View Full Version : PCM Diagnostics & Tuning
  1. Code P0106 ???
  2. Can you get an idea of exhaust emissiions using EFILive V5?
  3. NFB: Need some help with my laptop I use for my car
  4. Can't get Converter to lock. Please help.
  5. quick question about a/f mixture and 0 knock at wot
  6. Changed VE Table now i have a slight Hesitation!
  7. Pcm reprogram after engine swap a must?
  8. EFI Live V5 ?
  9. stock ls1 rev limit
  10. Installed Cam Need Help on Tuning Issues!
  11. Diablo Predator custom tune install problems.
  12. p1336 code wtf??
  13. ltrims and fuel pouring in? (Long)
  14. HELP non LS1, How do you reset an air-bag dash light ??
  15. I lower "IFR" by 2% , did this make PE WOT go up 2% or ??
  16. LS1-Edit/Program Can't "establish" connection???
  17. Installed new LS6 in 99 SS but no HP gain - computer issue?
  18. ATAP start-up question
  19. Now I'm getting pissed off........................
  20. Predator problems?
  21. Recurring P102
  22. ATAP for palm being a PITA!
  23. Segment 1 Check Sum is Wrong! WTF?!?
  24. BIG PROBLEMS! HELP!
  25. LS1 Edit help
  26. ecm tuning
  27. What can make one bank run leaner than the other?
  28. ABS and TCS Delete
  29. I think I'm retarded!! Really! Please help
  30. Cooling Fans don't Turn On?!?!
  31. MAFT causing 4 degrees of KR
  32. Whats the best
  33. SES Light.....??
  34. PLEASE HELP!!!! TUNING
  35. Anyone ever had Ls1 Edit not work?
  36. Need to reduce timming with LS1 Edit - How?
  37. Swapped to 30# acell injectors, now has horrible bog
  38. Any Body Know How to Figure Injector Offset
  39. Idle tuning?
  40. Thoughts on this AFR after cam???
  41. DTC 121???? TPS
  42. Are My LTFT's to Negative?
  43. P0449 how do I fix?
  44. MAFT Mounting Location
  45. Generator L-Terminal Circuit P1637 -- AIR System code PO410
  46. How to Reduce Timming with LS1 Edit?
  47. Tech Edge A/F meter???
  48. How much for Autotap and LS1Edit?
  49. stock 2001 ls1 file
  50. 2 sets of LTFT's in autotap, which should I use?
  51. Understanding Air/Fuel Ratio
  52. IAT tricking... except I need it to say the air is hot! help
  53. >>>THREW MORE CODES...PLEASE HELP!
  54. user manual
  55. Need some help tuning 224/227 Cam--Starts
  56. 2003 Z06 Top Speed Limiter Removal??????
  57. New spark plug wires and plugs installed, now the car is....
  58. Do You Have This Module??
  59. Efexts of H/C on A/F
  60. throttle sticks on my 96 LT-1
  61. P1637 Generator L-Terminal Circuit??
  62. Error DTC P0782 2-3 Shift Malfunction?
  63. stock tune anyone?
  64. file does not have a segment 1 ID???
  65. Anybody watch EGT's?
  66. 99 and up pcm on a 98
  67. LS1edit and new cam Idle problems??
  68. P1683 - Metering oil pump temp sensor circuit malfunction?
  69. Can I use a stock tune from...
  70. H/C Airflow....what is your max w/ your setup? .....
  71. EFI Live For Sale
  72. Tuning for turbo... Where do I start?
  73. Big Cam/Low Vacuum tuning at idle and part throttle?
  74. SLP Air-Temp Module OK with aftermarket MAF?
  75. MAF?
  76. 99 MAF on 01 Z28?
  77. locked computer?
  78. Warm starts car wont idle??
  79. predetor
  80. p0336 and p0327 code
  81. Anyone with similar mods and LS1 Edit inside please
  82. EFILIVE or LS1 Edit
  83. Will this LS1Edit file work with my PCM?
  84. 99 Camaro Cluster
  85. How Hard is it to Tune a Cam?
  86. what do IAC in park and in gear fields do?
  87. Rich at idle after cam
  88. can someone get me some screen prints of ls1 edit please
  89. PO137 and PO157 - which O2 sensors are these???
  90. Can you have your PCM reprogrammed with a new vin?
  91. Removing PCM?
  92. Tuning the GTP Bosch injectors?
  93. back to stock rev limiter?
  94. the cost of sequential management? *DELETED*
  95. EFIlive ??? '01Z06
  96. How would you tune this?
  97. Abuse mod ?
  98. LS1Edit problem....need help....
  99. not charging
  100. Lost timing
  101. Codes after Header Install..........HELP!!!!
  102. Plese help: Signal wire for Oxygen Sensors
  103. Should I get LS1 EDIT?
  104. Is EFIlive necessary if you have LS1edit?
  105. How important is the MAP sensor?
  106. Problems in first gear
  107. Running Air flow
  108. Torque managment
  109. What is VE? (tuning for hot starts)
  110. Revisiting Shift Points - N/A Compared to On The Juice
  111. 97 C5 ATI 9lb.-P1518, P1514, P1571 - Reduced Engine Power
  112. hear that IAC counts inop in A Tap 2.04. Any others?
  113. LS1 EDIT
  114. Barely passed NY State inspection - HC 0.57 out of 0.60
  115. Low voltage warning b4 edit
  116. Can LS1 Edit...
  117. How do I turn off my ABS INOP light?
  118. What program would u recommend?
  119. Just ordered a pocket dyno?
  120. Diablo Predator performance tune download help
  121. Setting Target A/F ratio at idle / cruise with ls1edit
  122. autotap ?'s
  123. What is the correct way to eliminate torque management?
  124. SERVICE ENGINE LIGHT FLASHES AT 75MPH?? ANY IDEAS
  125. Autotap and converter lockup
  126. Running Atap w/USB Serial Adapter
  127. Help with hot starts
  128. Torque management; please explain/help...
  129. Atap Analysis Question
  130. LS1 edit
  131. IAC counts too high how do I lower w/o drilling hole larger?
  132. Diablo Predator and TR224 or TR220 cam users here please..
  133. ATAP and Nitrous
  134. RPM's holding at 1800 for 10 seconds before going to idle...
  135. What is too low for O2 millivolts?
  136. Help with tunnig
  137. Throwing phantom codes....SES light flashing but no codes?
  138. Laptop Mount
  139. anyone in the READING, PA area
  140. PE versus injector flow.
  141. 2001 LS1 PROBLEMS!!
  142. What happens if you max grams per cylinder?
  143. Where is all my HP
  144. What do these 02 readings tell you?
  145. tuning shift points
  146. code trouble
  147. Palm based Dyno / Scantools?
  148. car not running good!!!!!!!
  149. Which O2 sensors should I have???
  150. Diablo Sport Predator tuning for 85 mm MAF
  151. How to tune med. load?/Edit
  152. Diablo Sport Predator
  153. LS1Edit, EFILive, AutoTap, Predator, Hypertech, etc
  154. please help- kr? and edit ? (long)
  155. Edit Tuning related issue's Q/ about fuel guage
  156. 01' and 02' cars.....How much timing are you running?
  157. Hpp 2000 on a 2003
  158. need help; engine problem
  159. For those of us who have Ed Wright tunning?
  160. How Do I log Shift Points A4 with A-tap?
  161. My LS1 Edit CD is unreadable? DVD ROM drive won't accept it
  162. Underdrive Pulley after dynotune with LS1Edit... Affects?
  163. Rev Limiter ?
  164. need help, KR problem
  165. Timing and Nitrous
  166. Wideband O2 ?
  167. What do bad O2's read as far as mv???
  168. Question on fixing Speed - O
  169. can I use a-tap with home pc?
  170. Hypertech or JET Chip
  171. Can MAP Numbers Help Detemine if there is a Vacuum Leak?
  172. Mail order tuning???
  173. whats the easiest way to richen across the board?
  174. system readiness efilive v5
  175. what A-tap to get?
  176. Looking for a picture of fuel and timing maps
  177. O2 sim trickery
  178. Surging & High Idle (LS1Edit)
  179. AFR to Mv conversion?
  180. New at this.....any ideas by looking at this graph?
  181. car has tuning issues with fuel!! Please help!!!
  182. MAF table edit with Predator?
  183. where can I find a list of SES codes?
  184. scanmaster reading low 400's WTF
  185. Please help me interpret O2 readings and compression test
  186. EDUCATE ME!!!!
  187. Need help quick - security light cut off the fuel pump
  188. SES light Flashes at end of track, but no code
  189. How much timing is too much?
  190. Tuning "?", more like definitions
  191. Does my scanmaster work on 02's?
  192. Pace MAF??
  193. PMAF cause surging?
  194. IAC Count is too Low?
  195. Autotap o2mv Question?
  196. Autotap not seeing IAC counts
  197. G-Tech Pro accelerometers on eBay
  198. P0153
  199. O2 mV to wideband AFR correlation - post your data
  200. detonation
  201. po748
  202. please need help in tunning (LS1Edit)
  203. Swappin T-56 to TH-400, what about pcm?
  204. LS1 Edit & Moving PCM to Different Car
  205. How do you program a converter to lock/unlock when it should
  206. a/c schematic or help
  207. Tuning results from Rapid motorsports within
  208. HPP3 and my BoltOns?
  209. Anyone know of a Laptop holder for F- bodys?
  210. Need to improve my 01 SS!!!!!!!!!!!!!!
  211. LS1edit worth it on internally stock car?
  212. I get the P0327 code w/cutout open in cold start...
  213. Those of you with the Predator.
  214. po1153 code
  215. FELPRO F.A.S.T expert needed
  216. Guys using PCMCIA to serial with LS1 Edit or Autotap
  217. LTFT's not close to each other. Also only using 3 fuel cells
  218. Difference between v4 and v5.2 MAFT's?
  219. Autotap or tech 2
  220. COT (cat over-temp) trigger?
  221. is the power programmer full of s#%t
  222. How do you lock the convertor using LS1 Edit?
  223. tuning with longtude headers
  224. LS1-edit - What are IAC and IAC PArk Posn tables?
  225. ATAP - "Attempting Communications" repeating
  226. Need FAST file for 396 N/A
  227. LS1-Edit - what are these tables?
  228. evaporation system readiness failed
  229. Can autotap's vehicle speed reading be incorrect?
  230. HPP 3and predator are they pretty easy to understand ?
  231. How do I get the SES light back on?
  232. ??Best method to keep the battery charged while editing??
  233. Got SES Code w/ these Mods
  234. How long for comp to relearn itself?
  235. MAF Tables
  236. Cleaning MAF?
  237. New H/C and LS1-Edit - power loss under accel
  238. Offsets for 83 lb Siemens injectors?
  239. Factory tuning and after MTI tuning via Auto Tap
  240. Lowering idle w/ LS1 Edit
  241. what do i do with the torque management?
  242. Can stock Tach be improved to read accurately/precisely?
  243. Quick Poll: How many running cats with COTS disabled?
  244. Logging Data From Tech Edge Wide Band O2
  245. Anything wrong with using 40# in a H/C 346?
  246. Anyone tune for money?
  247. Anybody using EFILive with a USB/Serial adapter?
  248. Help - need answers on Ltrims- Please -- Update
  249. What settings for HPP?
  250. ls1edit file for 4.10 gears and 26 inch tall tire.
