- Predator Problem!!!
- Heeeelp, I think they're screwing me...
- Predator Tuning Problem
- WOT fuel help please
- Help with ls1 edit
- EASE, trans temp??
- air bag light on
- How to lean out A/F ratio in closed loop?
- Hesitation Problem, Need help
- predator newbie with dumb questions
- new LS1 Edit forums
- possible false knock?
- Dealer ship can not communicate with vehical??
- I am stumped!!! Help! *DELETED*
- VE table vs Tip -In
- tuning questions, best a/f ratio and timing?
- Ls1 edit and O2's
- LS1 EDIT / ATAP EFI LIVE CONNECTION ?????
- AutoTap question?
- Predator custom tuning
- Predator
- Don't know where to go.
- Need help with edit
- EFILiveV5 and Oil Pressure
- LS1 Edit - KR, COT, TC
- Bone stock autotap #s...weak? please opine
- KR help
- NEEDED : 98 F-Body PCM, ASAP!
- Traction control
- Speedometer help and edit
- throwing codes
- p0121
- trouble codes, P-1133 and PO102
- HELP!!!! service engine soon light
- P0133 slow o2 response
- How to tell if prev. owner had my computer reprogrammed
- LS1 edit or ed wright tune
- I need a stock LT1 dyno sheet!
- I randomly lose TCS after working with fuel system.
- quick autotap question?
- cam and headers....need a tune?
- Car running after 7 months.. just 1 code now..
- Trans shifting into 2nd way too soon, only at the track
- any ls1edit gurus in the Sacramento area
- PCM has wrong tire size????
- ABS and O2's?????
- Idle help
- need help tuning
- Power programmer around Lexington, Ky area??
- Who makes the MAFT?
- Need help ASAP. Having a prolem at 5k-5.5k, car breaking
- auto tap
- Paging Supercharger/LS1Edit gurus...
- Is the factory speed slow under hard acceleration?
- What has to occur to activate the Low Octane Table???
- PCM
- Need Help!!! ATAP, LS1 edit not recognizing computer!!
- 99 motor in a98. PCM Differences???
- cooling fan help
- Threw code P0135
- Two Guys Garage - Hypertech = 120HP gain?????
- Pic of LS1 Wiring Harness inside
- Does any one know where i can buy a new computer
- Temperature Gauge fix for '99 & up?
- How good is the Predator?
- Low octane spark advance & high octane...
- Car running weird... help pls
- Can i gain from dyno tuning at the bolt on level?
- Can you tune with a stock O2 sensor?
- Tach not working?
- Predator axle ratio change
- First Autotap log tonight, help needed....*UPDATED*
- question about using laptop w/ ls1edit
- 1998 Diablo Sport Predator?!?!
- gm's tech 2 and ls1edit work together?
- Knock sensor conversion on 98
- ecm or bcm
- Help car wont rev past......
- is that bad 1.7 KR
- Adjusting Ltrims... What table in LS1 Edit?
- Help me with this code my car threw....
- What is the easiest way to calibrate my car for my 4.10s??
- why did my fuel trims go down to -8 or more after gettin gas
- MAFT directions?
- Tuning Questions about injectors....
- MAFT, new vs old
- Need edit file for 427 stroker
- I need diagnostic help
- Do I need differn't Injectors?
- Will LS1 edit work on the LS1 trucks?
- Will i be able to use my EDIT with a replacement ECM?
- ATI P-1SC timing issues (LS1Edit)
- O2 Sensor Question - Values varying widely
- does any one have info on the flash chips??
- High IAC's, how can I lower?
- Help, car running like crap!
- Help Knock from nowhere (long)
- Serial to USB converter for LS1 Edit
- i think i might have detonation but i dont know, help me!!!
- Just thew a code...P0171 ...........
- ACCEL DFI GEN 7 FOR THE LS1/LS6
- Which AUTO TAP to get?
- P 1 133 what is this code? help
- I need somebody to ATAP me-Still getting High RPM ping
- Lost 5 MPH in the 1/4 Any Ideas?
- Car bogs when going into Closed Loop
- Newest LS1 Edit Version....
- auto tap and efi live
- heatwave and 91 octane gas equal no power
- Warm/hot start issues, IACs, and "cruise control" effect....
- Air/Fuel Thought for self tuning
- Buying LS1edit next week. Where to start?
- P0175..(System to rich bank 2)..HELP!
- timing ???
- fuels trims, when and how to read them
- Knock sensors How Much???
- Predator & Shift Points for an A-4 with 3.73's?
- Diablosport Predator
- LS1 Edit Cable
- Injector flow rate table with procharger ?'s--->
- predator on more than 1 car......
- PO 171-174
- Hiting rev limiter only with et streets...
- Part throttle l-trims neg.
- 581 lift cam, will I need a custom tune from Predator?
- Injector Offset table for a 2001-2002
- P0106 Code? MAP Problem?
- AFR at 14.6 how to get it down in edit?
- Rolling rpm issue
- Help me with P0200!!!!
- Update on my hard starting problems and more...(LONG)
- Need some help with LS1 edit
- Threw a Code: P0410
- Dos version of A-tap
- LTFT's won't come down....not making sense
- I think I'm in TROUBLE!!!!!!!!!!!!
- Where does the red 53 spark retard wire lead to?
- LS1 16pin OBDII dataport pinout
- SES light help
- Just installed HPP3 and now I have an SES light. Help!
- dyno tuning question
- Opinions on Auto Tap EFILiveV5 for LS1's
- PCM codes 1125, 1276 & 1278
- Info for perspective predator guys....(Long)
- predator tuneing
- PLEASE help me out with this weird misfire problem.....
- predator info
- runninwiththedevil
- OK I need to find a dyno near Florence SC
- Ported/Descreened MAF - Hurt performance?
- Anyone ever open their LS1 Edit cable up? jumpers?
- did carputing send me the right stuff?
- Big thanks to Javan with B & B electronics with help on Atap
- SHIT LOST COMM DURING PROGRAMING.
- LT1 EDIT - ANY ONE STILL USING THIS. I NEED HELP
- ? on wires
- P0327 Knock Sensor Low Voltage... help!
- Stock Throttle Body hole size
- Wat size drill bit for tb butterfly hole?
- Computer differences ?
- help,,,,,,,proplem after new plugs
- predator
- G5X2 tunning nightmare!
- doesnt shift right
- Adjusting MAF to 512g/sec
- Disabling TCC lockup function
- Need tuning help... getting LTFT's dialed in
- i need autotap help, car is running bad
- Just got Predator: any basic suggestions on adjustment?
- How to move Auto Tap file from PC to Laptop
- time 4 tuning, ATAP logs inside
- Injector Flow Rate vs MAF table for Fuel Tuning
- PE VS RPM Table Question
- Will cleaning MAF help my problem?
- DTC P0300 (engine misfire detected)
- LS1 EDIT
- Removing 02s entirely?
- All possible reasons for a cylinder not to get spark?
- Anyone know a good tuning shop in SoCal Area? *DELETED*
- does efilive give you acurate afr
- LS6 intake and Z06 injectors installed
- wiring question
- Predator Newbie
- ls1 edit and predator together??
- What does TEA use
- SES light???
- ?? about tuning
- Some one Help (Predator)
- 1371 code?
- Who uses ls1 edit near LA???
- O2 Test?
- Predator re-sell
- How do i get ls1 edit?
- Ken Kelly's phone number
- SES code, P0430 just after last weeks P0161
- Changing torque management?
- Anyone experience the P0801 code?
- My PCM went poof while using LS1Edit
- Idle Problem After Ported TB
- What would cause my interior light fuse to keep blowing out
- "Black box" questions....
- Thanks!! - VE table adjustment
- O2 sensors...what brand and where to get??
- paging Jim Wilson with the 03 z06 and magnacharger
- Is there such thing as "LS1edit archives"?? if so i need it
- How do you richen the car
- Tuning with EGT.
- Speed Inc dialed in my Z!
- Will it be safe to run new engine without a full tune?
- DETONATION!! & PREDATOR??
- How to reset HPP3?
- predator or hypertech III?
- Troubleshooting a hard start???
- Need help ASAP please!
- STFT and KR question
- SLP 85MM MAF - bag it?
- Predator problems
- Flashing SES light. What's it mean?
- what to change first?
- LS1 EDIT ??
- ls1edit newbie
- Paging Harlan ... got some electronic questions
- Sending PCM off for tuning
- LS1 Edit & converter slip
- What type of singal does the EGR looks for?
- How did you get your heads/cam car to idle???
- LTFT aren't moving on atap
- DTC 0420 code?
- Tuner near OBX, NC?
- Can I delete Knock Retard for good with Edit??
- Showing P1416?
- Slow PCM?? is that possible?
- Throttle Body Cfm
- panhandle tuner?
- Has a few codes pop up...any advice?
- LTRIMS on bank 2 are very positive, while bank 1 looks ok
- Quick 02 simms question?
- Help, Not getting any Idle Air Counts
- Can LS1 Edit be installed...???
- why wont my converter lockup (go into OD)???
- Effects of Lowering fan turn on/off temps
- Got P0327 & P0332 Codes - Won't Go Away, HELP!
- Does this make any sense?
- MAF-T
- fuel tuning
- HPP III???
- 3.73 shift points
- SES help
- Will give free dyno time to tuner,for tuning my personal car
- SES - 4 Codes
