View Full Version : PCM Diagnostics & Tuning
  1. Shift Points
  2. WOT at 5600RPM car shuts off/backfire HELP!!
  3. Quick need help coil ground.
  4. Auto tranny tuning tables
  5. Light throttle surging...interesting find...
  6. 2004 Gto
  7. Supercharged C5 with lots of SES codes..
  8. What options available for a 1998 Chev Silv for VCM Tuning?
  9. Help with Predator in OC, CA
  10. 93 octance tuning = perfecto
  11. LM-1 O2 replacement ... which to get? and where?
  12. New to HP Tuners - Couple Questions???
  13. Tuning a Turbo or Supercharger.
  14. Arg! My HPT Cable is a potato! It sprouted!
  15. need some numbers, plz.
  16. tuning for new cam?
  17. VE Calculator
  18. HPTuners
  19. Tuning in circles... SD & IFR
  20. Looking for a tune
  21. anyone tune timing after 160 thermostat
  22. LS2 coils much better!
  23. Deteriorating Idle on 2004 A4 GTO; requesting help from experts...
  24. COT Question
  25. HP Tuners and XP Service Pack 2
  26. If I want to do a tune WITH the MAF, should I unplug it and speed density tune 1st??
  27. what should i chaneg on my tune now?
  28. What's all the hype over HP tuner?
  29. Speed density user guide
  30. Lm1 users need help!
  31. Ed Wright Tune and HP Tuner
  32. can someone please help me???
  33. Need Tunning Help Asap!!
  34. PCM #P0306 & 0356 Coil Trouble?
  35. HP Tuner customer issue
  36. My comp wont put out a reading
  37. Slp Maf..
  38. Can i use a 2 step??
  39. LS1 EDIT & HP TUNERS
  40. Temprature sensor on Air Box..
  41. High idle
  42. Adding transgo + SS3800 + 3.90s: tuning question..
  43. BCM/APM (little black boxes) questions
  44. Atap questions
  45. MAFT settings
  46. Knock sensors flooded w/ H20
  47. Problem !! Help needed
  48. Granatelli MAF screwing me up a little? if so, will LS1edit dyno tune definitely fix?
  49. Stroker Motor ?
  50. stock tuning tables
  51. How to get rid of abs light after 9" install
  52. MAF Wiring Schematic
  53. Accel Gen 7 and MAF-less
  54. 2002 PCM in 99 harness will it work?
  55. Can anyone reflash a PCM?
  56. Idle tuning... sound related
  57. Best soldering iron?
  58. Need some help with a code
  59. Some new HP Tuners EnhancedIO (1.5) screenshots *LARGE PICS*
  60. my 2001 camaro won't start
  61. hi idle/tcs inop/no codes= tcs prob?? NEED HELP
  62. Meaning of Upshift Torque Reduction?
  63. battery lost tunning
  64. Check out my !MAF mod
  65. Programmers
  66. Timing drops to Zero on decel?
  67. Killed PCM! Will edit work with reflashed pcm
  68. Need to lower desired IAC counts...
  69. Confused after reading VE sticky
  70. download a custom tune to a predator from a pc
  71. no power at ALDL connector, any suggestions?
  72. Diablosport Programmer Quick Question
  73. swapping pcm's ???
  74. Excellent tuning info inside...
  75. Where is the Headlight sensor on a 1999 Maro?
  76. Got a good deal on a DiabloSport Predator
  77. Should I get a tune....
  78. How to get a big cam to idle in speed density???
  79. looking for a tuner in il
  80. Car hesitating and stumbling don't know why???
  81. Tuning Spread Sheets
  82. KR when pulling 2000-6200 rpm in 2nd gear, only
  83. Shop & Tuner in CT or near Springfield, MA?
  84. No closed loop at WOT and low eng load
  85. tuner cat?
  86. Diablo tunes
  87. knock sensor code questions.
  88. Is Anyone logging with PLXDevices M-500
  89. Tuning without the o2 sensors
  90. MAF vs. SD tunes, pros and cons.
  91. 75 lb injector tuning ?
  92. running 89ish octane on a 93 octane program?
  93. LM-1 O2 sensor lasting 2 months ! WTF???
  94. predator tuning.car is rich
  95. MAF calibration Vs. Year ???
  96. Idle Airflow: Why is it such a pain... (already searched and tested stuff...)
  97. What determines the L-Trims?
  98. EFI VEpcm and ls1edit map vs rpm table
  99. Hego sensor?
  100. SES light flashing...WTF???
  101. LS1 Edit file...
  102. What is best method to find vacuum leaks?
  103. p0101 Maf performance code after heads install
  104. Is The Maf Translator Any Good? Is It Easy To Use?
  105. Running MAF'less..
  106. Understand how MAF works - DON'T DE-SCREEN IT!!
  107. What changes for larger injectors?
  108. BULLSH** codes....po410 and p0300
  109. HP Tuners/LS1 Edit Problem/Question
  110. Dyno tune
  111. WTF this is driving me banannas
  112. Car misfire P0300, NEED HELP! PLEASE!
  113. F.A.S.T. question
  114. P0102 !?!?
  115. p0327 and p0332
  116. CA Emissions, What Are People Doing?
  117. DFI7 or FAST?
  118. How to tune high load points on VE table???
  119. help with OBD-II code P1415
  120. PCM exchangeability?
  121. Hit 12.5 A/F on the dyno but o2's read 820 on the street. Normal?
  122. how to read oil pressure
  123. 230/238 cam tune help
  124. 2002 Z06 VE table
  125. is it possible that my tps voltage is low, causing my trans not to downshift at WOT?
  126. When is cam sensor triggered?
  127. Installed h/c, idles but tries to stall when I let off the throttle.
  128. HPTuners Need some insight
  129. MAFLESS...perhaps this will open new doors in intakes?
  130. tps voltage at WOT, what should the voltage be?
  131. Does anyone have ls1edit v1.3 or v1.4
  132. Tuning timing
  133. Need help. Falling on its face.
  134. how to connect efilive to other GM vehicle
  135. AFR question mine is not right.
  136. Knock sensor short circuit?
  137. LS1 Edit
  138. Question on the PE/RPM table and A/F results from Dyno
  139. 98 maf same as 99 and up?
  140. Afr - Help
  141. New Predator software
  142. Which one is better?
  143. MAF Table Scaling
  144. Bank 1 LTFTs go positive after I let off
  145. Poll: Have you switched tuners?
  146. SES light, P0102??
  147. Accel Gen 7 Users HELP..MST Sensor?
  148. Changing Gage Cluster help
  149. can I put 2001 pcm in a 1999?
  150. HP Tuners and LS1 Edit Comparison?
  151. Help....Fuses
  152. wont respond to mods
  153. knock sensor different types
  154. HELP - Predator & Dyno Tune together?
  155. Need help diagnosing odd problem with LS1
  156. Frustrating dyno day, need some help
  157. USB to serial Connector?
  158. fuel setting on hypertech
  159. Problems with knock sensors, PLEASE HELP!
  160. Need Help FLP wont shift to 3rd at WOT (Racing Tomorrow)
  161. Shot in the dark...
  162. Need Help!!
  163. Just installed h/c and 30lb injectors, need startup advice...
  164. TH400 tuning help
  165. IFR Table for 42# SVO Injectors?
  166. Air fuel reading needed.
  167. Please Sanity check my HPTune
  168. VE Tablel Correlations - to LTFT Correction
  169. Does anyone know a place in South Florida wheres they tune C5s or F-bodies?
  170. tach install
  171. What PCM's are compatible with my Tahoe?
  172. MAF tuning question after pivot table analysis
  173. help with hypertech ...
  174. Ls1 Edit and HPP3 Possible?
  175. Best Programmer?
  176. So where is the OPTIMIZE Button ?
  177. Great Setup For Tuning At Home?
  178. Changing pulley sizes
  179. WTF...HPtuners site down???
  180. Review my LTFT and advise
  181. When tuning off the MAF...
  182. 02 pcm in 99 Truck
  183. Oil pressure reading 129 lbs.
  184. Tuning Websites
  185. I need a Hand.
  186. predator tuning with cam
  187. any way to turn off adaptive learning?
  188. o2 help
  189. How do I get a sample of higher MAF frequency?? (what kind of driving sample)
  190. Carputing
  191. Need to get a tune ?
  192. URGENT!!Need Help!!
  193. How do you figure out your (Closed Loop...)
  194. Service Vehicle light?
  195. How to get false knock
  196. Low timing, but seeing no KR?
  197. Need tuning
  198. Anyone have the IFR table
  199. Trouble code P1416
  200. Swaping LS1 and LS6 MAP sensors???
  201. Help!!!
  202. Open loop/ SD tune is killing me
  203. maybe you guys can help.
  204. Fastech
  205. Manual fan switch problems
  206. P 0160 what does this code mean?
  207. Diagnosis of Engine Codes in MO
  208. Having some MAF problems (I think)
  209. HPP3 causing gear problems?
  210. Too much gas.. fumes killing me.. Edit Question
  211. Help! PCM is not getting power!
  212. Switching from 30lb to 42lb injectors?
  213. I hope this is the right place for this thread p1404 HELP.
  214. drive cycle...
  215. Need help with predator tune stuff after headers:
  216. No open loop at WOT
  217. 0420 code
  218. Ca. Smog trouble.
  219. Help tuning M6 car with 224 cam
  220. Strange symptoms
  221. LS6 Tach Signal
  222. help, what is crank relearn and how to do it?? misfire code and cant fig. out why!!
  223. anyone have a bin for 98 w/ 4.10's in an auto?
  224. hesitation after new fuel filter
  225. My car has never been Autotap'd, having someone do it, what do I look for?
  226. Tuning basics
  227. Compatability Q: HP Tuners & Westers
  228. Unplugged the MAF and did some logging
  229. Has anyone ever been to REV EXTREME?
  230. Need a spare PCM, due to ED WRIGHT lockout!!!!
  231. Does HPP3 clear codes
  232. Is the Chip hurint my performance?
  233. Is the Chip hurting performance?
  234. check engine lights abs gone and low fluid?
  235. Smog issues....pain in the ass....HELP
  236. SES light burned out.
  237. 4l60e shifting
  238. bad try
  239. wideband tuning - AFR
  240. Differences in tune for 5.3L and 6.0L?
  241. 98 ls1 oil pressure sensor pin outs?
  242. Camaro speed limiter removal.
  243. MAF Replacement Tube for SD Tuning
  244. Service engine soon trouble
  245. Man I love this site
  246. LS1 won't let me overwrite
  247. VE tuning. I've got a problem
  248. Had car tuned, now idle problem.
  249. Non MAF-less Tuning
  250. car is sputtering and back firing. PLEASE HELP.
