- I'm stumped: Intermittent Flatlining O2's(over 1000mv!)
- All these idle issues I see on the board... Here's what I've done & tried...
- ls6 maf on a 97 C5
- Taking the car down to Diablo next week for Predator Dyno tune
- Idle hunt: to much timing or what??
- is it better...
- Removing AIR with no codes?
- Gutted the cats, what codes do i turn off for the 02's
- Cat Over-temp Question
- Idle Problems after 110lsa cam, make suggestions please!
- P0101? What do I do? ***UPDATE : PROBLEM SOLVED***
- Cam guys: whats the most timing you have added at idle?
- Can LS1edit help get my tranny line pressure steady?
- Did I get a bad Predator, or am I just retarded?
- HPP3 settings
- computer tuning
- Help!!!!
- How to reset the PCM?
- Quick Question: A/F Ratio
- Need a little help guys: Idle Air Control Motor Position in ATAP?
- #6 Cylinder huge missfires...
- LTFT????
- postive LTRIMS at WOT??
- when is reprogramming required ?
- How do I set the miles on my car to O
- Is is possible to change the O2 Heater Circuit temp range with Edit?
- Say i want to tune in speed density?
- Do I have to tune my car with this cam 224/224 567/567 @ 114
- Check it out->Will this help with our MAF tuning or tuning in general?
- Hows autotaps palm pilot software?
- service engine soon!
- O2 simms (millivoltage) vs. A/F ratio
- using atap, how can i tune my base?
- i need yalls help desperately with my knock retard
- Help to trace the problem P0174/P0171
- Idle timing and cam surge what MAP values to change it at?
- LS1 Edit...
- predator shift points
- Injector Calc. V1.4
- cam/header guys need a few answeres
- How do i raise my TC lockup MPH under normal driving
- ls1 edit
- Should i worry {lean}
- LTFT Sanity Check
- Autotap AT1 v2.10 install files
- Tunning, LS-1 or Ed Wright
- St and LT
- Hypertech Programmer
- WTF car still won't idle! EXPERTS?
- FAST Performance or Fel-Pro?
- What A/F ratio to run??
- anybody flowed 85mm maf vs stock?
- Trace Analysis Software
- O2 Sensor
- LS1 C4B Supercharged.
- Might have a problem
- Why doesnt the SES code translator work??!?!??!
- Predator and custom tuning
- Off throttle tuning LTFT
- Just ordered Predator, do I need Atap?
- Help With HPP3!
- New C&S Performance Standard Pricing
- intsrument panel acting up on start up...
- extra O2 bungs for tunning - what location is best?
- O2s ??
- need to get dyno tuned dont know where in south florida
- Why lockup TCC in 3rd during normal driving?
- Could changing battery reset or mess up the PCM??
- Are these LTFT's too rich?
- Need Auto Tap Advice
- Any way around major programming?
- Help With Tuning
- Cam tune
- Predator vs. HPP3 on '02 A4 F-body
- Rev Limiter?
- O2 sensor wiring?
- MAFT tweak induces KR?
- Rev limiter
- Factory Rev Limiter???
- Using ATAP to see if front O2 sensors are bad?
- HELP car will not idle right?????
- I think someone turned the miles back on my car!!!!
- OK have some electric qs after install of shifter
- Question About My Dyno...
- Is it too much timing or not enough that creates surge @ idle?
- LS1 edit and Hyppertech
- LS1 Edit tuning did on a 224/.581 disapointed?
- Anyone happy with mail order tuning?
- Need help w/ tuning after Bauer TB install.
- no need for MAFT or HPP3 if you use LS1 Edit?
- EFILive and oil pressure readout?
- Gained 1 hp lost 5#tq with new tuning (questions)
- PROGRAMING AFTER A CAM SWAP
- help with maf numbers
- Is bigger better?
- Some confusion about file editing with LS1edit...help needed
- P O300. What do I adjust to prevent open-loop misfire?
- A little tuning help please...
- Any one ever hurt your batt using hypertech?
- Lots of LS1 EDIT Q's Please help!!
- Wiring Diagram
- PEvsRPM table need it for the ATI SC!!!!
- need help
- LS1/T56 into 67 Firebird
- Can someone tell me how to retrieve codes of OBDI?
- Fuel problems
- LS1edit file for ATI SC!
- need help with A4
- LS1 Edit, Predator, Hypertech????
- LS1 idle quality
- Help! Why does this happen???
- A/F Ratio
- Ls1 edit - torque managment?
- Edit Settings for a 160 Thermo?
- Moderators, SOME ONE HELP WITH THESE CODES!!
- HPP III RFG Tunning question
- SES lights with new Cam install
- new CALMAP vs FAST
- Engine idles at 1800 after cam install
- Engine dies on quick accelerator release
- LS1Edit or wait for TunerCat?
- Quick deliver from Carputing!
- Which side of the car is bank 1 and bank 2
- Shift Firmness & Shift Time
- changing front knock sensor
- What is this Error CODE?
- Buy LS1Edit or dyno tune for new cam
- Injector flow rate table ?'s...
- What is Cat OverTemp Protection?
- grinding throttle stop- question on voltage?
- Can the factory ignition provide enough spark for a H/C car?
- nearest dyno tuning with edit is where? FLP?
- How are you A4 guys checking KR
- DTC-PO410 What's wrong?
- Autotap
- Who has LT1 edit for an obd2??
- How can you tell if torque management is a problem
- What can I expect from LS1 Edit / Dyno tuning?
- Advanced LS1_Edit topic regarding reflashes and power numbers
- CODE SCANNER
- AUTOTAP- LOSS OF COMMUNICATION
- Fiew LS1 Edit questions and tuning
- Does AutoTap read ABS DTCs
- Any info on rapid performance?
- Performance Chip
- P0440
- Delete BlackBox with LS1 Edit?
- HyperTech Hyper Screwed me
- HOW TO CHECK IAC OPERATION
- Help with appropriate idle speed!
- LS1 Edit - Idle Air?
- Recalibrating MAF transfer curve
- About to attempt first LS1Edit burn, could someone look over my changes?
- rear 02's
- Will LS1 edit run on a 166mhz laptop?
- Should I have my Car Tuned on a Dyno?
- Dyno # before and after cam and headers. Disapointed.
- Need tuning help
- Anyone with an '02+ PCM seen this behavior with timing
- auto tap for the first time ....please help...
- Anyone In Ft. Lauderdale For Computer Tuning?
- ls1 edit?
- Any Dyno shops in the Los Angeles area?
- Did bump stop mod and now Engine Light!
- Car Dies in Reverse
- Anyone running Standalone Managment? ( Haltech/Tec3)
- Should I get the standard Atap or the enhanced version?
- LS1 edit,HPIII, or a Diablo?????
- IAC Park Position in Edit...
- A/F ratio is a bit rich! how much more power will it make?
- Programming for two F-bods..
- timing table questions
- Header bang and false knock
- P0155...should I be concerned?
- AMS Racing and LS1 Edit?
- Tire Size
- Can false Knock yield High degree readings?? I'm getting it at ~1750 RPM's ???
- Car started stalling this morning...
- EASE
- Need some help and advice
- Please look at my dyno #'s and tell me what you think
- HPP3 Experts help !
- 02 Question
- Dyno, and jagged upper rpm graph
- Can Someone answer this??
- ENGINE LIGHT ON
- Ease GM Enhanced scanner V2.5 shipping
- Effects of burnt front O2s
- ls1 edit/EFILive timing bug or just me, please help
- Anyone selling HPP3 for 98 LS1
- Slight poping and cutting out at part throttle acceleration....
- Disable Tourque Mang. With Edit
- OMG plz help ,
- Knock Problems...WTF!!!
- Where in NC to get a dyno tune?
- Dissabling torque managment in a m6 car
- Auto Tap vs. EFI Live?
- Custom Tunning
- Speedo Reset
- scaned car for fist time and need help(update!)
- High Octane Spark Advance...Did I forget anything?
- Do you reccomend MAF table or PE vs. RPM multiplication?
- Maft translator
- KR, timing retard and knock counts
- *LS1 Edit* Questions Before I Buy It....
- FLP dyno tuning
- Predator Tune
- HELP
- Optimal Air/Fuel Ratio
- LS1Edit newbie questions...
- Trouble shooting Code P0160 ?
- lterms
- Headers Glowing Orange!!!
- Torque Management
- What is the benefit of the zero vinfeature on LS1 EDIT?
- 58 degress of timing advance???
- Any LS1 EDIT Tuners In NORTHEAST OHIO
- Finally going to buy LS1EDIT and AUTOTAP but I have a few questions
- L-terms +5.1 cruise with 2 WOT runs resulting in .909 and .870 respectively??
- incar wideband O2 ??
- Autotap screenshot, I need tuning???
- Average timing @ WOT for 01-02 SS?
- PE vs RPM on LS1edit help!
- Injector size for ~ 400 RWHP?
- LTFT what cells do you monitor for BASE!
- My car = bad news. Can anyone help?
- SLP's new dyno testing and tuning facility
- System Readiness Test - incomplete
- does anyone's exhaust smell real bad?
- any dyno tuners in southern ny state?
- Easy way to lower rev limiter?
- any wireing guru's around???
- Mail Order PCM special......with overnight mail included!
- How important are cam spec's when tuning?
- Want to upgrade AutoTap...what do I need?
- TQ Management
- WTF bank 2 B2S1is all out of wack
- Spark Retard Limit (LS1 Edit)
- How to view ATAP log files?
- New CAM-need a file
- HPP3 doesnt adjust for A/F w/ power tuning?
- LS1 edit injector flow rate table??
- Ltrim's all f'ed up.
- Car won't start - Posible computer problem
- Help 4.10 gears A4 car and HPP3 what shift points
- how do i copy High spark advance to the low one?
- i really need help!!anyone can help me please!!
- stock timng and adding it?
- How to kill torque managment with M6, to be sure its not affecting anythign.
- Possible to delete TCS thru EDIT? Ala skip shift?
