View Full Version : PCM Diagnostics & Tuning
  1. can anyone confirm if a -2 LTFT is actually reducing the IFR table
  2. Help with pinging....
  3. Total misfire current count what is acceptable?
  4. What tune should I set predator at?
  5. flash a4 computer to m6 file.......
  6. How do i avoid downshift 3-2 on dyno ?
  7. What resistor for 10 degrees?
  8. Superchips Programmer Owners ONLY, PLease
  9. Would Dtc About Air Pump Relay Hurt My Performnace
  10. New to Programming... Need help getting started.
  11. Review of HP tuners after 24 hours
  12. I need help with big cam idle tuning
  13. Long term bank 2 weird reading????
  14. Part Throttle Tuning Help!!!
  15. Idle with AC on and car is warm
  16. Anyone have LS1 Edit in Tucson, AZ?
  17. Sporadic low O2 B1 at WOT???
  18. Engine Codes..?
  19. knock under load
  20. ANybody know what the PCM shifts a 99A4 at?
  21. Powering laptop whileusing Edit?
  22. TPS and throttle body question
  23. P1416 SES how to fix?
  24. First mods on the way
  25. Ses...
  26. removed the Secondary Air Injection System
  27. How to get rid of tq. Mgnt. with HP tuners?
  28. EFILive Data - Need help
  29. TPS code
  30. Header leak causing inaccurate o2 readings and tuning problems
  31. Mafless S.D. tuning has begun!
  32. Check gauges light but nothing happening?
  33. TPS problem possibly???
  34. Pedator or HPPIII
  35. BCM (body control module) replacement
  36. best programmer or tuning
  37. car is throwing a code..what do I do?
  38. LS1 code 351 related to coils...
  39. Does a MAFT do anything for part throttle power?
  40. WOT - LTFT is ~+6??
  41. Hidden shift light
  42. ls1 edit
  43. eratic STFTs. have a few questions
  44. New to the tuning world....
  45. Did ATAP....Got engine misfire code P0300
  46. Gear Swap Recalibrating
  47. scanmaster
  48. LM1 and RPM Logging
  49. longtubes and closed loop fueling
  50. Tuning question after injector swap..
  51. How many Tuners do Part throttle tuning?
  52. Gauge needless off.......correction???
  53. PE Table
  54. Predator gear change not taking...
  55. what would cause bad gas mileage?
  56. will ls1 edit that was from a 99 trans am work on my 00 trans am?
  57. New To diagnostics
  58. comp cam 224/224 hp tuner
  59. Predator set up help
  60. LS1 edit
  61. After my cam change
  62. Pin Out for LS1 TPS?
  63. car "chugging" with stall
  64. help
  65. Planning to go standalone with my FAST, not sure about certain gauges...
  66. Code P1153
  67. Catalyst test in AutoTap?
  68. Remove Maf ends for tuning?
  69. grams/cyl = ????
  70. TB screw
  71. ls1 edit procedure
  72. any "little Mods" before tune??
  73. Pids
  74. Changing custom program with HPP 3
  75. efi live saving screen shots ?
  76. c5 covertte owners, what is your idle TPS?
  77. Edit quirks - and a problem
  78. Dead O2 sensor?
  79. question on 3 DTC's found today
  80. Engine surges at idle after WOT runs...otherwise ok
  81. can u check codes with edit?
  82. accel dfi gen7 help
  83. Would love some help with edit
  84. Fuel trims
  85. egr low voltage?
  86. Do I need a new tune ?
  87. Tuning a blower with predator
  88. can someone explain the direct relationship STFT has on LTFT?
  89. Ws6
  90. OIL CHANGE light on and off sporadically
  91. Some EFILive guages dont function.
  92. Where to get a tune in Houston?
  93. Question on selling my LS1 Edit
  94. thinking about open loop...
  95. Range between B1S1 and B2S1?
  96. New here, questions re: timing in hp tuners
  97. someone please help with throttle follower table
  98. Need help tuning this HUGH cam
  99. help with #3 misfire
  100. Using MAP data to understand LS6 Intake restrictions....
  101. newbie tuneing question
  102. LFTF B2 is that on the drivers or passenger side?
  103. Best way to tune injectors that are "too big."
  104. Looking for autotap analysis tool - what to scan for, etc
  105. What could cause this??
  106. dyno after Predator custom - worth it?
  107. Motor Swap - What about the ODO
  108. ltrim question
  109. I need help tuning Gran Am Cam A4
  110. HP Tuner users please nudge a novice
  111. what should i go with
  112. My car won't goes past 6000RPMs, any ideas?
  113. My experience with Accel DFI
  114. Help With Codes Please!!!
  115. witch tuner to go with??
  116. Little help getting started?
  117. Hypertech Progammer 3 problem
  118. PCM and programing guys please look in here
  119. Procharger Tuning
  120. AC overcharged - compr. shut down?
  121. A/C clutch intermediate cut off ???
  122. what the...?
  123. rear o2's and more?
  124. Need PCM advise
  125. Dtc P0420
  126. Predator help
  127. car doesn't like A/C
  128. Help! Car has been dead far too long!
  129. tq manag?
  130. headers install - open loop now?
  131. ls1 edit info please
  132. P0327 knock sensor?
  133. TR 224 with stock tune. Is it ok?
  134. bad plug in port
  135. Hypertech programmer or Predator tuner
  136. switched from draw thru to push thru ltrims swing 15%
  137. Starts bad
  138. anyone have
  139. Need the ASA pcm pinout
  140. tuners:please check my diablo live data
  141. o2 sims
  142. SES Light Any Idea's
  143. LS1 Edit and Hypertech/Diablo
  144. fueling problems, pcm seems to go into speed density mode
  145. Quick HPP3 Question.NEEd Quick Response
  146. Tuners: Timing vs. MPH??
  147. Need some tuning help..car just dies at half throttle
  148. looking to buy efilive or atap
  149. when to replace o2's and a/f gauge question
  150. Carputin Blows a big one
  151. Will an Impala (baby LT1) PCM work in a F-body?
  152. Engine to Dash Pinouts
  153. DTC P1336 (Crank positon relearn)
  154. Timing Table for LS1Edit
  155. Timing Table for LS1Edit
  156. need a tuner in the North Arkansas or South MO area
  157. Programming with a laptop
  158. Those Ebay performance chips
  159. HPP3 shifting question
  160. How will engine respond to larger injectors?
  161. what does all the live data from Diablosport mean?
  162. questions about fuel trims at idle
  163. secondary ve table
  164. need help
  165. need explanation of air/fuel ratio measuring, guages, narrow vs wideband
  166. How accurate is the LS1 Scanmaster?
  167. disable the security???
  168. PCM tuning in Sun valley Idaho?
  169. Change Injector Size w/ Hp Tuner
  170. I see we have a new moderator!
  171. help
  172. Predator Or Hpp Tuner Question
  173. Help me get rid of this dredde Knock Retard!!
  174. looking for 02/03 Z06 VE table...
  175. LS6 PCM Table
  176. Considering HP Tuner Suite
  177. Aspect Ratio???
  178. Installing new PCM with remote start??????
  179. Venom 400
  180. Worth adding EFILive to ATAP Enhanced?
  181. PCM pin-out question ... not an LS1 (3800 GP motor)
  182. ECM Scanner Options - what's hot, what's not?
  183. UK LS1 owners. Assistence required.
  184. Crank sensor relearn
  185. Is this a low idle?
  186. Wester's vs. Nelson Performance
  187. Anyone at HP Tuners help me out?
  188. Fuel Trim Question
  189. Would code P0121 (TPS) cause built trans not to downshift at WOT? tuning problem?
  190. What is this called? Re: Coasting down a hill
  191. Speedo way off. HELP!!
  192. HP Tuner Users..........
  193. ABS Issue with slicks?
  194. IAC's too low? Did I go to big with drill bit?
  195. Need tuning help for TR224/112
  196. anyone live near whittier, ca?
  197. How to run open loop?
  198. fixed idle and now hangs up
  199. DAMMIT!!!! need help
  200. performance chip
  201. Car is really lean and other problems too HELP?
  202. Dumb Question: How do you delete the rear 02's using LS1Edit?
  203. Edit tuner in Minneapolis/st. paul?
  204. quik question....
  205. How to tune for a turbo???
  206. Help, Is it ok to drive the car???
  207. TCS acting wired lately...
  208. Mechanical vs. Electric gauages---whats the diffrence?
  209. I just pre-ordered HPTuners:Have questions
  210. Tuners - Where do you start pulling timing on a blower car?
  211. 02 SS Fuel Pressure adjustment
  212. Speedo not correct even after changes in Edit
  213. Issue with dyno numbers. Is it PCM related?
  214. WooHoo!!. justed fixed all my idle and driveability problems
  215. Autotap Oil Pressure Voltage = 0 ?
  216. Service Engine Light Came On
  217. what number to change to get the quickest knock recover
  218. Time for tuning yet?
  219. SES P0135 Code, HELP PLEASE!
  220. Need factory IFR table for 2001 C5 coupe, 6spd
  221. IDLE provblems in gear...
  222. Timing Tuner issues..
  223. fuel trims changed big time, what gives?
  224. just went TH400, now wont idle
  225. So fuggin mad with Edit
  226. 98 z28 cats removed
  227. hypertech or diablo?
  228. ve table adjustment question?
  229. question on using someone elses flash?
  230. Running lean - losing HP?
  231. LS1 edit retune after LS6 intake swap?
  232. Is it possible to hook up a MSD Digital-7 plus box or retard box to an ls1?
  233. What should I adjust using predator after 231 cam install?
  234. High/Low Octane tables...
  235. A4 Tranny Slipping After Programming
  236. book on ls1 tuning?
  237. LS1 TunerCat possible this month.
  238. OBDII and EGR @ inspection
  239. Using Tuning to lock converter up top?
  240. Tuning my 98 Trans am ws6
  241. need help problem with my 02 z28
  242. first time autotap
  243. A/F HP difference from 11.8:1 to 13.0:1
  244. Strange A4 Tuning issue... shifting at 63mph .. shoud be 73mph
  245. No more edit
  246. Help with nitrous activated timing retard
  247. Timing Tables
  248. Broadcast code problem? (messed up PCM?) Please help
  249. WOT and street tuning??
  250. having issues with starting
