View Full Version : PCM Diagnostics & Tuning
  1. Reading, Transforming, and Applying an RPM Signal to Electronically Turn Accessories:
  2. Installing an Autometer lean/rich gauge tomorrow, have 1 question?
  3. which connector is this??
  4. EIO and do I need it?
  5. Diablo programmer/tune downloads
  6. DFCO spark cut...what kind of requirements are there?
  7. LS1Edit MAF Table & VRam
  8. What other scanning software can I use with my HP Tuners cable?
  9. 03 PCM and Electric Fans
  10. High compression spark advance?
  11. Anyone running dual widebands?
  12. '98 to '99+ PCM swap
  13. anyone seen an OBD-II diagnostic tool for the RIM Blackberry?
  14. lead me in tuning my car, with hp tuners
  15. What causes early lock up...
  16. Factory PCM's RPM Limit:
  17. Need help with fans!
  18. Have a service engine light code "P0430" help!!
  19. Hptertech help me????????
  20. hyperpac?
  21. Hp Tuners Telephone Number In Valencia, Ca
  22. gauges
  23. I need help with a rough idle
  24. Questions about PO410 code
  25. Stand alone? For street
  26. What is the highest safe A/F ratio?
  27. car idled down to 300rpms, WTF?
  28. Tuning Calculation Tables!
  29. how to check 02 sensors ?
  30. Flashing Gm Computer
  31. Anybody have Auto Tap 2.10?
  32. P0300
  33. hey guys, how to get LTFTs down to negative?
  34. Help.. someone with any 98 M6 bin file
  35. G5X3 114 hp tuner file needed
  36. LM-1 wideband effort
  37. ok, does HPTuners make
  38. Ordering HPTuners BUT........
  39. laptop does not have the Hp Tuners hook up!
  40. 97 LT-1 6spd. flash file
  41. 400 for LS1 is it a good price?
  42. Who's The Best ???
  43. Deleted AIR, but still have question.
  44. 00 silverado starts and then dies, over and over, please help!!!!!
  45. Speedometer recalibrator
  46. Injector swap tuning W/ HPT
  47. Service Numbers
  48. SD Tuning with EFI Live, Wide Band, and LS1 Edit Questions.
  49. whats the best WIDEBAND o2 SENSOR
  50. LS1M Scanner
  51. Converter does not always lockup since I shoved the stock tune back in the car????
  52. DFI panel done
  53. Thanks Jimmy!
  54. Hot Cam Guys Come In Please
  55. Torque Mng. Tabel
  56. EFIlive new version and new hardrive slow?
  57. Car surgeing at idle!?!?!
  58. How does Wideband O2 hook up to HP Tuner?
  59. Where to start tuning for cam
  60. Diablo Sport Tunning Where Are you
  61. Point me in the right direction........
  62. TB blade hole...is this a table in the PCM?
  63. New tuning software
  64. IAT problem with LS6 MAF
  65. Help
  66. Main VE Table ?, Logged data vs VE Table
  67. Newbie Questions
  68. Basic code reader?
  69. hypertech shift points ??? 2.73 with auto
  70. which settings for hypertech
  71. Annual Christmas Day 150MPH run yields suprise?
  72. PCM to keep or return
  73. Need alittle help with tuning!
  74. False knock
  75. I Know this is LS1 Tech but...
  76. New to HPT. Car in garage until weather lets up. Can I do any tuning with HP Tuners?
  77. o2 sensor question
  78. ? for direct port nitrous guys on c5
  79. Dam SES light
  80. Tuning or other issues after Heads Install...need help
  81. predator fan backwards???
  82. Data Logging on Diablo Programmer??? And Timing??
  83. o2 sims... really a dynotune diff?
  84. Good news! My HP tuner arrived. Now the bad news......
  85. How soon for C6 / LS2 Software?
  86. Anyone do tuning in NC?
  87. What is the difference between the LS6 MAF and Z06 MAF?
  88. FAST sequential
  89. tuning myself, what does it involve?
  90. reduced engine power
  91. turn off reduced engine power in c5
  92. Show me the ropes with HP TUNERS?
  93. Bad O2's cause this kind of shit????
  94. 99 ss with code p0305
  95. Best tune in Chicagoland area?
  96. Probably dumb but hey im Paranoid
  97. Torque Management ? Does anyone know
  98. Dyno Tune
  99. brown tailpipes after removing cats????
  100. stock Tuning on MTI Stealth 2?
  101. adding 3" cats to my TD's ?'s inside
  102. are the any multi-tune programs?
  103. hppIII On My Auto Ls1 . Yep Iam retarded .
  104. Dyno Tune Cost
  105. Diablo predator vs Crane Cam power max
  106. banging Revlimiter how to fix?
  107. firehawk abs traction assist, how to disable
  108. zo6 ve table
  109. Anybody that knows anything about OBD-II emisions testing please come in.
  110. How will a bad MAF effect my tunning?
  111. Does anyone do low cost tuning in the Denver/Colorado springs area?
  112. 97LT1 obd II tuning software
  113. Gauge Cluster Pin Out (2002 T56 Trans Am)
  114. Tuning 408
  115. P0401 clean EGR, reset, then comes back
  116. Dyno tune....got nothing :(
  117. Service Engine Soon light!!!!!
  118. 40 Degree of Timing on Predator tune?
  119. Courtesy light is on all the time
  120. Tuning after LT's and ORY
  121. Just got my HP tuner
  122. HPtuners for 99 LS1
  123. Occasional stalling after Converter install
  124. Anyone in cen/east FL w/00 HP tuner?
  125. how to turn off traction control with edit
  126. Flash Back To Stock
  127. A4 T-rex File Wanted.
  128. Thrown code P0430??
  129. Who offers the LS1 edit in GA
  130. LT1 tuning software
  131. Need some help from the pros
  132. Where to put the wide band bung
  133. The SERVICE VEHICLE light...
  134. !ASR with HP Tuners
  135. Is an LS1 disassembly available?
  136. What do I need to do use a spare PCM?
  137. edit problems
  138. Math wiz to help solve 'formula' for HPTuner WB program....
  139. Please Help: My Car Wont Start
  140. Help...scanner won't read PCM?
  141. Car cuts off when launching at full-throttle WITH traction!
  142. [b]tuneing Help[/b]
  143. Lid and Cat back only, some KR/detonation, is a tune worth it? Dyno printout included
  144. question about ltft.
  145. P0420 SES light code.....cutout?
  146. Bank 1 Sensor 2 - how do I know what is what?
  147. TAC module update via LS1edit
  148. Open loop for a cam only tr224 car?
  149. Anyone in NC?
  150. Worth getting dynotuned?
  151. body shop customer tracking software...
  152. Need the directions to install edit
  153. Restrictor Plates madness!
  154. Ahhh idle airflow table needed!!
  155. Need Advice/Help
  156. 1 OR 2 Wideband O2
  157. Autotap question/problem
  158. question on the nelson tune
  159. Ordered Z06 MAF, got SLP...should I send it back?
  160. map sensor
  161. Dyno Tuning advise! Important, please read!
  162. Having some knock retard and lots of red in the ltft
  163. FAST tuning issues when cold.
  164. worth trying?(free)
  165. LS1 tuning maps - more for 32# or 37# injectors?
  166. HP Tuners Questions....
  167. Megasquirt EFI
  168. How Do U Know When Your Maf Is Bad?
  169. Fuel trim question???
  170. Question on Accel DFI
  171. using hp tuners for a window switch
  172. reprogramming computer for a4 to m6 swap
  173. ASR problems with turning on and off
  174. Lean Popping??
  175. Cold weather tuning questions???
  176. Hypertech Power Programmer
  177. I need a tune DFW Area cheap
  178. How ot extend MAF table/range
  179. a dyno tune for a b/o spray car?
  180. P0101 Help
  181. anybody knows what these codes are? PO102 AND PO803
  182. Paging NOGO
  183. EFIlive - Flashscan pic
  184. Chevy Racing Street Rod Computer???????
  185. new to tuning
  186. SES Light!!
  187. Stumped on Warning Light
  188. LS1 Accel Gen 7 please help- lots of fire!!!
  189. tuning VE, question about disconnecting maf
  190. Security light comes on randomly???
  191. Car stalls/bucks when reversing, wtf?
  192. 98 z28 w/ new headers, lost hp
  193. Newbie Questions
  194. ses light
  195. Timing Question
  196. Speedo = Tach? Other issues too...
  197. Problems after porting tb and adding new maf
  198. knock sensor
  199. dyno tuning around Oklahoma City
  200. Quick question ve tuning with a WB
  201. New turbo setup. What to tune with????!
  202. Tuners in seattle, tacoma, everett, marysville?
  203. Accel Gen 7 vs F.A.S.T vs BIGSTUFF3
  204. Q: Editing DTC for Readiness State- evap misfire
  205. How did you guys get so smart?
  206. Tuning problem or not?
  207. AIR/FUEL Ratio number???
  208. do i need tuning???
  209. cold start surge
  210. wich is better fuel reg 92 or 93 with alcohol
  211. Using a WB SD tune to calculate a new MAF table
  212. Missfire?
  213. Need Help with Cold Starts - Rich
  214. Need help on SES code
  215. Question about performance chips
  216. codes 137 and 430 any one can tell how to fix them?
  217. SES light
  218. Thrown codes: P0135 & P0137; after LT install
  219. tuning with the daiblo sport tuner
  220. o2 troubles
  221. CKP - Reading a Negative 15???
  222. What do I need to change to put 30lb injectors in.
  223. Tm & Predator?
  224. BS3 and Stock Gauges?
  225. Got a nasty problem!
  226. Dyno tuning near Pittsburgh????
  227. Code 336? Need some Help
  228. VE tune begins, questions and observations inside
  229. When to stop adding timing???
  230. Tuning?
  231. Editing transmission tables - HPTuners
  232. Knock sensor
  233. Why won't Autotap clear my Traction control or Airbag light...
  234. ECM Programming
  235. Locked HPIII for 98 Chevy
  236. Narrowband output from Wideband O2
  237. Where is S120 breakout circuit 121 white tach wire?
  238. Raw fuel smell coming out tail pipes!!!!
  239. electrical problem..
  240. HP tuners Computer requirements
  241. 02 Rich/Lean
  242. Stall & Big Cam
  243. AIR/FUEL ratio changes after ls6 and true dual install
  244. Traction control
  245. Mail order or dyno tune?
  246. Can I dump my current .bin file into spare PCM?
  247. Edit tune - still smell raw fuel at idle
  248. new motor does my computer need tuned?
  249. readiness bits - pre inspection troubles
  250. Another P0440 question
