- Need help with LS1 edit A.S.A.P please.
- Shift points for A-4
- Predator wont communicate?
- Can the VE table be adjusted for LTFTs????
- Getting a "stumble" at PT only
- EASE experts please help
- Is it really necessarily to have bigger injectors for better
- ed wright
- G- Tech Pro
- can Autotap check for cylinder compression?
- Switched Maf-t
- Car wont start randomly, just cranks???
- Predator W/3.73s
- ERASING A CODE?
- Need Delphi 55# Injector Tables
- FIGURE THIS ONE????
- Anyone running WIde Band O2s?
- This thing solved my MAF porting high rpm ping!!
- Autotap loses connection after 1-2 minutes, how to fix?
- HELP !!!!!!
- Is autotap difficult to use?
- Fan settings in Houston
- LS1 Edit / MAF Tuning vs MAF Translater
- EASE questions
- i really need some/any help
- I have a low oil light but plenty of oil
- I need autotap dos software
- injector scale close to stock for 36lb injectors in 422??
- Wo Hoo!! Got My LM-1 Wide-Band Meter Today!!
- Gear calibration
- Kpa High or low at WOT?
- New .xls file for Injector scaling plus misc formulas
- For 160* thermostat where should I have my fans set?
- anybody want to Turn off my egr/air codes for a few bucks???
- p0102 did search and replaced fuse...still have question????
- Is there a ODBII scan tool that can....
- How much hp can be gained from HPPIII???
- How to calc new tire diameter for LS1 edit
- THREW A SES CODE (NEED HELP FIXING THIS PROBLEM)
- got a TC lock prob. help
- Edit not working with SP4?
- Autotap and Edit questions
- 02 codes?
- O2's reading .02-.03 at WOT... HELP!!
- 2003 z06 pcm p1010 maf problem
- LTFT questions
- pulse width
- Why is my car so slow??
- Is the 01 BCM the same as other years?
- I have some questions about ls1 edit.
- Torque management????? I need help!
- misfire on number 4i am putting this in all the places that
- dyno tuning - table assist please
- What to Set MAFT at??????
- MAFT instuctions???
- 99 computer with 2001 engine?
- trouble code p0355 - need help
- Will SnapOnOBD11 scanner work to find A/F ratio and other...
- IAC count down to 12
- Car will not idle
- Has anyone fried their laptop with edit?
- How to see if u have KR?
- Tuner's come in
- Tech 2?
- Paging Nic00Z28M6: New Timing Table
- Constant 4 degrees KR... anyway to edit out w/LS1 Edit?
- TCS Won't work
- Does Predator work at less than WOT?
- TPS modification
- Spark Advance Excel Template
- HELP!!!! NEED TO RESET
- Where are injector pulse widths in EFILive 5...
- 98ss pulling max knock #'s help!!!
- Paging NoGo
- SES Light ?????
- Autotap guys within?
- Auto Tap reg code
- P140 no activity o2 Bank 1
- Computer chips
- ECT??
- Do you have to have Autotap to use LS1edit?
- Couple LS1Edit Questions
- what can LS1 edit
- LS1 EDIT?
- ATI Procharger Tuning Checklist (LS1Edit)
- maf ends and tuning
- HELP! Lost communication with PCM while using edit!
- Anyone know how to figure out an equivelant BSFC?
- Running Really Lean at Idle, what to do in Edit to correct?
- Programming and Little Batteries
- Minimum Pulse Width
- Hypertech vs. Predator
- am I too Fuel Rich???
- COMPUTER TUNING SPECIAL
- looking for scanner
- A4 Flashing SES Light
- LS1 edit?
- Please Help (tuning)
- Car Won't Start Help!
- Running Lean Up Top Bad!
- A-tap with predator?
- Can anybody help
- Predator Questions (Quick Help)
- Problems on dyno
- correct way to hookup wideband on dyno?
- troublecode p0757
- 224-230/238
- Anybody Interested In Tuning Me and Making A Few Bucks??
- Help me with MAFT and Headers
- Got Ease, did some logging...a few ????
- EASE disconnecting every 5 seconds
- Do I need new wires & plugs?
- funny smell after new cam
- HPP3 and a MAFT???
- Tuning an auto car with Edit
- Any way to trick EVAP system?
- Tach slow and limiter hard?
- LTFT's +5 - +11
- Site w/example .LS1 files?
- (LONG) I am going to be installing a new motor and....
- New cam.... need tuning help (KR)
- PCM swapping between 98 & 99-00 T/A's
- Alarm systems can cause misfire and damage Cats
- what program to buy for my application?????
- Can you use ls1 edit on top of hpp3?
- trouble code question
- Diablo Diagnostics
- Part Throttle Tuning Tables
- Headers are throwing codes. I might be SCREWED
- ANyone familliar with MAF workings / budget GMAF?
- Very rich on Startup only??
- I CANT GET MY CAR TO RUN GOOD!!!!!!
- Is LS1edit our only option?
- VATS bypass box??
- what version of ls1edit is out now? advantages of it ?
- running lean
- Surging issues
- trans lock up
- I wan't to buy LS1 Edit but fear its to hard to use
- Can someone explain gms/cyl?
- Team ZR1 EASE won't connect
- New LS6 FUBAR - Need HELP BIGTIME!!!!!!!!!!
- At which point would a rich A/F cause black smoke at WOT?
- Ping under slight throttle?
- what would cause this
- Monitoring bump stop mod with Atap?
- Can u increase wot timing on a Z06 after a "big cam" install
- Simple (?) LS1 Edit question... adjusting A/F
- Where do you buy LS1 edit?
- misfire question
- Which will work best for my needs?
- Strange problem, need help.
- tuning problem????
- fan settings
- Still having problems with hotstarts with new cam in a C5
- Looking for online engine diagnostic site...
- ls1 edit 8.1l injector values
- my car shut off today?
- What is the resistor ohm!!!!!!
- Any good tuners in so cal?
- Has anyone had good results superior auto in so california?
- Tuning L-trims with MAF vs Injector scaling
- when to stop using hpp3?
- Palm OBDII Scanner----LS1M Review
- BIG F#CK UP! NEED HELP ASAP!!
- Changing VE under 1200 RPM, or just in the idle area?
- Anyone know the exact # of re-writes the PCM can take?
- Shift Points and Rev Limiter for 4:10 Gears
- Can I "program out" TCS/ASR???
- Open Loop Fuel/Air Multiplier Table
- PO106-how to get rid of it?
- MAFT and WOT Timing
- NEED HELP ASAP!! Please Read--MAFT
- Where was the LS1 Edit user guide, and where else.....
- If my car has already been tuned via LS1 Edit.....
- What PID to monitor O2mv with EFILive.??
- LS1 Edit
- Questions about interpreting LTRIM & O2 data in Atap
- ? for all you ls1 edit gooroos
- Looking for PCM whitepapers and/or tech info
- Emissions testing and computer codes.
- best tuner in northeast ?????
- Why is autotap showing deleted codes being thrown?
- Making the computer think the AIR & EGR is still there
- Eating Gas
- PCM Parts Numbers
- car stalls when shifting into reverse on M6
- Anyone have Emission Insight for NY, I may be moving...
- can someone help me please
- Could cut-out cause P 420 code?
- Is this correct for SVO 36lb injectors
- Getting MAF low frequency
- CRANK A.I.R ????
- Please Help!! SES code
- PREDATOR AND A TORQUE CONVERTER????
- Idle RPMs drop below what is set in Edit....why?
- Stock PCM limits
- How hard is it to tune the ls1 cars and what would i need?
- Anyone know the normal MAP value for a cammed car?
- Interest in a digital knock guage with memory recall?
- LS1 Shop, Arlington, TX
- running rich
- what to do?
- "knock code" is it the Knock sensor??
- Chips By Al
- pcm controlling 4l80e
- Diablo predator or hpp3 whats better?
- settings with hypertech
- Best way to correct speedo? Options? Please!!!
- Changin misfire detection alter how many misfires Atap reads
- Dyno results got a few questions???
- I want all your opinions, remove the MAF screen or not?
- Mystery Code?
- how much gain from a good tune?????
- Can a usb to serial adapter work with LS1 edit?
- 0 KR
- speedo problem
- Best logging hardware/software ?
- IAC's how else can i get them lower
- Anyone seen this wideband?
- IAC's How else can i get them down?
- Will an HPP programmer or Predator make an ET Improvement?
- Where can I find a calibration table for a stock Z06 MAF?
- Air Temp Sensor - is this needed?
- rich at idle - fine elsewhere??
- My tune is screwed. Someone please look at my log.
- Will an LS6 PCM work...??
- o2 sencors
- How to reset PCM and return to stock tuning?
- Taking Ed Wright PCM back to stock ?
- Laptop issues.
- Need LS1 EDIT file from similar car.
- MAFT splice
- HELP! She just won't run!
- LS1Edit issue
- LS1 Edit and Autotap/EFI Live
- Can I buy the shop version of ls1 edit?
- TPS voltage on a VETTE-Autotap
- Will unplugging the EGR on a 99 make the car run bad?
- Anyone replace their knock sensors?
- Getting full knock retard, 12-15 WOT timing, F/R Knock codes
- What does flashing the computer do?
- Fuel Tank Pressure Sensor???????
- 110 OCTANE RUINED O2'S?
- copy of auto tap?
- Problems and more problems
- TUNING RESULTS!!!!
- Threw codes, replaced 02 sensor, and codes came back
- Pause Playback in EFILive
