- changing shift points in A4 with Tech II >>???
- throttle postions code...what gives?
- REALLY bad gas mileage? boltons and cam....
- LS1 Edit Question! (a real one!)
- O2 sensor question
- WHAT TABLE TO TUNE IN OPEN LOOP???
- Not reading IAC's ?
- LS1 Edit Question *DELETED*
- torque management what doe's it do
- help! Too lean!
- A4 w/ 382/229 cam basic tuning suggestions?
- Anybody tried this scanner?
- Where is the Evaporative Vent Solenoid?
- Lots of backfiring at idle....why??
- 36lb SVO injector tune....
- ECM reflash
- knock sensor code and 4*knock!! HELP
- Need help bad !!!
- turning off rear o2
- ls1 edit gains!!
- A4 / TCS-ABS / TPS - wierd behavior ? Help !
- wideband tuning with cats?
- Preadator programming not allowing WOT
- Another Tuning Option?
- Predator? Got a few questions.
- how do i make the lockup clutch engage faster
- Need Tuning help For 85mm maf I just descreened...
- wich 02 censor goes can guage go to????????
- Is anyone runing a aftermarket computer system
- trying to figure out problem
- P0480 + P0481 + P0507
- Spies in your car
- Please help with WOT shift points!!
- high octane vs low octane table
- Should I be tuning with MAF or Injector Pulse?
- will this upset the computer???
- LS1 Edit and Autotap woes
- BRAND NEW HYPERTECH POWER PROGRAMMER III *DELETED*
- KR in cells 14 and 15
- LS1 esit - can it download the stock PCM program?
- Computer doesnt read o2s?
- How do i check for a dead cylinder with autotap???
- decelerating in gear very rich. Any ideas?
- Help diagnosing codes....
- please help
- trouble codes on my LS1 swap.
- I'm looking for info on a predator programmer
- need 96 lb injectors, WOW
- Hayden Adj Fan Switch
- Phone # for Speartech?
- Large CFM MAF Sensors: What's Available?
- So many codes...so little knowledge..
- How do I find out what year PCM is in my Hawk?
- Help me crank my car without holding the gas....
- P0702 - Trans Control Sys Electrical - in an M6?
- P0108 and MAP troubles
- Question about flashing my PCM
- Tuning Needed in OHIO
- What is considered normal knock on LS1?
- Another tuning newbie!!!
- Tuning question, can someone help find the answer.
- How can you tell what A/F ratio is?
- Has anyone used Toluene to boost octane?
- service vehicle light-pt throt adjust???
- Torque management
- what will prevent P.E tables from working
- what is the best way to tune my car!!
- Does anyone provide Autotap instructions?
- AutoTap were is best place to get it.
- I know it has been done before!
- Can LS1 Edit...
- Just got my LS1 Edit(need help)
- turned off rear 02's and COT-can i still run cats?
- How do you clear an SES light?
- 140, 160, 1133, codes after long tubes
- For thos interested in hacking the PCM...
- Tuning tool and analysis for ATAP
- how to edit shift points
- Predator & gear change
- tuning for 12.6:1 then pcm alters
- No PCM in car question
- Unplug Air Bag Sensor?
- dyno tuning
- had a close call with ls1 edit crash
- Lots of backfiring and weird AF problems
- o2 sims and nitrous tuneing???? help..............
- MAF translator on 1999 SS
- HELP with timing stuff
- Gurus - what is considered rich/lean Pulsewidth at
- Car won't rev. over 3500 rpms?
- Adjusting Injector Size using LS1 edit
- Wideband O2 sensor placement?
- 30lb injector flow table for edit
- Help me get the car to idle....
- What value in ATAP tells me IAC levels?
- What are the reasons that a cam causes hot start
- Strange problem with speed calibration
- Car will not stay running, HELP! *DELETED*
- Car backfires on cold startups
- Any problem using LS1 Edit over Predator Tune?
- Deleting Insufficient code?
- A/F ratio dropping into the 9's, how do I fix this
- Idle speed too high until car is FULLY stopped?
- secruity light is on?
- ls1 edit?
- Predator tune for a 99+ gm truck
- 3 Tuning/logging/autotap/Edit ??'s
- Couple of MTI tuning ??
- O2 Heaters??
- Can some explain *knock*
- 8MPG! How come?
- tuning blower on an A4
- timing tables
- Which tune is best
- Flashing ses light but won't log to memory.
- Where are best dyno tuners for ls1 near detroit???
- what year gauge cluster?
- anybody using Fast Sequential System??
- need help edit timing table
- ls1 edit
- Stupid Stupid Idle
- heads and cam tuning help please
- MAF table tuning question. Effects at WOT?
- LS-1 Edit tuning, does elevation matter?
- Best Place to buy O2 Sensors?
- please help dial in my MAF Table
- Need help with o2 sensor totally lost!!
- truck won't start- cranks won't fire.
- Which Tables to Edit to help with Lockup Issues...
- Please help me fool this tach...
- tune job and a pulley
- 18% lean ltrim's at idle
- Cars running rich help!!
- Open loop A/F ratio adjustment?
- Help, Heads/Cam Swap Complete, PCM dead
- Shooting Flames!
- check engine is on
- Help! Low IAC counts, injector problems & misfires
- Is/was there a 98 egr valve recall?
- tach phantom
- Heads and Cam tuning help please?
- Hypertech Problem!
- Error Code P1416
- LS1edited car, now injectors will not fire,
- would tuning do this
- why do people use after market comuters like fast?
- dash engine light??
- What is a GOOD AFR
- maft tunning
- downloadind my current tune job to a CD
- Has anyone heard from Tunercat??
- Downshifting causing SES? Please help!
- Predator modified tune ??
- ses light dim and flickering
- Anyone have tuning done by Rapid motorsports?
- Help my car IDLE.... NEW CAM.....
- Misfires that won't go away help!
- o2 sensers shut down
- Auto Tap results
- p0106, p0101, p0103 after cam install...
- hit 120 MPH and car died
- F.A.S.T vs tecIII
- Is This Normal O2's reading lean in 1st and 2ed???
- EFILIVE V5
- 1999 Camaro SS desperately seeking advice on MAF
- injector flow rate ques for edit
- How do put stock 98 PCM file /w LS1edit?
- O2's are killin' me!!!
- Keyspan USB/serial adapter problem
- Somebody please try and shed some light here.
- Where can I get custom tuning??
- Predator settings
- MAT sensor
- Gains with HPP3??
- More and more O2 sensor issues
- Who would be willing to rent LS1 edit for $100week
- SES, knock sensor question
- Will EFILIVE work well with 2000 gmc truck w/5.3??
- ls-1 edit ? adjusting, surging Idle w/ new cam
- Predator and NOS
- Rich Idle on SC car
- Long term FT
- Adjusting AF using LS1Edit "?"
- Will MAF-T stop surging and stalling ?
- how can torque management effect an m6?
- Is LS1-Edit difficult to use...
- spark knock
- how many of you turn off misfire detection?
- LFTs and LTRMs? What are they?
- Predator and a MAFT
- Need Help Quick about MAF
- How to get an extra ls1 edit cable
- 02 sensors?
- Can someone explain this with the Advance
- backfiring
- Removing Knock??
- dyno in charlotte area?
- no accelration? 4-3 gear changing.
- Timing Tuner.. *DELETED*
- Shift points on Hpp3 after gear swap???
- Dont want SES light, can I re-use stock O2 sensors
- What is the pre-programmed predator tune?
- 2 Autotap runs, need help
- WTF??? What the hell is going on with my HPP???
- mustang dyno questions.
- does predator email you programs or....
- Anyone had a defective 02 sim replaced..
- someone please reply to this post
- Best place for Dyno tune in Detroit area?
- Tuning in Dallas Area
- Question on TPS voltage
- have a few questions with edit
- Predator Problem?! Need Urgent Help Please
- My rev limiter just lowered itself?
- LS1 Edit and HPP3
- Predator vs. MTI Custom Tuning
- Will programing be the same
- Getting a PO327 code. Is it the front or rear KS?
- o my goodness!!! programming woes!? everyone help!
- How to program a blank PCM?
- Intermittent P0420, P0430 and P0748
- cam position sensor-startup only?
- Electronic Throttle Control (ETC) ????
- Which is best?
- what and how can programming mess up my motor?
- Passenger side pre-cat O2 sensor problems.
- o2sim problems, SES light, scanned codes what next
- Having problems LS1 Editing for 30lb injectors
- Where to buy LS1Edit?
- Anybody in Sweden have a Tech II ?
- Changing injector scale for 42lbers?
- Any company can tuning my car by e-mail ??
- how do I fatten up PE
- SKIPSHIFT NOT WORKING!!!!!
- IS HPP3 WORTH GETTING NOW?????
- car wont shift please help
- setting my rev limit with diablo
- predator problem possibly
- LS1 Edit Fan Settings
- Is a MAFT WOT adjustment instant?
- When Do I need to get the Predator reprogrammed???
- LTFT numbers and o2 numbers
- Laptops for LS1 Edit
- predator performance
- Autotap log looks pretty bad
- Any Recommendations on the Diablo Predator?
- A TC ,Torque management , $500???
- Having KR issues and losing MPH - EFI Live files
- Predator diagnostic monitoring
