- How to set Rev Limiter with LS1edit?
- Set base timing with LS1 edit?
- Do I need Auto -Tap???
- "Incorrect Checksum" Problem with EFILIVE V5
- what does LS1edit have that EFI live doesn't for performance tuning?
- Ltrims Min and Max
- blower / turbo people. where do you start pulling timing?
- Swaping pcm's
- Car won't idle.. is this because of the lsa on the new cam??
- EFI Live
- KR in high gear
- LS1edit says my pcm isnt licensed
- Tunning Ported MAF Question?
- Rev limiter with 1:85 rockers
- Who Can Tune it in Houston?
- HELP i ned this sensor......
- LS1 Edit cannot eliminate DTC's. Carputing won't fix it.
- HELP!!! Did !Wires mod and now car wont start
- can car be wb dynoed with duals under car?
- Still fighting electrical gremlins
- A4 ported MAF kills transmission? HELP!
- Part throttle tuning step by step.
- Manual fan switch useless?
- Can't connect to car's comm port...WTF?
- LS1edit and fan switch?
- dumb dumb mistake
- Which N/A induction pieces work better with PCM learning?
- misfire - #3 HELP
- Why does my car redline at 6200 when I used LS1 edit to program a 7000rpm redline?
- PLEASE help me :(
- Can't kill P01860 and P01810 codes
- ls1 edit tunning a new cam
- Tunning Help
- Ease V2 scanner released
- Exhaust throwing my computer off?
- Just can't seem to get the shifts right with Edit!
- how can the PCM just die for no reason?
- Timing Tuner need some info!!!
- sell 02 simms after LS1 edit?
- Need LS1 Edit file for 2000 M6 with TR224
- What happened to the price increase topic?
- Horrible Lean Miss
- U guys are scaring the shi.........
- HPP3 and 3.90 gear... tire size?
- LS1 Edit : AIR pump?
- LSI Transplant
- O2'S fouled
- question about rear o2's
- ls1 edit purchase
- why is my timing in the teens?
- heads+cam=scerewed up tach
- Quick Hypertech Question
- Holley 50-pound injectors rated at ??? psi
- EFILiveV5
- Flash files
- new code popped up today...P0704
- This Atap reading ok for a cam?
- Ghanging Gears w/ HPP3
- Advice on these wacky ltrims
- WOT Voltage?
- Test Messge
- I need a LS1 File or help!!!
- Scanmaster mounting
- LS1 Edit drains my battery?
- DTC #0171 and 0174 both banks lean?
- Knock problems
- Should I put my Stock MAF ends back on before I use LS1-Edit?
- Need idea's on tuning
- !IAT mod
- Has Anyone Successfully Tuned an Open-Loop Program?
- Going back to stock injectors...can I run them at lower FP?
- Torque Management on a m6?
- P0420 - Is Bank 1 the driver's side O2?
- MAFT help - need advice
- Hypertech question
- Problem with my laptop and the LS1-edit cable
- Need help tuning my 83 lb/hr. injectors...
- TPS Adjustment?
- Pic of MAFT or settings for dials
- Someone should make a module to adjust idle rpm's
- USB-serial adpt. can't use ATAP anymore!
- How to lean out part throttle with LS1edit??
- MAFT version?
- Injector Flow Rate
- How much is LS1 Edit Cable?...If you already have software..
- Can a maft adjust one bank at a time?
- LS1 Edit vs. Auto tap
- LS1 edit and Knock Retard
- Normal or Not?
- Advance Timing
- What is fuel cell 0 ?
- MAFT tuning had Ltrms at 0 and WOT at 930's.....
- Windows 98 or ME or Win 2000 Pro? Which is best for EFI LIVE and Edit?
- LS1 edit has ALOT of options...
- Codes Help!
- Scan Master ????
- Size Injectors ????
- Heads/cam 02 LS6 odd results: Updated
- My new Dell doesn't have serial ports?
- LS1EDIT vs. Hypertech?
- Question about HPP3
- How do you know your injectors are maxed out??
- Need some wiring help
- Were can I get PCM Reflashed?
- What is "EVAP" System??? Computer threw about 4 EVAP codes...
- PCM Updated
- ls1edit/dyno question
- Help! P0500 Vehicle Speed Sensor Malfunction
- o2 sensor location
- P0327 Code Need Help.
- What triggers the Barometric pressure reading?
- Spare PCM
- HPP3 w/ Vig 3600
- ???? ANY DIABLO UPDATE??
- SES Question
- N20 part of "Timing Tuner" ??
- Couple questions about tuning my MAFT...
- My thoughts on the Timing Tuner......
- Need help dealer doesnt know...
- Open Loop Mode: How do I...
- Are exhaust gas analysers good for tuning??
- Formula for calc'ing HP based on MAF flow?
- So what exactly do I need to buy EFI Live?
- question about the PCM "Learning" after tuning
- MAF ends causing ping at low engine speeds?
- O2's at .92. Spend $ on a maft?
- ls1 tuning
- LS1 edit and Autotap
- question about positive LTRIMS at WOT
- changing gears with edit
- texas emisions
- Please Help, Where is a wide band Dyno?
- Eratic idle only in open loop
- HPP3 and it's effect on timing advance
- When du you offset the injectors and....
- ? Adjust PE tables first or MAF tables?
- SES Diagnosis - NEED HELP!!
- Which diagnostic tool?
- O2 Volt question?
- KR problem
- P0107 anything to worry.
- Need 99 LS1 Edit Software
- question about mafs.
- What does Closed loop mean?
- How can I check my MAF with A-Tap
- Switch 3&4 on MAFT w/GMAF?
- AutoTap
- HELP!! Car problems (long)
- Looking for Shop to do Wideband O2/LS1Edit tuning!
- Unknown SES light?
- 5.3 heads or GM ported LS6
- So tell me again why the APEXI S-AFC will not work on the LS1...
- Check Engine light flashing....Help!!
- How much timing advance is too much??
- What should you do using LS1 Edit after removing cats?
- Does anyone have any tips for using LS1 Edit to pass emissions?
- crazy question, but ned answer anyways
- MAFT
- Injector Wiring ???s
- How to contact carputing/ ls1 edit makers...
- EFI Live adjustment ?s
- LS1 edit questions
- P0171 & P0174..what causes it??
- Pin out for fans on Z28 pcm
- Hot Cam Idle Problems
- Error P1416?
- MIL after header install
- ? about LS1 Edit cables....
- What version of Autotap?
- New Lap-top A-Tap issue??
- Transmisson Trouble
- Injector Offset - Definition
- strange idle problem
- KR in 1st gear below 4k RPM's during WOT?
- EFI Live newbie, Help me figure this stuff out
- Welp, I successfully screwed the pcm with ls1edit
- BCM Scan - anybody - help
- 0 Degrees Advance?? What gives?
- Do I need LS1 edit?
- MAFT? What do I need and which one to buy?
- AutoTap Fixes O2 readings
- Who needs dyno tuning in Northern California???
- Secondary Air Injection (AIR) System ???
- KR-->KR-->No KR-->KR
- Need SES help!
- Anyone have a flash file (ls1edit) for a setup close to mine ...?
- Interesting O2Simm anomoly
- does this code causeloss of performance
- Right bank missing, help!!!!
- surging problem??
- PCM
- Battling Knock Retard... Is if False?
- Having some electrical problems
- First time to dyno my 01 conv.
- HPP3 trashes my pcm
- ls1 edit or dyno tuning
- GM site for pcm recalibration availability....
- MAFT and the infamous P0102 Code Help
- Whats Cause this Code P1133
- Maf-t switchs
- 10 Bolt Rear - whines after dealer oil change
- LS1 edit and the future
- What is the Autotap "Hardware"
- Where to buy LS1edit
- Paging ChrisB and any other LS1 edit genious's
- Difference in stock MAF sensors 98-02?
- How much power am I giving up?
- Using LS1edit to setup PCM for injectors....
- Possible to have ~0 KR
- Autotap Registration
- Another O2 Problem for you.
- Need LS6 - LS1Edit file - stock
- Am I on the right path?
- Question on custom tunning
- Highest CompRatio On Stock Tuning
- Can I get my SES light scanned w/ Hpp3 installed?
- Pace mass air Descreen or not?
- does any body have any info on ls1 edit
- help with false knock retard
- P0102 after reverting to stock MAF
- Got Dyno Tuned, what fo you think....
- '99 pcm with a '01 engine ls6/intake
- Where can I get car scanned
- Pro Tuning In St. Louis Missouri
- Live monitor both front 02s
- Easier way to delete the EGR?
- Just Bought 97 Z28..........Do I have a speed limiter?
- Atap/MAFT Help Needed
- Reflashing '99truck pcm to '02truck pcm?
- SES Light Please Help
- can you warp valves with open headers
- What is the proper air/fuel ratio?
- what triggers the alternator to hi output?
- Need Help ASAP.
- Will I set off a code with long tubes and off road pipe.
- Can I run my computer w/ MTI tuning w/o.......
- I was wondering about the PACE LS6 85mm maf..
- ? about fuel trim cell and edit
- still cant find out why low MAF is set!!!!
- Paging Matt Harlan
- Soooo.... What can you do with Ls1edit?
- Will I still need my MAFT?
- Can too high of a number in ls1edit for shift firmness break something?
- Need advice on Atap readings...
- MAFT compatability with PACE 85mm MAF
- Passing emission testing???????
- EFI Live question
- Good running engine = ? timing
- What 4-8 sensors for basic reading using AutoTap
- Gauge Re-Setting or Recalibration ?
