between 98 and 99+ ls1's?
  193. SD Tune w/out Running a VSS
  194. No power in drive
  195. PCM/cam sensors/LS2 Throttle body
  196. Idling high. Not TPS or IAC. Help! HPT log.
  197. ASR problem
  198. p0102 code
  199. mail order tune with heads/cam install
  200. cam idle set? TSP torquer v2
  201. Maf
  202. replace O2s with widebands
  203. PE table question....boosted applications
  204. help with tuning and cost of tune
  205. Help keeping it running
  206. Need help understanding tuning software
  207. Cam sensor compatible?
  208. Take a look at my Tune please.
  209. Holley vs bigstuff3???
  210. swapping mid tubes for longtubes,do I need to retune?
  211. MAF reading
  212. On-Vehicle Dyno
  213. Jet DST ?
  214. tuning
  215. When to tune for bolt-on's?
  216. 2001 truck 5.3 pcm.
  217. What size injectors do you tell your computer you have? E85 question.
  218. Tps value
  219. Optimal RPM for MPG tune
  220. 94 LT1 TunerProRT nor C.A.T.S. working????
  221. BEST Computer Tuner?
  222. HP Tuners ?
  223. Switching from SD Closed Loop to SD Open Loop Questions!
  224. HP TUNERS & EFI LIVE with MASTER EFI TUNER
  225. 2005 LQ9 and FBody wiring/PCM
  226. mac mentor scannor review need help
  227. Bin File Help... Tuner Cats need a factory 98 camaro
  228. P1626?
  229. Injector Pulse Width vs Battery Voltage Table
  230. Problems after Aeromotive fuel system install. Question on tune.
  231. Tune with head cam install
  232. Good deal on GM IAC Valves (PN17113598)
  233. NA E85 Tune, looking for some input
  234. PCM limited to 8k how?
  235. 5.3 in s10, blade style maf ???
  236. Wideband test pipe ?
  237. Can I drive my car with one o2 sensor unplugged?
  238. rear 02 sensors
  239. Turning stuff off via HP Tuners
  240. LS1 in 95 Trans-Am runs for 2 seconds and dies..
  241. HP Tuners Standard version without Wideband
  242. EFI Connection 24X
  243. help with a tune
  244. Need to get OBDII (dash side) port? Where to buy?
  245. P1639
  246. Help with VE tuning....log and tune inside
  247. NGK AFX Powerdex with NTK sensor standard?
  248. I think I have a bad tune!!!
  249. LT1: Timing Curve for best performance?
  250. Texas Speed MOT or Frost MOT???
