View Full Version : PCM Diagnostics & Tuning
  1. Need A-Tap help quick
  2. Tranny tuning
  3. False knock...now what?
  4. Buy ls1edit
  5. cold weather...
  6. Fuel Trim & VE
  7. PCM/voltage
  8. Cant get Radio Lights or milage to work any thought?
  9. O2 deletion w/ Edit
  10. Can Someone explain Knock?
  11. Seeing negative LTrim numbers at WOT
  12. What parts would be required to activate a circuit once ...
  13. If you have a "mail order tune" step inside.
  14. LTFTs are +20
  15. Predator Tuning
  16. Timing questions for you HCI and larger ci cars
  17. tranny swap, PCM flash, and Edit question
  18. EasyLink Question
  19. TPS install??
  20. ls1edit
  21. LS1Edit save problem
  22. I need a 6.0L or a 5.3 Truck Maf Table
  23. P0153 HO2 slow response bank 2 sensor1
  24. Diagnostics w/ Predator
  25. OK, I'm confused??
  26. Tuning Idle and Timing on TR224
  27. Best way to tune WOT, PE/RPM, IFR, MAF
  28. Favorite Laptop model for LS1 Edit and AutoTap/EFILive?
  29. Do u need to drill the TB with a cam on a C5?
  30. car won't start, any help???
  31. Why did the LTFT's reset after refuel?
  32. Laptop battery goes dead with edit, but OK with Atap?
  33. Dynoing friday....any tuning tips?
  34. Loss in Gas Mileage! Is it O2 sensors?
  35. Pros/cons of deleting front O2 sensors?
  36. I dont know if this goes here but i got a big problem need h
  37. d t c po154 ??
  38. LS1 ignition coils
  39. cost of tuning
  40. Anyone heard of Davis CarChip data logger?
  41. Part throttle knock (ATI)
  42. LS1edit... is there ever a GP..
  43. Tuning and knock.....
  44. x1 cam tuning...wont idle at startup....
  45. Missfire on #3 cyl after 4700 rpm (any help appreciated)
  46. result of deleting codes from computer and NC OBDII testing
  47. What about the "other" computers?
  48. How to remove my 'puter to send to mti
  49. LS1 Tuning
  50. Vig 3200 and Predator
  51. Help need to know how to lean out car!! Don't have LS1 edit
  52. LS1 Edit, What to expect
  53. Missing 98 SS
  54. Price for O2 sensors?
  55. OBD2 "Plug In" Emmissions Tests and LS1Edit
  56. Help Help Please
  57. What is the diff in LS1 edit, and hyper tech?
  58. How do you disable the knock sensor
  59. Programming for OBD2 emmission tests
  60. Hypertech 98 Camaro LS!
  61. Car runs bad lean..........
  62. AutoTap upgrade... What does it entail?
  63. edit and rev limter? shift light problems
  64. Please go to this link if you are running a FAST system...
  65. Not sure how to buy autotap...do I need the EFI Live version
  66. Have the HP..where are the times?
  67. KR after LT install?
  68. ls1 edit-ors
  69. Ignition timing?
  70. "service vehicle" light
  71. H & C, post your PE RPM tables....
  72. LT1 Edit ..order.. plz help ??
  73. Spread sheet to determine injector size.
  74. gonna hit dyno, what should i expect with these mods?
  75. removing egr eliminated pinging!
  76. values for 43 lbs and 57 lbs injectors?
  77. Problems with IAC and AutoTap
  78. took out egr and cats, need advice on LTRIMS
  79. KR comes on religiously at about 4500 RPM in second gear...
  80. po 133 & 135?? need help
  81. LS1Edit V1.3 - IFR 100kPa - 20kPa???
  82. New Data Reduction / LS1 Edit Automation Software ->
  83. Predator Users - PE Settings – Which way to lean out car?
  84. need help NOGO and anyone with edit knowlege
  85. What PCMs to look for
  86. Dynoed yesterday... Running really rich... need help...
  87. Tuning for a stall converter
  88. Gettin' dyno tomorrow morning-Whats your guess?
  89. Th350 in place of 4L60E
  90. LTFT's...
  91. Problems connecting to PCM w/Autotap
  92. strange o2 readings
  93. O2 sims...codes for efficiency problems....
  94. New injectors and fuel system, problems...
  95. V1.3 LS1 Edit IAT - MAP Table
  96. no way to get rid of kr without edit?.....
  97. worth tuning my car...
  98. SURPRISE! SURPRISE! P0300 Reset itself?
  99. Cruise control on a non-cruise car?
  100. Edit v1.3 Timing vs Temp Table
  101. Can anyone here review my EFILive Data files?
  102. will a miss cause positive or negative ltrims?
  103. do I need a 98 pcm harness if I used a 98 block and heads?
  104. Is it worth it to tune my car on 100 octane??
  105. For you do-it-yourselfers
  106. Wideband Monitor GP
  107. Anybody figured out what the "Throttle Cracker" does yet?
  108. Edit( IAC and RAF) changes for G5X2 cam
  109. SES Light , Codes PO135 and PO155?
  110. Predator and MAFT
  111. CHECK GAGES light come on during acceleration?
  112. IAC counts. What should they be at in A4
  113. '99 PCM in a '01 car=NO GOOD!
  114. SES light keeps coming on, same code keeps getting pulled!
  115. Car struggles at WOT
  116. changing high octane table to the low octane table
  117. Accel 30# injector Question vs Stock.....
  118. PLEASE HELP!!!!!!!!CAR MISSING @ WOT AFTER HEADER INSTSLL???
  119. 42lb injector tables?
  120. Edit Eng. Diagnostic ???
  121. AEM working on stand alone EMS for LSX based engines
  122. Help! Cannot get A/F above 12.7
  123. Why buy it?
  124. check engine light
  125. Cam surge at startup.
  126. Predator shifting??
  127. signs of bad o2's?, help, pics inside
  128. Harlan Window Switch and Shift Light
  129. Is VE or MAF primary management?
  130. rev limiter
  131. Autotap
  132. crank position sensor code
  133. knock retard question using autotap
  134. part throttle tuning help
  135. diagnostics
  136. Anyone know the airflow calibration table for SLP MAF?
  137. ls1 edit
  138. M6 to TH400...anything in edit need to be changed
  139. swapping PCM's and I already have edit??
  140. Bad O2 Sensor
  141. A/F is black(Pro Stock John, anyone?)
  142. does anyone in houston area do tuning on a 5.3 truck????
  143. i need help about total timing
  144. ses light?? please!
  145. car won't lean out at WOT?
  146. WTF is check sum error
  147. PCM Settings for Cooling Fans On/Off vs Temps?
  148. Accel DFI Gen7 w/ Wideband O2 option
  149. High LTFT even after alot of tunning?
  150. Firmer quicker shifts
  151. Please Help SES Light On!!!!!!!!!!!!!!!!!!!!!
  152. Misrouted harness cause codes???
  153. Getting high and low MAF frequencies, CKP sensor code
  154. Hypertech?
  155. too much background noise while on dyno
  156. Converter lockup problem after cam install.Misfire code del.
  157. PE vs. RPM...max enrichment allowed...?
  158. Dead Battery.. now no gauges???
  159. A4 shift points with edit
  160. What do I look for when testing a N2O setup w/autotap?
  161. ses light
  162. P0300 DTC after cam install?
  163. Going from ported MAF to stock MAF
  164. Where to learn F.A.S.T. system in-depth?
  165. Idle stumbles when coming to a stop, then recovers
  166. How to lean out part throttle in LS1Edit?
  167. 42's n/a anyone have a file?
  168. Who can explain how the tach signal wire works?
  169. when adding heads to cam-only, is retune (LS1edit) needed?
  170. Closed versus Open Loop
  171. so does this look right?
  172. Significance Of LTFT & Tuning
  173. whats P1153
  174. log screen shots.......... HELP
  175. tunning
  176. car throwin codes??
  177. Right Bank Running Lean
  178. Car dies when I let off the gas quickly
  179. woohoo, got my auto tap today (some ?'s)
  180. EFI V5 Live users........ Help
  181. Reprograming PCM using LS1 edit & HPP3
  182. Speartech conversion car throwing a P0102 code
  183. Printing in LS1 Edit?
  184. Correcting Speedometer in LS1 Edit for non stock tranny
  185. shifting help
  186. RPM switch
  187. Where to get dyno tuned in south Georgia/north Florida area?
  188. Fast or DFI ???
  189. pinging still?? i want everyones imput please
  190. predator or custom tuning???? i need help!!!
  191. Predator Custom tuning???Where to start??
  192. NEED HELP WITH SHIFT POINTS (USING PREDATOR)
  193. hurry COT help!! no cats can i delete?
  194. Reseting PCM
  195. Rev limit and shift points?
  196. threw P0172 and P0175 have questions
  197. Spark plugs
  198. welp... still 4* KR at WOT ... can MAF be culprit?
  199. idle going up and down till warm
  200. Car won't start after swap to A4
  201. what is COT ?? and how do you disable torque managment ???
  202. Need A Tuner in South Florida or Orlando
  203. In car laptop holder
  204. KR question
  205. racing chip
  206. SES Light On!!!!!!!!!!!!!!!!
  207. a few questions on hpp3
  208. About to order LS1Edit...got some questions!
  209. autotap efiliveV5 pro ???>>>>
  210. Procharger timing issues
  211. Dataloggers for use with OBDII?
  212. After the basic.................
  213. Car stays in low octane map all the time, why?
  214. anybody with wideband setup
  215. autotap-are timing advance readings less any knock retard?
  216. Proper tunning vs RWHP Races - come inside
  217. how to tune out knock retard
  218. running super rich while in idle & pt
  219. Can i remove the cruise controll anyone done it?
  220. cooling fan temps
  221. HPP3 questions please help
  222. My buddy's Jetta
  223. Breathing mods and edit
  224. Cincinatti area tune
  225. Timing and tuning questions
  226. ses light, WTF?
  227. not hitting 100% TPS at WOT...big deal?
  228. Disconnected MAF ???
  229. Surging issues
  230. vehicle speed sensor code??
  231. Code P1415, WTF???
  232. Can you re-sell a Predator?
  233. EFI Live MAF Help Please
  234. closest place for tuning?
  235. pulling cats what do I toggle off in ls1edit
  236. Why won't my misfire problems end?
  237. What ways can you tell if a car is in open or closed loop.
  238. Make sure I got this straight, on idle vacuum kpa to In Hg
  239. HKS Super AFR tuning
  240. First Dyno after H/C
  241. what's causing my P0101 code
  242. Do I need a tuning?
  243. Anyone use this cable with EFILive or A-Tap?
  244. Will LS1 edit log diagnostics like autotap?
  245. Shift Kit + LS1 Edit
  246. TUNING OUT "ABUSE MODE" w LS1 EDIT??
  247. Why wont car start?
  248. 160 Thermo
  249. harlan 2 step
  250. Where is BCM
