- Please help me ! SD or MAF tune
- EFILIVE pls hlp ????
- help fouled plug ?
- Need help deciding on a tuning solution
- New big injectors and now rpms going up and down
- Problems with Diablo
- Wideband O2 Sensor Placement
- diablo super chip? questions.
- Throttle follower decay question
- gauges dont work after heads cam install
- Want to go back to stock
- check engine light code P0803
- Hp tuners or EFI live - Which one is better - Looking to buy
- DBW to DBC Confusion...
- is hptuners scanner helpful if car won't start?
- VCM read Failed at loc 6000 error checksum
- Can I Fix A Tune With A Handheld?
- What is wrong with my tune / do I need to send my computer off? Professional help plz
- chip burner eprom tuner? tx
- Todd @BlueThunder2racing
- Can't stay connected to lap top
- Looking for a Tuner in the PA WV VA MD area.
- looking for a e85 tuner in nw indiana, mich, ill
- Nelson Tuned PCM, what is the Tach setting? 4Cyl or 8Cyl?
- Hp tuners how old are you?
- did 99+ pcm swap in a 98 car..no fuel guage with fuel segment
- The Buck Stops Here (cam surge gone)
- finally got to the track
- Mailorder tune , big problems after cam.
- need help getting HTP to download
- HP tuners question
- Eliminate 3rd gear lockup with hp tuners?
- Changes in weather effect tune?
- Help With Stripped Down Control....LM7 in a Jeep, Very Basic
- 1993 Pontiac Firebird LT1 w/major problems!!
- 402 stroker hp tuners help
- Question bout maf tables
- Ed Hutchings still tuning?
- fast injectors do u like em?
- being to rich on the afr hurt boost levels
- ses
- need help LS3 in 02 Fbody
- 2000 a4 wiring harness, what goes where?
- O2 sensor question
- Multi-tune options?
- Drive by wire vs. drive by cable and tps
- need help bad
- help! n2o tune setup
- timing question
- anit-theft mode help
- Service engine light
- P0220 adjustable
- gauges and codes
- map only hits 50 kpa??
- cat O2 sensor computer trick to read good emissions or what?
- How to turn off dash lights....
- HPT Trany Help please
- commanded afr at wot
- tuning software
- whattype of tune will i need?
- Will a 99+ gauge cluster work in a 99+ harness swapped car
- Fuel trims out of range sometimes
- bucking V6 camaro
- 3 Bar Map
- high idle, tune related?
- tune parameter
- buy hp tuner
- New DiabloSport Trinity Update! 1999 - 2006 vehicles now supported!
- Is this a dumb idea? Wideband wiring idea...
- Service engine soon
- flutter between 1300-1800 rpms?
- tuning issue?
- Ngk Afx wideband
- Tune out ASR
- Dual Fans - dual problems...
- P0157 Long Tube no Cats
- Painless wire harness
- No signal from ALDL (DLC) with engine running.
- PCM Electrical Question
- HP Tuner or EFI Live?
- heads up display!!!
- 402 stroker tune
- Anyone wanna take a look at this tune?
- 98z28 with 2000 wiring harness and pcm no gauges work
- Start up help.
- 98 harness and pcm on 02 lq9...hp tuners
- Cant get injectors to fire - w/ driver box
- 99-02 harness into a 98
- Bad experiences with 1_bad_ls1 mail order tunes?
- ODBII port working now. Pls give some advise on this tune/scan
- What wideband should I get???
- Do I have to get a tune?
- tuner vs scanner
- Twin turbo 404
- loking for a base tune
- Lean Misfire
- Tune out codes??
- 58x to 24x Wheel
- rough running but rich?
- HpTuners 5.3 w/'02 ls6 cam no emissions looking for tune file
- p0101 & bogs - What next?
- What to change for just injectors? I forgot.
- Strange Idle
- Ls1 camaro turn off after warming up. Need help.
- Programming PCM for Swap
- Autometer WB gauge and HP Tuners ??? How to
- HP Tuners SOS from Florida
- Bad WOT Backfire-Turbo-Need Help-HPT Scans Included
- Tuning Software
- Bolt On Tune Sale
- pros cons of removing maf
- ETC Throttle Oddity? Scan inside..
- best sponser to buy hpt?
- Never Tuned, input appreciated
- efi live misfire pids wont monitor.
- What questions should you ask your tuner?
- speedometer recal only with diablosport
- Wideband sensor and gauge Qs
- P0327 knock sensor code question
- 2 bar map question
- What pcm is this?
- Tuning for e85
- Idle related problem...would need some direction
- Tuning at Idle - Open Vs Closed Loop
- Disconnect MAF ?
- 408 intake backfire issue help!
- HPT suite 2.22 install in Window 7
- Point me in the right direction
- Where Do You Find That Table?
- HP Tuners EIO
- I got a mailorder tune...but (problem, need quick help)
- HP tuners VCM Suite v1.0 Questions
- STFT Question??
- PLX wideband question
- HPT,E40 SD--tables that control AFR@startup & first seconds of run time
- Truck wont start
- Closed loop makes car go LEAN
- 95 lt1 - obd1 pcm
- Quick Question.
- SD back to maf
- lq4 & zo6
- Went lean on bottle, could tuner have added fuel?
- Where should I mount my wideband sensor
- Dead spot part throttle
- Mastach aldl pinout help
- SES code PO155B. Help please
- what is the exact reason(s) speend density is better?
- Surging & car kills
- LT1 - OBD1 - 4L60E to TH400 swap - PCM need flashing?
- no start issue
- Need help TPS problems
- Vats bypass???
- Reset air bag system after DERM replacement?
- turning off O2s with HP Tuners
- Oxygen sensor problems
- For Sale: Superchips Flashpaq
- datalogging with autometer nexxus gauges and hp tuners pro
- swapping PCM
- Aftermarket MAF causing problems?
- P0452B Fuel Tank Pressure Sensor Low Voltage
- Looking for a tuner in MI
- can my wideband commander be fixed?
- mods and no tune question
- PCM code reader and tuner
- Anyone have a copy of Calibrate Success DVD for sale?
- ANOTHER SET BACK, wire harness??????
- File Error
- Need help with PCM swap. Willing to pay. Need ASAP
- MAP code
- where I can get or order??
- Please help O2 and knock sensor prob (screw NY state inspection)
- pcm tuning
- Weird Security Light Issue. NEED HELP
- anyone know the pcm connector part numbers?
- LS3 in LS6 CTS-V ECM compatibilty issues?
- N E 1 Use a Autometer W/B 4 Hp Tuners?
- ASR off and still get the Trac Light, I need you insight!
- Converter Locks/Unlocks...Tuning Advice
- Who Can build me a Tune for my Truck?
- dyno tune or buy hp tuners
- Quick programing question, 4L80E
- 5.3L/4L60E in a 67 C10 issue...PLEASE HELP
- Is my MAF/tune FUBARed?
- speed density tuning how do u like it?
- Still Running Lean...
- I had 16 codes showing!! HELP!!
- 98 Trans am with 2002 computer
- P0300, just a tune needed????
- cold start question
- New to this
- FAST 90 Swap Idle Issue. Speed Density Tune
- help
- Turbo timing
- Finding the right BCM
- Which programmer 2 use..?
- wide band with 0-1v output
- 94 camaro gauge issues
- dyno tuning in iowa???
- automatic headlights
- Rob Raymer at Evans tire in Richmond Ky yesterday
- PO327 & PO332 Knock Sensors
- tune questions
- Electrical?
- Injectors in Banish DVD?
- Dyno Tuner in near Nashville????
- Handheld tuning options for '98 cars?
- Ford style TB (TPS)
- Low Impendence or High?
- stockish running lean?
- What would cause no fire on cylinders 2,3,5,8
- Auto to manual help
- Props to cunningham motorsports
- Tuning after LT's and LS6 Intake?
- Rich / Lean Codes
- Question bout EFI live
- 98 pcm
- Changing parameters with someone elses diablosport?
- datamaster
- what to set timing table? cam, heads,
- Unable to communicate with OBD
- MSD Timing Twister shutting down
- Ubuntu?
- Fan issue - they just wont turn off
- Frost Tune Question
- P0430 help!! Won't go away!
- Hypertech programmer, one quick question..
- Can I use a 98z harness to put a 5.3 in T/A?
- Tuning with a netbook or with a laptop?
- Tuning after LT's and LS6?
- Speedometer question
- What tune for Yank ss 4000? Mail order ok?
- Aeroforce pt401 scan gauge on a 1998 trans am problems any help???
- Retune needed for start up w/ new cam?
- wont start ,spark on one bank????
- Wideband's which would you choose from these 3 and why? (AFX, LC-1, AEM)
- 2007 STS-V Wont Downshift Manually
- Revs Hightower with tps plugged in
- 94 lt1 into 96 ta body...no spark and no fuel pump
- Help Needed: Intermittent hard start...
- good tuner in the nashville area
- Maf calibration, in the PCM or maf itself?
- Need pcm tuned for 4.10 gears who can do it?
- Have a few idle tuning questions ("LS6" with stall)
- how to get IAC's into range??
- Frost tune and tr230 cam only. Anyone running it?
- Looking for a decent set of instructions for Dynojet Wideband Commander
- Hyperpac Programmer or PCM tune?
- Bluecat Tuning in Kentucky...
- Need help with a P0106 Code
- Advice on timing adjustment
