- Reflashing '99truck pcm to '02truck pcm?
- SES Light Please Help
- can you warp valves with open headers
- What is the proper air/fuel ratio?
- what triggers the alternator to hi output?
- Need Help ASAP.
- Will I set off a code with long tubes and off road pipe.
- Can I run my computer w/ MTI tuning w/o.......
- I was wondering about the PACE LS6 85mm maf..
- ? about fuel trim cell and edit
- still cant find out why low MAF is set!!!!
- Paging Matt Harlan
- Soooo.... What can you do with Ls1edit?
- Will I still need my MAFT?
- Can too high of a number in ls1edit for shift firmness break something?
- Need advice on Atap readings...
- MAFT compatability with PACE 85mm MAF
- Passing emission testing???????
- EFI Live question
- Good running engine = ? timing
- What 4-8 sensors for basic reading using AutoTap
- Gauge Re-Setting or Recalibration ?
- Tips on a faster, firmer shift with LS1Edit
- LS1Edit vs EFILive vs AutoTap
- Odd HPP3 Questions
- Probelms with o2's
- MAF and Injector problems
- CHIP
- Help is my pcm screwed
- Does Ed Wright make good dyno numbers?
- LS1 edit
- slp air temp.module with hpp3
- Anybody get the "TCC lock-up through the shift" to work??
- Anyone using the timing tuner yet?
- New AutoTap = different O2B1S1 readings
- AutoTap checklist (Ver.5)
- chicago land suburbs auto tap???
- Where to buy LS1Edit
- Custom Tuning
- Whats the highest you would go w/the rev limiter on a stock motor?
- Tranmission Programming LS1Edit
- Hypertech and 4.56 gears, need HELP!
- first dyno run
- P0341 Camshaft Position (CMP) Sensor Performance
- Problem with Superchips
- I need some LS1 edit help BAD!
- Got the RX7 running, but stumbles very bad.......
- Anyone using the ls1 timing tuner?
- Please Help guys :( What do I do after I've saved my csv file as a workbook??
- What type of chip? Where to get it?
- KR and what the heck causes it?
- Where to buy spare PCM?
- ?'s on timing with a modified LS1...
- LS1-Edit + AutoTap, combo shipping?
- Car acted up after Read PCM w/ LS1edit??
- Where can i get a copy of LS1 Edit before I buy it?
- anybody know what causes a low voltage at the TPS?
- O2 sensor "low voltage" SES light. Please help.
- ETC Limit
- ED Wright or thunder for tuning?
- Have a wierd problem and nobody knows the solution...Need Help!!
- AutotapV2.02 O2 Loggs Are Crap, Whats The Deal?
- TSB/Recall
- 2001 Injector Limits?
- First Autotap Runs, Couple Of Concerns, Couple Of Questions
- Dealer upgraded computer programing
- Very strange.....
- Dyno Shop Locator
- I can't find an old post of mine! But here's the info. you guys wanted...
- Rear ABS and VSS...can it be the same?
- ltrims=25%
- Surprising Dyno Session Today. LS6's like 22 deg Total Advance.
- diablo tuner
- That damn SES Light!
- Two-Step Wiring on a 1998 M6
- Another emissions thread!
- Idle is pissing me off! Any ideas?
- Anybody know what causes this?
- Q.'s HPP3 (vs. SuperChip)
- Any Tuners that can help me...Please?
- MAFT and trans line pressure
- Could LS1Edit effect the Fuel Gage?
- What does:" Mass Air Flow (MAF) Sensor Circuit Low Frequency" mean?
- Anyone know the AIR delete codes??
- Rate on 6.0L '01 injectors?
- MAFT/LTFT's and Dragstrip use
- MAFT Add-on
- using a maft and autotap vs a dyno tune???
- Tach wire for 99& newer camaro????
- How much Knock retard is bad?
- what gauges do you recomend...i live in florida.
- MAF table only goes to 11250HZ for '97&'98, how do I add equiv values to 12000HZ?
- running too rich! need help please!
- LS1 Edit: need help in:cam, EGR,AIR, ford 30lbs ASAP please!
- Maft and its use
- NEED A LITTLE HELP FROM U GUYS
- Which version of Atap should I get
- LS1 Edit Track Testing... Is LS1Edit worth it on a stock car?
- Need help with code P1514
- O2 Sims
- where to buy ls1 edit
- Car is acting WACKO!
- Anybody want a HPP3 for a 2000?
- FTRA & Lid...
- Help, SES after SLP manual fan switch install
- Checking injectors
- The new CAT Over Temp feature added +12RWHP!
- LS1 edit R232 jack?
- Need ATAP help ASAP!!!!!!!!!
- PE vs RPM
- Remove Cruise Control - does it throw code?
- P1683? Driver 5 Line 3?
- Car leans out at 5K RPMs everytime today on dyno
- TPS device
- WTB: 2002 Hypertech Programmer
- First LS1Edit session....
- EGR and AIR code ??
- Can atap or edit tell what timing table?
- Rev Limiter at 9000 rpm in 5th gear on 2002 Z06???
- Paging Racinrick
- EFILiveV5 question
- Hypertech problem....
- NEED tuning advice Ltrims
- Code P0757
- First Dyno (graph inside) - How can I lean the A/F?
- Ltrims are around 17-21 normal driving, what to do to MAF table?
- How do I adjust the "CAT Over Temp" feature in V1.1?
- new user to LS! Edit....a/f ??
- how do i check Injector Pulse Width on A-Tap?
- IAC Counts question
- Increased the high octane spark advance...did I do this right?
- Need tech help......
- Looking for 2001 LS1 Edit File
- LS1Edit. Where is user data?
- MAF Frequency Codes
- Whats up with my o2's?
- hpp3 button not working!
- TeamZR1 and other emission I/M240 scan experts...
- New to LS1edit...Rev Limiter???
- though its some 25 horses, would you trust a tuner with your car?
- Question on Spark Retard Limit Tab???????
- Car idles high in gear?? seems to be after cam install
- Autometer tach/shift light install questions
- Explain what low frequency MAF is
- VE Table Values Who knows
- hypertech3
- Laptop computer connections to .....
- some one explain ls1edit ver. 1.1
- torque management
- Problem, only when it rains....
- lean or rich?? what do I Iook for in A-tap
- HPP 3 Tuning on an A4
- 4000 -> 6000 RPMs I'm at 12.2->11.9 A/F
- How do I get rid of TM or something else
- 4 degrees KR, help!
- P0121
- So what is this info good for?
- ok I searched and searched and couldn't find an naswer... issues with 95 LT1 car....
- SES light turned off??!!!!
- ls1edit in Calif SF bay area
- can edit delete tcs?
- Hpp3/LS1 edit ?
- Autotap for Palm "Generic" -v- "Enhanced"
- Questions about SES
- ramchargers nitrous&timing controller
- engine missfire?
- New Cam...TC won't Lock-Up
- Raising Idle with LS1Edit
- C2 Cam Installed Need tuning help.
- Front KS
- How Much For Computer Wiring Harness?
- What do tuners pull on EDIT to rich/lean the car???
- TCS light????
- Interesting IAT question
- Injector Constant question ?
- questinon about PE table.
- Info on tuning shift points with LS1-edit
- what should my car idle at.?
- Why does my car shut down after several runs? Need help!
- Single Turbo Tuning for truck
- EASE vs ATAP / LS1-LS6edit vs EFI Live
- Can you delete the AIR pump with LS1Edit?
- Wideband Calibration
- Maxing out 99 injectors?
- how long to get ls1 edit
- perfect air/fuel ratio?
- What EFILive parameters to baseline
- power from tuning
- PROBLEMS .....
- can resetting ses light using fuses hurt editing???
- Flooring it from a roll in 1st....no go, Torque management???
- Need help with SES light code PO300
- Ideal air/fuel ratio
- 98 TA > LS1Edit change shift points by RPM or MPH?
- KR at high speeds 110+
- Rev limiter in neutral for M6??? --LS1 edit idea inside
- iac motor count
- More fuel...is it better??
- Edit gurus: how to add timing at low rpms??
- who can tune really well?
- Timing question
- Electric fans on truck with ECM ??
- HYPERTECH POWER 3
- PCM Tuning for dummies
- MAFT tuning and injector help
- STOCK COMPUTER&HPP3
- Does ATAP show duty cycle of injectors?
- can LS1 edit delet the "security" light and the "brakes inop" light?
- Torque managment removal?
- How do I download the latest version of Autotap?
- Hpp3 timing increase?
- Basic parameters adjusted to increase hp?
- Which version of AutoTap is the best?
- hypertech???
- Paging ChrisB ........ correctedmaf.xls
- MAFT Translator
- atap on a palm?
- Got Edit, can't get rid of P0757.....
- Is LS1 Edit worth getting for a stock engine...
- What is the best diagnostic tool....
- someone explain map and psi for me!!
- Hope someone here can figure this one out.(long)
- EASE scans observations
- shift point question and ls1edit, why so many tables
- Does WOT PE really look at LTFT?
- AutoTap
- 02 sims did make a difference.....
- PCM years in different cars
- MAF Question
- Need help with these codes!!
- Anyone run constant open loop?
- ls1edit?
- LS1 Edit site
- P0332 ses CODE?? WTF?
- LS1 Edit questions .. if I had a...
- LS1 Powered Sand Rail Problem
- what causes a low MAF failure???
- what exactly is ASR ?
- Will I need tuning?
- fuel cells
- kr, will just not go away! dont know what else to do
- Where to adjust timing retard w/LS1 edit?
- Check engine light on. Need help with codes.
- Should L-Term readings be done at idle or cruise?
- Wierd TPS problem
- Whats with my damn O2s?
- Knock Retard Due To Solid Mounts
- O2 Sims
- i know this isn't the right forum
