View Full Version : PCM Diagnostics & Tuning
  1. P0449 code ( HELP)
  2. Do I need larger Injectors
  3. Please help with spark knock problem...
  4. predator problem
  5. Looking for cell data
  6. Automatic Guys? Timing question.
  7. Hypertech Problems FYI
  8. Dyno tuning or not?
  9. Reading Injector PulseWidth??
  10. What is----------->
  11. disable CAGS w/Diablo???
  12. torque management and drive by wire help
  13. My Long Tubes =(
  14. Westers Tuning
  15. My LS1Edit isn't working???
  16. Is KR Easy To Spot on Dyno Graph?
  17. When changing PE vs RPM my LTRMS change
  18. Running very rich- ok to drive, bad for new muffler?
  19. MSD shift light Qs...
  20. Diablo for tuning after cam install??
  21. NeedNeed Help ASAP.. Tried all that I know to do, but still nothing works.....
  22. G-Tech/Pro??
  23. Predator's capabilities w/eliminating lean cond
  24. EGR/AIR removal on LT1?
  25. Question about a diagnostic code
  26. About MAFstock vs. 500hp
  27. do i need to wideband my car or will ls1 edit do the trick..
  28. VE tables
  29. Can buy used Predator for $300
  30. Jet performance Chip?
  31. How rich does it get to throw a P0172/P0175 code
  32. Idle Problems?
  33. Any ideas on fixing racing idle when slowing down?
  34. dyno tuning
  35. Logging VE's
  36. SES light = Knock Sensor... does it matter?
  37. LM-1 RPM Cable now available
  38. Any reason for tuning for idle that wont learn
  39. So, how can an LS1 actually run rich?
  40. I have a code, help
  41. Off Road Long tubes with no tuning.
  42. piggy back module for boost control.
  43. Whats the difference betwen High Octane and Base spark in gear??
  44. Laptop ports for edit and ATAP?????
  45. Upgrading LS1-Edit from v1.1 to v1.2 or v1.3 ?
  46. Obd - No Power
  47. Been gone for awhile....
  48. P102 MAF Low Circuit Input
  49. how do I Disable second gear starts.
  50. Running open loop question.
  51. How Low Can you Go
  52. Honeycut you know who this is, tuning question?
  53. PE tuning after ported heads
  54. IAC counts at 0
  55. Closed Loop Fault
  56. Reprograming a 1999 LS1 PCM for a 2004 LS6 ?
  57. Fuel Trim Won't Adjust!
  58. car sucks after tunning
  59. another question about predator
  60. o2 readings? .900+ rich or lean?
  61. Knock retard
  62. Need Help Quick
  63. Throttle follower tables?
  64. P0200 anybody?
  65. Cam install tuning???
  66. PCM question for conversion
  67. Is tuning needed for 30lbs injectors
  68. Need PCM for LS6 ?
  69. Anyone had a tune "dump" on them??
  70. Can someone help me out with an atap datalog?
  71. 93 Octane = 9* KR...100 Octane = 0 KR, now what?
  72. Oil usage caused by rich idle after cam?
  73. IAC counts
  74. ed wright tunning
  75. Maxium injector duty cycle - OBD-2 software
  76. How To Reset Hypertech Settings (for Resale)
  77. Any tuner's in AL?
  78. Tuning
  79. Jeremy Formato@FasterProms...Great Tune!
  80. Do I need to tune?
  81. Where to get a PCM?
  82. Stock timming and AFR
  83. Fuel trim & Timing
  84. 1st time trying to use Edit????
  85. Will this work with autotap software?
  86. Help, SES "lean"
  87. Question for you LS1edit and computer guru's
  88. Cheapest way to change shift points?
  89. Anyone know if a MMS 229 v2.1 can pass sniffer w/cats and tune?
  90. Have the 1415 bank 1 code after heads/cam/exhuast install. Any ideas?
  91. questions about tuning
  92. programmers?
  93. Need Info: First time for a Knock Retard Code.
  94. Question about tuning(please help)....
  95. Ported ends vs. stocker for tuning?
  96. What does the PCM do when you gas
  97. LS1 edit vs. Predator...
  98. Can I delete the ABS INOP, brake light,
  99. Loading .ls1 files in ls1 edit
  100. Stock vs hhp3 tuning w/tr220
  101. O2 sensor code 1133,1153
  102. PE Multiplier too small?
  103. Running rich....how much lost hp??
  104. Predator programmer!!!
  105. I have a possoble short somewhere, any guesses?
  106. Just a plain electrical mess
  107. Car is missing up to 1500rpm
  108. Is it to cold to tune?
  109. CKP Variation Learn - How does it work?
  110. Fault Codes
  111. What does it take to flash PCM back to stock?
  112. Cat Overtemp? When to use?
  113. Is MAF-T compatible with GMAF??
  114. Cold Start Open-Loop
  115. Speedo Calibration
  116. KR Gurus, need some info?
  117. anyone selling a predator?
  118. LS1 Log File Analyzer, what is it for?
  119. Questions about Ltrims at idle...
  120. Clearing codes with Predator.
  121. How can I delete the SES light for good?
  122. tuning help, what else needs to be done??
  123. Gear change messing with rev limiter
  124. Low idle
  125. Very Wacky Ltrim/Fueling Issue - Looking for ideas
  126. My DTC
  127. TR224....Car smokes some after running hard.
  128. LS1 Edit or Predator???
  129. basic vortech tune with ls1 edit
  130. MAF flow numbers? help me out please...
  131. Security Light won't go out - why?
  132. Maf Vs Sd Tuning Debate
  133. Drilling the Throttle Body.
  134. A-Tap logging info needed....
  135. gonna dyno, what nubers to check...
  136. Help Fast
  137. can heavy engine load cause KR?
  138. High and Low Octane Tables EXPLAINED!!!
  139. Are you happy with your Predator, those that have it?....
  140. power gains?
  141. toasted PCM.. fu*king awesome
  142. Hypertech power programmer?
  143. Signs of bad coil.
  144. H20 in PVC catch can???
  145. no spark after replacing head gaskets
  146. help me out here :(
  147. Anyone know what causes the "poor MAF performance" code to be thrown??
  148. Cam surge cure?
  149. Tuning for LT's with MAFT and autotap.
  150. Flash PROMs for viewing?
  151. P1153 code ?
  152. Cold Start Help ?
  153. Running a little rich
  154. TM on M6
  155. New (?) Engine management software???
  156. Anybody ever got a cam on a 108lsa (about 44 deg.overlap) to run right?
  157. VE Tuning for S/C, confused????
  158. PCM tuning mods for EGR removal?
  159. PCM tuning in Las Vegas
  160. Code P0894
  161. ls1 edit??
  162. 100% duty cycle
  163. When to tune?
  164. Help! Diagnostic code P0141???
  165. stupid question... but!!!!!!!!
  166. Mail order Tunes
  167. KR issues
  168. tuning for a yank 4400
  169. ok wierd one here
  170. were to get ls1 edit program
  171. Users of LM-1 AFR meter and true duals....
  172. Question regarding tuning and torque converters
  173. Can you turn off the TCS light w/ edit?
  174. how come ATAP/Live works but Eidt will not connect?
  175. Will IAT module work with Predator?
  176. Knock retard during crank?
  177. LS1 Edit, at all user friendly??
  178. i changed my plugs and now im running rich, normal?
  179. Why did older LS1's have higher stock timing than the newer ones?
  180. Replaced Both Knock Sensors & Wire - STILL Codes Are Set!!
  181. !egr !air
  182. Help with Idle issues
  183. Anyone know their Ignition Voltage?
  184. Who uses LS1edit with USB
  185. asr reversal
  186. Some questions about predator
  187. put in new plugs, fuel trims off...help?!
  188. ASR OFF Light
  189. Car stumbles when it's wet/raining outside.
  190. LS1 Sensor Locations
  191. Truck tranny files??
  192. F-body vs. Truck PCM
  193. A place for tuning
  194. Help!!!
  195. maf ends tuning for tranny line pressure
  196. Paging ChrisB - LS1 Log File Analyzer.
  197. What to monitor on Auto Tap for ......
  198. Code P0343, how to go about a fix?
  199. o2 sensor part #?
  200. Service Vehicle Light Stays on
  201. TEA knows tuning
  202. whats? po133 and po155
  203. Reasons for false knock?
  204. Help using Autotap for a no start
  205. What happens when 02's die?
  206. Dyno Tuning in the STL, Mo area?
  207. Auto tap help
  208. 8mpg, running rich, vacuum problem, and GM will not service my car.
  209. auto tap code?
  210. Ideal A/F ratio?
  211. Which Tables To Adjust?????
  212. Problem with O2 readings
  213. Desktop dyno file of the Ls1
  214. What does ABS INOP means?
  215. I've been gone for awhile, but im back again, and need help.
  216. Has anyone else ever had this problem?
  217. Opinions on Predator?
  218. Ebrake,headlights.....
  219. WTF,Search feature sux ass!!!
  220. Has anyone used the FAST LS1 fuel management system?
  221. Anyone have a MAF Table for a 03 Z06
  222. Tuning after header install .....
  223. Iac reading on atap and questions
  224. A/F ratio question
  225. LS1Edit & subsequent log info - AFR
  226. Does a 98 car need it's own cable/software?
  227. Battling KR
  228. PO103 code ( HELP)
  229. What to do with bad maf harness/wire?
  230. How would you swap a year 2001pcm in my 98C5 as the 98s stink for WOT shifting!
  231. ls1 edit
  232. Procedure for WOT tuning...How?
  233. LT1 Edit
  234. How do you read two dif year (LS1 EDit)
  235. Knock Sensor help
  236. How much Knock does it take to go Lo-Octane?
  237. timing questions
  238. Need tuner in California!!!!
  239. LTFT at 25 :(
  240. HPP3 question
  241. Closed loop,fan turn on,& thermostat
  242. buying AUTOTAP
  243. P0300 goes set at idle when cold
  244. Adding timing help with idle?
  245. LS1 Edit guru questions
  246. P1133 Code PLEASE help!!!
  247. richen up part throttle???
  248. Weird EFI readings and problems...please help.
  249. Buying LS1edit
  250. Does A-tap 2.1 (DOS) show KPA?
