- scanmaster reading low 400's WTF
- Please help me interpret O2 readings and compression test
- EDUCATE ME!!!!
- Need help quick - security light cut off the fuel pump
- SES light Flashes at end of track, but no code
- How much timing is too much?
- Tuning "?", more like definitions
- Does my scanmaster work on 02's?
- Pace MAF??
- PMAF cause surging?
- IAC Count is too Low?
- Autotap o2mv Question?
- Autotap not seeing IAC counts
- G-Tech Pro accelerometers on eBay
- P0153
- O2 mV to wideband AFR correlation - post your data
- detonation
- po748
- please need help in tunning (LS1Edit)
- Swappin T-56 to TH-400, what about pcm?
- LS1 Edit & Moving PCM to Different Car
- How do you program a converter to lock/unlock when it should
- a/c schematic or help
- Tuning results from Rapid motorsports within
- HPP3 and my BoltOns?
- Anyone know of a Laptop holder for F- bodys?
- Need to improve my 01 SS!!!!!!!!!!!!!!
- LS1edit worth it on internally stock car?
- I get the P0327 code w/cutout open in cold start...
- Those of you with the Predator.
- po1153 code
- FELPRO F.A.S.T expert needed
- Guys using PCMCIA to serial with LS1 Edit or Autotap
- LTFT's not close to each other. Also only using 3 fuel cells
- Difference between v4 and v5.2 MAFT's?
- Autotap or tech 2
- COT (cat over-temp) trigger?
- is the power programmer full of s#%t
- How do you lock the convertor using LS1 Edit?
- tuning with longtude headers
- LS1-edit - What are IAC and IAC PArk Posn tables?
- ATAP - "Attempting Communications" repeating
- Need FAST file for 396 N/A
- LS1-Edit - what are these tables?
- evaporation system readiness failed
- Can autotap's vehicle speed reading be incorrect?
- HPP 3and predator are they pretty easy to understand ?
- How do I get the SES light back on?
- ??Best method to keep the battery charged while editing??
- Got SES Code w/ these Mods
- How long for comp to relearn itself?
- MAF Tables
- Cleaning MAF?
- New H/C and LS1-Edit - power loss under accel
- Offsets for 83 lb Siemens injectors?
- Factory tuning and after MTI tuning via Auto Tap
- Lowering idle w/ LS1 Edit
- what do i do with the torque management?
- Can stock Tach be improved to read accurately/precisely?
- Quick Poll: How many running cats with COTS disabled?
- Logging Data From Tech Edge Wide Band O2
- Anything wrong with using 40# in a H/C 346?
- Anyone tune for money?
- Anybody using EFILive with a USB/Serial adapter?
- Help - need answers on Ltrims- Please -- Update
- What settings for HPP?
- ls1edit file for 4.10 gears and 26 inch tall tire.
- Rev limiter whats it set at factory
- There's something wrong with my car, but what is it?
- How much power to gain goin from 18 degrees of timing to 28?
- MAF Translator ?
- 38 lb. injectors and Edit?
- Auto Tap V2.03 users
- Need help with Harlan 2-step
- Secondary VE table *DELETED*
- EFILIve vs Autotap
- EVAP SES lights?? whats wrong?
- SES Light, Misfiring, and Rough Running ... Need Help
- anyone from ohio have an autotap?
- Wheres does the overMAF limit DTC grams/sec come from?
- SES Light came on, WHY
- Random Misfire after H/C ?
- Which one's better- ls1 edit or autotap?
- what are some basics?
- Palm Pilot
- SES light is killing me...
- Over limit of grams/sec?
- Injector swap from 28.8 to Accel 30#,which table in ls1edit?
- Diablo Canned Tune + Hammer Cam
- PINGING?
- Can someone email me ls1edit software? I lost mine
- Great webpage for ls1 tuning
- tuning for more cubes
- HPP3 is it worth it?
- What to tune for LTRIMS when MAF tuning doesnt work
- code pos 1153
- Need info/help with Strims
- LTFT at +25 after H/C change?
- Fuel-air-ratio settings?
- Tuning with a C2 Cam?
- Fuel Trim Cells and Tuning?
- Why buy a Predator from James at runninwiththedevil.com???
- Code P1635
- Where is the idle control motor?
- WIDE BAND O2 KIT??
- New gears on a C5, need to program?
- Service Vehicle Light on
- What does unplugged IAT do?
- Scanmaster Gauge Mounting Bezel For Sale (Ebay) with picture
- idle relearn procedure?? where to find?
- Mobile laptop power adapters. Power your laptop in your car
- Change stoich from USA 14.7 to CA 14.2 ??
- Lost power with stock MAF.
- Heads/cam tuning
- Changed MAFS back to stock. Now have knock
- Oil Pressure reads -106 kPa with EFI Live but car guage ok.
- Elive5 & serial to USB connector?
- TCS going crazy
- WAT KINDA THINGS CAN I DO WIT GM'S TECH 2?
- Ease, Autotap or EFILive
- LS1 Edit Info For Cam Project.
- EFLive- can you log 12 or 24 parameters?
- Injector Fow rate..
- EFILive bidirectional controls?
- Tranny cooked? Please read...
- instaalled a 160 degree thermostat???
- Secruity light
- stuck EGR = lean ??
- A/F guage
- Tuning necessary w/ TR224/114 in A4?
- Non-EGR car part throttle timing
- Owners in AZ come inside
- what are all the codes to delete the EGR crap?
- Main Volumetric Efficiency Table - What's it do??
- Which tune would be best?
- Misfire feature
- Timing table
- Do they work the same way?
- What was adjusted?
- More timing how?
- What is the real difference?
- Oil change %
- question on KPA vs RPM
- trying to log Spark Retard
- Got an SES light today
- installed a cam and having problems
- diablo
- Please Help with Interpreting Numbers!
- help with defintions of PCM error codes
- maft
- phone # for Carputing?
- IAC and Advance Question
- How bad is PO751 1-2 shift solonoid stuck off?
- DYNO LOCKING UP CONVETER
- I have an Edit MAP question :)
- Vin # transfer to new PCM?
- LS1 Edit Woes
- Code P0106 any ideas ?????????
- coolant fan relay control circuit!!!
- Car running rough, what could it be?
- Please help...air intake problems (codes 171,174 ext lean)..
- Anyone using LS1Edit on a Laptop with XP??
- iat -map timing adjustment
- gear shifts with hypertech programmer help!!
- Engine dieing at 3000 RPM
- P0430
- BOOSTAT4500 ? 4 u *DELETED*
- hypertech question
- HELP! Short-Shifting out the hole - any ideas?
- mail order tuning
- po121 and 122
- LS1edit on 4.3L V6 motors
- Autotap laptop question
- random misfires seem not so random
- Belt slipping off after HPP3
- IAT Timing Tricker?
- Anybody know where to tune for deceleration??
- autotap
- what are PE tables?
- LS1 edit ?
- Quick question about LS1 Edit
- LS1 limit
- Knock knock...
- Tuning/Emissions TR 224/114
- Adjust injector PW to bring Ltrims negative?
- Scanmaster Owners Help Needed
- Do I need tuning or what??
- Which side is Bank 2?
- Upgrade for my autotap software.....
- Surging after startup in gear
- what kind of lap top do you need for auto tap?
- LT1-Edit ?
- cheapest method for adjusting fan turn on?
- LS1-Edit Dyno Tune in San Jose area?
- LS1Edit question
- help. Does this sound about right?
- Help, P1154????
- Need Help with a 3 pin connector location
- Autotap / LS1 Edit and OBDII
- AutoTap / EFILive question
- TP sensor reading at idle?
- Rev limiter limits??
- How does the ECM figure which piston is at TDC?
- warm startup really pissing me off
- Hypertech, Superchips,etc ?
- Edit and Trans shift vs. Rev Limiter
- Throttle follower w/ engine run-time?
- Injector fault?
- G5X2 flash files...?
- What program will measure duty rate on injectors?
- Only need decel and idle A/F trims-how???????
- SES Light and no Apparent Cause
- Can someone explain how to tune with fuel cells?
- How to dial in LTFTs?
- cheap and cool stuff on a laptob?
- Auto tap Question on LT's
- Fuel Trim Cell Questions Please...
- Desired Shift Time
- Edit is kicking my ass :) A-4 with 4.10 gear will
- increased fuel pressure, LTFT changed how do i get
- Emissions test in AZ
- base performance tune on stock car?
- How do you improve part throttle response?
- How to order LS1 Edit
- P0102,P0135,P0158, HELP!!!
- ses light, please help
- Paging HVAC Gurus, HELP!
- optimum air/fuel ratio???
- anyone else having limiter problems?
- WOT KR showing timing change
- 14.5:1 for 5 minuites then 12.0:1 tired of ls1 com
- P0430 Code
- Quick LS1Edit Bigger Injector Tuning Question...
- P0107 - Idle Issues, Help!?!
- Second License of LS1edit
- Can someone explain this?
- What could cause this ?
- C5 Automatic with 3:15 gears
- Torque Converter queston with Edit?
- LS1 tuning question... (without PC tuning)
- Help, predator wont work
- HELP Freaking Out here!
- I need advice please
- need help with next step in tune
- Have Predator and H2
- need help with flow rate table
- Predator rev limit and gear shift setings
- Trouble codes on ECU, deletion and questions
- Predator and A4 shift settings
- changing shift points in A4 with Tech II >>???
